PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Won't Crank..
  2. Help Running very rich on driverside.
  3. 2.5 bar map?
  4. how do you change to a 2 or 3 bar map
  5. Need advice on Superchips 2725
  6. Where in Chicagoland area can I get a Good Tune!
  7. #### Gainesville - March 19th - Formato Fasterproms Tune Session ####
  8. Good timing map for MSD 6LS?
  9. Does the PCM shut down the engine if the battery is not present?
  10. Need some help tuning
  11. HP Tuners???
  12. A3 to built 4L60E/4000 stall swap, need trans tune file
  13. Scanner help
  14. Exhaust dumps...super lean now HELP???
  15. Thoughts on 100mm MAFs
  16. HPTuners Idle issues
  17. big stuff 3 contact?
  18. test for fryed pcm?
  19. aem plug and play?????
  20. pcm tune columbus ohio?
  21. any lt1 tuners in memphis
  22. lc1 wiring
  23. How much Altitude change allowed before retune?
  24. hptuners wideband offset
  25. P0704 Code and throwing codes for both O2s.
  26. need help slight vibration.....
  27. HP Tuners question
  28. Which tuner is right for me?
  29. GMPP LS3 controller-anyone from GM think you can help?
  30. Sniffer Emissions
  31. Tuning software?
  32. Is it ok disable "power enrich" and "boost enrich when tuning in HPTuners?
  33. The Process of Frost (Review)
  34. A4 To M6 Tune?
  35. Fast managment tuning question
  36. Using 83#injectors HPtuners only goes to 63....
  37. Help TPS 1.25v from pcm at the plug
  38. Dyno tune now or wait until summre blen gas?
  39. please help ( P1111 and P0113 )
  40. Input on troublesome codes
  41. Low res circuit code 0016
  42. Hp tuners learn here!!!
  43. Need to change driver side cat, will it shut off SES?
  44. will this harness fit the d585 truck coils
  45. Passing OBD II with EGR, AIR, and rear O2 sensor tuned out
  46. Using A Predator Programer To Play With Shit Points When I Have A Custom Tune
  47. Stall converter tune question
  48. Generator L Terminal P1637? / Possible alternator problem?
  49. Wideband AFR Problem?
  50. AFR at WOT in the 3k area??
  51. Bosch or AC Delco front O2 Sensors?
  52. got Dyno tuned today
  53. Throwing bad o2 sensor codes after axle install and tune
  54. fbody gauges and truck harness?
  55. p2008, p0020, p1000
  56. HELP!! denso o2 sensor part# ?'s ls1
  57. Knock Retard???
  58. Cruise Control won't work after wheel spin
  59. Will a PCM reflash at the dealer reset my tune?
  60. Idling Problem
  61. HELP lt car puting ls in it!!
  62. Gainesville and South Florida - Formato Fasterproms Tuning and Porting
  63. gear change - speedo tuning
  64. data logging and turbo math help
  65. True Respect! Frost!!!!!!!!!!!!
  66. Intial Tuning for speed density and 60 lb injectors.
  67. o2 questions? need help!
  68. looking for the best how to and learning info for useing HP tuners
  69. trying to see how much of need i am for a tune...
  70. Hooked a battery charger up,Now my WS6 wont run???????
  71. Hp pro or standard. Turbo car way to rich
  72. tuning with converter swap?
  73. Random engine misfire code- please help
  74. Looking for a tune
  75. anyone know how to get ahold of Glenn Lipinski?
  76. New LS3 only runs at 3000-4000 ????
  77. need help 04 GTO 402 stroker!!!
  78. About to get a tune
  79. o2 sensor problem
  80. Worth it to get a tune right now?
  81. I Read the VCM with the DOORS OPEN !!!!
  82. LS3 5th Gen Pin out diagram?
  83. tune question
  84. 24 byte 98 PCM question
  85. Airflow error to Effective Area
  86. need youR help guys need tune software for 94 trans am(LT1)
  87. 98PCM to 99+PCM Questions
  88. Wideband power
  89. Where is the injector scaling chart ??
  90. WB AFR shows something differnet to O2's
  91. needing a hptuners bin for 5.3 turbo
  92. narrowband O2 and LC-1
  93. Car won't start with new injector data
  94. where do i find iac counts
  95. O2 sensor question
  96. Dissabling the rear O2's & AIR
  97. engine wire harness question
  98. Please help!!! Very frustrated
  99. question 98 ls1 ecu and limits for 4l60e tuning
  100. 1987 shortbed chevy with a 6.0and a 4L80E
  101. answer needed asap. attn foff667
  102. Horse power house
  103. Can a Automatic PCM be flashed for a Manual Transmission?
  104. ABS Inop and Spazzing Lights
  105. Tune and use as generic scan tool
  106. Bad BCM?
  107. P0152, P1133 and P1152
  108. (LT1 OBD2) Anyone use Auterra Dynoscan?
  109. Can you adjust your a/f with the lc1
  110. Need help/info....
  111. Why am i getting this p1510
  112. 1999 Camaro Wiring Diagrams
  113. Datamaster logs - Something not right with my LT1 - Any ideas?
  114. Wiring up an ls6
  115. Idle Issues: hanging at 12-1400
  116. Re-flashing to stock parameters?
  117. Hp Tuners credits
  118. LC1 error code 2
  119. ground locations
  120. Summit EFI tuning DVD
  121. Timing under WOT ??? help!
  122. vin and os
  123. Would a modified MAF turn on bank1 and bank2 lean condition codes?
  124. '96 LT1 VIN into a '02 LS1 PCM? EFI Live/HPT
  125. Wiring Spek A/F Gauge for Wideband
  126. video of "part throttle lean" condition!! tuners please advise!!
  127. MAF bad?
  128. HP Tuners Issue can read but not write to computer
  129. tuning and wide band questions
  130. Engine light on a 05 Malibu due to opened gas cap.
  131. Help idle problems
  132. If I buy a new PCM...can I have my current tune dumped into it.....
  133. Wideband question on installing?
  134. help me learn from this log
  135. MA tune needed
  136. Front Oxygen Sensors - Intermittent Problem
  137. Who has racecar tuning tips?
  138. who is considered the best tuner in PA?
  139. intermittent low oil light even with sensor unplugged
  140. O2 Simulators
  141. types of tunes
  142. ls1 swap in a toyota with dbw help!
  143. Can someone take a stab at this.....maybe PCM related
  144. Another "which" wideband question
  145. Its been awhile, and I'm rusty
  146. Racepac dealers...
  147. Can Datamaster datalog AEM Uego wideband?
  148. PIST, Car finally done and my tune goes to Safe mode..
  149. diablo predator + Gear settings ((Need help))
  150. Whats the (BEST) Wideban/AFR tach ????
  151. DBW throttle pedal compatibility
  152. Need help engine swap cluster acting up.
  153. Fast or big stuff3
  154. CEL off with o2 codes on?
  155. Autotap question
  156. Richer and Richer at idle with SD tune
  157. hp tuners bullshit
  158. dynotune?
  159. is this a decent wide band guage?
  160. Impact of Exhaust Flow on Tune
  161. E67 ECU FI tuners or tunees CHIME IN!!
  162. Rear 02 Sensor Question
  163. 99+ knock sensors on 98
  164. totally new to tuning, diablo predator
  165. Wait4Me tune and Diablosport compatibliity
  166. L92 VVT e38 cam swap tune with a t56?
  167. Tuners in Houston area
  168. do i need a tune
  169. Clearing Codes Permanent?
  170. wireing harnesses
  171. refresh my memory...
  172. gm vdr(vehicle data recorder) / scan tool 1996-2010
  173. Opinions on my thoughts/plan...
  174. weird iat issue on h/c ls7
  175. Where would one learn to tune professionally?
  176. obd1 Tuning software
  177. 99 pcm ?
  178. Truck maf from a 99 sierra 5.3 is it 85mm?
  179. 2000 TA LS1/T56 tune issues
  180. Tuning a turbo LS1 with EFI Live
  181. Wideband placement
  182. h/c ls7 wont start easy
  183. P0160 code(heated 02 sensor)
  184. tuning gains from headers
  185. lq9 swap
  186. WTF LC1 wiring question
  187. need help with tunercat
  188. P0157 O2 sensor Bank 2 Sensor 2 - Help
  189. whats the stock pcm limits
  190. Are these number OK or a bit low?
  191. need help with my wiring harness
  192. Where can I get the computer reprogram
  193. Wideband!?
  194. needing tuned
  195. Tuning My Car.
  196. Do I need LTFT trims
  197. HELP! My diagnostic connector isn't working?
  198. tuning&injectors?
  199. HP Tuners to FJO wideband Q's
  200. New to Tuning..
  201. im thinking about getting into tuning myself
  202. Steering sensor code
  203. anyone know how to fix this code???
  204. jet dst/mxscan
  205. LC1 will go lean as soon as the coolant reaches 192*
  206. Tuners in So-Cal???
  207. po327 code
  208. need help
  209. knock warning system?
  210. misfire after cam install
  211. E38 ECM, does it have the TAC.........
  212. Do I need MAF and rear O2?
  213. Mail order Tuners!!! Step Inside!
  214. How to remove pins?
  215. C5 PCM question
  216. Can anyone explain the details of how the LS1 control system works?
  217. PCM programming.com - Feedback?
  218. Help! Did M6 to A4 swap...trying to load A4 tune with LS1 edit...
  219. tune or not after ls6 intake?
  220. lt1 meets turbo now time for a tune...?
  221. tuner in arkansas?
  222. Mass Air vs Speed Density
  223. 2000 Stock 6-Speed Tune
  224. O2 sensors
  225. Help
  226. HELP spedo not working after header/full exhaust install
  227. looking for pcm pin outs and wiring diagram
  228. ecm/pcm recommendations
  229. GMPP LS3 E67 ECM on my Blazer Won't Start.
  230. Mail Order Tune
  231. Can you swap front and rear O2 sensors to get rid of code P0133?
  232. ECM vs. PCM vs. ECU?
  233. Where can I get pins for PCM and blue and red covers for terminals
  234. Have an AEM wideband need cable for tuner to use??
  235. Who has FI Setups that make 900+RWHP?
  236. 98 PCM, Big Cam Issue
  237. Crate Motor Tune
  238. VE tuning on a '99 C5
  239. LC1 setup (ground offset)
  240. About 20 miles after tune car pops a P0101 runs like crap? At a total loss..
  241. Do I need a tune after gear change?
  242. EFi live help
  243. I need a tuner. Who can do it?
  244. any problems with dashdaq
  245. Tuning a GMPP PCM
  246. No start issue. Need help!!
  247. 08 Z06 Misfire Issue
  248. Looking for a Reliable Tuner in or near OH!
  249. Which tune to go with?
  250. LS3 Hot Cam Tune
