PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. what would be the best way to tune turbo ls1
  2. Mike from diablosport PLEASE HELP.
  3. HPtuners and transmission tables
  4. Worst... Tune... Ever...
  5. Anything esle for a basic tune?
  6. Do you use a PLX Wideband?
  7. Plx question
  8. Cant you use HPtuners editor on multiple computers??
  9. sniper tuning
  10. afr, tune problem
  11. FASTCHIP TUNE GOOD? Ed Wright Performance good?
  12. Need to get a wideband I want to go with innovate but.......
  13. TR6 plugs turbo'd what gap ????
  14. HPTuners Rep
  15. Oxygen sensor questions
  16. P0137
  17. Random misfire at WOT...
  18. Problem with my HPtuners, can somebody help me out?
  19. odd tuning problem
  20. EFI Live tune for trans?
  21. Dyno Tuning Near Nw Arkansas?????
  22. popped 33 codes YEP you heard right 33 codes but curious.....
  23. Does a cutout effect tune?
  24. Coil#4,6,7 NO FIRE! Crank Sensor? Reluctor Wheel? Tech Guru's Inside!!!
  25. Anyone know where I can kind stock LS1edit files? (did a search)
  26. dispalcement on demand for 2001 vette
  27. Knock Sensor Deletion!?!
  28. anybody using megasquirt on a 5.3
  29. ses light after 18" wheel install?
  30. Loosing power upon launch
  31. Oxygen Sensor Burned wire
  32. 56 RWHP Gain On Induction Changes
  33. When will thse codes clear?
  34. Car Hitting Rev Early
  35. HP tuners question
  36. About to FIRE new motor - Fuel Injector Question
  37. 2 Coils = No Fire.. WHY???
  38. Getting a mail order tune. Tell me what you think.
  39. need help with wiring quick!
  40. Spark Arching Issues
  41. Electrical issues
  42. No green wire in LC-1
  43. Does this make sense?
  44. LS7 throwing codes ??
  45. Any LS7 tuners around today?
  46. Shop tuning tools
  47. lt-1 Edit trans programming
  48. What is the best MAF sensor?
  49. Will this MAF sensor work in my camaro?
  50. New cam tune, have a couple ?'s for answering
  51. Why Does my Car Surge like a MF when going into reverse?
  52. HP tuners help w/ my car!
  53. Progressivly getting leaner???
  54. HELP!!! Code P1154
  55. Idle Trims
  56. trans wont shift on 1st-2nd under wot
  57. Tuning Question
  58. car feels "sluggish" every now and then
  59. Want to buy HPTuners for LS3 C6 today!
  60. sd tuning efi-live corvette car wont idle
  61. 02 simulator quest
  62. Possible ECU problem.
  63. Lack of WOT power
  64. Hypertech Power Programmer ? Any good?
  65. Speedo Messed Up! Help!
  66. any adverse affects of raising the timing?
  67. EFI Live guru's Please Advise
  68. A/F gauge placement
  69. please help me with table D0801 and D0301 torque reduction
  70. Question about torque management
  71. Need Some Help
  72. I Cant Get My Car Tuned!!!!
  73. hptuner tuning ve via wideband question
  74. Car Hits The Rev Limiter at 5K and is set at 7K?
  75. 2000 5.3 liter truck...new engine, flash pcm with a 2002?
  76. What should I log at track ?
  77. o2 sensor question
  78. Passenger side bank of motor not firing
  79. GM HighTech Review???
  80. Can a WB 02 be used as a narrow band?
  81. Halltech Venom install - now SUPER lean - HELP!
  82. Need Mail order tune??
  83. MS4 idle tuning
  84. eng sens fuse keeps popping
  85. Dual tuning a possibility
  86. tuning calibration ?
  87. Software options for changing my tunes
  88. Diablo Tune
  89. EFILive Locking up Laptop!!
  90. MAF help please !!!
  91. 85mm Maf Calibration Values
  92. Tuning questions? tuning options?
  93. EFILive and RoadRunner Best Price?
  94. Price of computer???
  95. Do I NEED A TUNE
  96. knock sensor too sensitive?
  97. Tuners for cheap
  98. Can only get 95% TPS. WHY?
  99. Can i extend the wires for my wideband sensor?
  100. Code 0327:knock Sensor/low Circuit Voltage???
  101. New LC-1/EFI Live Issue
  102. ckp relearn question?
  103. Best place to locate port for WB dyno tuning?
  104. Expert tuning help please!!!!!!!
  105. Gas Mileage.
  106. How do you remove the BCM?
  107. Help So Confused!!!
  108. tuning in olsd
  109. how to wire after market tach.
  110. ? about this harness
  111. Accel Gen 7 guys help!!!
  112. How low can the idle be set?
  113. Wideband o2 replacement??
  114. lt1 Tune
  115. DO I STILL NEED o2 SIMS USING DIABLO AND ORY?
  116. ve tuning question
  117. plx wideband to hptuner
  118. Unusual idle occurance with new injectors
  119. 98 computer, how can i get over 8,000 rpm????
  120. Po751
  121. ia a 99-02 PCm better than a 98 and is so why
  122. Diablo website download help please!!!!!
  123. P0102 Code I Checked The Fuse Already
  124. EFI LIVE/LC-1 Tuning problems, Please help, tuning experts
  125. mass air/air temp adapter
  126. Newb tuner question
  127. maf problem during tune at high RPM
  128. ta may not be running right
  129. P0343 w/ dual roller install
  130. New trans...need tune?
  131. EFI Live users: little comparison info needed
  132. Transmission problem due to tuning?
  133. Same year To same Year PCM swap.
  134. how many people run with there knock sensor zero'ed out?
  135. solid mounts causing me to pull timing?
  136. HP Tuner & EFI Live users come in...
  137. 416 L92 in LS1 Camaro, Runs Rough, No Power
  138. need o2 sensor help
  139. 02 simms inc? or no?
  140. PO171 and PO174
  141. DBW and tps
  142. Confirming questions about BCM replacement
  143. Which tuner would you suggest?
  144. Lightweight Battery?
  145. Help please , stock 2002 Z28 , Pinging badly !
  146. How does HP Tuners Respond to Windows Vista?
  147. LC-1 wideband question?
  148. PO113 (IAT Circuit High) PLEASE HELP
  149. Knock at idle?
  150. Redhardsupra's ve spreadsheet
  151. DiabloSport Predator III Locked?
  152. po103 Low Frequency Code :bang:
  153. would this tune work for this setup
  154. Running Rich
  155. Pulled 4 codes tonight
  156. Transmission and Drive By Wire Tuning Training Video
  157. leaving wideband o2 installed when not using it?
  158. tried everything please help with security light!!!
  159. Alternator swap ... could that have been my problem ???
  160. lt1/boost
  161. Basic modifications with HP TUNER????Please Help!!
  162. Stock Tune: Why does my idle dip so low?
  163. Idle does not drop from 2K-2.5K until car stops???
  164. Commanded Afr Does Not = Actual Afr @wot
  165. Hypertech programmer III question?
  166. ls1 edit help..99 ecu in a 2000 car? will it work
  167. stall converter locking up every now and then?!?
  168. Transition SD to MAF, now weird startup phenom..
  169. Does LT Headers Affect the AFR?
  170. Tuner in Grand Rapids Michigan?
  171. could use a little help
  172. best handheld tuner
  173. Swapping PCM in a CTS-V - Is there an odometer issue?
  174. Who can help my modify my stock tune to get my camm'd Z28 running?
  175. fuel trim help asap
  176. Best user frendly/eaisest tuning software?
  177. Pro-M MAFs?
  178. im having a problem with my 99 vette..help
  179. Help for LS7 tuning
  180. lt1 tuner in nor cal
  181. cold starting issues...
  182. Is this a sign of needing a tune?
  183. PCM is locked... need suggestions.
  184. Autometer wideband users in here
  185. is there always going to be some knock retard?
  186. AeroForce o2 sensor help, come inside please!
  187. Who repairs PCM's?
  188. 100 Wet Log
  189. Tune attached, suggestions and opinions
  190. WB bouncing all over
  191. Trouble shooting P1637?
  192. car is surging/bucking on decel...help!
  193. AFR at 11.5-11.9 at WOT at 5k rpm
  194. Car going lean after starting
  195. Need Help Firing Up Car (eletrical)
  196. Does anyone have a LS1 Edit flash file for all bolt ons A4?
  197. Which Wire for EBOOST2 RPM signal?
  198. 32 degrees timing NA.....then swap to 16 degrees for 300 shot.... options?
  199. LS3/L92 Head folks, how much max PE timing are you getting?
  200. LS1 Edit Question
  201. tuning my ls1 nova
  202. Wideband help....
  203. newbie to efi live w/log
  204. reliable tuning shop Phoenix/mesa AZ area???
  205. P0420.. But I deleted my 02' soncers.. Mistake?
  206. need help!!
  207. Tuning with a MAF
  208. Diablosport predator/ worth it
  209. Trying to use a WB o2 with the EGR input
  210. Tuning Questions
  211. Broken Diagnostic port?
  212. Oh SHIT.. Got rear 02's deleted Need reflash???
  213. how to get EVAP monitor ready?
  214. best place to get a fast system
  215. L92 Swap into a Fbody, None of the PASS coils firing?
  216. Question..
  217. To wait or not?? Critique my starter tune!!!
  218. Persistent Knock
  219. Thanks HPT staff!
  220. Tuning DVD or help
  221. running lean under boost?!?
  222. rpm limit increase?
  223. Help choosing headers for NC emissions
  224. running like crap in higher rpms
  225. Tune to bypass O2 sensors to pass emissions
  226. Dyno Vs Dyno
  227. Concerning codes P0172 and P0175
  228. Best Tune shop in the Nation! G-Force
  229. tweaked the MAF tables, now have this problem
  230. intercangeable PCM'S?
  231. Tuning tips needed.
  232. Standalone , is it worth it
  233. MAF Hot Wire for Wb
  234. o2's going out?
  235. P0300 and P1637 - "blinking" Odometer?
  236. Asr Constantly Off!
  237. Flash help
  238. I got some Codes!!!
  239. C5 Z06 - CAGS light as a shift light
  240. Do I need to re-tune idle RAF?
  241. When IAT hits 100*, car basically shuts off
  242. Codes + asr off
  243. Tuning with NB and WB
  244. T-56 swap
  245. ls2 swap
  246. Tuning for Big Stuff 3
  247. speedo question
  248. do it my self where to buy efi live and af meter
  249. car stalls
  250. code po336 crank position sensor
