View Full Version : Conversions & Swaps
- 2003 6.0l 4l80e into 95 Silverado Conversion Questions
- viper v10 swap
- 5.3/6.0 swap into 89 Suburban
- nissan 240sx (S14) with Modded GTO pan (tons of pics)
- Power steering reservor question
- 98 3 wire temp sensor connector
- GTO LS2 package in V6 Bird?
- It started!!!!
- 5.3l S10
- FS: Mock-Up block, heads, oil pan, etc.
- Pics of Fox Mustang and Chevy II conversions
- Ls1 conversion- power estimate?
- How Much Are Complete Engines Costing From the Junk Yards?
- 6.0L LQ4 with Denso A/C Compressor Question
- what's needed to fire my ls1 up?
- mounting PCM in a fox
- 2nd Time Conversion
- walbro fuel pump...
- Stock 2002 LS1 parts great for swap
- Aftermarket oil press guage fitting?
- LQ4 + Z31 Turbos
- LS1 + TSi=
- Dynoed my LS14. Running way rich...discussion on how to fix it.
- Japanese Car, American Muscle
- The LS1 mini cooper lives!!!!
- 2nd gen camaro conversion?
- Ohm range F-body fuel level sender
- 240sx manifold/header solutions
- ls1 clone ??
- ls1 in homebuilt aircraft!!!
- left bank lean
- LT1 to LS1 swap A/C question
- quick question about swaping t56
- Coolant Sensor Leaks
- "LS6 cam, how do i know?"
- GMPP front accessory kit part #?
- ls1 in 65 el camino
- Swap adapter plate pics
- ls1 motor/dash swap into lt1. Help please!!
- accessory questions
- lt1 conversion into a truck with a vortec
- The BADDEST Evo VIII on the planet
- LS1 swap fuel rail ? & part number
- just finished my custom intake
- Fast Intake with NW TB. what ECM is needed?
- LS2 or LS6?
- MAP low voltage ....
- newbie...with a ls1....but not in your typical car
- Is a ls2 gto oilpan the same as ls1 gto oil pan
- lt1 in 88 s10
- problem with new style GM fuel connectors
- New guy question
- LS1 swapped into an EVO!
- Motor mount plates
- LS1/First Gen Camaro Hooker motor adapter plates
- Which T56?
- LSX Fox
- Truck Manifold 1st Gen
- 6.0 L swap into a 97 tahoe 4x4 auto
- 93 Del sol ls1 swap
- Round 2 on my 87, Custom ehxaust, crossmember, installed cutout. LOTS OF PICS!!
- 95 Camaro V6 conversion to 99 LS1
- Trunk manifolds facing forward with C5 accessories?
- What year wiring is the best to convert???
- no spark/fuel
- Relocating A/C
- slave adapter...
- Brake question
- We are in trouble!!!!!!!
- Gas Gauge?
- LSx accessory bracket setups
- LS1 into 77 C3 windage tray question
- Who here has bought a donor car for the drivetrain?
- Questions about 5.3 carb in 89 Mustang
- scan my ride harness?
- Quiet exhaust suggestion
- MAF or not?
- 5.3 fuse box
- putting an LS2 into a 94 t/a question
- difference in exhaust manifolds
- My friends 87 Formula
- Project LS2
- Softer mounts for 240 swap
- Finally! Pics of my 5.3L 1950 Chevy truck
- External Fuel Pump Reccomendations
- Trans Mount
- 1967 RS Camaro LQX Swap and Resto Project
- TIP: LT1 Camaro fuel system mod for LS1 swap
- Bigdog's Wagon
- Ls6
- Anyone running a T5 behind their LS1????
- 66 malibu 5.3 finished
- LS1 kit car project
- LS1 swap into sn95 mustang...wiring question
- Transmission position indicator?
- ls2 in thirdgen Headers Questions???
- Need help with 240Z rack & pinion swap
- O2 sensors help with wiring them to engine wiring harness
- Wiring Diagrams and Connector diagrams 2004 GTO (my gift to ya'll)
- Automatic or 6-speed
- good info on Bosch O2 sensors, to determine which is yours.
- Need Parts For 69 Camaro LS1 Swap
- F-body Intake on LQ9
- Basic questions not shown above....
- rwd celica ls1?
- Troubleshooting - extremely rich running V8
- LS1 into 91 chevy truck
- HELP!!! ASAP!! how do i hook up a low voltage warning light to an ls1? sandrail swap.
- 700r4 kickdown kit
- Oil pressure sender help!!
- Gas Ohm to Electronic Guage?
- My Donor LS1 Has 95K Miles
- A/C Question for an S10
- 63 Impala 5.3l conversion
- Best Ls1 motor mounts for 67 camaro that offers optimal engine position
- need a pulley mount size on alt bracket
- stainless works headers with S&P mounts
- Drove my LQ4 powered 81Z this weekend.
- resistance reading on LS1 fuel level sender???
- Current Consumption
- 1st Gen F-body Converters inside please
- LT1 M6 to Truck LS Engine Conversion?
- Does anyone have a part# for WalbroGSS340 in tank pump for G-body elky??????
- Its Alive!!!!
- s-10 radiator
- Few pics of 55 with ls1 swap
- Intake swap
- Difference in camaro floors on automatic vs manual
- couple crappy vids of my notch......
- ls2 swap in third gen camaro
- Knock sensor plug different speartech harness??
- wiring help 66nova -04 GTO LS1 I have all the donor wires and boxes
- It's running again
- Help Problems Mounting LS1/240sx
- Using stock exhaust manifolds in my 69 camaro?
- truck intake to car intake for swap
- 6.0 Chevy
- Finally Alive .....
- Ls1 into 88 S10 questions.
- ls1 or ls2?
- 10 lbs of LS2 in a 5 lb BMW - 56k forget it
- 2002 5.3L Throttle Control system delete?
- 2002 LQ4 harness on a 05 LS2
- 1994 gmc v6 swap to v8
- Ls2 vacuum informated needed
- '02 ls1 in '71 Chevelle....I need some guidance
- my transmission is leaking from what looks like a T fitting
- Schoenfeld headers on '71 Chevelle?
- 67 camaro wiring
- Engine Temperature? Can this be right?
- What fan for ls1 wiring harness?
- Updated pics from BMW Z3 conversion project
- Fast intake and NW 90mm, what else do i need?
- 5.3 harness
- 07 Z06 brakes for sale
- LS1 swap in 1990 silverado?
- Pin outs and wiring for different OS/PCMs?
- LS conversion for D-Body Cadillac Coupe DeVille
- Which LSx models and years come with close ratio tranny and conventional throttle?
- 2004 corvette motor help
- 95 A4 bolting to a 2000 LS1?
- how hot does ls1 get till fans go on, i need rad. hose advice too
- s10 guys need a harness have new currnet performance harness cheap
- Fitting 2000 Z28 interior into a 70 Chevelle El Camino
- ABS fault = UK MOT failure
- Ever heard of this ebay seller?
- corvette filter and reg
- cheap LS1 hybrid car for sale
- remote oil filter kit
- Ls1/Ls6 engine swap motor mounts 55.99!
- LS1 in a silverado???
- L82 swap
- Truck tb to ls1 intake?'s
- Map Sensor/Brake Booster Relocator?
- Chevelle LS1 swap headers in a G-body?
- LS1 from ebay? into a genII camaro? your knowledge pls
- how about some sticky/folders for each popular swap?
- Will a 6.0 auto harness work on 5.7/6speed?
- Jeep wrangler ls1 start up video!
- Temp sensor - can I tap the threads in the head?
- 6.0 in el camino/g-body swap
- New motor in an F-body, best way to go?
- C5/C6 Rear End Conversions?
- heater core coolant flow?
- starter trouble, which stud is +?
- i need some info
- v8 tj conversion started...
- What timing pill in my edel 7118 box?
- People really do put LSx's in EVERYTHING!
- Interesting LS1 Engine compartments
- electronic throttle quit working
- Anyone in Phoenix?
- No Spark!
- started ls1 in blackwidow for 1st time
- Driveshafts? What are you using?
- 4.8,5.3,6.0?
- 1971 Chevelle Twin Turbo (pics)
- BACKWARDS!! Lt1 into an LS1!
- headers
- ETC Throttle Body, Pedal and TAC on EBay
- Welding oil pan on the block
- stupiest question on this forum....
- Cruise control in a conversion?
- LSx/th350-400 flexplate questions
- S14 240sx to LS1 Wiring
- S10 lower hose w 4.3 radiator
- Pics of my swap
- wiring up the ls1 starter?
- Ls7 oil line routing
- Anyone need the GTO pan?
- 81 C-10 LS1 swap
- help! autometer temp reads way off!!!!
- LS1 fuel pressure
- LQ9 conversion
- Fuel pressure build up on input at rail???HELP????
- I am the proud owner as of today of a 2000 LS1/t56 WS6 Trans Am!
- ls1 /4runner
- finishing 5.3 into '71 need help
- CARB. LS1 Is a 95 S-10, anyone Done it?
- wierd question
- 1st Post-Bought LS1 Today
- Pan Dimensions!!
- radiator hoses in 1st gen
- What steps to part out a car for ls1 drivetrain
- LS1 engine and T56 tranny in 87 El Camino
- 2nd gen
- Completed E36 GMW.. 1993 357is
- DOD with a stick
- 4L80E woes
- Running Right
- For Sale : '91 LS1 Mustang Coupe <-------
- Think these might be good headers for a conversion?
- Corvette vs. GTO front accessories
- Hooker mounts....Alternator clearance issues
- Will I be throwing CELs?
- Part numbers for fuel system
- mustang chassis wiring help
- $1200 a good deal on a clean RUNNING 89' FC RX7 GTU 13b-5speed??? Has 104,000 miles
- My LS1 swap is COMPLETE...well..almost
- Speartech question
- the best place to buy a 6 speed(t56)?
- Remove voltage regulator + wiring (1970 ElCamino)
- Plugging Oil Pressure Switch
- 1st gen header question
- LS1 Plug wires with headers....
- My 383 Chev powered Holden Torana
- Mazda RX7/350
- Ls1/chevelle Turbo mount question.
- Video of my LS1 swaped 240SX (aka 346SX) 0-60-0 Runs
- Another 3rd gen camaro LS1 swap
