- Does anyone use Tuner Cat?
- Torque Converter Tuning
- PO102 Diagnostic code, p/s help!
- HPT and LC1 problem.....
- Help Low timing?
- crane cams tuner help
- having a problem logging maf hz and dyn air in hptuners
- P0753
- Programers!!!!
- how do i pull timing with ls1 edit?
- Question on Error Messages
- dynojet wideband commander owners
- how good are mail order tunes?
- Sweeping guages now GM standard in 2006
- Tuner Options for 96 a LT1
- funky elelec problem (gauges jumping all over, blowing gauge fuse)
- need a bin file for a 2000 supercharged f-body
- Tuning
- Please Help. Mysterious problem!!
- timing question.... 2002 Vs 99
- PAGING REDHARDSUPRA or HORIST
- offset table for 42# FMS injectors
- WOT Advance - HP Tuners
- Can a 98 be tuned?
- Need help with a sudden problem...
- How do I pull timing on the spray with ls1edit
- What is a good tuner thats easy to learn to use?
- HPT Question about Dynamic Airflow
- Edit install on a Toshiba Satellite laptop.....
- Case re-learn with LS1Edit?
- Darn brake lights not working on 94 TA
- Stalling/surging when coming to a stop/reverse
- P0200, P0300, & P0301 Problem solved!!! (Very Long)
- New EFI Live Version Released Part#2......
- Torque Management
- Tuning fuel trims using narrowband
- 0300 code - metal plug shields - arking?
- LC-1 for HPTuner
- 4Channel to 3Channel setup?
- ? bout buying tuners
- Excel worksheet
- look at my ve table i think its jacked up
- grams per cyl, and dynamic cyl air
- Need answers tuning for stall with hp tuners
- wideband question
- Tech2 Data Log Questions.
- HP Tuner guys, any way you can do this?
- stock o2 data for LC-1 narrowband sim?
- EFI Live Flashscan File for a Futral F11 Cam
- at 0 throttle the o2s go lean and trims go WAY +
- Ideal AFRs
- Gen VII..... man I must be dumb
- Iac, Experienced Tuners Please
- Need Scanner Logfile
- What 2 fuses is it you pull the reset the computer?
- PCM diagnostics?
- New Version of EFILive released
- Have a short...
- 94 Z28 scan tool
- Crane Powermax Tuner track results
- help me
- I may be stupid for asking, but...
- Quick question, please help
- Need Help: Hard To Start After Engine Is Warm
- Please help with vig 3600 B4 I go back 2 stock!
- Pinging stock, pinging partly tuned! help me kick this pings ass!!
- Throwing a few Codes
- Operating system 12225074 needed
- Question Or Thought about smoothing VE Table??
- shift firmness
- Tuning for a 200 shot??
- mail order tunes
- Need Quick Advice!
- HELP with 98....
- how low is your adaptive idle response time?
- WTF is this....P0106 Map/Baro Ckt Range/Perf ???
- problem connecting up to XD-1 from my laptop
- turbo tuning
- Another basic question
- P1133???????
- what airflows for fans 1 and 2
- rpms come down too slow, rev isnt as fast as i like
- dfi or fast
- Chip or no Chip?
- hp tuners help
- Calling ALL Tuners
- misfire help please!!
- with no throttle, STFT's shoot up to +30 or higher
- tps showing 1% WTF?
- P0172 & P0175 Codes, VE tuned in, Maf Recalibrated?
- Autometer Pro Comp Tach Install
- Does a tune with A4 line pressure @100% make a difference at WOT?
- Help!!! Cold start with A/C on sucks!
- tuning from MORE PERFORMANCE
- front o2 sensors
- Please read, info needed asap PLEASE.
- Timing rising after 6600 rpm?
- Need help with Hypertech power programmer
- Those racing chips you see on ebay
- Electrical Issue.
- Running SD with an automatic all the time...
- Blower tune vs. N/A tune, what chagnes?
- Starting Problem...No power to the Fuel Pumps...intermittently
- Help with tuning a 408-where do I start?
- New Tuner Questions
- Anyone Know Where To Rent A Hypertech Power Programmer
- How To FI Tuning?
- air system questions
- Diablosport Download tunes
- HPPIII won't turn on...suggestions?
- Detonation with excessive KR
- PCM code....Not Ls1 but GM
- Which tune ?
- Connecting wideband to PCM
- Controlling LTFTs
- Wire harness question.
- Post your tips on eliminating bucking here!
- question about 150 IAT reading causing retard?
- Any Good Shops Want My Business?
- p0307 cylinder 7 misfire
- Delta Chip alternative
- Need help!! Throwing codes
- Growing Pains
- Low Voltage Bank 1 Sensor 1
- Cheapest way to get started?
- wot fueling question
- Interesting - Speedo calibration
- Code Delete Charity
- How do I retard timing with the Diablo Predator?
- bolt-ons and turns out I'm gettin KR 5degrees worth
- Adjusting timing after ve table
- ATTN: WS6FirebirdTA00
- o2's read slow sometimes others they are fine
- HPT bin from supercharger setup?
- wb readings during decel
- L Trims
- mail order tune....
- Deleting AIR, revisited....
- Vinci Hand held tuner Error !
- having some odd throttle issues after latest tune, and dont know why
- HPTuners or LS1.edit-which one?
- What is everyone getting for ac airflow adder?
- hesitation
- Car sounds terrible!!
- Reset codes?
- HP TUNERS help on fuel tabs...
- Wheel Sensors - PSI
- HELP -- PO131, PO137, PO151, PO157 codes - new sensors???
- All Tuners please read.
- question about tuning shift points, never done it before...
- any ideas on po172+175
- Whats the stock timing on a 98 Z28 A4?
- Tuning out lope with BigStuff3
- Problem programming LC-1
- Cheapest decent wideband o2 setup?
- 6.0L ECM and harness
- Few problems with tsp tune.
- messing with overspeed and underspeed spark correction
- EFI Tuning options
- looking for some help, getting constant 4* KR, at 19* WOT
- Looking for stock tune
- All this idle stuff is getting me ...........
- How the MAF really works
- this is odd, tcs off light came on when i reved up???
- Really Wierd Ft Problem
- Switched from M6 to A4, how do I fix the speedo?
- any tuners in the IA,NE,SD corner
- HP Tuners with bad 02's...bad???
- my impala and tahoe
- Idle 800 below 10 mph, idle 1000 above 15 mph WTF?
- where to buy ls1 edit?
- Low Voltage SES codes
- Help Me Please
- Codes
- what does adaptive idle control?
- is there any way to adjust the speed the car corrects fueling when at idle?
- VE Spreadsheet
- Mulitple Codes
- when to change 02 sensors?
- 1998 tunning?
- Pontiac Firebird 1991
- SD tuning and automatic, issues idling
- 1st tuning experience
- Timing & all idle tables w/ bigger cam
- HPT and LC-1 not working right...HELP
- throwing some codes
- HP Tuners Wide Band Question
- Yeah!!! i just ordered my hptuners
- problems with pe need help
- efi live tuning....at efilive.com/forums
- I'm really confused....
- Wanting to learn how to tune...
- Corvette:GM DESIAC gms/s - Is this in HP Tuners???
- IFR for 42# injectors??
- view past codes?
- HPT question about Desired IAC steps vs. Desired idle effective Area
- Reset to Stock-LTFT????
- Help...how to capture a dying car..
- Symptoms of an erratic Crank Position Sensor?
- Professional tune!?!
- STIT, LTIT arent consistent in 180* coolant temps?
- TPS problem
- H/C Swap completed, Quick Idle tuning question.
- Techedge WB with Hptuners
- h/c car hunts for idle EVERY time it is started up?
- maf tuning method and strange trims
- Help me get rid of these pestering gremlins!
- A/C and idle. wont stay started. Wont to change in HPT?
- Weird Idle Issue after WOT?
- Please help me diagnose this problem
- i want absolute timing control but can't get it.
- Do i need a tune
- getting some random knock?
- can someone help me with a code
- Wideband in stock O2 bung for SD Tuning???
- 99z jus dyno'd
- Help with codes
- HP Tuners Problem
- what are the conditions for closed loop?
- Another VATS question,,, did the search..
- help on resetting computer :(
- Ordering Megasquirt for my 98, what all do I need to order?
- tc shutter while driving in gear locked
- SES Light
- Tune Parameter HELP!!
- auto criuse controll
- Best Tuning Route to take?
- Problems with STFT tuning???
- ?? Lean, to Rich ?? someone explain
- help 97 z28 no start no com. with pcm
- SES light just came on, and I dont like it.
- Secondary AIR relay location?
- Tranny Swap A4-M6
- VE Tuning (octane tables)
- EGT data in graph form inside...may be useful
- Getting frustrated with negative trims
- traction control took a vacation
- Built motor, raised compression, nitrous and 93...
- 3 Altenators dead in 3 weeks! help please!
- if i lower pe, how should i increase the ve in those areas?
- prop fuel, my results did not show HP Tuners explaination...
- Initial tune for homebuilt turbo system
- Ok need a tune but how?
- steps i took in getting idle, come in and add to it/correct me haha
- TCC - tuning question
- ODBII Pass or Fail???
- Anyone on here have experince with tunning STS kit
- light throttle load surging... P0101 ? MAF table ?
- Who can edit 01 V6?
