PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. New mods, Can I drive to dyno???
  2. hp tuners help...
  3. obdwiz software qusetions ?
  4. dumb wideband O2 tuning question
  5. Car started hesitating bad after clutch install
  6. no tach signal, ecu?
  7. PCM programing
  8. When to throw it on the Dyno?
  9. Should I try fix my own tune or just re-tune from scratch???
  10. Lets Talk GMLAN (J2411 SWCAN-Bus)
  11. Hp tuners with hypertech
  12. Turbo injector issue... Help
  13. Camaro gauge cluster oil pressure and gas gauge help
  14. GMPP engine controller a/c request pin?
  15. tuning a brand new vehicle, why ?
  16. Any tuners in Northwest Ohio? Lima area?
  17. LS7 MAF Help.....I Have searched and cant find my answer
  18. HP Tuners
  19. need help! LQ9 runs great UNTIL it reaches operating temperature?
  20. how to hook up a PCM to HP tuners without going through harness?
  21. 4L80E Input Torque
  22. LM-1 and IAT/CLT tables
  23. What to use for speed density tune
  24. Anyone here knowledgeable with tuning?
  25. Tune or stall problem?
  26. off idle reponse falls on face
  27. PCM Question
  28. No com with Tcm or PCM with tech 2
  29. Questionable engine - want to hear it run before having it tuned...
  30. Exhaust making a terrible popping!
  31. tuning strategy differences? eddy current dyno vs inertia dyno
  32. Need Holley Dominator EFI Help.
  33. Mail order tune with Cam?
  34. P0102
  35. Poor Throttle Response After 90mm Install
  36. advice on live data obd2 scan tool purchase for diag. and tune
  37. DTC help
  38. how "smooth" should a VE table look like?
  39. Car dies at cold temps and if idle to long.
  40. After megasquirt, engine cuts off at 4700rpm
  41. tuning the 5.3 questions.
  42. System Lean after header install
  43. PCM/wiring harness question
  44. 99 to 01 OS Hptuners doesnt read sensors
  45. Need Help figuring out the year of my F-body Ls1 Harness
  46. Misfire Data from Snap on Scanner MT2500
  47. Engine stalls when a/c turned on
  48. speedometer off?
  49. Misfires After Tune
  50. ecm swapping?
  51. injector flow rate vs kpa
  52. HP Numbers?
  53. Does anyone have the blue cat tool?
  54. 896 PCM, can you flash a 411 tune into it?
  55. Map sensor question
  56. Mail order tune Help
  57. southern ga tuning??
  58. Tuning bolt on
  59. Misfires on 2 and 3 at 50+Mph
  60. Help! horrible stumbling issues at low RPM
  61. Chasing My Tail....is my desired airflow suppose to be at 0?
  62. Rolling idle issues after 2 Rounds of tuning with 228R Cam. Help Please
  63. Thinking about learning how to tune my car, where to start?
  64. HP Tuners and tuner lock question
  65. Troube Shooting/ Tunning my 280/LSX
  66. Tune Time Performance in Lakewood
  67. PCM, ECM & BCM clarification
  68. 98 T/A with 99 harness with 02 pcm swap problems
  69. mail order tune
  70. GEN IV Truck MAIL ORDER TUNE ?WHERE?
  71. Trying to get dyno tune but I CANNOT due to my o2 sensors
  72. Long Hot Start
  73. Pegged 25% LTRIM - o2's seem ok?
  74. Found a PCM -Good for anything?
  75. Modern muscle
  76. 98 99 engine harness differences
  77. Tuners in the chicago area???
  78. I'm about to pull my hair out... AEM wideband install?
  79. Guide to Electrical Best Practices
  80. Question about VATS and tuning credits
  81. Shifting Issues
  82. VATS Tuned(or fried) itself out?!? Call me crazy
  83. where does pcm(red) #10 tach wire go???
  84. Quick question
  85. Ls2 harness help needed
  86. 99 ws6 ls2 6.0 trans am
  87. Dyno tune in southwestern PA.
  88. LT1 heads and cam timing map.
  89. Holley Efi Tuners in Indiana / Chicago ?
  90. Flashing a 99 pcm with a 2000 tune
  91. Flash a new tune - car takes several ignition cycles to start - Why?
  92. Hot start problems hunting at idle
  93. MSD6010/MS1, MS3.57, or MS3x
  94. 4.3 harness conversion to 5.3
  95. VVT with 4l60e without ISS
  96. Noob Tuner
  97. pulsing problems
  98. Picking up an 05 harness and pcm need help
  99. has anybody delt with race proven motorsports
  100. Trip odometer is resetting itself.
  101. ltft max bank 1 koeo
  102. Fuel Tank Pressure Sensor
  103. Holley efi
  104. loading up after 5k
  105. Holley Dominator 1 wideband or 2?
  106. TPS sensor code after new cam and top end install
  107. “Service Active handling” & other DIC Codes after headers/manifold/tune??
  108. Holley dominator efi
  109. Air Lid to 102 Throttle Body Coupler? MAF or SD??
  110. Need harness help, LT1 to LS(LQ4) swap
  111. HHR RWD w/LS1 computer help
  112. repin a 98
  113. Aeroforce Interceptor Gauge Owners
  114. Getting desperate!
  115. need some advice.
  116. HELP! descreened maf was told i need a new one!!?
  117. New to Site and Need Help
  118. Mail Order Tunes
  119. dwell timming issues
  120. Process For Different Computer
  121. Code p1518
  122. 24x Reluctor Wheel 58x PCM Programming Fix?
  123. to MAF or not to MAF?
  124. Logging Injector Data
  125. Convert Drive by Wire to Drive by Cable
  126. Selling My HPT...in Classifieds...has $10,000 in unused credits on it
  127. P0342, P0343, P0430..heeelllpp
  128. Frost dual flash pcm
  129. 98 PCM swap to 99&up Re-pin Questions
  130. P0757 Shift solenoid b stuck on 2002 camaro
  131. 07 avalanche (l92) wiring harness and ecm on an ls2
  132. No 2-3 shift under nitrous
  133. Cost Effective Code reader?
  134. intermitten PE
  135. speed sensor code ?
  136. Troubleshooting p0133
  137. Easy tuning projects?
  138. Need help with 93 octane tune knowledge
  139. The salvage yard ripped me off..
  140. Little tuning help needed fast 102 instal
  141. anyone got a good write up on how to cure idle hang via hp tuners?
  142. So-Cal: LS Engine Dyno Tuning..Where??
  143. Does this sound like a tuning issue?
  144. rear 02 sensor delete help
  145. Any efi live tunners that can tune via e-mail?
  146. Can a 01 ls1 ECU work on 98 ls1 WITHOUT THE HARNESS?
  147. PCM or TPS problems?
  148. Looking forward to getting tune.
  149. o2 sensor
  150. first data logging not sure on what to use?
  151. Merry Christmas everyone!!
  152. NGK AFX, HPTUNERS, WIRES install
  153. Hp Tuner BE vs PE on a 3 bar OS
  154. Need help...
  155. 3 new crank sensors in 3 weeks?
  156. Tune changes with open headers?
  157. 98 formula TSP224/228 surges in park
  158. Emission Question, LT1 to LS1, possible to pass?
  159. Who got a Frost Tune?
  160. Writing problem with 03 Z06 HPT
  161. Its about time!!!!!!!
  162. Bench Top ECU /ECM Programming Cable
  163. Good Tune shop near Stamford, CT
  164. Ordered a PLX AFR gen 2 + DM-6 today, anyone here run one?
  165. Introduction | ShorTuning
  166. dyno and tuning southwest michigan northwest indiana
  167. security light, why is it on?
  168. hp tuner
  169. Engine Code P0008....
  170. E85 tuning
  171. Data log and tune
  172. How to log fuel pressure using U7198 Diablo handheld.
  173. Who would be a good canidate to tune an LT1 after a 24x Conversion by e-mail
  174. What causes tip in knock
  175. Blew stock pistons twice on twin turbo LS2 with low boost-- Please look at my tune!
  176. Stock 98 tune
  177. HELP!! IAT, MAF, Tune??
  178. speed signal
  179. Need some help with my 98
  180. Wiring help
  181. 24x 12v not 58x 5v, cross-bred GTO LS2
  182. tuners in south eastern ohio
  183. louisiana tuner
  184. same vin pcms
  185. MAF spikes to 2500 cfm.... I take it that is not normal?
  186. ls1 no power in gear
  187. Help ABS pin 20
  188. 1998 Trans Am cutting out - Can't figure it out
  189. Which tuner cable Moates or Tunercat?
  190. Who has stock-like, or better than stock, idle manners with big cam and/or big CUBES
  191. LS1 running lean....
  192. Fuel trim question
  193. Cam position sensor low input
  194. Question about PLX wideband
  195. tuners in houston area
  196. tunnig issue speed density
  197. lets talk about idle tuning!
  198. About to get tuned... can you think of anything else for me to do
  199. Another SD question
  200. Does anyone know...
  201. EFI Live and VIN number change question
  202. DBW woes...
  203. p1133 and p1153
  204. idle issue. help!!
  205. Air/Fuel ratios... is this normal?
  206. Diablo handheld question
  207. LS1 barely runs, unusual circumstances. Need serious wisdom here. Where do I start?
  208. map code and throttle fault - advice
  209. HP tuners & VVT help please!!!
  210. 99 ls1 computer w/ 5.3 truck MAF p0102
  211. PCM swap specific questions
  212. Will a bad cam sensor do this?
  213. DIABLO INTUNE users, chime in
  214. Help, 10.0 at WOT with n.o.s
  215. looking for a good tuner western pa!!
  216. Tuner near arkansas
  217. help looking for fast injectors offset timing table
  218. LS1 TPS Problem
  219. P0336 with 383 build
  220. ATTN hptuners experts. Transmission segment swap
  221. Where is the throttle blade adjusting screw on a Fast 92 TB?
  222. 5.3 tps issue
  223. Ls1 stumbles and hard start
  224. PLEASE HELP with P0342 code, Tach drops to zero
  225. Help!! Running Issues "Open Headers"
  226. Help!! Running Issues "Open Headers"
  227. 2002 5.3 wit a 4l60 into a 79 malibu
  228. tune shop
  229. HELP PLEASE!! i need help from a hptuners guru..
  230. Megasquirt or factory PCM and standalone harness?
  231. What codes to delete 4l80e swap
  232. Go SD or stay MAF?
  233. recomend a tuner in dallas area
  234. autometer speedo not working..help please
  235. Rough idle and stalls
  236. 2.5 Bar map with a 98 PCM
  237. Cold start issues = not enough air with Fast 92 TB
  238. MS3 CAM + HP TUNER Help
  239. Runs Like S***
  240. EFI Live injector tuning with turbo question..
  241. Quick prestartup question
  242. Wtf is this??
  243. dyno tune vs mail order
  244. PCM help
  245. Where to mount my LS1 computer in my 69 Camaro?
  246. PCM requests TCS to be Disabled???????
  247. got 2* of knock at the track, need some help
  248. bad miss/stumble
  249. Controlling a fixed displacement AC compressor with a 99-02 f-body PCM questions...
  250. nnbs intake swap on l33
