PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. PCM battery light control
  2. I need this stock file plz ..
  3. Do I need a retune
  4. Misfires p0300 po151
  5. WonÂ’t run
  6. Does the Fuel You Choose Matter? (Engine Masters)
  7. Harness and PCM question
  8. Low Res mode and batch injection
  9. lm7 gt45 tunning help
  10. 2002 WS6 M6 - Can't keep idle low after new battery
  11. Good Email Tuners/ hp tuners
  12. P0606 code after base tune?
  13. Lean stumble with hard rev from idle, help
  14. No crank sensor signal , bad ecm?
  15. Tuner Pro 'addresses' vs HPTuners? Correlation?
  16. 98 to 99-02 PCM swap help
  17. Tunerpro: How to use Vehicle Platform Type/Vehicle Options Table?
  18. assuming check gauges doesnt throw codes?
  19. Questions and advice for getting into HP Tuners
  20. IAC/rough starts
  21. Read P01 alcohol %
  22. 2017 Silverado 1500 Diablo Sport Tune
  23. need a mafless cam tune for ls3 e38
  24. Gear Ratio change to a E39 ECM
  25. torque app errors ?
  26. Questions about idle tuning and throttle bodies
  27. Holley 3 Bar Map Settings Help. 554-107
  28. Basic first tune
  29. EWP Control with dominator
  30. 6.2 idle quality w/cam
  31. Tuning for A4 Shift Corrections after Ring & Pinion
  32. Extra wires on DBW harness
  33. T56 behind an LM7 - A few questions from a Newbie
  34. p0307 code
  35. Codes after heads and cam swap
  36. Do you pin the harness to match OS?
  37. How to download L33 tune from 1 ECM Upload to another. Disable VATS. Most affordable?
  38. losing my mind.. 896 pcm speed density tune... dont have EGR or AC for Wideband
  39. HP Tuners: Target Lambda (Engine-Fuel-Temp Control)
  40. Holley ECU and stock gauges
  41. generic wideband
  42. LQ9 TAC module taking down pcm
  43. MAF vs Speed Density Tune
  44. STFT Open Loop - yes or no?
  45. Air temp and VE table question
  46. 896 PCM with 411 tune?? Not loading correctly?
  47. 5.3 PCM, TAC, TB Compatability
  48. Rich idle
  49. Random 4l60e Codes
  50. scanner air bag resets
  51. Which MAP PID should I be tuning with? Big discrepency between the two
  52. u0107 after writing tune
  53. How do i find a tuner that runs EFIlive?
  54. Part Numbers Needed for "Card" or "Blade" style Mass Air Flow Sensors for LS1 (1998)
  55. Which HP Tuners package is right for me
  56. Is this normal for a VE table?
  57. Anti lag via HP Tuners / IAT sensor recovery
  58. AFR vs Lambda... why ever use AFR?
  59. 98 ecm issues
  60. 17 Camaro SS 6.2
  61. 99 Z28 gauges unresponsive, help!!
  62. TPS and MAF help asap please
  63. Have a question about using a newer ecm and harness in a 2001 f body
  64. Hard cold starts and dying while driving
  65. What HP Tuners tables deal with RPM change when the clutch is pushed in?
  66. Idle vacuum
  67. Got the MAF pretty close to dialed in. What should I work on next?
  68. Changing cam sensor Location
  69. air bag codes
  70. LS1 START and KILL
  71. where to buy ECM for 99 Trans Am
  72. 07 tahoe ecm
  73. Ignition and Blow Thru
  74. VSS questions with 0411 ecm
  75. TCM to ECM communication question
  76. Yet Another VSS Sine Wave Thread
  77. Looking for the LS Tuning shop around utah
  78. 2017 Sliv 5.3 6L90 - DOD Disable and TC Disable in 1-4 Gears
  79. Question about MAF logging in an M6
  80. Injectors
  81. MAF frequency stops at 5250?
  82. Os 1263005
  83. GenIII HCI - HP tuners help needed - rolling stop stall
  84. Open-loop due to system failure
  85. LSA swap with 6l80 won’t WOT 1-2 shift
  86. Lm7 swap dies with throttle
  87. Knock Sensor
  88. LSA E85 Remote Tune Possible?
  89. Can Someone Please Look at this scan
  90. Car is running lean on startup
  91. Anyone have an E38 PCM laying around
  92. Holley Terminator X Max
  93. HP Tuners deciphering knock feedback (non-LS)
  94. 2005 Tahoe multiple random misfire, won’t stay running suddenly
  95. Stock 411 ECM Compensate
  96. Unusual A/C issue.....PLEASE HELP!!!
  97. Computer, manual or automatic?
  98. Can someone please take a look at my HPT datalog?
  99. OS12613248 Need open loop idle
  100. VATS Disable
  101. Starter pulses but truck won't start
  102. Bank 2 02 sensor stopped working
  103. 02 sensor code zo6
  104. HPTuners Operating System swap question
  105. DIY e85 sensor display
  106. 07 C6 cannot relearn vtd to e38 ecm
  107. 07 Dodge Magnum 2.7 to 08 Chevy 5.3 piggyback problems
  108. Backfire/Popping at high RPM 1st gear WOT only
  109. Need Help with diagnosing Single Cylinder Misfire
  110. Holley Terminator X Freezing issue
  111. WTB Tuner Cats
  112. 2002 LS1 From C5. Random throttle lockout
  113. Injector Size vs Idle Mixture Control, E85
  114. Is my tune causing this slow RPM build? Or is it the torque converter?
  115. 93-97 Retaining factory gauges / AC / Heat / Etc with Terminator
  116. '98 Corvette LS1 swap...
  117. Need help with a T87
  118. Cobalt SS 2bar Map in Holley EFI
  119. Car revving super high on cold start
  120. 411 PCM & Swap Harness o2 Issues & Solution
  121. Replacement Ecm VIN question
  122. C5 A4 Dead Pedal in Reverse
  123. C5 A4 Dead Pedal in Reverse
  124. 99-02 harness/ pcm
  125. Increasing engine braking
  126. Misfire on front half of engine
  127. Ls conversion drivability
  128. A few final Terminator Max X questions
  129. O2 sensors not switching and codes
  130. Scan tool not connecting to PCM 99 firebird 3.8
  131. Should I Attempt a SD Tune?
  132. Modifications effect on valve timing
  133. LS1 doesn't always start on first try, second try works.
  134. Superchips for multiple tunes, need some help
  135. Start up Rpm
  136. obd2 port not seeing ECM
  137. Keeping ABS with FWD to RWD conversion?
  138. Tow Haul Switch
  139. L77 6.0 going to LS7
  140. PCM swap for LQ9 swap.
  141. Term X vs EFI Live
  142. T56 swap
  143. P0106 After LC9 to L96 Swap
  144. Speedometer works but problems with shifing
  145. Efilive cax files
  146. 0411 timing
  147. Random running issues.
  148. E67 ECM / 6l80e TCM compatibility - no signal
  149. Bought a Project Truck, this seems like a insane amount of timing.
  150. Gen IV motor in 4th gen z28 cam sensor and o2 issue
  151. L83/6l80 Swap OBS Limp Mode
  152. Recommendations to tunning shop near midland texas
  153. Traction control issue when turned off
  154. No 12v reference coming from pcm for cam and crank sensors
  155. 09354896 ecm with red and green connectors
  156. Narrow Band O2 vs Wideband O2
  157. Gm 17124187 injector on L31 0411 IFR
  158. False Narrow Band O2 Data At Idle
  159. Hp tuners, Gauges, and wideband integration
  160. alternator buzzing
  161. Terminator x max
  162. Volo chip
  163. Holley TermX L92 tune-up help
  164. Mass airflow
  165. Why can't I get my IAC counts lower?
  166. Tuning stock LS1 for more power
  167. Engine Computer Help
  168. Engine Computer Help
  169. Boosted Ls2 cam swap, how should I adjust my spark Timing at WOT?
  170. Knock that won't go away
  171. Simple Injector question (I hope) Deka 80
  172. Knock sensors still codes
  173. Wideband install help
  174. Can I put my friend's HP Tuners program on my laptop?
  175. Adjusting Injector Flow Rate vs Vacuum Table
  176. GM connect and cruise programming
  177. Serial Wideband Questions HPT
  178. high idle lq4
  179. scan tool
  180. Dead cylinders/misfires on swapped LS3
  181. Very confusing O2 sensors
  182. Looking for Tuners in Colorado or Wyoming
  183. Pin out needed
  184. PPV Vs. CTS-V tunes
  185. E40 T42 4L80e conversion - What's the current verdict?
  186. Please help! trans issues/idle issues
  187. LS/T56 Dies when clutch is engaged
  188. L83 6l80e K5 swap problems
  189. 02 WS6 not connecting to ELM327 Bluetooth adapter
  190. Top 3 tuners in DFW?
  191. Supercharger Tune help?
  192. Idle issues caused by STFT
  193. E85 Turbo Spark Plug Reading
  194. 99 ta ls1 missing with codes
  195. 0411 swap c1 pin 46 (MIL) has power
  196. pcm for n/a 6.0 with magnum 6 Spd
  197. Bench Flashing PCM's
  198. Code P0302 - Missfire - need Help!
  199. Break-in / start up Qs
  200. Any tuners in dfw that would go to the track and tune
  201. Tuning my fbody.... HP tuners Books anyone....
  202. Tuner needed
  203. Can someone steer me to a good RESCALING thread? (HPTuners)
  204. L92 ECU with manual transmission?
  205. Got screwed over big time. 11 Camaro SS GPI Cam and head tune
  206. Electrical issues
  207. Gear/Tire wizard issues HP Tuners
  208. LS3 swap MIL on no code, rich idle, looses tach signal
  209. HP Tuners MPVI2+ to AEM 30-4110 Wideband for scanning
  210. Can i save a file written from another MPVI and then use it with mine?
  211. Spark no fuel ,pump cycles though
  212. P0068
  213. Engine stalls on hard braking e38/t42
  214. This one has me stumped, P0101. Help!
  215. Tuning help!!!!
  216. Anyone logging fuel pressure from the EGR channel?
  217. Good idea? Street tuning timing with vbox? Doable?
  218. idle hunt after transmission rebuild
  219. LS2 into a 2002 Camaro. ECM questions.
  220. HP Tuners bad experience
  221. 4l60e wot shifting another thread
  222. VSS PPM 4L60 Trans Tune Issue
  223. Starting Issue
  224. New Tune on 2000S 10 4x4 with 468Int 472exh. 262in 272exh 110degree
  225. wont start
  226. Terminator X tuning
  227. Adding meth to whipple
  228. Wiring harness.
  229. Recommendations about CAN bus
  230. Is Frost still tuning?
  231. Adjusting rev limiter with diablosport after HP tuners dyno tune
  232. 05 envoy e40 ecu manual flash
  233. API Tuning reputation
  234. Vats - BCM issue help?
  235. Trans Tune Issues w 4L80e?
  236. Questions regarding HPtuners
  237. stock Pcm or Holley terminator x
  238. VATS and BCM
  239. Pulling timing during long uphill towing?
  240. Ms3x and bosch 210 injectors
  241. Trouble with my tune
  242. Stock 4l60e tables
  243. P0606 with GMPP controller kit
  244. Stumble on start to idle transition
  245. Good LS tuner on east coast
  246. How much tuning do I need to do
  247. Holley terminator x problems. Please help
  248. Ve tuning with manual trans
  249. Gen 4 VVT control with Holley Terminator
  250. Terminator X with digital dash
