View Full Version : Conversions & Swaps
- HotRod style 240sx LS1 headers
- My sub $4k Ls mustang build (quick vid too)
- Trying to see if these Hookers will clear on my Nova
- What gages run off of the standard ecm output of the ls engines
- 1985 Monte Carlo 6.0 LQ4 swap
- Geo tracker is completed
- BRP Mid-Length headers 64-67 A-Body
- Going from a th350 to a 4l60e, what are my options for my speedometer for my 72 cheve
- GTO power steering pump
- $400 Tailshaft adapter a MUST!!!??? What the?
- 2004r stall?
- auto to m6
- Carb LS ?
- How big is your Edelbrock
- MAF or no MAF?
- More O2 Sensor Questions
- c1 corvette ls swap without new frame
- low cost recal, electronic speedometer?
- 6.2 powertrain in A body
- Wont start... a few questions
- Trying to get my car started w/o MAF
- 6.0 TWIN TURBO LQ4 Aerocharger!!!!
- Is my 2001 6.0 an lq4 or lq9 ?-from a pickup
- New - Ford 76 F-100 with a 4.8 Vortec
- 4.8L to 383 Build??
- pics of my ls swapped 84 cutlass
- Which suspension spring to buy for my fox body ls1?
- Help!!! Ls1 no-start.
- classic instruments - calibrating speedometer??
- gto oil pan
- need pinouts gm 19166569
- 69 chevelle
- need c5 pedastals for my rx7 swap
- Whats it take to keep her cool?
- ls1 3rd gen
- water temp gauge (autometer)
- oil pressure wire...
- 67 camaro help.....
- 87 IROC 5.3/w th350 budget build
- Help me out! Mustang swap guys with aje mounts
- How far can a 5.3L be bored out?
- 400 - 425 HP on 87 Octane - 6.0L (or 6.2L V8)
- 5.3/6.0 into a 85 fullsize bronco
- 1986 dodge conquest project!!
- stock Ls3 fuel pump in aftermarket tank
- Need some cam help for an lq4 4x4 swap
- R4 Compressor Bracketry-Who Makes It??
- LS swap into a 67 Camaro help!
- lsx mustang (need tips)
- throttle cable ls-x into 72 chevelle
- Tell Me I'm Not Crazy
- 97 Lt1 going into a older camaro.
- Need info for LSx Swap into a 72 Chevy SWB 4x4 Pickup
- lq4 powered 72 caprice coupe restoration
- L92 Pass Upper AC compressor bracket Vintage Air
- Contact Info For Monte Carlo John Please?
- finally got around to painting the 67 before the ls-fest
- fuel level gauge question
- need someone with aftermarket gauge experience
- Fox body guys, what are you using for a throttle cable?
- C4 corvette - 5.3 "LSX" engine swap project [PICS]
- no oil pressure
- LS1 with T56 in XJ6
- how do you get the injectors into the intake??
- Have new fusebox for engine install (89 Camaro)
- driver and passenger door switch questions
- 1969 chevelle LS1
- ?s on AN fittings
- mustang guys with aje crossmember
- driveshaft question...
- 5.3L LM7, drive by wire, on my engine Run stand
- swapping a tci 6x into my fbody...shifter wiring question
- Mazda RX8 LS1/t56 Swap
- need help...dbw to dbc???
- 97 V6 auto going to gen 3 motor
- 1993 c1500 swap help
- Now I've gone and done it...LSx Astro van coming soon
- How to get codes from check engine light
- How to lighten 74 camaro
- engine harness problems
- carbed LQ4 w/LS3 heads
- JZ Motorworks/LHX pan baffling
- Brake pedal hiem joint size???
- LS1 Into 95 FZJ80 Land Cruiser
- Cruise Control (DRW)
- Check out the two Twin Turbo set ups
- Budget E46 Track Only Car
- Putting a 6.0 in a ski boat
- Correct belt routing for alternator/wp only with truck accessories?
- 3 wire coolant temp sensor...difference???
- temp guage ? on 89 suburban swap
- 5.3 to 6.0 swap turbo silverado
- 70 Camaro RS LY6/4L65e build
- 240sx hatchback lsx
- Cheap Shorty Headers
- Any other way to hook up for tach signal?
- Stock LS1 aluminum drive shaft. Worthy of modifying for swap or too weak?
- Oil Cooler Plate Help with Dynatech and Autokraft
- pics needed
- LS sonoma
- tac module to pedal pigtail
- if the motor is ran hot...
- 1971 Chevelle/ls1,4L auto swap
- speedhut gauges
- 5.3 swap in to third gen camaro Q's??
- 1 piece front end?
- Fuel Pressure in 99 Tahoe LQ4 swap help!
- LQ4 in a 83 camaro
- need dimensions for autokraft oil pan
- LY6 with T56 in 2000 Trans Am?
- recommendations on conversion?
- truck accessories (a/c comp) with edelbrock engine adapter plates
- truck accessories dont fit in my jeep swap!!
- Fuel Pressure problems
- Malfunction Indicator Light....
- Alternator getting relatively hot!!
- carbed blow through!!!!!!
- 3.8l to ls1 swap
- Ttruck/camaro intake pulley relocate belt part number????
- What gauges for 72 Nova
- 2nd Gen install kit on a 1st Gen, Will it work?
- Coolant temp adapter to use stock gauge
- power steering fitting
- Real world experience with your Abbott Cable X. Please tell.
- !!!HELP!!! Swap almost complete car wont start!
- LS motor in 86 Monte Carlo SS
- Best cluster for Corvette C4 with 4.8?
- 1979 Ford Failmont (4.8/Big Turbo/TH400)
- New, first LS engine, Swapping into Jeep, lots of ?'s
- ls3 480 el camino video
- fuel pump
- No spark after LS1 swap? Checked everything I can think of...
- LQ9 into a 68 Firebird
- OBD Port Connection to PCM 5.3 '03
- My quest to solving my fuel tank dilemma
- Best gen III oil pan for oil control?
- Chevelle long tubes???
- ls1 temp gauge
- 317 heads
- temp gauge
- Shifter hole size & boot for t56 install
- LQ4 alternator pigtail?
- Good places to look for wrecked donar F bodys?
- wich heads to use?
- Engine and tranny swap price
- just bought an 04 gto intake
- Firebird -68 pictures
- Corvette accessory drive in fbody ?
- Hotwire Kit??
- Oil Pan.
- LG Motorsport / Kooks Collector hybrid headers
- ls1/t56 07' tacoma xrunner
- ls1 in a 57 chevy
- sn95 swap
- Compression of 2004 6.0L
- 91 s10 5.3 turbo swap
- f body brakes on 67 chevelle
- Ls1 to ls7 z06 swap
- have a question about 1970 impala
- Possibly WTB LSx/T56 A or F Body
- 4L60E doesn't shift WOT
- F-body Heater Hoses - in and out?
- lookin for oilpan that clears crossmember on my g-body....please help...
- run or not to run a fuel regulator
- Relocating coils
- Those who have done your own standalone
- LS2/T56 into a 70 Chevelle By Deserttaco
- 3rd Gen, Lq9 swap Fuel pump question
- dbw or dbc ecm and wireharness ??? how can i tell what it is??
- So the junkyard screwed me a little
- Where to buy L92 rockers and stands used?
- Best electric fan set up for the street.
- 2002 Tahoe service manual?
- Using the 2005 LQ9 harness in my swap, how do I handle the throttle body?
- A body motor mounts/adapters ratings & opinions
- Prepping an old gas tank for in tank pump
- LY6 6 liter tach wiring
- LS1 harness for engine dyno
- LQ4 Motor Swap
- 2000 LS1 harness to a 94 Z28 M6 Camaro...
- One wire alternator hook up PLease help
- Truck MAF sensors
- 2010 Summer project
- Is $1200 delivered for a '05 LQ9 complete w/accessories and harness a greatd deal?
- Swapping 2005 LQ9 into Fox Body. Please help.Lots of ?'s, please try to answer some!
- Nissan 630sx 383 LS1 in a 240 (more pics)
- Where in socal are people getting there ls motors for swap?
- cooling fans not coming on with A/C
- whats the difference between ..
- 5.3 is overheating, no water in top radiator hose, help?
- 4l60e transmissions, which years are correct for genIII engines?
- Automatic AND 6 Speed harness?
- V6-V8 Swap
- Recommendations for fuel system?
- LS1 Swap
- Dakota Digital dash panel (PICS!!)
- 67 Nova L92
- Finally Running
- alternator wiring
- 5.3 in a c4
- crank position sensor when did they change from the 24x? to 58x?
- Pan and k Member question
- Want an LSX in my C4 Vette
- TPI to LS1 (tons of questions) sorry!
- LS2 Starter/Altenator Wiring??
- Any other Manuals aside from a T56?
- Fan wiring
- 4L70E/4L60E tranny cable into 68 Camaro
- 2nd gen swap
- Ls3 g35 swap
- 90 Formula GETS TEASED (LS1/700r4)
- Coolant Level Sensors Purpose?
- Air intake "flex" tube, where to get it?
- 4" intercooler NOVA?
- my 79 reliant kitten ls1 th350
- Carbed LS3 Tuning Help
- Another 5.3 t76 notch
- 2000gt 5.3 swap
- Sd-pc
- LS3 intake seals
- wiring help
- What ECM to used?
- Classifieds Link: Unused Hooker LS Swap Headers: 67-69 Camaro
- when getting a used gen III at what mileage do you buy as rebuild only?
- best mild cam for my 5.3 with ls1 intake....
- Harness/pcm?
- Help with OBD2 connector on ls1 swap
- Cannot get msd 6010 to connect with computer
- map sensor
- Finally making some progress on my '79 Malibu
- Air intake reduction... how small is too small for LQ4?
- lq4 with l92 heads
- Build Questions - LQ9 L92 Fox
- Alternaror bolt up
- Remote Bleeder System
- LSXS14 Trade: Corvette accessory brackets for Camaro (S10 guys)
- 76 Malibu VS ca emissions, HELP!
- Ls1 into a 1995 Mustang
- What power steering line for a first gen s10 with an LQ4?
- 2005 Nissan 350Z with LS2 (6.0L) Swap.
- What about a 1997 E-class?
- 72 Chevelle Conv. SS LS6/ Tremec 5-speed
- LQ9 w/ fbody 4l60e...quite a few wiring questions
- Help me identify these plugs/hoses! (pics)
- what do you guys do about state inspections?
- Anyone do gauge conversions?
- 69 Chevelle, couple questions?
- 5.3 into Cadillac BRougham
- 1933 Ford Coupe/Roadster Stroker Build
