PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 [197] 198 199 200 201 202 203
  1. Anyone have Desktop Dyno?
  2. Putting together an LS1 edit FAQ - need input on topics ->
  3. Another ATap ?
  4. Atap reading problems...help.
  5. ls1edit?
  6. finally got edit able to use my ed wright program
  7. Will a car run richer on the street or dyno?
  8. Dyno tuned car, O2's went down to 830mv!
  9. ANY ONE in New York with autotap and ls1edit??
  10. HELP!! Idle trouble after TR224 install
  11. Easy question
  12. Tapping and Editing to Tune LTRIMS, quick question
  13. whats up with new autotap?
  14. Need Help??
  15. need assistance with engine problem
  16. Engine pinging at WOT after G2 lid install...
  17. tech 2 what can i use it for
  18. Where can I get LS1 Edit Program?
  19. bank 1 - drivers side or passenger side?
  20. Air Pump Coolant Disable Temp in LS1 Edit
  21. HELP HPP3 Problem, ASAP
  22. LS1Edit for the Body Control Module (BCM)
  23. Does anyone else make a Knock Out Box?
  24. Where to get a new VATS module?
  25. WHere to get a spare PCM?
  26. Tech II??????? Do they need the car?
  27. SLP Maf can it be tuned?
  28. HELP! CAR WONT START (NUKED PCM??????)
  29. CLUELESS
  30. Failed MD Emission Twice -- Please Help with Tuning
  31. Calling LS1 Edit tuners
  32. Anyone in Dallas?
  33. Need help with SES codes please.
  34. Help with codes please: PO122 TP low voltage, PO133 PO153 slow response O2's
  35. LS1-Edit ? 4 the More Knowledgable
  36. what would cuase code P1336 Crankshaft Position System Variation Not Learned
  37. Need help w/ injector tuning and LS1 edit
  38. Flow chart for SVO 30# injectors..
  39. Anyone have Carputing's Fax number?
  40. Ported MAF ends and LTrims?
  41. Octane booster is a mystery to me...
  42. LS1-Edit and Knock Sensitivity
  43. HELP! PO327 & PO332 Knock sensor .
  44. Kpa explained.....
  45. LS1 Edit – Torque management questions
  46. AutoTap Remedy
  47. EFI Live Bi-Directional Question
  48. Scan Master Vs. AUTOTAP
  49. Any ideas on what would cause such large deviations between the O2s?
  50. Engine Timing
  51. HotCam tunning with Edit?
  52. tuning ?
  53. What does PO430 mean?
  54. Is the MAFT version 4.0 OK?
  55. Autotap pricing
  56. Need Advice: PE vs RPM Adjustment
  57. when i try to save my edit file... ERROR
  58. is this theory accurate?
  59. Let me borrow your LS1 EDIT file.....
  60. LS1 Edit and Nitrous tuning
  61. Dealer performed Computer update on 99 SS, now major lean.
  62. O2 Simms On Front Cats
  63. '99 WS6 Temp Guage
  64. HYPERTECH shifting ????????
  65. Very little advance at wide open throttle
  66. how to richen up crusing ??
  67. best and close to Iowa for tuning
  68. Different LS1Edit Question
  69. do i need new cats according to auto tap?
  70. Holley Commander 950 questions
  71. Is LS1 Edit Shipping?
  72. LS1 Edit Question.
  73. LS1edit timing advance.
  74. Autotap V2 inside
  75. NEED HELP IN KENTUCKY with LS1 edit
  76. LS1edit Questions form a Newbie......
  77. Hypertech III & 80GMAF 4sale for a 99LS1 $400.00
  78. Is ls1 edit as good as it sounds
  79. How to run atap at track
  80. Can an exaust leak cause KR ?
  81. Negative LTFT's of -8 to -10 creating Poor Off Idle response and Poor Part-Throttle..
  82. P1639 I looked it up but don't know what it means???
  83. SES light burning out?
  84. tuning ??????????
  85. MAF questions
  86. A/F ratio reported by Auto Tap compared to Wide Band, How close?
  87. Help needed please
  88. Which timing table for idle?
  89. How long does the Hypertech take to kick in?
  90. Basic ATAP ???? inside PLEASE!
  91. does Ed Wright have web site?
  92. Why no SES light?
  93. Hypertech Power Programmer # 3 - Is it worth it?
  94. How can I tell if my Ed Wright program is locked?
  95. voltage output of knock sensors?
  96. Trouble Code after headers... what does this mean?
  97. Still running too rich with MAFT, what are my options?
  98. battery terminal problem
  99. newbie question form oldie. Atap and timing and kr simple question.
  100. Which do you log? LTFT or LTFT Avg
  101. What is the exact fields I need to monitor for rich/lean
  102. TIMING RETARD PROBLEM
  103. maft!!!
  104. Opinion on A-Tap numbers
  105. who sells LS1 edit
  106. EASE trace size??
  107. airpump disable?
  108. Who gets these two annoying codes??!!
  109. TCC Calibration
  110. calibrating 42#ers on ls1 edit.
  111. Ltrim's 25% at idle???
  112. Ltrim's 25% at idle???
  113. TC Lockup
  114. Which one of these conditions would cause KR?
  115. Is there someone in the Charelston SC area that help me tune my car?
  116. MAFT question: What's a good base line setting after installing Long Tube Headers?
  117. HPP3 power tuning: what exactly did they change?
  118. ls1 edit and reverse lock out solenoid?
  119. Is there anyway to look at LS1-edit software before I pay 550 for a cable?
  120. what is to lean on the o2's
  121. Misfire codes
  122. Help me with a MAFT question
  123. PCM programming?
  124. car won't start, help!
  125. Relation between Low and High Octane Timing Tables
  126. Crank Position Sensor Relearn and LS1Edit
  127. Can LS1 Edit shut off ABS warning light?
  128. Tachometer Signal From PCM???
  129. auto tap???
  130. EASE Diagnostic Software
  131. Woohoo!!! Autotap 2.0
  132. O2 sensor is going up and down up and down, is it bad?
  133. Just Happened, Multiple codes all at once. What is it?
  134. LS1Edit dyno tuning package... How much & what should it contain?
  135. 6.2 reprogramming? or replace
  136. PO102 Please help the new guy!!
  137. Problem after H&C install
  138. PO171 &174 System too Lean(Bank 1&2)???
  139. atap?
  140. PID
  141. Wideband oxygen sensor location???
  142. MAFT Questions
  143. Inlet Air Resistor (Timing Tricker) Test
  144. What do you guys know about the old MAFT..?
  145. Car feels slower after 2 weeks with the MAFT?
  146. LTtrims ????
  147. Ignition Timing advance at WOT
  148. Some Lterm ?'s and observations.
  149. hot start surging????????
  150. Question about engine readings
  151. Proper way to reset computer
  152. Tough PCM Question
  153. Any MAFT Experts Out There???
  154. Auto tap
  155. how to advance/retard timing with LS1edit??
  156. Test Your Witts Please Help
  157. Computer option for those without laptop and want LS1-Edit :)
  158. Coolant light coming on?
  159. LS1-Edit crapped out!!!
  160. DTC & Spark Advance Question
  161. O2's Average WOT Question
  162. Wide Band Tuning > Ok, sounds good, so how do we adjust anything?
  163. P0107 map sensor low voltage??????
  164. Ready for some fun? Tell me if a MAFT can solve this!
  165. LTerms ?
  166. vats problem
  167. What causes DTC PO751?
  168. PCM Burps....
  169. Ricer (show off) or not?
  170. PIN #
  171. Knock Sensor Low Voltage
  172. Some Autotap #'s. What needs adjusting.
  173. msd window switch??????
  174. PCM Throws a temp code
  175. What is the MAF frequency range at Idle?
  176. LS1 Edit And MAFT
  177. Screen Shot of EFILive V5 :-) (Two large pictures)
  178. home made o2 simms ?
  179. home made o2 simms ?
  180. what is rich and what is lean.
  181. TUNING!!!!!
  182. Do you need Autotap with LS1 Edit?
  183. 98 PCM....
  184. Car searches for idle on a warm start
  185. Tuning O2s ???
  186. What are my PCM options to make more power?
  187. Code PO327, PO430???
  188. car won't start??
  189. Airbag light stays on constantly
  190. Iac counts and idle qualitly
  191. New AutoTap PALM V1.0 pics
  192. How do I eleminate TM with Ls1 Edit??
  193. questions about IAT sensor
  194. Ltrims and Ign. Advance ....Quick Question
  195. Anyone else with a '98 and LS1Edit a little pissed?
  196. ?? fake out the knock sensor??
  197. How to Desensitize Knock Sensors
  198. Autotap For Pocket PCs!
  199. Who's gone from ED Wright Tuning to LS1 Edit & gained power?
  200. DOUG RIPPIE MOTORSPORTS
  201. SHOULD I GET CUSTOM TUNING?
  202. PCM 2000 vs PCM 2001
  203. LTs installed... now misfires (?)
  204. 02 or not o2 ?
  205. S term /Long term Trim
  206. Misfires, Misfires, Misfires
  207. Data Logging & LS1Edit?
  208. can i do this...
  209. New Autotap V2.0 ScreenShot
  210. Excess KR at WOT
  211. New Autotap software coming soon! (long)
  212. a4 shift kit and hpp3
  213. LS1 edit....SAve file?
  214. VSS Sensor
  215. Newbie to A-tap, what to look for?????
  216. How hard is it to use LS1 EDIT
  217. Who can do custom programming on the ECM for F-bodies?
  218. Ed Wright
  219. Tulsa Ok where to get car tunded?
  220. So what EXACTLY has to be done with Edit to make TC lockup work?
  221. Relearn idle w/ or w/o MAFT attached?
  222. ATI Procharged vette......getting DTC p1514 ????
  223. Does Carputing (LS1 Edit) have a phone number?
  224. Idle question
  225. Is LS1 edit out for 01's yet
  226. Can I flash my '99 M6 PCM to '01-'02 revision?
  227. How hot should my car be running
  228. low efficiency codes
  229. Will anyone help regarding DTC-P0443
  230. MSD Stacker Ignition
  231. what terminals are for the cooling fan outputs?
  232. TR 230/224 is in , now can ls1edit fix these issues
  233. How much to tune my car?
  234. hypertech(who has the best settings)
  235. ls1 edit and auto-tap questions
  236. MAF Compatibility
  237. Keep losing connection
  238. Still Tuning
  239. Simple Question!!!!!
  240. I am getting SES light with codes turned off in Edit?
  241. engine rpm.s stay up when throttle is closed????
  242. What does a stock WS6 (6 speed) dyno at?
  243. Datalogs!
  244. Got computer done, car wont start! WTF!!
  245. Tuning issue... MAFT and AFPR issues! Help!
  246. Tuning WTF?
  247. What does the PCM do when the airbags deploy
  248. MAF-T switch question??
  249. Scanned the car tonite, and this is what it said...whats it mean?
  250. code p0420
