PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. How do i avoid downshift 3-2 on dyno ?
  2. What resistor for 10 degrees?
  3. Superchips Programmer Owners ONLY, PLease
  4. Would Dtc About Air Pump Relay Hurt My Performnace
  5. New to Programming... Need help getting started.
  6. Review of HP tuners after 24 hours
  7. I need help with big cam idle tuning
  8. Long term bank 2 weird reading????
  9. Part Throttle Tuning Help!!!
  10. Idle with AC on and car is warm
  11. Anyone have LS1 Edit in Tucson, AZ?
  12. Sporadic low O2 B1 at WOT???
  13. Engine Codes..?
  14. knock under load
  15. ANybody know what the PCM shifts a 99A4 at?
  16. Powering laptop whileusing Edit?
  17. TPS and throttle body question
  18. P1416 SES how to fix?
  19. First mods on the way
  20. Ses...
  21. removed the Secondary Air Injection System
  22. How to get rid of tq. Mgnt. with HP tuners?
  23. EFILive Data - Need help
  24. TPS code
  25. Header leak causing inaccurate o2 readings and tuning problems
  26. Mafless S.D. tuning has begun!
  27. Check gauges light but nothing happening?
  28. TPS problem possibly???
  29. Pedator or HPPIII
  30. best programmer or tuning
  31. car is throwing a code..what do I do?
  32. LS1 code 351 related to coils...
  33. Does a MAFT do anything for part throttle power?
  34. WOT - LTFT is ~+6??
  35. Hidden shift light
  36. ls1 edit
  37. eratic STFTs. have a few questions
  38. New to the tuning world....
  39. Did ATAP....Got engine misfire code P0300
  40. Gear Swap Recalibrating
  41. scanmaster
  42. LM1 and RPM Logging
  43. longtubes and closed loop fueling
  44. Tuning question after injector swap..
  45. How many Tuners do Part throttle tuning?
  46. Gauge needless off.......correction???
  47. PE Table
  48. Predator gear change not taking...
  49. what would cause bad gas mileage?
  50. will ls1 edit that was from a 99 trans am work on my 00 trans am?
  51. New To diagnostics
  52. comp cam 224/224 hp tuner
  53. Predator set up help
  54. LS1 edit
  55. After my cam change
  56. Pin Out for LS1 TPS?
  57. car "chugging" with stall
  58. help
  59. Planning to go standalone with my FAST, not sure about certain gauges...
  60. Code P1153
  61. Catalyst test in AutoTap?
  62. Remove Maf ends for tuning?
  63. grams/cyl = ????
  64. TB screw
  65. ls1 edit procedure
  66. any "little Mods" before tune??
  67. Pids
  68. Changing custom program with HPP 3
  69. efi live saving screen shots ?
  70. c5 covertte owners, what is your idle TPS?
  71. Edit quirks - and a problem
  72. Dead O2 sensor?
  73. question on 3 DTC's found today
  74. Engine surges at idle after WOT runs...otherwise ok
  75. can u check codes with edit?
  76. accel dfi gen7 help
  77. Would love some help with edit
  78. Fuel trims
  79. egr low voltage?
  80. Do I need a new tune ?
  81. Tuning a blower with predator
  82. can someone explain the direct relationship STFT has on LTFT?
  83. Ws6
  84. OIL CHANGE light on and off sporadically
  85. Some EFILive guages dont function.
  86. Where to get a tune in Houston?
  87. Question on selling my LS1 Edit
  88. thinking about open loop...
  89. Range between B1S1 and B2S1?
  90. New here, questions re: timing in hp tuners
  91. someone please help with throttle follower table
  92. Need help tuning this HUGH cam
  93. help with #3 misfire
  94. Using MAP data to understand LS6 Intake restrictions....
  95. newbie tuneing question
  96. LFTF B2 is that on the drivers or passenger side?
  97. Best way to tune injectors that are "too big."
  98. Looking for autotap analysis tool - what to scan for, etc
  99. What could cause this??
  100. dyno after Predator custom - worth it?
  101. Motor Swap - What about the ODO
  102. ltrim question
  103. I need help tuning Gran Am Cam A4
  104. HP Tuner users please nudge a novice
  105. what should i go with
  106. My car won't goes past 6000RPMs, any ideas?
  107. My experience with Accel DFI
  108. Help With Codes Please!!!
  109. witch tuner to go with??
  110. Little help getting started?
  111. Hypertech Progammer 3 problem
  112. PCM and programing guys please look in here
  113. Procharger Tuning
  114. AC overcharged - compr. shut down?
  115. A/C clutch intermediate cut off ???
  116. what the...?
  117. rear o2's and more?
  118. Need PCM advise
  119. Dtc P0420
  120. Predator help
  121. car doesn't like A/C
  122. Help! Car has been dead far too long!
  123. tq manag?
  124. headers install - open loop now?
  125. ls1 edit info please
  126. P0327 knock sensor?
  127. TR 224 with stock tune. Is it ok?
  128. bad plug in port
  129. Hypertech programmer or Predator tuner
  130. switched from draw thru to push thru ltrims swing 15%
  131. Starts bad
  132. anyone have
  133. Need the ASA pcm pinout
  134. tuners:please check my diablo live data
  135. o2 sims
  136. SES Light Any Idea's
  137. LS1 Edit and Hypertech/Diablo
  138. fueling problems, pcm seems to go into speed density mode
  139. Quick HPP3 Question.NEEd Quick Response
  140. Tuners: Timing vs. MPH??
  141. Need some tuning help..car just dies at half throttle
  142. looking to buy efilive or atap
  143. when to replace o2's and a/f gauge question
  144. Carputin Blows a big one
  145. Will an Impala (baby LT1) PCM work in a F-body?
  146. Engine to Dash Pinouts
  147. DTC P1336 (Crank positon relearn)
  148. Timing Table for LS1Edit
  149. Timing Table for LS1Edit
  150. need a tuner in the North Arkansas or South MO area
  151. Programming with a laptop
  152. Those Ebay performance chips
  153. HPP3 shifting question
  154. How will engine respond to larger injectors?
  155. what does all the live data from Diablosport mean?
  156. questions about fuel trims at idle
  157. secondary ve table
  158. need help
  159. need explanation of air/fuel ratio measuring, guages, narrow vs wideband
  160. How accurate is the LS1 Scanmaster?
  161. disable the security???
  162. PCM tuning in Sun valley Idaho?
  163. Change Injector Size w/ Hp Tuner
  164. I see we have a new moderator!
  165. help
  166. Predator Or Hpp Tuner Question
  167. Help me get rid of this dredde Knock Retard!!
  168. looking for 02/03 Z06 VE table...
  169. LS6 PCM Table
  170. Considering HP Tuner Suite
  171. Aspect Ratio???
  172. Installing new PCM with remote start??????
  173. Venom 400
  174. Worth adding EFILive to ATAP Enhanced?
  175. PCM pin-out question ... not an LS1 (3800 GP motor)
  176. ECM Scanner Options - what's hot, what's not?
  177. UK LS1 owners. Assistence required.
  178. Crank sensor relearn
  179. Is this a low idle?
  180. Wester's vs. Nelson Performance
  181. Anyone at HP Tuners help me out?
  182. Fuel Trim Question
  183. Would code P0121 (TPS) cause built trans not to downshift at WOT? tuning problem?
  184. What is this called? Re: Coasting down a hill
  185. Speedo way off. HELP!!
  186. HP Tuner Users..........
  187. ABS Issue with slicks?
  188. IAC's too low? Did I go to big with drill bit?
  189. Need tuning help for TR224/112
  190. anyone live near whittier, ca?
  191. How to run open loop?
  192. fixed idle and now hangs up
  193. DAMMIT!!!! need help
  194. performance chip
  195. Car is really lean and other problems too HELP?
  196. Dumb Question: How do you delete the rear 02's using LS1Edit?
  197. Edit tuner in Minneapolis/st. paul?
  198. quik question....
  199. How to tune for a turbo???
  200. Help, Is it ok to drive the car???
  201. TCS acting wired lately...
  202. Mechanical vs. Electric gauages---whats the diffrence?
  203. I just pre-ordered HPTuners:Have questions
  204. Tuners - Where do you start pulling timing on a blower car?
  205. 02 SS Fuel Pressure adjustment
  206. Speedo not correct even after changes in Edit
  207. Issue with dyno numbers. Is it PCM related?
  208. WooHoo!!. justed fixed all my idle and driveability problems
  209. Autotap Oil Pressure Voltage = 0 ?
  210. Service Engine Light Came On
  211. what number to change to get the quickest knock recover
  212. Time for tuning yet?
  213. SES P0135 Code, HELP PLEASE!
  214. Need factory IFR table for 2001 C5 coupe, 6spd
  215. IDLE provblems in gear...
  216. Timing Tuner issues..
  217. fuel trims changed big time, what gives?
  218. just went TH400, now wont idle
  219. So fuggin mad with Edit
  220. 98 z28 cats removed
  221. hypertech or diablo?
  222. ve table adjustment question?
  223. question on using someone elses flash?
  224. Running lean - losing HP?
  225. LS1 edit retune after LS6 intake swap?
  226. Is it possible to hook up a MSD Digital-7 plus box or retard box to an ls1?
  227. What should I adjust using predator after 231 cam install?
  228. High/Low Octane tables...
  229. A4 Tranny Slipping After Programming
  230. book on ls1 tuning?
  231. LS1 TunerCat possible this month.
  232. OBDII and EGR @ inspection
  233. Using Tuning to lock converter up top?
  234. Tuning my 98 Trans am ws6
  235. need help problem with my 02 z28
  236. first time autotap
  237. A/F HP difference from 11.8:1 to 13.0:1
  238. Strange A4 Tuning issue... shifting at 63mph .. shoud be 73mph
  239. No more edit
  240. Help with nitrous activated timing retard
  241. Timing Tables
  242. Broadcast code problem? (messed up PCM?) Please help
  243. WOT and street tuning??
  244. having issues with starting
  245. spending alot of time in cell 22?
  246. idle problems and 15*timing at WOT
  247. predator tuning problems
  248. Cats and A/F Ratio
  249. no comunication with pcm after reprogram?
  250. Flashing a PCM
