View Full Version : Suspension & Brakes
- Any Maryland Performance Shops!!!
- Need help on Koni install
- koni's but what springs???
- Relocation Brackets... Which brand to go with?
- Can c5 Z06 calipers fit on an 02 fbody
- Anyone run the Bilstein BTS-7501 kit
- Which performance coil springs should I go with??????
- SS/WS6 rims and 6-piston brakes
- Cutting springs
- So... I can just call sam anytime??
- Front lower perches on shock install won't fit over top of shock?
- Best Brake Pad
- Car sits funny now
- Cutting a Hotchkis spring
- How much space between tire and fender
- QA1 F-Body Setup
- auto x auto
- Rusty rotors
- BMR springs with a 9inch?
- which springs
- will V6 rotors work?
- Broken torque arm bracket?
- Line lock wiring Q?
- need to adj LCAs?
- pro-kit or sportline??
- Can I drive w/o the line lock wires hooked up?
- rattling noise
- HELP FAST leaks on line lock
- Brembo blanks + Hawk Pads
- Lakewood lift bars
- How easy to warp rotors??
- Front Sway arm bushings look like they where tosted over a fire-what kind to get next
- Coilovers?
- Powerstop rotors
- Advice: Looking for brackets to convert to C5 brakes on my Camaro plus part #'s.
- Does cutting springs increase spring rate
- energy suspension part #
- Konis 3rd gen rear 4th gen front
- thinkin of getting UMI PB and LCA
- upper strut mounts?
- Koni SA....WOW!!!!!!!!!!!!!!
- Weld in or Bolt on??
- Lakewood Driveshaft Loop Install
- Suspension Plans good?
- ahhhhh
- UMI adjustable TQ arm clunking??
- Do I need rod-ended LCA's or stick with poly?
- eibach or intrax
- Something wrong with my shocks?
- should i worry about bumpsteer?????
- I think I really messed up my Brakes
- Torque Arm and LCA's installed but....
- Anyone with Factory SLP Bilstein Suspension?
- strut tower braces
- need help with rattling suspension noise please
- Need help fast anyone!!!
- corvette caliper swap, please help!
- Blown shock maybe?
- C5 brake conversion work with fbody SBBL?
- Wheel bearings
- Torque specs for Spohn Panhard Bar
- UMI chassis torque arm good for what I want?
- P/N for Decarbon shocks?
- Setting proportioning valve?
- car torque's over
- Eibach Prokit or Sportline....Post pics...
- SLP Bilstein shocks and struts w/ BMR lowering springs
- Wheel alignment?
- springs with stock shocks
- Sway Bar install question...
- slotted rotors
- Wilwood clearance?
- bumps hit to hard
- Stock height springs
- Gone Bad Shock or Spring?????
- Lowering Springs on 18's!
- lowering springs
- adjusting koni sa
- how do i install new front springs???Urgent!!!!
- Worth getting just rear shocks?
- Make Sfc
- Need confirmation on front ABS
- What should I do about wheelhop?
- NEW C5 Rotors how much are they worth?
- Tips or Write ups on Rear Brakes
- anyone see this kmember
- how much for rear shocks and do they
- Front shock question
- Some DMS Q's...
- Canyon Carving/Street Suspension Setup Review (long)
- Back brake noise?? help please
- Scrapes and its not even lowered? Or is it?
- HELP! Need to know which way CDS rotors go!
- LT1 calipers on LS1 car??
- chassis/suspension..?'s
- best drag suspension on a ws6
- Umi Suspension ?
- Suspension, powersteering, LS1 brakes on '93 T/A 111k miles
- ls1 aftermarket springs on an lt1?
- rack and pinion
- How Much $$$$ To Install Two New
- my brakes at 80 -90 mph the steering
- 18" ZO6'S-LOWERING SPRINGS-HOOKER LT'S???
- ASS SAG!! stock suspension??
- quick swaybar question
- After alignment shake
- motor shake/clunk?
- UMI Performance components - Road Race weekend #2
- Most comfy ride ...
- E Brake ?
- i give up, squeeling brakes
- heater hose mod
- Bleeder valves????
- im stupide help me out?
- QA1/Prokit to QA1/QA1 Springs
- heater hose...reversed?
- spherical rod ends?
- WTF...frozen rotors?
- Question about my rotors.
- What Does Everyone Have their KYB AGX Shocks and Struts Set At?
- Suspension Hell!! Anyone who's changed out their springs/shocks in here NOW! BIG PICS
- Besides being able to center the rear end...what are the benefits of a panhard bar?
- Brake bleeding question
- Installing front and rear sway bars
- Time for brakes!
- qa1 f series
- Can't figure out what springs are on my car..lol..look
- pulling to left & too much wheel play
- control arm relocation and BMR X-treme adjustable control arms
- Koni SA vs. Koni DA
- lakewood traction bars
- Stock Vs Aftermarket Rotor Weight
- DMS SFC Pics? Help?
- boxing in LCA, and panard bar
- SJM LL and abs delete. Brake light on after install?
- Suspension Suggestions
- rear sway bar
- smaller caliper for f-body
- Brake experts only!!!
- Drop question/suggestions 56k comeback next week
- Does chassis mounted TA negatively affect handling?
- suspension question
- i got spohn SFC
- frontsway bar!
- Pro Kit and SLP level II Bilsteins ok?
- Eibach Sportlines value?$$
- pics of Koni shocks and stock/hotchkis springs
- Dash brake lights on '96 Z28
- Brake pad friction
- Caliper temperature question...
- How much do SLP SFCs weigh?
- Torque arm question
- Need help with Lowering??
- Lowered on stock shocks...?
- Boxed SFC?
- Qa1 / Hal Shocks and Springs
- so i removed my front sway bar...
- Car sits 1/2in lower on drivers side?
- Spring Help Please!!!
- Just ordered Koni SA's
- REAR ride hight adjustment
- chopped front tires
- Why is my "brake" and "abs inop" lights on??
- fixed or adj. lca's
- pulling to left and too much wheel play
- WS6 springs and Trans am Springs...!?!?!?!
- ZO6 caliper install
- TA / Axle Vibration Solved...Almost
- Hotchkis or BMR Lowering Springs?????
- pro-kit
- What settings do Koni's come from the factory with?
- Just got my Superbite Kit!!!! Torque Arm, LCA's, and Relo's... Now I have ??????
- Found out I have Jamex springs. Who the F is Jamex?
- Gen F HAL's, ride?
- What happens when all your fluid bleeds out?
- umi chassi mounted torq arm????
- Feels different after new wheels ..Strano help?
- LG Coil over kit... does it fit Firebirds?
- ABS INOP light came on after header install...
- how to get 800 horsepower to teh ground
- any1 have prokit with slp lts?
- 100K Suspension Upgrade...?'s
- Ride height on Qa1s with rear stock springs??
- G2 springs Vs Eibach
- Koni Sa's and Ground Control nightmare
- help with pads
- STB Install
- Rear brakes not working?
- relocation question
- are subframe connectors a good first suspension mod?
- Will these calipers work.
- Which Torque arm with TSP TD and Moser 9" ???
- Best coil overs? GW? etc
- Replaced pads and rotors again new "smell"
- Just ordered my Koni SA shocks
- Best performance spring kit
- Tokico Performance shocks
- Lowering springs
- swaybar/stb...questions
- Can anyone give me step by step on removing and greasing guide pins?
- Question about UMI parts...
- Difference in Springs
- Brake sensor Question
- *** Drilled / Slotted ? ***
- Calipers
- Brake Caliper Bolt
- help!
- LCAs questions
- All over the road
- Bump Steer kit.
- Bleeding Brakes 3 channel
- Anyone make their own torque arm??
- abs question
- RPM Speed LCA and Relo Brackets, Any Good?
- Rear Air Bag
- KYB AGX and H&R springs
- Brake Calipers
- 2002 z28 115.000 miles -shocks rear
- Want to change lowering springs
- Need zinc coated rotors.
- Will it fit ---6 point bolt in cage
- non-drilled/slotted rotors that wont warp?
- Handling is very bad -- Need help asap
- I'm guessing you can't get Strano bars anywhere but Strano's??
- EVER heard of tokico suspension package
- looking for a steering adapter 6 bolt
- Bilstein HD's (not your typical question)
- Need a good shocks/struts combo, maybe even new springs, help
- HELP!! Changing front shocks!!!
- what shocks to use with hotchkis springs
- Edelbrock Shocks?
- Whats causing my squeaking?
- What to get and how much would I spend?
- Which way should slotted rotors face?
- UMI 3PT SFC: weld in same as bolt in??
- Bilstein drag shocks?
- Alignment Question
- Slalom times for f-bodys
- Strano Performance Lowering Springs
- Dilema..
- Rotoworks?
- QA1 question
- Swaybars and Endlink spacers
- Thread sealer on solo bleeders?
- Wilwood SL-6 Front Brake 6 piston Calipers
- control arm bushings and a arms
- let master cylinder run dry....will I need a Tech 2??
- k members
- Squeak/Bang Bang :)
- Turn One power steering pump...
