PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. P0307 and P0357 ?????
  2. COT delete ?
  3. Idle surge???
  4. Big Pcm Question!!! Please Help!!!
  5. Partial throttle tuning
  6. Anyone willing to comment on my HPT VE tuning efforts (attached bin, and log)
  7. What is wrong with my car??
  8. summer time...codes ahoy!
  9. Getting odometer reading without engine
  10. What is my problem?
  11. Code PO751
  12. Security light causes car to not start
  13. Strange startup issues after OS change
  14. tunned by Connely's in Houston,TX??
  15. boost timing????????
  16. SLP MAF/2002 Camaro
  17. WTF?! I threw 7 OBDII erroe codes!!!!!Help!
  18. Ethanol and Tuning question
  19. Has anyone been tuned by Mark Oldani?
  20. WTF is causing this lean 1st gear?
  21. Curious to know if anyone has tried the Aeroforce gauges...
  22. Is there a tuning doc for FI?
  23. SES Light on, got the trouble codes...help plz
  24. ABS INOP with larger tires on rear....?
  25. BS3 question
  26. Rich in O2 B2S1 Ok in O2 B1S1
  27. LS1 Edit and Emissions???
  28. ses light flashing
  29. Diablo Custom Tunes???
  30. timing for a stock 02 cam???
  31. +15 ltft iat idle
  32. Possible to change a 98pcm to 99+
  33. VSS signal style?
  34. SES suprise
  35. Ok now what... biting the bullet w/tuning?
  36. Timing on bigger cams
  37. Code P1518 and P0108, car idles at 3-4k rpms when moving!!!
  38. SD vs MAF
  39. What table would cause this problem?
  40. What's the best way to pull fuel out of the mid-range (too rich)--dyno sheet attached
  41. MS3 going in, any tuning tips?
  42. Step by Step RAF Tuning Instructions...Can't find
  43. Air/Fuel madness.... maybe a stupid question?
  44. Scaling IFR to - LTFTrims for 60lb injectors-26%!!!
  45. drop in rpm between shifts, what
  46. help! intermittent misfire
  47. Accel enrichment
  48. TB issues
  49. p0480 and p0481
  50. Wiring?
  51. dual fast 90
  52. PCM VSS pulues mod ?
  53. code p0101 ?
  54. is my ecu goin on me?
  55. Trans SES Light
  56. little bit of turbo car tuning problem
  57. Gm Tech Ii And Custom Tune
  58. Gen 7 and Mallory ing NO START ?
  59. big stuff 3 vs fast
  60. lc-1 reads 20.0 after warmup wtf??
  61. Idle trouble again.
  62. Guys, help me out here...car keeps blowing fuses (bank 2)!!??
  63. Inspection Tune
  64. SLP Diablosport question
  65. serial port help!
  66. Wide Band O2 In Stock @ SDPC
  67. HP tuners WOT shift points are hit or miss?
  68. No need for MAF?
  69. Superchips progrmer question
  70. no com sinc
  71. ok cant fig out what this is....
  72. [B]Need input P0300 & P0336![/B]
  73. Need VSS help
  74. timing tables for 2,73 gears vs 4,10s
  75. My first scan please comment.
  76. Oil Change Light?
  77. Since everyone is talking about MAFs...Fired up the custom 100mm maf
  78. Good supercharged tune
  79. Denver?
  80. Number to LS1 edit?
  81. HPT: Cannot find VCM!!?? Don't understand...
  82. What do i need to see OBDII SES codes ?
  83. Cant read the ECM - need help
  84. LC1 in the X-Pipe
  85. Running lean on bank 2
  86. 3 bar with HPT
  87. Any tricks to making a 3 bar map car run on 1 bar software just to get to the dyno?
  88. Custom connectors for wiring LC1 narrowband/wideband/EGR
  89. SLP maf?
  90. Tunning to run 150 shot N2O
  91. Timing tables for N2O
  92. Bank 2 reads lean - what's the deal?
  93. programming shift points
  94. does my car need a new tune
  95. EFIlive guru's...
  96. SD tuning && STFT/LTFT correction..
  97. Dyno tune?
  98. Tune, tune...
  99. problems after tranny swap
  100. Do I just need a tune?
  101. Threaded GM IAT sensor???
  102. No more p0153 or p0133 Slow Response O2 codes
  103. Carolina Auto Masters Dyno Tune... what to expect?
  104. different ltfts
  105. Looking for EFILive logo
  106. SES code in speartech system
  107. Speed Density Log
  108. New Motor what to scan?
  109. ltft maxed out
  110. tuning programs??
  111. O2s flatlining-railing, I just cannot figure this out
  112. O2 sensors not working.
  113. What VE table is used in SD
  114. Stock Tach Stopped Working!!!!
  115. High/Low Octane Spark Tables
  116. PCM swap?
  117. diablo tunner
  118. lt1-edit ??
  119. Looking for a usb to serial driver for hp tuner
  120. Closed Loop A/F
  121. Surging Idle....please help
  122. Pinging!!!
  123. how much of a loss?
  124. trouble with WOT TCC.
  125. VAG-COM interface?
  126. any Copnay or person can tun ????
  127. DTC code P0704
  128. Retune w/ new fuel pump?
  129. lc-1 wideband guage
  130. LS2 beta testing...KC area
  131. Getting tuned?
  132. Car wont idle
  133. EFILive suggestions for first scan?
  134. ed wright tune...
  135. GM specific P1639 code?
  136. Tach problem
  137. I know NBO2's are unreliable, BUT WTF
  138. A4 Downshift problems
  139. Vinci Handheld Question
  140. EFILive Scan Tool Only NOW $249
  141. Help with tuning....
  142. HELP!!!!!!!!!!!!!!!!!!!!!What kind of tune????
  143. what the f*** am i getting myself into???
  144. bigger fuel injectors and rails
  145. anyone know what table to adjust the staring throttle % on a LS2 with HPtunners
  146. tuning boost w/ 1 bar ??
  147. Speedo extension P/N
  148. IAT Tricker
  149. major idle problem
  150. Check my connection real quick, LC-1 to HPT for NB/WB setup
  151. Some help for Camshaft Tuning
  152. can someone review my log?
  153. COnverting LS1 wiring to LS2 PLEASE HELP
  154. AFRs unstable during boost???
  155. interesting KR question??
  156. What's more accurate: Autotap or Autometer guages?
  157. hypertech pp3 or pp plus?
  158. timing and grams per cylinder
  159. i need a edit
  160. Cams & Sparks
  161. Max torque range?
  162. Pe fueling problems at the track
  163. I'm driving a 01 SS question is do I require a tune after installing headers ?
  164. Is there a minimum pulse width for injectors in general?
  165. Switching to 99+ pcm questions.
  166. exact DTCs for readiness tests
  167. O2 input - which one???
  168. Car Ticking Question??
  169. Po300
  170. Crank position sensor Missing higher RPM's
  171. k&n filter making my car run lean
  172. lc-1 not switching like narrowband(stupid code)
  173. Should my A/F fall off under accel?
  174. sluggish open loop
  175. egr and air pump. can they cost you
  176. stock o2z with lid, 60 grams per cylinder
  177. FAST90 install and retune help, log pics inside.
  178. !urgent Please Help!
  179. First time EFILive for readiness test
  180. Rev limiter and Nitrous
  181. Secondary(SD) to Primary(using MAF)
  182. O2 sensor/missfire question
  183. Throttle Position Output Wire?
  184. gas mileage question
  185. Knock, Knock, Knockin on my door
  186. more air pump problems
  187. No Tach Code PO00336 crank shaft performance variation
  188. Found the problem w/ my 98 TA but have question
  189. crank re-learn
  190. best spark timing for soparchargchs ????
  191. what general AFR are you huge cam guys running at? daily driving ranges
  192. Stock AF Ratios
  193. COT Enable?
  194. Tps
  195. VE tabel question
  196. Electrical Help!!!!!!
  197. LS1 Edit, PCM Binary that has a similar setup as mine.
  198. Mail tune good enough for break in period?
  199. quck help please
  200. AFR readings on gauge different from EFILive logs....
  201. bad tps?
  202. 2004 gto predator tune help!!!
  203. service vehicle light when maf disabled?
  204. Hypertech and E10 (update)
  205. STILL Electrical problems.
  206. 2002 WS6 wiring diagram
  207. Predator DAT Viewer
  208. AC causing fan on early
  209. New to Tunning need help
  210. hand held for 98?????
  211. Installing different clusters...
  212. pulled some codes... need help
  213. Diablo handheld question
  214. Scanmaster detecting knock
  215. 6.0 in F Body
  216. Security light related to longtubes?
  217. need expert advice
  218. HyperTech Turners
  219. hc-1133 Fault code any advice
  220. New tune for my LT1?
  221. Locking torque convertor up at WOT in 3 gear
  222. LTFT's Hung Up
  223. where is it best to increase timing?
  224. Catalyst code.
  225. Transient fueling (hey jimmy)
  226. Do i need a tune?
  227. MAF tuning for dry nitrous ? here
  228. Diablosport
  229. Gas mixture and spark advance
  230. LS2 Motor Swap into Rice Burner
  231. HP Tuners 98 2 Bar Knock vs RPM PE
  232. question about knock retard and timing
  233. can someone look at my log.
  234. AFRs bouncing at WOT...why??
  235. Hanging/fluctuating idle, tried everything! Please help
  236. engine codes
  237. engine codes 26,27 and 77
  238. Tuning help for my 98 TA F14 cam & bolt-ons only
  239. to tune or not?
  240. Emission test results >
  241. deleting rear o2 sensors
  242. Pulling timing down to 10
  243. Any tuners near Memphis?
  244. Did I contaminate my o2 sensors?
  245. need help. misfiring
  246. What ohm resistor is on the SLP MAF?
  247. What should I scan/log when doing dyno to check "State of the Tune"?
  248. HPT Backlog:
  249. Help! All my servuce lights are on!
  250. newbie
