PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. T56 question
  2. Will an LS2 intake fit an LS1?
  3. 98 swapped firebird roller fs:
  4. Any swappers need a harness? Step in
  5. Lt1? Ls1? Awd bravada t56?
  6. beware of eastcoastengines-com. pcm tuning or wiring harness
  7. LS1 conversion in 68 camaro...side pipes too much to ask for?
  8. 1964 Skylark undergoing heart transplant
  9. Air intake tubing,what to use?
  10. 4l60E years /
  11. Truck Accessories...Alternator Only
  12. How much power will this make?
  13. 71 chevelle + 6.0 w/ 4l60 = wait and see
  14. Harness info?
  15. coilpacks and harness
  16. ls1 into an 84 camaro
  17. Modern interior conversions?
  18. fuel pump???????
  19. Help with my DBW
  20. brp vs edelbrock?
  21. 6L carb motor, cam suggestions ?
  22. LSx into a early C4? Anybody?
  23. 5.3 engine picture showing sensors
  24. LS mech temp sensor
  25. LSx ALuminum block in a 2002 Suburban
  26. how hard is it to swap a ls1 into a 94 lt1 fbody?
  27. Head/Block/Cam Compatability
  28. MAP Sensor + Carb
  29. engine wiring harness of choice??? list here please...
  30. LS1 swap complete, 99 Miata on track
  31. fuel rail covers on a carb intake?
  32. LS1 260Z conversion
  33. Truck A/C w/ F-Body Accessories?
  34. LS1 into LT1 F-Body 2 days??
  35. what size fuel line ?
  36. Chrysler VSS into a Chevy Dash/cable
  37. Truck Accessory power steering pump
  38. spare tire?
  39. Need cam for 5.3 in 72 Chevelle
  40. Does anyone have a 77-78 TransAm converted?
  41. LSx conversion questions
  42. ls1/t56 into a 1965 malibu ss
  43. 240sx Guys: WTT GTO LS2 Oil Pan for LS2 Vette Oil Pan
  44. Need info helpon reluctor wheel/drive by wire,MSD??
  45. anyone have a spare ATS clutch bracket to sell?
  46. Fuel sending unit gasket p/n
  47. What radiator are you guys using for your swap?
  48. O2 sensors?
  49. Best cam for the steat in 6.0
  50. Fuse Box Ideas !!!
  51. v6 to v8 camaro swap question- trans mount & driveshaft
  52. ok guys need your help
  53. Stock 4L60E...What Would Your First Mods Be???
  54. Swapping an LSx into a 95 Z28..
  55. Just another Miata swap - building a race car with a V8Roadsters kit
  56. Looking for Fox body Turbo Pics
  57. Stand alone wiring question
  58. S10 Long tubes!!!!!
  59. 2008 Hummer H2 L92 Wiring Diagram + Pinout
  60. l92 swap in 86gt mustang HELP MEASUREMENTS/ PICTURES NEEDED
  61. C6 Headers in 68 Camaro/LS1
  62. F.I. fuel tank sending unit ?'s
  63. Searching for a motor??????
  64. LS1/t56+foxbody
  65. anyine selling fox/ls1 k member or headers?
  66. Fuel Lines/Canister Hook up question on pump side
  67. LS 1 in '79 Trans am
  68. 86 Iroc LS2 T-56 SWAP PICS
  69. Stock 4L60 trans dipstick work with G-body swap?
  70. EFI fuel line, single or double flare?
  71. LS Lotus, here it is!
  72. What oil pan will work in my 55 chevy?
  73. 69 Translam
  74. Changing gear ratio
  75. LS2 Swap into 62 Impala
  76. Fbody radiator
  77. 6.0l & 700r4 install
  78. silvia lsx question(s)
  79. 318i ls1 build thread
  80. More fuel system ?'s and options
  81. Fbody headers and C5 oil pan(batwing)
  82. cadillac XLR with a LSx/t6060?
  83. Do the LS7 exhaust manifolds fit any closer to the engine like "block huggers"?
  84. Motor mount questions truck vs fbody
  85. Gas Tank Vent line (and other) questions
  86. What did you jet your Carb? COME ON IN!
  87. Those who have modded their CBW pedal...
  88. Your opinion is push rod lenght causing valve train noise?
  89. Holley Pump Discharge Nozzle size
  90. My new project, have some questions (a body)
  91. Dry sump & accessory drive
  92. 45 or 90 degree thermostat housing for a 5.3
  93. 65 A/BODY SWAP Questions
  94. Catera/ Bitter SC?
  95. bbk long tube header question
  96. fuel rail help
  97. How different are the sensor locations on the 6.0 Lq4 vs Ls1
  98. O2 sensor?
  99. anyone have 1 of these??
  100. 1963 Chevy II 408" L92
  101. Ls1 to a 200r4
  102. 4L60E VSS Conversion - Tranny Question
  103. Fast Intake on a 6.0L Truck engine
  104. Carb's LQ4 And TH400 Stall Question
  105. Whats up with the fuel return
  106. v6 to ls1 wiring?
  107. wiring harness
  108. Even Hitler likes the LS2
  109. C5 pedal question
  110. Stall speed for a LQ4/TH400 63' Nova?
  111. 57 Chevy + Procharger?
  112. ls1 t56 w/ls1 auto harness?
  113. Headers
  114. t56 on ls1 problems
  115. More wiring questions
  116. Stacking coil packs.
  117. Need help/advise swapping LS1 into '61 Biscayne
  118. DBC, E38 question
  119. 416ci into TVR Cerbera
  120. 06 Lq9 in in 95 f-body have some questions
  121. 99 lq4/700r4
  122. Carbed guys need a fuel system?
  123. Lq9 were should i start
  124. 56 chevy p/u with 04 gto
  125. Adding crusie control to 99 v6 camaro with ls1
  126. lsx air cond bracket
  127. 5.3 carb going into a LT1
  128. Truck TB and MAF, on ls1 intake in fbody
  129. 84 Cutlass lq4 swap pics
  130. polished OEM covers
  131. LS into Toyota Tacoma
  132. video of my gta
  133. 98 coolant temp sensor to autometer gauge help!!!
  134. lt1 to ls1
  135. G body headers options
  136. Rear gears Mileage impact (A4)
  137. Wiring Harnesses
  138. want to put pics of my swap ?
  139. will this work
  140. Carbed 2nd gen questions
  141. new an looking for some help 5.3 swap onto 75 c10
  142. another 2nd gen camaro swap..
  143. ls1 gauges
  144. Mount plate adapters
  145. buying 1st gen conversions
  146. Edelbrock LS engine mounts
  147. Could you do a 4 eye LS1 EFI swap?
  148. -6AN to 3/8 inverted flare
  149. V6 to ls1 or sbc
  150. 5.3 into bravada: wiring diagrams needed
  151. Third gen LSX
  152. l92 into 86 fox body INFO PLEASE
  153. T56 Floor choppin
  154. How reliable has have some of you’re swaps been
  155. HEADERS GURU HELP 72 pick-up/LS1
  156. Any unforseen problems from swaping truck to f-body accessories?
  157. Fueling options for EFI FI estimated 600rwhp 69 Nova?
  158. V6 Vert to LS1 Question
  159. Need a complete harness ASAP, anyone have connections?
  160. HELP!! 5.3L Bolted to a TH350 tranny
  161. LSX Fox swap questions
  162. LS2/4L65E reving slowly
  163. Another '68 C10 + 6.0 Swap
  164. Oil Pan/Valve Cover Questions
  165. Lq4 + th400 = ?
  166. More info on the Hybrid block(Motown LS)
  167. MAF difference?
  168. v6 to ls series tb/maf question
  169. v6 to ls series fuel questions
  170. LT1 to LQ4 swap
  171. 89 RX7 Vert LS1/T56/Cobra diff IRS
  172. New project colorado
  173. motor mount help...
  174. 64 Chevy II ls1 goes 10.96 first time out.
  175. New Project! 78 Malibu LQ9/4L65E W/Cam Swap
  176. Aftermarket fuel system plumbing...
  177. trying to find the park position on a 4l60
  178. 2005 3/4 ton wiring harnes help
  179. Ls1 stang s400 turbo progress
  180. Fan driver question
  181. Help, fox motor mounts just started
  182. LH8 pan...lowered car
  183. Clutch pedal switch
  184. Where to find out what bolt sizes are and where to buy them?
  185. 2006 5.3L LM7 Alternator wiring
  186. BRP oil pickup girdle=grinding
  187. msd 6010 box questions
  188. Lq9 240z.
  189. Boxster LS1 swap: Ideas needed plz
  190. header gasket
  191. lt1 t56...ls motor? can it be done?
  192. T56 swap into a '70 Chevelle
  193. MegaSquirt, any good write ups?
  194. 2nd Gen LS1 install kit
  195. Running too rich?
  196. DIY harness mods..
  197. Quick Disconnect fuel lines
  198. SM465 behind LQ4
  199. 69 camaro ls headers needed
  200. Fuel pump/Fuel tank
  201. A4 to M6 swap in a 98 vette
  202. Knock Sensors
  203. Does anyone know....
  204. Few new recent pics of my turbo lsx 240sx
  205. SDPARTS and customer service?????? non-existant????
  206. LSx/T56 into 1983 Capri RS
  207. fuel rail swap question
  208. Lsx mustang, NEED PARTS!!
  209. 6.0 wagon...winter updates
  210. Oil pan sealing?
  211. Mac mid lengths in a fox body
  212. Designing a Fuel System
  213. Could this be the cause of my carburetor problems?
  214. Ls1 alternator
  215. WIW- Complete Top End
  216. 6.0 in a 96 Chevy 3500 currently a diesel, how hard
  217. Coil bracket problem...
  218. Speartech LS3/6L90 swap package available!
  219. Who has swapped 6.0L/4L0e into 01 Duramax/Allison silverado?
  220. LQ4 bolt into a 4.8 V8 silverado with 5speed?
  221. Should I order from gmpartsdirect.com?
  222. Anyone put an LSx in a cadillac allante
  223. wire harness what one
  224. 98 Sending unit.. How different from 99+
  225. what to do if!!!!!
  226. LSX in Notch Back
  227. 2 last wiring questions c230 2001
  228. Oilpan swap?
  229. Lq4 pcm pinout
  230. where to get 4" alum pipe
  231. Carb'd & front mount Distributor, fox swap is ALIVE
  232. 1 Week, 390 Man Hours 20 Phone Calls to John @ Speartech
  233. Water temp and oilpressure senders to LS3
  234. oil pan kit
  235. Turbo Kit for LS1 in 1st gen F-body..
  236. LSX Mustang f/s (project car)
  237. LS6 Wide body Monster Miata
  238. up to date pics of my foxbody swap
  239. 2007 5.3 Into 1948 Chevy 5 Window Pickup
  240. LSX into Ford Bronco?
  241. LS1 in an 85 toyota 4runner or pickup?
  242. Trimming LS1/F-body fan & shroud?
  243. kst8engineer - '71 Chevelle LS1/T56 build thread
  244. pics of ls1 into fox
  245. ls1 swap into IS300 chassis
  246. tach
  247. 1991 Mustang LQ9/4L80E swap
  248. Which tranny cooler lines for 86 Monte Carlo?
  249. Water Pump outlet & heater fitting mods?
  250. lq4 auto/manual.
