View Full Version : Conversions & Swaps
- 95 c4 corvette 5.3 swap
- where to buy wire harness at? input help
- 69 Camaro LS7 T56 Protour
- ECU/wiring pinout 2005 GMC Sierra 4.8L/4L60E
- Harness rewire question
- How I mounted my fuel pump
- ? for first gen swap
- Professional LS Swap 2002 S-10 (anyone out there?)
- Building a LQ4 to put into a 95 camaro.
- lq4 front engine accessory question
- 5.3 Swap questions
- Removing Smog on a E-rod Crate Engine
- 1990 Vette LS swap?
- 4L80E slip yoke selection help
- Spec twin disc
- Traction handicapped... not sure where to start
- New edge 6.0 wiring
- 96 impala ls swap , i need help guys !!
- Possible Cause of High Oil Pressure
- Custom Oil Catch Can
- 1st gen camaro / firebird shifter mod.
- please help foxbody conversion guru's
- ls to muncie; what starter do i use?
- 76 skylark factory ac box, fuel&wiring set up
- Cowl Induction for a Chevelle LS-1
- LS3 waterpump heater hose routing
- TH350 Dust Shield (flex plate cover)
- 1993 RX7 - 2012 L99 /T56 swap dyno w/video
- LS3 GM Performance Parts front drive kit 19257325
- brake line size
- power steering pump on my c3 vette
- Factory harness rewire
- Anyone local to reprogram my ECM?
- starter engaged....permantly
- CX racing Vband to T4 Elbow question
- Wash water drain holes for intake manifold?
- 1966 mustang ls3 th400
- DYNO BLASTER LS1 V8 Makes This the Coolest BMW Z3 Ever
- running wires under the intake?
- thanks to Bill at BP Automotive
- Vintage Air Drier Port Sizes
- junkyard fuse box ????????
- Need help with parts interchangeability for my upcoming build.
- 1968 Camaro budget 5.3 ls HELP
- D3 Performance Engineering LSx Twin-Turbo G35 Coupe
- 1968 Camaro LS 5.3 Swap Help!!!
- Ridetech VS QA1 Need Help
- LQ4 Purchase Question
- need intake help/ knowledge
- 98 SS LS3 411 tcs/ABS delete wiring Q
- lq4 accessory's with ls6 intake
- New Project build :) some more import muscle!
- Project change over. Bye Bye Foxbody, hello new ride.
- 1967 "Trackmaro"
- El Camino 1971 LQ9, fuel pump relay clicking, HELP!!!
- No power to fuel pump in run position
- key switch not powering starter problem
- what stall to use?
- '65 C10 SWB Build
- need to identify this connector LS2...help
- First swap build, need suggestions. FC LM7
- Fuel tank venting
- plug id help
- 5.3 swap help!
- ls wiring
- 94 LT1 Trans guts into a 98-2002 ls1 trans case
- Can this be done!?
- 4.8 t56 swap in a s2000 rear end issue
- 6.2 truck motor ?
- Fox with gm 6 speed question
- Chevelle radiator hose
- Lq4/tko600 single turbo 2000 mustang build
- slave cylinder adaptor
- F body radiator hose question
- 69 LS1 Camaro Engine Mounts
- ls1 240sx
- ls1 fuel sending unit.
- '85 Monte SS Twin ON3 70's
- LS3 Engine Builder/Vendor Question
- gen 4 F-body long tubes on A-body
- Stiff/poor brake feel on LS1 mustang... Hydroboost problem?
- 1999 lm7 5.3
- Anybody have?
- old school hot rodder
- motor mounts 71 chevelle
- spark,fuel,no start
- Problems when not using native transmission in swap?
- ls in 1955
- Fox ls swap, silly question on cooling fans setup
- Vats help?
- 4x4 Truck motor mount
- 4l60e to 4l80e
- lq4 and 4l60e db cable and computer
- 5.3 turbo build in 89 fox body coupe
- Lq4 swap into firebird
- APP pigtail pinout
- Metal work
- Wire gauge size for stand alone harness?
- 94 Ranger L33 TH350 2wd
- My 96 trans am 5.3 swap
- Finished LQ9 swap in 99 Tahoe; problem with WOT shift. Any ideas?
- Holley AC compressor bracket spacer?
- G body turbo drain?
- my dipstick does not want to go fully into the block. Need help
- Calling for all 70-73 Camaro LS swap owners
- Another belly button Lsx 67 Camaro vid - 585 HP
- Anyone know where to buy GM harness Terminals?
- A Datsun Pickup Packing LS1 Power Does an Epic Burnout
- New to 5.3ls... need help getting it started
- Need help!! Jeep cherokee LS swap
- c5 vette water pump distance
- late 60's c10 on a 2001 tahoe frame
- 1999 Camaro SS LS3 Swap
- 4L80E transmission yoke
- 4L80E in A Body 65 Chevelle
- Newbie requesting help
- Looking for ideas on 350rwhp
- 5.3 Waterpump Mustang
- A body rad to LS F body wp hoses ?
- Wanting to LS Swap a 70 Firebird...need info
- 6.0 in 69 Camaro Possibly supercharged or turbo
- 1990 Hardin Marine Cheyenne Jet Boat
- Need Harness Help
- TCI Outlaw shifter for 4l80
- 2004 LQ4 swap, are rear oxygen sensors used?
- New edge body wiring
- 6.0 or 5.3 LS 69 Camaro conversion
- Fuel Rail Interchange
- LQ4 with L99 water pump and truck accessories
- Hybrid Electric 1949 Chevy Pickup, Advice Needed
- 1965 A Body Chevelle and 4L80E
- Pedal to TAC harness and TAC to TB connector from one vendor?
- 1959 Apache stepside truck.
- LQ4 in a 1967 C10 combo help
- Cold Air Intake for LT1 to LS swap???
- PCM To Engine? Will This Work? (LS1 Into '08 S2000)
- '63 chevy ii starter/starting issues
- 04 GTO Full swap, VATs deleted car still won't crank
- Fox mustang Dynatech headers
- LS3 – 525HP / Legend LGT-700 Conversion in a 66 Pontiac GTO Convertible
- 73 Camaro lq4 swap help
- on to the next project: 79 Malibu LS swap nonsense
- a/c compressor wiring
- 1961 Pontiac Tempest wagon - 2004 GTO merge
- Engine Alignment issues with BRP mounts on 2nd Gen firebird
- ls1 swapped into a 95 z28 harness modifications
- Mustang coupe with LS1 and s480 STREET TERROR
- Z32 300zx vs 240sx (S14) for LSx Swap
- Stainless Y-Pipe swaps???
- 1996 LS Camaro Oil Pan Advice PLEASE!!!!
- 06 5.3 build
- 1980 Camaro LS TURBO Swap
- 1967 Cougar build (over 500 pictures and videos)
- Will gen1 swap headers work in gen2 camaro ?
- 4L60E wiring...
- truck accsy's in 4th Gen??
- To paint or not to paint
- Trans cooler
- LS1 Fuel rail covers on a 5.3 with Truck coils...anyone done it?
- Coil brackets question
- LS3 lower water-pump intake--any others that fit???
- Chevy Square Body Truck New Build - Need suggestions
- Couple swap questions
- Cool Deadwood Nights
- Another VSS question 8k or 128k?
- 5.3/60e in a 90 Bronco II?
- New and have a quick question
- Opinions please
- 5.3 swap to 93 foxbody
- Thinking of switching to front and mid motor plates
- c10/crown Vic tube chassie project
- Has anyone done a 2nd gen F-body with truck manifold turbo?
- wiring harness help.. gurus get in here
- 5.3 swap 86montecarlo
- LT1 to LS1 - Ignition Fuse Question
- 6.0 swap into mustang experts please enter
- 4l65e ?
- Has anyone swapped
- Cap on radiator and a pressure tank with a cap?
- 6.0/4L80 in Jeep TJ, which mods would you make to motor ?
- how much is too much fuel pressure?
- Magnum shifter options
- ecm help needed again.
- Take a look at clutch master cylinder.....
- Need advice on 5.3 swap
- differences between gto n camaro slave cylinder????
- LSA fuel system e rod kit
- Best aftermarket harness ever?
- 240z Swap Logistics
- 4L60E add on harness?
- No throttle response on new swap.
- What fuel lines typically used?
- Can anyone ID these connectors - LS2 Engine Harness
- LS1 stand alone harness; C100 / C101 / C105 plugs question ??
- 1st gen help with brake booster studs
- Little red express
- manual coolant temperature probe
- Part numbers for PCM contacts and delphi connector contacts?
- looking for conversion help/tips
- Lr4 4.8 swap help in over my head
- this pos
- throttle body difference?
- rear end
- Anyone think this could be used as an inverted flare fitting?
- Swap it out?
- 94 Trans Am HARDTOP LS1 SWAP 95% complete
- HolleyHooker LS swap kit for 68 Camaro or?
- Early 5.3 front dress on LS2?
- Texas Speed
- 4x4 S10 future project
- a/c kills engine on swap
- 2002 lm7 - 2006 gto t56 pilot bearing
- 1980 corvette, 5.3, e85, microsquirt, turbo, 4link, 8.8...
- E36 m3 ls3
- Opinions needed: LS into 3rd gen Nova
- Need a little help with Wiring harness
- Any ideas on what to do with a weird idle problem?
- Electric cooling fan motors.......anyone found any good replacements.....?
- parts needed for swap
- L92 into '39 chevy wiring/ecu questions??
- Schoenfeld ls mustang headers !!!!
- G body oil pan and header help
- 1981 Camaro 5.3/4L60E Tight Budget Build
- Seeking ls engine advice for 1st Gen Chevy II wagon
- trans stuck in limp mode plz help
- Intro and New LS1 owner question
- oil temp sender in Holley 302-2 pan
- alternator 13501721 info
- 78 malibu, need 5.3 harness help
- fuel trim issue..need help pls
- Need a little advice on an LS swap into a '62 Chevy Belair
- LS3 64 IMPALA almost done
- lq4 swap build
- LS2 with LS1 harness?
- 75 Thunderbird Ls Swap ?
- Gto ls1 in 70 c10??
- anyone done a 71-73 mustang swap
- chevette throttle cable?
- HELP! 5.3L to th350 issue
- Is an LS4 an option for me?
- Lq4/t56
- Wiring Integration Question--Swap
- O2 Sensors Wont Work After Conversion...
- 75 Big Big 5.3 Swap ???
- HOOKER LS Exhaust Manifolds in '64 -'67 GM A-Body?
- ls2 engine harness preference?? dbw
- Necessary to notch front X-Member on 61 Chevy for LS3?
- Can't Get Scanner to Link
- TR6060 help
- LS1 vs LS2 and LS2 vs LS3 - perceived difference in performance?
