PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 [103] 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. built 4l60e, no downshift to first
  2. just data logged
  3. Security light is always one.
  4. NGK wideband installed
  5. i will be getting tune
  6. SS won't start, missing key chip/resistor, what resistor for resistor mod on VATS????
  7. First start codes and sensor values....
  8. Autotap software, can some one hekp me out?
  9. MY hptuner's won't open the hpt. files. help
  10. MAF failure causes
  11. Crane/Vinci Tuner, now what???
  12. I think I need a tune
  13. Where is the best place to power and ground my wideband?
  14. Tunning VE table w/HP tunners
  15. 99 stock tune with 98 injectors?
  16. chose the wrong os what do i do
  17. Vinci Tuner Won't Work & Tune Needed
  18. How Many rpm = 1 mph with a 3.73 gear?
  19. weiand intake/tuning problem
  20. Using a Predator after an LS1 Edit tune?
  21. HPTuners file
  22. I have a question about Tuning a Converter with HPT
  23. HPtuners please check this tune out
  24. Calling Out E38 Ecu Tuners!!!!!!
  25. This is the pcm right?
  26. Hookup for LC1 Controller to V2
  27. advanced non-ls1 help
  28. LS1 edit...
  29. rescaling fuel gauge for ls ls- s10 swap.
  30. service engine soon light
  31. '02 pcm in a '99?
  32. EVAP: I need to know how it works....
  33. Cold Lockup Table **easy Q**
  34. LM-1 display is not the same as Flashscan input
  35. NE1 Know How I can Check NB V on PLX M-250?
  36. no start
  37. cooling fan tune for 160 degree thermostat
  38. Swap or not to Swap 98pcm to 99+
  39. efi live question
  40. Help with check engine light
  41. EFILive E38 Support, Second Gen Allison Support and other Streams Released to public!
  42. 99 Camaro Z28 - ALDL connection bad
  43. tuners inside need help
  44. what to tune to chop up my idle
  45. LTFT's ~10 after wb SD MAF, enabled CL
  46. LS2 Conversion Tunning
  47. Trouble with my O2 reading
  48. Tuning or just too long storage issues?
  49. What's the best tuning software out there
  50. Going to EPP tomorrow! Help...
  51. Timing tuner with a nitrous tune...questions
  52. PCM too hot?
  53. HP Tuners question, Is there anything to be gained...
  54. MAP sensor output voltage table
  55. ECT sensor problem
  56. TPS question.
  57. Camshaft sensor
  58. need help ASAP with missfire/bog
  59. becoming a beginner at self tuning...
  60. hpt w lm1
  61. gauge
  62. ok what are the possible causes for these codes...
  63. Procharged-Trying to tune with EFI Live
  64. 1998 PCM part number
  65. Spark Plugs
  66. Quick AFR question
  67. MS3 & Idle Problems
  68. Several engine codes...
  69. Newbie PCM questions
  70. help!
  71. need help!!
  72. trouble>> fault codes
  73. Code scan with custom tune?
  74. newb question
  75. Need 1998 LS1 PCM Pinout Diagram
  76. MAP sensor, PCM output questions... Probably simple.
  77. Converter Not Locking UP???
  78. Decleration Problem with BS3 program going 15.9 lean on decleeration!
  79. Efilive And Diablo Predator
  80. Is this a Bad Idea? Timing Related...
  81. pcm tuning
  82. Redline Motorsports!
  83. MSD oxygen sensors claim 1300*F could this be the solution to LT Header O2 troubles?
  84. hp tuners a/f question?
  85. service active handeling system light is on .......why
  86. (EFILive) Im wanting to lower fans temps
  87. PCM failure ?
  88. Advice on my HP Tuner Logs
  89. How does the PCM determin a misfire?
  90. Tuning Fuel Pressure
  91. Optimizing timing
  92. do i need a bigger maf
  93. help please!!!!
  94. Knock retard problems need some help.
  95. is my TPS bad?
  96. asr randomly turns off
  97. Tuning ?????
  98. PLX install help through EGR
  99. Drive by wire Technical ? .
  100. JET DST & VISTA
  101. What would cause P0171/P0174
  102. HPtuners please help
  103. HOLY CRAP...look what fixed several problems
  104. PCM Schematic???
  105. How did you run your LM-1 Wide Band to the inside of your car?
  106. Sponsor/Other help wanted for Base tune C6
  107. Re sell EFI Live
  108. Weird misfire problem...
  109. Diablosport Predator plug wire
  110. Problem with map sensor
  111. ses light code question?
  112. mail order tune?
  113. Help
  114. Diagnostic Port wont work?
  115. abs, idle problem!!
  116. MAF specs
  117. 5.7 Hemi tune results
  118. Hp tuner questions..
  119. Help: KR when starting from a stop!
  120. Getting 0300 code. help
  121. SD = Low Cylinder Airmass?!?
  122. Basic PCM Questions
  123. hp tuners ls2/l92/l76 bin file?
  124. cam/intake/head/injector swap missfire
  125. tuning out rear o2 sensors
  126. HPTuner problem
  127. Another "Quickin Question"......P1133
  128. Changed the Cam sensor and still throwing code!!!!
  129. Wideband
  130. ELive Tune bad
  131. BS3...crank reference input
  132. cam/intake/head swap missfire
  133. Po332 knock sensor
  134. Idle fuel flow
  135. Recommended Fan Settings for 180 tsat
  136. Where should I put my Wideband Sensor?
  137. A long shot but?
  138. Whats the biggest cam you have run with a stock tune ?
  139. Unable to read/write tune
  140. Any benefit from tuning?
  141. Whats my best option?
  142. i want to make 93 0r 94 octane gas
  143. Scan tool problem or car problem?
  144. can someone look at my tune and see if im on the right track?
  145. pcm flashing
  146. Tune or no tune?
  147. Code P0106 question
  148. can i keep the 93 tranny when switching to a 94 pcm?
  149. tuning individual injector flow?
  150. Help Asap
  151. Some quick help for HP TUNERS
  152. Slight hesitation at low rpm.
  153. LS1 Edit gurus Cant get truck to hold timing
  154. Crossed o2 wires
  155. USB TO 9-pin adapter not working.
  156. tune for headers
  157. what would cause this?
  158. dtc 637
  159. Pros/Cons of a Speed Density Tune?
  160. i need an LT1 Dyontuned in Georgia
  161. need help, car won't start
  162. Where to start tuning
  163. Trying to tune MAF
  164. Can some1 look at this tune
  165. Emissions readiness after battery disconnect
  166. MAF question??
  167. stock fuel pressure?
  168. Mega misfires at idle...
  169. p0200
  170. bcm and ground locations
  171. Need help--PLEASE!
  172. knock retard turned off, timing still retarded
  173. Old TSP 231/237 112 timing tables
  174. Diablo Trinity?
  175. torque convertor tune?
  176. MANY Questions (93 EPROM, Data logging, TunerPro R/T users?)
  177. SD tune for a street car......or keep the MAF
  178. PLX SM-AFR/DB-5 problem................
  179. Ls1 scanner software?
  180. holden pcm
  181. efilive autotap combo problem
  182. Some codes...
  183. Opinions on FAST vs Accel DFI 7?
  184. FAST Flash Handheld Performance Programmer
  185. Hypertech Questions
  186. a couple engine code questions
  187. HPTuners question?
  188. Take a look at this tune and let me know what you think PLEASE!
  189. Damnit what to do now?
  190. Thoughts on msd coil packs.
  191. trans
  192. First Tune
  193. tuning question
  194. 2 PO300 Codes (Random/Multi Cylin Misfire)
  195. trouble codes. Please help.
  196. Diver side running extremely rich
  197. Changes when adding 90/90
  198. 2004 C5 Z06 427 - Flashing A/C light
  199. LM-1 programming with EFILive V2
  200. What is going on here? Fuel Trims
  201. What's the voltage from the PCM to fuel gauge?
  202. Tons of codes and car wont start.........PLEASE HELP!!!
  203. Spark and PE - TorquerII, can everyone share their tables?
  204. need 2002 Z28 PCM pin diagram ASAP PLEASE!
  205. p0351-58...problem!!!
  206. pros and cons of using stock o2 hole for wideband?
  207. Can anyone help a NewB understand how to tune fuel
  208. BS3 boost controller
  209. Has anyone seen this code when trying to flash a remanufactured 98 PCM?
  210. PCM HELP ASAP 98to99
  211. New PCV - Knock sensor calibration?
  212. Is It Time For A Tune...??? Or..
  213. spark knock when hot
  214. Pin outs and wiring for different OS/PCMs?
  215. LT1 Dyno Tuning
  216. Deleteing out EGR codes(Ford taurus)
  217. Elevation change on a SD tune car.
  218. Tuning?
  219. Well i did it!
  220. hptuners not working
  221. Could someone hook me up with a stock tune??
  222. Got a Hypertech 160 Thermostat... what temp do you guys tune your fans for?
  223. Backfiring
  224. Tuners Inside Please!
  225. Help with wideband (lc-1)
  226. Surging @ idle when cold and temp gauge slight bounce
  227. Predator Equiped
  228. throwing 4 codes....
  229. started Going lean on top end AFR 19.5 WB help!!!!
  230. O2 sensor readings
  231. where is it
  232. How Long before Tune?
  233. Anyone tuned their fuel level gauge?
  234. Optimizing WOT P/E and spark
  235. understanding the maf and turbo?
  236. Predator & speed density
  237. MSD Coils, Spark Dwell? Other tuning?
  238. Not going into closed loop
  239. PO118 After Heads Cam Install
  240. Can't Change Timing??
  241. PCM from different "year"
  242. P0102 and P1336
  243. Pageing Gomer!!!!!!!!!!!!!!! or any tuner in Huntsville
  244. NEED HELP! Problems Starting
  245. DRL MODULE CONTROL FUNCTIONS & WIRING
  246. Speed Density Conversion
  247. small problem with a code
  248. Ordered Hp Tuners...
  249. need help with a code
  250. bolt on tunes
