PDA
View Full Version : PCM Diagnostics & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
  1. Car won't start after PCM reset
  2. wanna play with excel sheets, but
  3. i have a problem when i raed my pcm ???????
  4. How do you tell the car?
  5. 2 Bar MAP's
  6. someone with a similar tune?
  7. FAT idle wont change...can you help?
  8. Bone stock Z28 idles smooth at 500rpm?
  9. LS1 PCM used for older EFI conversion?
  10. Computer reset's after sitting?
  11. PCM problems with a boosted car...
  12. Bad o2 causing misfire?
  13. Does the MAF reading look normal here on dyno (pic)
  14. 2.0 wideband histogram not working?
  15. Cost of a tune....
  16. Consistant hesitation in Dyno pull-----Help
  17. Hesitation when shifting
  18. Bolt-on tune?!?!?!?
  19. car throwing many codes.........
  20. Cold start with MAF
  21. How can i reflash the pcm
  22. Has anyone ever repined....
  23. Idle Issue on my Z06
  24. why wont my STIT go to 0 when driving?
  25. really bad idle on warm start....please help me out
  26. Need help/advice!
  27. many codes thrown..........
  28. how long to download the pcm with LS1Edit.
  29. LTFT going + at WOT, why?
  30. can outside air temperature affect idle?
  31. Can WideBand O2's be left connection all the time?
  32. hpt 2.0 can I copy over user defined values?
  33. Yet another stinking MAF question...
  34. share your tune.....please
  35. 383 bin files?
  36. HP tuners or LS1 edit
  37. DTC Emissions readiness tests
  38. HPTuners to tune stroker with YSi Vortech?
  39. car does not like timing!
  40. Zeitronix A/F set up gets my vote.
  41. Code Problem Need help
  42. need help with prop fuel tables in hpt
  43. obd11 or obd1 ????
  44. Spit & spudder
  45. Data logging in pcm for Etc
  46. Issue with RAF table and STIT/LTIT
  47. PLEASE HELP...i have a terrible missfire. scanned today have readings/live data.
  48. 0bdii Will Not Scan
  49. Fast XFI or Big stuff 3 tunning?
  50. working on sd ve tuning...will someone look at my logs?
  51. fuel button did not work
  52. Any way to trick the PCM into thinking it's in drive?
  53. Tuning an LS1
  54. good pcm question?
  55. 2.0 Scanner Problem - Anyone Else?
  56. fuel button on front of editor
  57. runs like ass in SD when cold
  58. handheld or Full tuning suite for ...
  59. Quick question about hp tuners liscensing..
  60. do i have to unplug maf
  61. Best tuner for bolt on 01 Z28 M6?
  62. Why are 99-00 & 01-02 LS1 VE tables so different?
  63. how to fix idle start up airflow?
  64. DFI file/help
  65. TPS HELL, someone help me!!!
  66. anyone have this problem???
  67. Any ideas of where to start looking?
  68. What the heck is garage mode?
  69. were to get my car tuned at
  70. best ECM tuning package for mild turbo setup
  71. Should I wait or pull the trigger (EFI-live/HP-tuners ?
  72. Looking for a table...
  73. Experts please: IFR and inHG Explained?
  74. 4 Codes = 1 Problem? (P0161, P0410, P0412, P0418)
  75. Issues with HPT 2.0 reading through editor
  76. predator gear change problems
  77. stock 02 z28 hi - low oct
  78. MAFless tuning on C5
  79. P0300 code - help please
  80. o2 sims.. but have code thrown?
  81. gitting my car tuned
  82. Checked codes and had Eleven!
  83. 98 vette cutting fuel at wot
  84. Stuck on low octane table?
  85. LTFT learning question
  86. hand held programmers
  87. HPTuners vs aftermarket trans temp gauge?
  88. throttle follower issue with FAST 90/90, A4, big cam....
  89. Do it yourself tuning
  90. Thinking of getting HP TUNERS
  91. if i set STIT memory to 0 it wont work?
  92. Need LS1EDIT file #9352261 !!
  93. best way to compensate idle airflow vs oil temp?
  94. Wait4MeTune??
  95. ve table map units
  96. Small Q
  97. P0103 on my 98 TA
  98. Resetting PCM? / Car will run better??
  99. Problems getting motor running properly?
  100. no SES light with MAF disconnected ?
  101. car won't idle w/o MAF (SD)
  102. HP Tuners - 2 Bar VE Table.....
  103. Turbo Timing Table, what does it look like?
  104. A4 tuning question about idling up to 20mph by itself...
  105. Help with LS-1 edit
  106. AFR question before & after cats.
  107. got my lc1 kit today and gotta question..
  108. all this driving?
  109. problem with SES light, help?
  110. HP Tuners F-body vs Y-body
  111. Base Spark vs. Hi / Lo Octane Spark tables.
  112. predator reflash
  113. HP Tuners ?
  114. who is good with excel?
  115. What would cause an O2 to read 438mv?
  116. A/F gauge
  117. VE tuning
  118. Going from 42lbr's to 60lbr's tomorrow..
  119. What's all this stuff about the MAF anyway?
  120. help please
  121. PO418 PO412 and PO410
  122. Having an odd problem with my car...?
  123. LTFT and STFT problems....
  124. Since a C5 doesn't have a true IAC ......
  125. Wire splice connectors..
  126. Help me,need help with trans/tuning issue???
  127. already screwing w/stuff I shouldn't:HPT2.0
  128. Car stalls at stops.
  129. so does anyone out there have a sts tune for hp yet ?
  130. Innovate LC-1 question........
  131. LS-1 in a SandCar
  132. Hptuners Is # 1
  133. Basic Cam Tune questions
  134. can a tune go bad? need help.
  135. cruise control effect??
  136. 2 and 3 bar
  137. HPTuners and effective area
  138. Post your favorite HP Tuners VCM Suite 2.0 Screenshots
  139. Speedometer synch problem!!
  140. Speed Density tuning??
  141. IFR's for mototron 60# injectors??
  142. need some help....
  143. Racetronix Delphi/Lucas 37# Injectors, IFR & Offset
  144. Tuning or tranny trouble?
  145. SD tuning using LTFT's with EFILive
  146. Issues installing 2 versions of HPT 2.0
  147. SES Light trouble
  148. easier MAF tuning with 2.0
  149. Lock-up Issues
  150. HPTv2.0.16 vs RAF Spreadsheet..
  151. how to add fuel?
  152. Pinging...
  153. LTFT effect on WOT, give me understanding
  154. New Tune
  155. Dual WB02 option w/ FAST
  156. HPT 2.0 and CASE Learn
  157. 2 bar map setup w/o custom os
  158. 98 maf limit - is it the maf sensor, or the pcm?
  159. how to set timing
  160. Going through HP Tuners 2.0
  161. What to tune with a high stall converter? po757 code
  162. will a LS1 computer work with a LS2?
  163. whats the name
  164. ok fess up, who wrote the HpTuners 2.0 installer???
  165. Firing order y body v. f body?
  166. Wideband reading indcorrectly....
  167. interior harness interchangability
  168. failed emmisions with codes disabled??
  169. online schematic?
  170. No Spark Someone Please Help
  171. How to scale timing table for most power??
  172. help with p0757 code
  173. Genisys OTC?
  174. ses light tune ?
  175. VERY negative LTIT+STIT, Huh???
  176. v 2.0 where is it .
  177. htpp with 100 shot
  178. Press release EFILive and Duramax Programming
  179. VCM Suite 2.0.16 Available Now!!
  180. Just in case there are some Duramax guys in here!
  181. RPMs hang around 1100 till I come to a complete stop
  182. Speedo is off.. Will it effect shift points?
  183. o2 ?
  184. Change Oil code
  185. SES code, throttle body sensor?
  186. Battery draining
  187. AFR205s Optimum Timing
  188. Nice tuning program for LT1 for 1995 Trans am
  189. Wanted - 2000 C5 A4 HP Tuner File
  190. Anyone discuss effects of MAFless with A4?
  191. anybody have bin close to this?
  192. Megasquirt Setups and Mafless
  193. Anyone make traction control more useful with tuning?
  194. o2 readings vary bank to bank
  195. getting rid of engine management?
  196. anyway to cut down on exhaust fumes?
  197. Intermittent Starting on LS1 '99 C5 Hardtop
  198. Is There A Way To Drive W/o Head Lights?
  199. Help ? about tune
  200. Photos of MAFless bellows
  201. Predator Programmers $399.99 + FREE Overnight Shipping!
  202. FAST, MS, or BS3?
  203. Running open header / closed loop
  204. Anyone have pics on how they ran their LC-1 through the car??
  205. Lazy / slow o2 sensors at idle
  206. Not happy with slp MAS, making changes need guidence.
  207. tuning a yank 4400 stall..I need info
  208. Shift Speed Settings
  209. Throttle Position / butterfly location / sensor voltage
  210. does autotap or efi scan abs sensors?
  211. No Rev Limiter
  212. Excel MAth Gurus..I need help
  213. tuning
  214. KR problem right off idle, any ideas on how to get rid of it
  215. Vacuum leak or is the tune off??
  216. P0300 Misfire Code...Amongst Others
  217. Vinci Tuner Quesiton
  218. Final solutions to get rid of that darn P0135 Code!! Start here:
  219. lc1 ?
  220. Free Flash program?
  221. shifting point (3.73)
  222. Can I send someone my dad's heads/cam tune?
  223. EGR code help
  224. HPTuner PID help
  225. Please Help!
  226. RAF spreadsheet ver 1.2 (bugfix update)
  227. G5X3 install, now code PO300 misfire detected....
  228. EFIlive w/Flashscan over HPTuners - Which One to Buy?????
  229. Help with codes P0133 and P1133
  230. idle spark advance vs idle airflow
  231. Help with codes.
  232. question on tune
  233. need help with mytune up
  234. Part Throttle KR...hpl & excel files enclosed
  235. Tune- Compensate for Fuel Pressure Drop
  236. Cammed cars what are your RAF
  237. Case Learn
  238. 02 Sensor Codes... How To Get Rid...
  239. MAF problems?
  240. Hp Tuners
  241. crappy starting symptoms
  242. Stock LS6 program to run stock LS2
  243. Low Oil sensor, low oil light in car is always on
  244. Scanner PIDs not working
  245. Adding PE = No Effect
  246. Any bad things about running 160* degree t-stat?
  247. What exactly affects knock learn?
  248. codes c1232, c1233, c1248
  249. Sluggish at times during Accleration. WHY?
  250. very odd airflow numbers, issues when adding air
