View Full Version : PCM Diagnostics & Tuning
- Gear Tuning (Outlaw Motorsports)
- EFI Live/ Moates.net Road runner
- Stock T-Stat Fan Settings
- Question about HPP3
- Mounting my new 3 BAR MAP
- Safe tune for a new motor
- hp tuners no open ports
- Trans Table Base Shift and Force Motor
- anyone have a working 228R tune?
- Help with performance chip etc.
- those in SD..if you removed your maf come in.
- Tuning a 2002 Z06 Tomorrow..
- LS2 Edit Lock
- LTFT's way positive
- Tuning out CAGS "skip shift"
- Basically stock LS1 pinging?
- F*ck DTC P0300.
- looking for HPTUNERS BIN FILE for stock 346, 60# injectors, 317 heads, small cam
- Hypertech ??
- HP Tuners updated VCM Suite Feature List
- Rich Exhaust/Gas smell what is the best solution?
- Please Help!!!!
- Just ordered EFILive commercial!
- Question on EFiLive!!!!
- Anybody change the analog output of a LM1 for more resolution?
- Timing Retarded
- ANOTHER overheating issue with the WB????
- Tuning "funny"
- Stock Cats Question
- Need stock bin/tun file for 04 GTO A4
- Using HPTuners or other software w/ DESKTOP PC and LONG cable?
- Rev Limiter Setting
- Need some help....
- Force induction questions
- Camaro speed limiter
- Wideband temporary install for tuning?
- HP Tuners VATS Security Light Question
- Laptop+Scanner+Brains=Tuning (Maybe?)
- What Would Cause......
- SES after headers
- WOT Timing? for Big Cam, Heads, High Compression on pump gas
- lm1 /hptuners
- check out my graph pls
- Tuned my Ve Table
- LS2 and LS7 binaries now available :)
- HP Tuners VCM Suite Help Files Are Now Online!!!
- What kind of power increase?!
- would this 2 step work i head msd has something now!!!
- HP Tuners VCM Suite Demos
- highway vibration
- How much timing on 91 octane 11:1 and stock cats?
- newb here needs help
- Supercharged Guys!!!! In Here!!!!
- Quick autotap question
- big problem
- Back to the Airflow vs rwhp calc discussion
- just bought a laptop. how to connect to car
- How many !Maf/ !O2 sensor cars?
- iam i missing out on a lot?
- P0101 & P0121
- Which 2 tables for FAST 90/90
- Header codes
- now wich is the right 2bar?? part#>.
- i messed up
- cannot figure this out????????
- EFI Live OS question from their tutorial.
- Quick VE table question
- Converter and Gear Tuning Help Needed!!
- idle after cam install
- Trex tune...can i borrow yours?
- How to reset a 95 sonoma SES light?
- Timing, Colder plugs, high compression ect...
- Scan tool shows MAP in KPA, but LS1_edit shows Grams of air per cylinder ??
- Would I be a retard if I upgraded Autotap instead of just buying HPTuners?
- 2bar upgrade help....
- yet ANOTHER O2 problem!!
- diablo predator
- Do I need a tune?
- Maf?
- IAC - hptuners
- need help fast //please//// read//////////
- Electric fan question
- HPT histo MAF Tuning
- How to put stock tune back in PCM - Predator killed it!!
- Air Fuel ratio 14.6-14.7 at WOT is the best?
- Car is retarding timing for no reason!!
- EFILive tuning help
- "Advanced" Predator/A4 tranny tuning
- 02 SS Tuning?
- ms3 bin
- Predator Question
- Saving A Hpt File (quick Help Please)
- Using A Stock Tune File
- Difference in O2's???
- New Ses Code After Cam Install?
- Is it harder to tune with a fast 90m setup rather than a ls6 intake?
- emission TEST - Plug in Connector
- 3 DTCs
- Does this sound right?(Scanmaster numbers)
- PID problems
- Very weird problem with air fuel experts inside please
- Smog/O2 sensor Question.
- Steering bog/tuning problem
- ses light, another 02 problem
- Non-Ls1 97 stratus P0125 (coolant) help?
- Controlling LS2 on Gen 3 PCM?
- Hypertech power programmer
- Stock PCM Retune?
- SES light- low O2 sensor reading.
- ? about tune and battery
- HP Tuners LS7 tuning available...
- Leaving the LTrims Disabled
- tune for the car?
- Tunning with Microsofts UMPC's?
- How Much Fuel!
- 402 w/ stock injectors base HP Tune Please.
- Almost passed smog test, how to reduce HC in tuning?
- tuning for no map sensor?
- Tuning and density altitude question.
- EFI LIVE SD question.
- Piggyback Stock PCM
- EFIlive question
- auto tuning..is it possible?? (not related to trannys)
- can someone please help me with tuning...?
- Wideband o2 placement?
- please i need help car acting up
- Failed emissions but no SES light?
- someone please help? codes and throttle delay problem
- Delete Rear O2
- LS1 edit ?'s
- Closed Loop......Why?
- How do I view freeze frame data in HPT?
- Tuning after install!
- Calibrating MAF with bad VE...possible?
- which is better and gives most power?
- How to Log LTIT and STIT with HPTuners??
- How to disable PE for doing SD tuning
- !!!!!ASAP need to pass emissions/get inspected
- Code Problems!
- P0441 & P0420 Please Help!
- f13 and heads
- LTFT's ...installed dual springs
- O2 Sims Front and rear?
- Vac Mod tranny tuning???
- Crazy tuning question
- How do u copy tables in LS1 edit?
- 2006 tuning
- New motor tuning??
- tune maf or speed density tune????
- tuning question
- Riddle me this...AFR/VE riddle
- VE table ???????
- adjusting speedometer with efi live
- Sweeping gauges on startup trip meter reseting
- i need a little help with My new custom OS
- HPT read any PCM?
- Which tables are referenced during SD mode?
- trouble code P1419? anyone?
- P1336
- cam install, speedo stopped working
- torque management
- Fuel Trims Trouble Shooting
- Ls1 Edit
- camshaft
- Who to go with?
- Po410?
- Casper's Electronics do they offer a discount for Ls1Tech Members
- Switching LT to LS
- Questions about HPTuners before I purchase
- need BONE STOCK 2002 A4 FILE
- TSP or Vinci???
- Trying to fix negative LTrims, but VE table seems to have no effect
- Predator reflash for new vehicle
- Ms3 Owners Step In
- Lost my handheld HPPIII HELP!!!
- HP TUNERS - runtime errors...can't connect
- P0171
- How to lower NO emissions ?
- does hptuners have....
- Engine misfire related to valve noise?
- Torque Management
- knock sensor wire part #
- Why can't I see the PE table IAT vs. enrichment?
- Limp mode maybe? Tuning help?
- P1518 Help!
- Limp mode code
- LS6 Valet key HP drop?
- Air Pump codes for delete
- HELP, code P1419?
- WOT AFR question
- Wanting to learn......
- Learned something today (SD Tuning)
- Using A 02 Tune On A 00 Car
- Codes P1153 and P1133
- Software
- 73 camaro conversion
- Is this a good tuner DiabloSport Predator Tuner
- high idle on 408 stroker
- Got my close 2 stock LS1 tuned!!! (WOW)
- HP/TQ Dyno graph ?
- Has anyone converted to E85?
- pcm ? low trac light
- Help. DTC P0117
- a quick question about custom OS.SD tune
- MAF=Knock No MAF= No Knock...what gives??
- Air/Fuel tune needed?
- hp tuners question
- 420 code after header install
- AC clutch relay?
- are all stock LS1 mass air meters the same
- G5X1 Cam tuning ..... need help!!
- Need help...car running poorly
- Extra HP W/diablo predator programmer?
- Help Car Runnin Rough Ses Codes P0131 P1133 P1134
- Crank Relearn after PCM Changes
- Hitting rev limiter on shifts?
- Swapping from 98 ECM to 01-02 ECM help!
- Fast XFI or BS3 or Accel Gen 7
- Dtc P0134?
- Which side of the exhaust is bank One?
- LS6 MAF table
- BS3 INFO needed (sponsor?)
- Maf not throwing the right code when set to 0
- c5 idle and throwing flames help please
- deleting pcm question
- Timing? Where to set it
- LS7 install problems (computer)
- Need Help!!!!!!!!!!!!!
- anyone with supercharger tune?
- Help I can't pass emissions!!!
- GM 85mm MAF
- tuning on th TREX CAM
- LC-1 question
- Maf
- FAST for LT1???
- 402 knock sensor
- What is the purpose of Full Rewrite?
- Anyone receive their MPVI?
- kr warning light??....
- Help - Need Immediate Help - Vinci Tuner - Help
- Corvette guys with big cams and 90 mm TB's come in!!
- tune vs. programmer
- knock O' meter??
- 58 SDM code
- checking a/f with 02s
- quick question about efilive and VE's
- 0137 Code
- wideband O2 sensor's??
- Would this do any good
- Please help I NEED a stock 2.73 99 vette program
