PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Hptuner or tech 2
  2. DBW throttle pedal values
  3. Is it okay to "duplicate" the OBD2 Port?
  4. 04 GTO need idle help i'm ready to burn it idle problems
  5. LS2 Idle Issue
  6. Tunerpro guys come in lt1
  7. Ls1 MIL p0650 code
  8. mass air flow
  9. owners of a LSA + LS9 cam and a 2.55 upper pulley, seeking help
  10. 5.3 to 6.0 swap -- can I replace my 2005 ECM with a 2004 ECM?
  11. Who is the best efi live ls1 tuner?
  12. How to "Split" a 5v Signal
  13. Tuning and Shop Appointments
  14. e38/gen 4 gurus school me up
  15. wierd stumble at 1500rpm
  16. Car stalls while driving, then starts hard
  17. Can't get tune right
  18. LS3 tripping idle control system rpm
  19. Micrsquirto firing issue
  20. Tech2Win question....I/M readiness
  21. comp 54-428-11
  22. Wideband install
  23. 0280158187 injector on ls2?
  24. 112 octane tuning question.
  25. 0411 swap, no pcm power
  26. engine dies when fuel pump is on
  27. Okay to drive?
  28. Bad misfire under load
  29. PCM With DBC, Flex and 2 bar Real Time Tuning
  30. Which part to test on TAC Harness Plug
  31. 2002 trans am v8 5.7 ram air not wanting to start
  32. 6.0 Timing
  33. MAF Reading at Idle
  34. Easy/updated way to add wideband to hptuner standard?
  35. G/CYL question
  36. Advanced Auto, says GMC is throwing P0135 PO155 & P0300 codes.
  37. Misfire
  38. Reduced Engine Power Issue
  39. tuning software
  40. 343 code please help
  41. 4l80e always reads -38
  42. Dead Miss?
  43. Tech2 Diagnostics Question
  44. need help trouble shooting an issue
  45. Segment swap issues.
  46. First run on stand, idle erratic and LT B2 not close to LT B1...scan attached
  47. General Newbe Question about Tuning
  48. Can anyone please advise? hptuners forum = little help
  49. Logging Problems With HP Tuners
  50. Gear Change In EFI LIve
  51. m6 to A4 seg swap idle issues
  52. HP Tuner buy or use the tuner's equipment
  53. Deka 80 EFI tune question
  54. Start up tune advice
  55. LS2 swap starts & dies with VATS removed
  56. Turbo 5.3 Swap into 1995 Trans Am
  57. 05 GTO after os change
  58. In need of two bin files...
  59. Handheld Turner for my situation?
  60. Checking EFILive cable for unused licenses??
  61. Idle/stalling issues
  62. Sensors needed to make ls1 run
  63. Help Needed TPS Sensor
  64. what 33 lb/hr injectors for 2004 lm7
  65. In need of some direction
  66. Houston, TX LS1 Tuner
  67. another IAT sensor question - works after 15-18 mins
  68. Tuning limitations 24x vs 58x reluctor wheel
  69. 20% TPS at idle?
  70. Best lsx tuner in NC
  71. erratic idle
  72. Closed loop trims go -35 help
  73. Tuning out LTFT for more consistency
  74. HP tuners MPVI2 problems
  75. E40 Scanning and Tuning
  76. 228R 5.3 2.5 heads timing at wot?
  77. Tuning an LS1 with unknown camshaft
  78. DST LT1 files
  79. Newbie
  80. TH400 with original VSS how to program in HPTuners
  81. Torque pro app p59 ethanol content
  82. Maf problems
  83. Cam Tune
  84. Injector rating for boost referenced FPR
  85. Fuel pump issue
  86. I need more than 4063lb/hr in MAF table in HPTuners, help save my track day!!
  87. 2 Derale Pusher fans causing bank 1 to go lean?
  88. no flex fuel spark advance adder on 3 bar p59
  89. Tuning with a turbo - Log included
  90. Will 1999 LS1 Tune work on 2002 LS1?
  91. Just got it back from the tuner.......
  92. Simulate knock?
  93. Bad map sensor readings
  94. How to tell if left and right O2 sensors are wired backwards?
  95. P0343 code
  96. 2004 Stock LS1 P0171 code help
  97. Boosted L33 stutter at WOT
  98. EFILive Flash Scan V2 Black Box Help
  99. C220 harness pin G brown fused output ignition
  100. RussK log lower than expected?
  101. No Codes when powered up off board
  102. 94 z28 flashing problems
  103. Need someone to look over my log (HPT)
  104. HELP!!! Holley EFI wiring solution.
  105. DFW tuner for upp twin turbo vette
  106. ms3pro no start.
  107. Tuning Issues
  108. Will a tune fix this problem??
  109. Good and Bad: Car got totaled right after i had it running perfect
  110. 2008 corvette c06 ecm immobilizer delete
  111. RTMR & RFRM fusebox difference
  112. L20/6L80 swap -e38/t43- idle surge in gear SOLVED
  113. 2004 gto running rough after hot start then clearing up
  114. CEL woes on LS swap
  115. Is every tuner different??
  116. 02 camaro Ss 370 troubleshooting
  117. E67 VSS settings - HP Tuners - Heeellllppp !!!
  118. Fuel Gauge Level Sensor Issue
  119. LS1 stalling and idle issues
  120. LS1 Maf on a dorman LS2 intake
  121. Looking for a shop to tune my 4l65e
  122. Need a 2004 GTO BIN FIle
  123. Hptuner failure & IAC
  124. E85 and Flex Fuel for street strip
  125. What to watch for to keep it from gernading
  126. Upload hptuner files here
  127. Ls 3 - 480
  128. Both O2 Sensors acting weird
  129. Rich on e85 stoich
  130. 6.0l no spark
  131. Front O2 and MAF Delete?
  132. ecu tuning in ne ohio canton akron to look over tune
  133. anyone running ac with an ms3 camaro?
  134. ECU options for LT1-> LS Swap
  135. O2 Issues
  136. Iac steps vs effective area table
  137. Which ECU to go with??? S10 (Sonoma) 6.0/4L80E swap
  138. Looking for a cable to data log aem 30-0300 with flashscan v2
  139. Need service manual help!!!
  140. L99 into a LS3 2014 Camaro No Start
  141. Weird problem with my LS2 swapped Camaro.
  142. inches of vacuum ls7
  143. Monitors
  144. L99 swap - no cranking at all
  145. Boost control trough egr circuit
  146. ls1 rpm gauge
  147. Traction control problems
  148. Fresh LS Volvo
  149. Wanted hp tuner mpvi1!!
  150. TQ Lock Up / Diff Noise / Lugging question
  151. Popping and backfire on decell and Intial Startup
  152. Installing a standalone ECU in a 2000 GMC Sierra 4x4, need help!
  153. 2000 GMC Sierra PCM piggyback help
  154. HP Tuners Application Key - Am I Screwed??
  155. wanted hp tuners mpvi1
  156. Whats the secret to unlocking 2017+ gm tcm 8/10 speed?
  157. Holley Dominator. No rpm signal and no fire
  158. camaro a/c pressure sensor to switch swap?
  159. AWD Dyno and tuner in SF Bay Area
  160. How to get throttle open sooner at launch
  161. Heated mirrors drain battery.
  162. Engine stalls when coasting to stop
  163. Which ECM, and why?
  164. New Day, new issue E39a pcm not charging
  165. No tune, will it run?
  166. Ecu 411 with gm e85 flex fuel sensor
  167. Stock cam/head LS1 with supercharger...base airflow tuning
  168. Microsquirt no rpm sync
  169. Temporary tune?
  170. I need some help tuning for bigger injectors
  171. Injector data
  172. HPtuners (standard) , LC-2WB question
  173. red/blue ecm and Tmap
  174. Does anyone else have crazy AFRs after flashing new tune to PCM?
  175. 1999 GMC Yukon ECU reset
  176. Dyno recomendation local to me
  177. Heavy throttle from a stop - Timing goes to ZERO (or negative!) - what's going on?
  178. tuning a tuned port injection ?????????????????
  179. New LS3 6L80 install
  180. MAF erratic
  181. Incomplete O2 sensor monitor and heater
  182. Any wendor/dealer that can help with tis2web?
  183. need Help! i am trying to figure out fueling
  184. boost enrichment?
  185. Main Ve question
  186. Drivers side missfire after ignition hot wire short, fried ecu?
  187. Help with loading new tunes through EFI!
  188. Tune is done dyno results on the LS3 stroker
  189. T56 tuning
  190. O2 Sensor Heater always on with ignition ??
  191. Lm7 swap no start
  192. Will NTK wideband be damaged it it doesn't heat up?
  193. Troubleshooting lean spikes on large throttle transitions
  194. Normal idle cold start, high idle warm/hot refire
  195. Knock sensor help
  196. LS 376/380 Tuning
  197. Tuning after stroker/bigger cam install??
  198. Share a tune?
  199. 36lb Bosch 165-FIC36LS1B Short Pulse/offset?
  200. CONFUSED Hp tuners MPVI2
  201. 3bar SD setup, no start, what am I missing?
  202. School Me on Throttle Cracker/Follower
  203. 2003 OUTLANDER Scan tool live data OL-Drive Question
  204. can’t write to ECM
  205. How to DATALOG LNC-2000 ignition retard on HPTuners
  206. Trying to make sense of Power Enrichment
  207. HPT OS Question
  208. Tuning issue on new ls3 stroker
  209. 2007 Escalade chassis - ABS/TC/BCM?
  210. 0411 PCM , Tahoe pump and Dakota Digital gauge?
  211. Fast Idle
  212. Lm7 no spark
  213. Engine stand startup - fire but no idle
  214. Howling thru the airfilter...
  215. swapping BCM with HP tuner
  216. dod delete
  217. Vcm scanner mounting
  218. Help chasing codes P0507 P0172 P0175
  219. Tuner Recommendation South Louisiana
  220. RussK idle config, how many times till it works?
  221. Help P0158 and C0896
  222. Need Help with tac module please.
  223. Odd idle hang
  224. hp tuner
  225. conflicting engine temps front driver and rear pass head ports
  226. 3 bar SD TURBO tune, back to 1 bar N/A tune questions
  227. Looking for dyno tuner in NJ, DE, Eastern PA
  228. 98 Camaro Mail Order Tuning Question
  229. standard tranny is in the 2011 2500 series truck. now for tuning?
  230. E85 and boost referenced regulator
  231. Cam idle tuning
  232. melted coil low reference wire
  233. Struggles to start when warm
  234. 99 z28 tune file HPT
  235. Best tuning school, course or individual who teaches tuning for GM HPtuners?
  236. Tuning a 418 in a 1998 firebird
  237. Random ruff idle when slowing down only !
  238. Help CL after OL tune. Same VE but WB fueling help
  239. Why NB/WB flip readings at CL/OL operation?
  240. Adjust o2 flow rate with full exhaust install?
  241. P0342 and P0343 Camshaft Position Sensor 24x Swap
  242. My stock lt1 live run file
  243. What are these modules?
  244. New LQ9 Build stumble at half throttle
  245. 4L80E Swap trying to rule out tune
  246. TPS reads 100% at all times
  247. 8.1L vortec - Low vacuum at idle after rebuild - Need expert help for this puzzle
  248. 67 Stand Alone - No Communication
  249. Fuel pump Relay issue
  250. Codes After Head and Intake Swap
