PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 [198] 199 200 201 202 203
  1. Can someone explain MAP to me please? Other ???'s w/in...
  2. Ltrim table and graphing question
  3. is auto tap the best?
  4. What year TA had a performance shift switch
  5. MAFT???????
  6. BV performance tuning@ Speed INC?
  7. What do all the variables mean?
  8. quick answer and insight appreciated.
  9. Possible with LS1 edit?
  10. Regarding LS1edit & ATAP
  11. What is autotap, LS1 edit???
  12. AutoTap: What to check?
  13. slp air temp module
  14. AutoTap Logging
  15. MAF-T "mode" switch questions
  16. LS1 edit
  17. stupid question from a stupid person
  18. Anyone use the Auto-Xray?
  19. dyno tuningw/MAFT on a humid day.
  20. need ls1 edit file
  21. cam installed need some help
  22. Lean, mean, and damaged?
  23. Coil Pack Wiring Diagram?!?!
  24. If I bought MTI S2 H/C and have LS1edit...
  25. need ls1file from a similar modded A4 car
  26. Any info about the DiabloSport Predator tuner?
  27. Bad O2?
  28. HPP3 is in!!
  29. More Tuning Questions!!
  30. Hypertech for 2002
  31. Need Help asap.
  32. LTerms / STerms
  33. C5 with HUD?
  34. Can the LS1 edit do this?
  35. LS1 Edit and Auto Tap serial/USB port questions
  36. What the heck is TTT
  37. ls1 edit purchase ? .. Group buy
  38. anyone got the afr on a 98 model under control?
  39. Problem installing Atap
  40. P0300 and LS1 Edit
  41. Help with ATAP readings please.
  42. Tuning MAFT
  43. strange 02 SS M6 problem
  44. Another Torque Management Question
  45. Knock sensor codes Po327 and Po332 ?
  46. What should your timing be at WOT???
  47. 99 MAF vs. 85mm MAF
  48. Does anyone have a link where I can download Microsoft Excel?
  49. New Dyno Numbers
  50. Best Scanner?
  51. Service Vehicle: No state of health of PCM?
  52. KR only in 1st gear? Change timing below 50mph?
  53. Tuning after LT headers & ORY w/O2 sims......
  54. Q about used HPP3's
  55. is edit supposed to have a LS1_ED2 zip file?
  56. gettin these tranny codes.
  57. P0801??!!?
  58. Need some advice guys.....
  59. LS1 Edit help needed!Please!
  60. Edit experts or puter geeks out there.. need info on error code
  61. LS1 EDIT USER GUIDE DOWNLOAD
  62. Any publications on the current Gen-IV / LS1-based PCM?
  63. MAFT+ worth the $$ over MAFT?
  64. New to LS1 Tech!
  65. What is MAFT???
  66. HPP3 >>> M6, anyone?
  67. how much timing is torque managment pulling
  68. Low octane timing flag
  69. Head lamp motor
  70. LTFT imbalance while in FTC 22 causing a bad lean condition. Help!
  71. 98 computer fit in a 99 car?
  72. LS1 Edit: Warranties, PCMs, and Safety... Oh my!
  73. Will ported maf ends lean A/F WOT on 01 Z?
  74. can someone send me a LS197-8 file from edit zipped
  75. Will ported maf make WOT leaner on 01 Z?
  76. AutoTap: DOS or WIN-XP
  77. Will scanmaster pick up the Torque Man. spark retard?
  78. Need Help bad...SES Light is on...know codes....how do I fix it?
  79. just installed headers got service engine light????
  80. What is LS1 Edit ??
  81. Anyone see this new Predator tuning device from Diablo Sport??
  82. LS1 Timing controller in final testing now!
  83. Will HPP3 detonate with NOS??
  84. Harlan where are you. I need a shift light
  85. I can't be the only one in the world with this code!
  86. Going to be doing some LS1 Edit tuning soon...question...
  87. Starting problems!
  88. How do you adjust PE vs RPM table?
  89. Data Link connector
  90. Battery relocation
  91. Torque Management and MAFT readings
  92. MAFT and ls1edit
  93. Will LS1edit work without ATAP
  94. Going for emmssion testing, how should I set the MAFT?
  95. Nosedive on shift fixed; peeved w/Autotap
  96. Proper way to Dyno Tune a D1-SC w/LS1Edit ??
  97. what should timing be at?!?
  98. HELP! is this code normal or happen frequently!??
  99. HOW 2 remove PCM to ship 4 tuning???
  100. Put SLP LT's on, now getting codes
  101. P0704 CODE ANYONE EVER HAVE IT
  102. LS1edit or Autotap?????
  103. LTrim Question
  104. Paging ValvegoD!
  105. Dyno with Wide Band and A-tap results
  106. Tuning question........
  107. MAF vs. Frequency Calibration table
  108. WTF?....Troubleshooting Help wanted....
  109. Temp gauge?
  110. Whats Wrong With My Timing
  111. Dallas,TX area?
  112. Custom Programming & Resetting PCM ?
  113. HPP3 tells me to replace 9V battery???
  114. EASE Question
  115. WOT timing is real low...
  116. Ported MAF ends
  117. LS1 Edit
  118. Hypertech???????
  119. Where can I buy HPP3?
  120. Any One Heard from Harlan
  121. Scan Tool info? Autotap? LS1Edit?
  122. LS1Edit connector
  123. how much to adjust PE vs RPM table
  124. Looking for a LS1 edit file...
  125. LS1Edit questions
  126. HELP W/ HPP III INSTALL
  127. LS1 Edit Files
  128. Everything you always wanted to know about how your A/F works!
  129. can backed up exhaust make KR worse?
  130. Lost fuel pressure..What to look for??
  131. help, how do i use ls1edit to richen my mix at wot just in 3rdgear?
  132. Help me out with dyno, A/F, and ATAP data.
  133. Where can I get LS1 edit?
  134. How to calculate A/F ratio with AutoTap?
  135. ses codes P0134, 0135
  136. Who is best at tuning PCM with Ls1edit
  137. Max MAF adjust % with edit?
  138. IAC counts..
  139. Do O2's effect performance?
  140. MAFT Base at 15% rich and WOT at 6% rich. O2's WOT ~.935, LTerms +4.7% and +2.3%
  141. ATAP / MAFT ????s
  142. Closest place to get my PCM tuned???
  143. Security Light..
  144. Security Light..
  145. will ls1-edit know i have a return fuel line
  146. anyone tried bosch 02's?
  147. O2s are killing me
  148. Computer ,Cam switch Question
  149. 85mm MAF help
  150. ***Need AutoTap & Laptap***
  151. Weird problems!!
  152. P0704
  153. Ease Diagnostics
  154. Whats the best way to change a/f?
  155. Will the LS1edit cable work on 98-02 cars?
  156. Is it possible to ruin your OBDII with a MAF
  157. Diagnostic's
  158. eliminated my KR and lowered injector pulse width just by changing gas brands...
  159. SVO 30# injectors
  160. will this happen when timing is low?!?
  161. hpp3
  162. Will techII change my a/f ratio?
  163. gutted cats,installed02sims...now REAL rich...help?
  164. MSD Stacker8 Igniton...
  165. HOW TO TURN OFF OIL LIGHT???
  166. People with MTI tuning : Does your 2-3 shift 'slip'?
  167. Please help - Autotap newbie - several 02 codes
  168. Is my set-up too lean?
  169. Getting started ?`s (comp. tuning)
  170. Low RPM miss...black smoke(please help)?
  171. keep blowing engine sen. fuse under hood car stops running
  172. Geoff and Paul from Thunder Racing...
  173. Tuned a Forced Induction car today (500rwhp)
  174. help, i am geting slower
  175. lockin a4 in 3rd?
  176. S.E.S light after o2 sims
  177. Desperate: getting codes know what they are but not how to fix
  178. Autotap issues
  179. upgrade to LS1 Edit 1.05 issue
  180. tuning help, is this how i should start?
  181. 11.91 0n custom tune?
  182. Occasional PO300 code pisses me off.
  183. How to set your WOT timing from the drivers seat.
  184. SE Florida LS1Edit?
  185. do i have to reset my PSM after replaceing o2 sims?
  186. Ls1 Edit and Hpp3 HELP!!!!
  187. What is the best diagnostic tool?
  188. Setting the idle speed with LS1Edit
  189. C5 IAC count vs Fbody IAC count
  190. Hpp3 for sale in Louisiana
  191. PLEASE HELP!!!!!! need help asap
  192. HELP!!! Security light issues....
  193. Miss at 1500
  194. ls1 edit question!
  195. New member question about autotap
  196. How do I retrieve SES codes with Autotap?
  197. Anyone using POWERLOADER that TTS sells?
  198. How to adjust W.O.T. timing with edit?
  199. Please verify programming checklist for h/c pkg.
  200. Really low idle???
  201. PCM software and cals for a 99 F-car?
  202. car wouldnt start....security light stayed on?!?!
  203. How to adjust w.o.t. timing with edit?
  204. Status of TTS DataMaster for OBD-II?
  205. Does anyone know what the differences are between the older MAFTS and the newer ones
  206. Idle problem....Can someone please help?
  207. how to figure injector constant?
  208. More MAFT tuning ??? (5.slowklr)
  209. Autotap shows fuel cell 18 being used for idle??
  210. i need your help
  211. reset or disconnect odometer?
  212. Where to set Rev Limiter and Shift Light?????
  213. pcm compatibility?
  214. New mods should i get the PCM tuned??
  215. misfires!!! any help?
  216. SES CODES?? please help??
  217. KR getting worse, someone please analyze this
  218. Autotap version question
  219. LS1Edit,......this may be an awesome new feature!!!!!!!!
  220. ls1edit
  221. 2-4-6-8 MISFIRE...please help
  222. Detonation and adjusting MAFT for higher summer temperatures
  223. "Service Vehicle" light?
  224. Holley Commander 950
  225. EGR & AIR removal..
  226. somebody please explain this code . . . p0442
  227. LS1 edit and new computer
  228. LS1 EDIT Version 1.05????
  229. Injector sizes....
  230. Threw a couple codes about Switching Bank 1 Sensor 1 and Heater Sensor or circuit??
  231. any minnesota guys with autotap?
  232. ls1 edit
  233. what to change for cam swap??
  234. MAFT????
  235. MAFT tuning????
  236. East Coast Tuner
  237. OBD2 Scanner Help....
  238. TACH WIRE ON 98 C5
  239. my 50# injector tuning woes
  240. question about .ls1 files..............
  241. HP Formula Needed
  242. How do you get the averages in Autotap using MS Excel?
  243. Tuning Help
  244. Anyone ever adjust a/f with an Apex Super AFC?
  245. LS1-edit, on a 99% stock LS1 benefits...
  246. Detonation, air/fuel, and MAF Translator ???
  247. What's the average rwhp increase from computer tuning on a heads/cam car
  248. How much power and I losing with a lower timing?
  249. .ls1 file settings for a 212/218 cam
  250. Need .ls1 file for TR224 cam
