- Speed Density Tune
- LS1 Edit---------Unknown PCM
- Throwing P0135 and P0300 codes
- engine code need help
- I Need Tuning Please Help
- Having a "stutter" at 4500rpms mis fire? Have ATAP sheet..
- Is HP Tuners for me? Please Advise
- HPT...is there anywhere to get an un-bias...
- Do I [I]need[/I] to wait for HPT 2.0?
- Question about F-Body PCM hardware
- sensor help?
- New MAF Table Spreadsheet and RAF Table
- Need 04 GTO stock Bin...Anyone????
- What should the LTRIMS be at idle for a properly tune cam car?
- Gorillachipz?
- knock sensor question
- HP Tuner Question
- B2961?
- anyone ever heard of this?
- NYS inspection - finally passed emmisions!!!!!!!
- Pcm Problem
- Is not buying the EIO cable a mistake?
- Predator Wiring
- Set boost w/ls1 edit or adj. boost with HP tuner 2-bar/E-boost?
- Running Airflow Spreadsheet (LTIT/STIT)
- Accel Gen VII keeping me from joy....
- Fuel Trims and Fixed Orifice PCV
- diablo help
- Power loss at 5300 on dyno
- Setting Up MAFT #'s
- Iam getting a heater code of 1133 Why?
- I need to test somebodies knowledge
- need help on code po121
- Here are some EFi logs i want you guys to glance at!
- Confused - diff between EFILive 6 & Flashscan
- Got a M6 224 112 bin?
- Lockup converter programing
- LTIT & STIT
- Nothing like messing it all up with a Mod
- p1133 ? and p1153 ? What?
- When I make changes to the idle parameters does the PCM need a learn time?
- Predator internet tune files?
- passenger side bank = no fire! help me out please...
- P1637 code messages-help :(
- OBDII maxes out at 7000 rpm?
- Help with HPP3
- Thanks to .....................
- Any way to see if Im close W/O Wideband?
- Diablo tunes
- Got rid of my Granatelli MAF but car is still running lean
- ProScan OBD-II / Dyno / Quarter Mile Analysis Tool - $99 GP!!!
- Should I bite the bullett and buy HP Tuners?
- coolant temp gauge jumps..?
- WideBand Sensor Placement
- Q about AEM wideband wiring....
- The new F.A.S.T XFI
- longer time users of HPT
- which two fuses do i pull to reset my pcm (lost cover)
- Help! Am I running out of fuel?
- Wide Band in Stock Sensor Hole
- Dyno and Tune in SE Michigan
- Melted loom causing P0131?
- SES Light After Cam Install
- disabling pass. airbag?????
- Am i going in the right direction? VE related
- Some VE Table Values at 0. Idle at 2,700 rpm. Help!
- new to tuning need some help
- How high should I set my rev-limiter
- Idle timing ?
- vats
- 0.01 g/cyl @ 15.05 stock map (muuuccch higher in reality) WTF??
- NEEDED: LT1 MAF Table in Excel format
- problems with emission test ?
- need 04 z06 ve table
- DTC 1515 - Electronic Throttle position sensor
- Idle (STIT/LTIT)???
- how to delete the rear O2 sensors using LS1edit?
- Dynamic cylinder air.. got a question
- Is this a good sign?
- HPtuners Wrong software??
- HP tuners + wideband help
- Should we create a Wiring (working title) Forum?
- How Do You Log at the Track?
- engine start up
- Thottle cracker and throttle follower tables
- what effect does adding timing have on A/F?
- car bogging
- ok to tune with multi. programs?
- Difference between Dyno Tuining and PCM mail-in
- Prob with O2's. Help
- Open Loop, Closed Loop???
- Check engine light
- PLX Wideband
- looking for a know mail order tuner who uses HPT
- What O2 Sensor is best?
- Sticky Consolidation Poll... Also what else do we need?
- *READ ME FIRST-- Tuning Docs,VE/MAF, SES Lights, FAQS!!!! + more! *01/31/07*
- 2 bar speed density?
- Car backfires/hesitates/feels like its losing power
- Tuning After 233/233 Cam
- Anyone share a .bin for 30lb injectors?
- Open loop Vs WOT
- EFI live flashscan users:
- pcm fried or reflashing!!!???
- Need help with trouble code: P0011
- I'm a fast learner, but...
- What controls converter unlock throttle position?
- HP Tuners v2.0 release date?
- what is the best tuner for me?
- Over Heating ???
- Ls1edit Rev Limiter Problems Help!?!?
- How much did you advance your diablo's timing?
- is that hesitating a miss fire?? or something else?
- Quick Help with LTFT tuning
- wiring harness
- Chips...
- help...i have asa cam sould i use...
- HP, vs. EFI Live, vs. Edit
- question about my diablo sport tuner
- +25% fuel correction at idle- why?
- Is going from Diablo to LS1 edit to HP tuners bad on the PCM?
- Idle proportional fuel tables? On/Off?
- hey guys, new scanning PDA, ls1m?
- WTF, Lots of rain this weekend and now the car...Help?
- verify good tune ??
- predator reset ????
- People that relocated their battery to the back - question
- 2.73 geared vette and WOT shiftpoint and TM questions
- is mult. tuneing from different tuners bad?
- tach problem
- Car wont start!
- BS3 Help
- Fixed rough idle when very cold TR224 / mild cam
- Change in elevation
- Mail order tune > Who's is the best?
- FMS 30lbers, VE need to be reduced more?
- uhhh.....
- Excessive VE values?
- Recommended diagnostic tool for semi-pro?
- missfire for what????
- DIY Wideband o2???
- ses light still on after installing o2 sims
- Help with idle dipping
- Serial Port Adapter
- got code po102
- Rear o2s
- Another OBD II inspection question....
- run lean?
- Newbie tuning questions
- How to stay in open loop (obd 1)?
- Need help tunning cam and lowering LTFT
- Trans Line Pressure Logging - Electric Sender?
- need help car won't idle
- Tach installation?
- Problems with O2 sensors?
- Calculated new MAF Table
- HPT 2.0 ? or Mega Squirt
- Please Help, Wont Go Into PE Mode (Detailed)
- PCM Question
- will splicing the cranl position sensor wire affect its performance??
- what makes fans come on?
- can someone give me there file for LT's/ORY/CB on a A4
- Another newbie with a question??
- What are the symptoms of bad o2's?
- can someone with a 98 car go look quick..
- Help No Reverse
- HELP!!!! Car won't start
- Crane Tuner
- Begginer's question
- Need to get through inspection What "Type" to set DTC's to?
- need tune file for TR224
- Tuning a 402 (8) from a H/C 346
- suggestions on idle problem
- need help??
- Delphi 42# ?
- Finally, How to Tune 101!
- what to change in tune for a 100 shot?
- line pressure?
- Engine Revs between shifts
- Timing Low at WOT
- DSP tunes
- Need A Ls1 Edit
- PO102 code Please help
- Help with cold start surging
- Torque Management
- How do I cure rich idle?
- Proper tuning order?
- Dead Pcm - Ls1edit
- I Really Need Some Help! Screen Shots Inside!
- A4 to M6 swap reflash?
- Any non-LSx/LTx tuners on this board? SD tuning virgin
- Another LC-1 update
- about to order hptuners, a few ???
- Deactivating a Harlan 2 step
- Base map suggestions? (Cam, Head, 1st start)
- Dash instruments
- ? about Long Term Fuel Trim and Timing Advance readings...
- LTFT Tuning and tuning below 1500 RPM
- HPE now offers tuning for 99-05 Trucks!
- What to do with LTFT
- computer mod question
- Trouble Code Question
- anyone ever used a motec engine management
- EFILive on a LB7
- EFI Live ?
- Quick Question About TCS Logic
- A/F problems..HELP
- knock sensor help...
- is it possible to reset the odometer??
- how much hp do you lose from 93 to 91 octane?
- Anyone tell me what's up with my A/F reading?
- Blinking Service Engine Soon Light?????????????
- TQ Management Disabled Only at WOT?
- question for F.A.S.T users (problem with car )
- Help! Need source for connector
- G-Tech info
- Dead battery , short circut
- Tuning Virgin
- BS3 / Stock gauges - interface
- looking for a good dyno tune in minneapolis
- Time to talk dyno's
- Po503
- knock sensor
- Could somebody please look at my O2 sensor readings?
- Question about MAF sensor.
- Please Help With Timing
- Why is tuning needed?
- logging transmission
- Gear/Tranny Related Tuning, Need Quick Help
- TUNE of AFR is BETTER on DYNO or ON THE ROAD ???
- Converter slipps ...help
- Engine surges at higher rpms and when cold..
- Crash course on OS
- hp tuner
- LM1 EIO question, WB02 says 14.8 HPT fluctuates..
- HP tuners tunning for boost
- Ve table ?
- Stuck the MAF back in to test bucking at takeoff
- problems with hptuner
- I need a LS1 edit
- Tuner Question
- What could be wrong with tuning to have TQ so low???
- FMS 30lb IFR table tuning.
- writing to LS1 edit tune with GM edit?
- Looking to buy Efi Live???
- Security Light is on..
- Constant driver side front 02 heater circ failure!!!
- Low Oil Level Sensor
- Can someone who's tuned a BIG cam please post steps?
- what's going on here (screenshot)
