PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Circuit 439
  2. JCG 68 Camaro
  3. Removing Harness from 2005 GTO
  4. VSS 4L80E 4WD Question, Which One?
  5. Transmission Wire Questions
  6. Need some help.
  7. abs delete????
  8. your 2 cents please
  9. 62 Impala LSX Headers.. Need Help
  10. Corvette exh manifolds in a 67 Camaro?
  11. will this work
  12. f body dash in g body
  13. 67 Camaro LS1 Rear Brakes
  14. 4l60e wiring help
  15. 99 tahoe 4l60e tranny swap questions
  16. 5.3L Cam shopping!
  17. GM retro-fit oil pan ....
  18. Need wiring help 240Z + 2006 GTO LS2/T56
  19. Engine harness ?'s 5.3
  20. Well Guys im Back
  21. Jegs LS conversion kits???
  22. need some advice? changing over a 95 bird into a 2001 t/a
  23. 66 chevelle 6.2/6l80
  24. Quiet Exhaust Suggestions
  25. 88 Silverado LM7 swap, questions
  26. 77 trans am LS1 swap or not?
  27. Best place for custom harnesses
  28. '68 Lemans Turbo build
  29. Stock A/C system from a 98 camaro into a 69 is it possible??
  30. 94 Mustang 5.3L TH350 Swap
  31. LS2 Miata need help with the ignition
  32. 84 camaro?
  33. 5.3 VS 6.0 in 81 Trans Am, which is better?
  34. flywheel spacer
  35. DBW pedal mod
  36. 6.0L & T56 install ?--need slave cylinder bolt size and flywheel dust cover soln
  37. 72 firebird ls1 conversion
  38. Wiring, wiring, wiring......
  39. LS Engine Hardware
  40. Starter Help
  41. Buzzer comes on when I hit the brakes and seat belt light won't go off?
  42. VSS and Low Oil Level Switch Delete Question
  43. 5.3L Vortec into an 86 Chevy K10
  44. ls swap in a 91 firebird
  45. lQ4 install into mustang ii crossmember header/steering shaft fitment
  46. 84 cutlass gauge cluster swap????
  47. Question about transmission cooling lines
  48. 74 chevelle/malibu all aluminum 5.3 swap
  49. 84 Corvette 5.3 build
  50. Ls1 swap
  51. My build PICS, 1990 300zx LS1/T56
  52. 96 ss soon to be 408/t56
  53. Flywheel Issues?
  54. Oil pan help
  55. Another 6.0 Fox Body
  56. EZwire universal chassis harness??
  57. 12v hot in run/crank
  58. Gbody fuel tank and sytem for ls1 swap
  59. 84 Monte 5.3 Build
  60. LQ4 Engine Harness Identification and Wiring Diagram Request
  61. 443 LS 67 Chevy II Wagon update - Holley Hi Ram
  62. 2500 transplant
  63. What OBD2 Port To Get
  64. JIC vs AN Fuel Fittings
  65. Front O2 Sensor Question
  66. Chevelle 4.8 Turbo
  67. Oldmobile motor mount question
  68. Vibration!!!!!
  69. Need Wiring digram or pin out for instrument cluster '99 TA
  70. Racetronix/Walbro pump kit for impala tank in A-body--problem installing
  71. LS2 alternator
  72. Delphi oxygen sensor connector
  73. 86 cutlass harness question
  74. EFI tanks lose/lose situation
  75. 84 notch 5.3 th350 build
  76. Truck wiring on a LS1
  77. daily street driven nova
  78. Need help adding TPS & IAC to harness
  79. Quick vids of my ls1 Lexus SC300
  80. Ebay Harness
  81. E40 pcm
  82. LS1/4L80E tuning?
  83. vertical mounted tb
  84. Twin Screwed No More! - Re birth of an Mz3
  85. Fixed and variable displacement A/C compressors
  86. Merry christmas!!!!
  87. 70 Pontiac A Body, will these mounts work?
  88. 05 gto/ls2 ??
  89. 1972 240z Blown Hybrid
  90. DIY Stand-alone LS1 Harness Video
  91. Tach on ls engine?
  92. ls3 cams 3bolt,1bolt
  93. Intake build ?
  94. Ls1/ TH400 swap 93 5.0, need some insight
  95. LQ4 idenification
  96. 1970 Vista Cruiser / LQ9 / 4L60E
  97. fuel pump pcm signal
  98. Ls3-tci 6x e39 528 (pic heavy!!)
  99. Low Profile 102mm throttle body (no IAC, no air fitting... bare with just TPS)
  100. O2 sensor plug and wiring quetion
  101. dont know where to post....5.3 vs ls1
  102. Oil Filter doesn't fit!
  103. Making A/C operational without PCM???
  104. 5.3l swap
  105. going from 58x4x to 24x1x
  106. 6.0 LQ9 into a foxbody
  107. My Lokar Dipstick Doesn't Work!
  108. Corvette reg/filter
  109. External FI pump for a regular gas tank?
  110. Sumped tank for FI
  111. Project: Stang' Bang: New Edge Turbo Build... class? Track?
  112. G-body swap
  113. shorty headers
  114. 1965 C 10 Headers
  115. Custom LS wire harness
  116. 04 GTO harness,pin out for fans
  117. need help with foxbody swap
  118. LS2 manifolds
  119. Has anyone used the GM retro fit oil pan?
  120. Need help locating pinouts charts
  121. Question about reverse lockout
  122. Help on my LQ4 accessories & intake stuff (multiple questions)
  123. LS1 Blows up, go back to ls1 or upgrade?
  124. Dipstick and tube length
  125. 3800 S/c swap
  126. corvette balancer on 5.3?
  127. 91 camaro MS4 cam and PRC heads install
  128. ls1 into 89 mustang
  129. ls1 s10
  130. Truck harness in an A-body, ecm/fuse box location
  131. Lashway Motorsports project X-Raided - check it out!
  132. Garage Built AWD Camaro
  133. Using my 0bd2 wire harness/pcm for a sbc 400 yay or nay and why!!
  134. Need help identifying this plug
  135. Engine harness compatability
  136. F-Body Pan
  137. T56 crossmember modifications for a 69 C3
  138. 98' F-Body fan install
  139. New conversion project, need all the help I can get
  140. no power to my fuel pump
  141. Oxygen sensors- I'm going INSANE
  142. Intake piping
  143. Clutch Pedal Stops for T56 Install?
  144. Exhaust and Gasket questions
  145. New on ls1 world!!
  146. sbc 400 help!!
  147. finally started ls swap 78 bu
  148. 1969 Nova L33 swap
  149. airbrain question of the day!
  150. 4l60e shifter help
  151. Need someone to verify brake switch wiring please
  152. LS1 into 1987 Firebird wiring info.
  153. DBW or DBC Help
  154. Mast oil pan
  155. LS6/T-56 swap: '71 El Camino
  156. 4l80 to 4l60 harness
  157. Help, I need a DBW pedal connector
  158. getting ready to start a ls conversion in a 63 nova
  159. Which side is the pressure side on the gearbox? 11/16 fitting or 5/8?
  160. How to Mod Turck MAF, to get IAT???
  161. Keep getting P0507 code
  162. LQ9 Wire Harness Help Please
  163. Turbo 4.8 LSx SC300 - 509rwhp @ 12psi
  164. 1991 Supra Turbo
  165. Removal of wiring harness from 05 GTO
  166. LS2 into 70 Lemans Air Con Questions
  167. GM A-body trans crossmember, flip??
  168. Truck Intake to a LS1/LS6 Intake - w/o changing all the pulleys/pumps?
  169. Route 66 Motorsports EFI fuel tank.
  170. 5.3 in a 78 benz??
  171. Anyone ever do a Landrover Discovery Conversion?
  172. Conversion and stock guages
  173. drive by wire questions?
  174. 4th gen firebird headlight control module
  175. 2001 lq4 fuel line questions
  176. Options for an Aluminum block if already have 4.125 stroke crank and want 4.030 bore
  177. Need accessory part IDed ASAP!
  178. my 98 v6 camaro
  179. Tach signal using 5V Ref and 10k resistor???
  180. Rock Valley Stainless Tank LS
  181. ls3 t56 swap 72 nova clutch pedal question
  182. Need some help DBW to DBC swap, and choosing a harness for my 2009 5.3 swap
  183. 00 5.7 4l60e behind 00 5.3
  184. universal exhaust hangers/mounts?
  185. Aje lsx mustang mounts - Flip them?
  186. Front ride height going from all iron to aluminum motor
  187. GF822 fitting size
  188. carb conversion kit
  189. Paddle Shifter Options?
  190. Cam Options Cutlass 6.0 Swap Questions
  191. chevette???
  192. Missing anything?
  193. gmc s15 lq4 swap
  194. 5.3 will not run part 2
  195. how to remove (external) snap rings on the Slip Yoke without damaging them?
  196. List of questions: 69 A-body Brake conversion
  197. c6 corvette swap ?
  198. adapter for a t56 to old style speedo
  199. Gen III Electronic Pedal on a Gen IV?
  200. Ls7 exhaust manifolds modified to fit narrow chassis
  201. LS1/4l60E 67 Pontiac Tempest
  202. Keep the DBW or convert to DBC?
  203. Time to de-pin my swap
  204. Ls harness questions
  205. all performing 5.3/4l60e
  206. 3rd Gen Camaro LSX swap LOTS OF PIX(going to take a little bit)
  207. 1950/2001 chevy truck
  208. What Tranny Fittings?
  209. 1970 GTO LS1/4L60e Swap Check List - Do I Have Everything Covered??
  210. Need help with my Trans Am
  211. Getting Cruse Control to work with a 6L80/L92
  212. 1982 Corvette??
  213. SN95 LS Swap Headers
  214. wiring tachometer
  215. Which race harness for LS7 and AEM Series 2 ECU?
  216. Quick-Mod on how to mount a 11" Brake Booster into a LQ4 A-Body
  217. 98-02 Camaro Motor Mount Bolts
  218. Project 600zilla - LS2+T56 350z swap
  219. Has anyone used the factory center console gauges on a 69 Camaro conversion?
  220. Grinding ribs on a GTO oil pan for clearance???
  221. ls-1 oil sending unit cinverision
  222. is it possible???
  223. Wrx
  224. Psi website updated!!!!!
  225. 2010 Camaro Exhaust Manifolds
  226. looking for fuse box wiring diagram for 99 z28
  227. Need some input
  228. LS1/T56 in third gen
  229. ly6 engine start/run wiring
  230. another Lsx mustang
  231. LS starter fitment to BB Bellhousing
  232. ls1 miata race car build.
  233. Dynatech LSx Mustang swap headers
  234. 1988 chev pickup speedometer
  235. ls1 s10
  236. 6.0 In 71 Chevelle, Pulley Q's
  237. 97 ls swap have some questions
  238. Wiring LSX!!! how-to VIDEO INSIDE!!!<----
  239. Need help with harness
  240. Ctsv 6 spd auto help
  241. Advice needed.installing vvt ly6 6l80 in a hot rod.
  242. 5.3 or 4.8? cant tell
  243. Wich headers for LS1 BMW conversion ?
  244. 1998 LS1 C230 pin H? Th350 ??? to.
  245. What model LSX (size & year) is best for a BBody.
  246. LS1 / T56 DD e28 BMW Build
  247. conversion question
  248. Working on my wiring harness I have a couple of questions.
  249. Danny's Miata. Self Built Badassery
  250. Want to build a LS notchback...where do i start?
