View Full Version : Conversions & Swaps
- anybody done a LQ9 or similar into a 1st gen camaro or bird
- 6.0&4l80e into 82 ton 4x4 chev truck?
- converting LS6 58x to LS2 24x
- 88 camaro ls1 need advice
- Need some direction: Electrical gurus
- 1988 mustang 5.3 ls TH400 swap
- mustang swap headers?
- Loss of Fuel pressure after 5.3 to 6.0 swap in my Blazer
- F body Instrument cluster hook up.
- OBD2 Diagnostic Plug
- What is a ls1 with a t56 worth?
- *X*X*X*X* Carb conversion section *X*X*X*X*
- 24x LS2 harness questions.
- 62-67 Chevy 2 Kits (Starting Mock-Up)
- 1968 Firebird, LQ4, TH350, Driveshaft Question
- Exhaust Flange help
- LSX 454 and a 6L90 in a 72 k5 blazer?
- 72' nova ls1/4l60e swap
- Need advice: Junkyard scammers
- fixing to test waters
- Wire loom and techflex
- 4th gen headers in a 3rd gen?
- upcoming 6.0 lsx chevy 2 swap have q's
- Best Holley rebuild kits -opinions
- '70 Nova LY6/TH400 6.0VVT
- LSX into foxbody?
- question on 5.3
- TKO 5 speed w/ ls1
- connector id help
- need help with duramax diesel question
- A few swap questions, steam vent, evap canister, shifter relocation.
- Question for 6.0 swap in a 86 Chevy Pickup !!Help!!
- oil pressure sending unit
- changing compressor back on my sanden sd5h14
- LQ4 damper puller
- Couple LSx/T56 2nd Gen Camaro Install Questions
- hp on a iron block 5.3 with ls2 heads and stock ls2 cam???
- Ls swapped IRS cars..... whats your best 60 fts?
- Replacing an L31 with an LS1 in a 99 Suburban?
- L92 wiring starter - first startup
- 1963 impala/ trailblazer ss rear end swap
- pcm tuning
- lsx header options for 1st gen
- Power Steering Reservoir hitting
- ls1 in 68 firebird
- kit for LS3 swap into 67 GM A body?
- Ebay harness recommendation
- For all the Mustang swap guys, Dynatech has GREAT customer service.
- No IAT wiring?
- Anyone have a part number or have an extra IAC pigtail?
- 1995 240sx LS1....so close need help.
- 85 c10 header?
- Swap Gurus, help me figure out what ECM I need
- donor Car wont crank 2004 Pontiac GTO
- Removing harness wires from leads L92
- What motor mount? 69 camaro
- For those of you that want to use the truck acc. with car intakes
- question: 700R4 connector on Belair w/327
- Is there such a thing as too much a/c Compressor?
- TVR Cerbera ls1/t56
- fuel pump?
- Anyone know what pins are used on ls1 coilpack connector
- 72 nova front springs
- LSX Power Steering Pump in a '70' Chevelle
- LS1 in a 93 camaro
- Need help with trouble codes
- Custom steering linkage? Who's done it?
- factory gauges
- Lil Red Riding Hood 91 s10
- Looking for VSS Pics in 4x4 4L60E setups.
- 79 T/A to LS1/A4
- ls1 240sx swap and ca state reff?
- G-body Wire Harness
- 5.3/T56 swap, S10 or Colorado?
- Carbed LS swaps...
- Need headers for ls1 transplant in a e34 bmw
- How much power can the stock LQ4 handle?
- corvette donor car for 69' Camaro! need help.
- Noob 6.0L question
- completely lost on the s10 ls swap
- Chevelle temp gauge help
- Foxbody Swap, need a little help.
- 425rwhp goal, budget build: LQ4/5.3? LT1?!
- Need help, putting sbc 350 in a bmw e34 wagon
- Will 17" wheels fit a 2006 GTO that had 18"
- Trans am/Firebird Swap
- 2005 ls1 wiring
- Pulling my hair out
- 95 tbi tahoe lsx conversion
- 68 c-10 5.3 and th400 build
- LS1 cam kit
- racepaq UDX dash water temp issue
- Cant get engine running DTC1336
- Just install axel ratio. What is the period training?
- Getting parts together for my c4 LQ9 swap, what to use?
- MAF/intake trouble
- ls oilpan question
- Possible to mate LS flange to small block chevy headers?
- 1979 trans am to ls1/t56
- mustang ls1 swap with t56 6speed parts
- pics from 2010 ACD festival
- Need bigger injectors for truck intake
- 1991 S10 LQ4 Project
- oil pressure gauge
- Holden One Tonner / C5 ZO6 drivetrain
- A few LS1 swap questions
- DBW Cruise control - No worky!
- painiting radiators
- Braided Throttle cable housing
- A/C and Maggie...what compressor brackets work
- 400+hp out of a 5.3 is it possible???
- questions on conversion from 01 firbird v6 car to ls1
- solid motor mounts ls1 to 89 camaro?
- Good cam for drag racing ls1
- Kooks headers in 2nd gen F-body?
- ls1 swap in 89 camaro headers?
- 84 C10 short/wide 5.3 install
- Question about 99 6.0L pistons
- different coil types
- Power steering with hydroboost cap off.
- LS1 or 6.0L Iron block Camaro
- Has anyone seen a LS1 swap into the new body Mustangs?
- Hooker versus Edelbrock LS Conversion Header Kits Camaro
- Temp sensor?
- LS6 Carb Conversion
- Please help me with building fuel system for Mustang LSx Swap (Pictures Inside)
- Jeep CJ7 Body on a C4 Chassis powered by LR4
- factory ls2 gto headers on a g-body?????
- Questions on LS swap
- Replacing GMPP computer
- 5.3 t-5 will it work
- 1966 GTO / lq9-T56 Wiring issue
- 5300 center dump headers
- Finally have the gauges for my 67 swap!
- LTX to LSX
- wiring help!
- Another Mustang gets a Heartbeat
- Is the LS/4L80E similar in size to Chrysler 318/727?
- what fuel line would you use?
- 92 chevy swap
- Want to drop an LS1 into my Foxbody
- LSx swap on a budget.....possible?
- radiator hoses
- 98 trans am ls1/ls2 swap, auto/t56 swap
- PICS!!!!The LQ4 Twin-Turbo Aerocharger is here!!!!
- Crankcase ventilation
- LS1 swap ideas
- 1966 Nova 6.0 7.12 @95 mph ***NOS UPDATE***
- Another fan/relay wiring question
- need help , lsx into a 93 z28 $estimate
- Blowthrough 6.0 FOX
- what wiring harness to use?
- LS1 and 200-4r to L92 / T56 in 71 Chevelle convertible...now Gen V LT1 6L80e swapping
- Edelbrock Carb Intake Q:
- 2004 gto motor modding help
- any s10 4x4 ls swaps out there, please post
- What is this?
- mustang forums.
- lq9 cam recomendations
- first gen camaro/firebird lsx headers
- PCM short circuit?!
- LS1 cam
- Just a couple ?s on 91 s10 with ls1 swap
- Idea
- Pull engine + trans or engine only
- I'm swapping an LQ4 & 4L80E into an '84 Monte SS & need help
- E39 BMW 540 LS Swap Completed
- DBW pedal in Nova
- grey wire truck alternator
- TRex in LSX
- new caddialac blown motor will it fit a F-body
- LQ9 and T56 in my 67 firebird
- LS1 Brake Dimensions
- Noob here!! Need help pls
- FYI Harness Sale $349.99
- My LS1 Jaguar XJ6 runs!
- Checklist for Purchasing a Donor Engine
- fox 83 whit 6.0 questions
- Carb'ed guys with sumped tanks and external fuel pumps...
- Trailblazer SS
- Anyone in Texas to have do a swap?
- 5.3 alt plug
- Looking for online Air Filter Catalogue with Specs
- LSx to SN-95 advise needed
- Block Heater plug?
- competition rock crawler(jeep) buggy - need cam vs torque converter advice on 4.8L
- G body with TKO?
- New guy, new project
- setting engine angle
- Project "Homegrown" -65 Nova LS2 and KB s/c-
- A body tie rod clearance?
- Help FAST!! please
- lt1 and ls1 radiator difference (transmission line)
- ls 6.0 help
- Starter Question
- Where is everybody mounting the PCM on First Gens?
- Noob needs help locating VIN
- my dyno numbers, sheet and video inside *Now with 10 bolt carnage*
- Swap - starts and dies 3 seconds afterwards
- LS1 Jeep TJ headers
- Temp sensor question; ohms, and thread pitch.
- 69 camaro ls swap oil pan trouble
- Conversion guys, did you buy a wreck to pull from or piece it together?
- Anyone have dimensions of the stock clamshell mounts?
- Another noob from so.cal
- lq9 belt driven accessories
- What tranny bolts to a 5.3 Impala engine?
- Not getting full throttle with pedal on DBC
- Chevy II build 6.0 gto
- Chevelle almost complete
- updated pics of my 84 z28 LSx swap #2
- 90 ls lx convertable
- Do I need a fuel pump inertia switch?
- converting r-12 to 134
- Radiator hoses for L92 part number
- 95% done with 96 mustang ls1 swap....few questions. ...PLEASE HELP
- 5.7 iron block build advice
- LS swap on a budget questions
- WTB: Need some DOD/AFM lifters
- MAF sensor wiring
- Project esCamaro
- VATS module
- 1st gen mustang: build thread!
- Anyone ran into this problem w/th350 sbc converter and LQ9 Flexplate?
- LSX swap into a 1964 Chevelle L98 4L70e
- F Body Exhaust Manifold flanges
- 5.3L in a 1941 Art Deco GMC Truck
- Well she is done and heres the video
- Spectra gas tank pump failure?
- Voltage?
- New CA smog law. Bad news!
- which o2 sensors?
- Truck Alternator Wiring (Yes, I've searched!)
- ECM differences
- sound clip from my LS6 kit car
- Been a long time...
- Alternator Issues
- dumb question: can i rotate the stock fuel rails?
- steering box / alternator clearance issues in a g-body
- 2000 ls1 A4 harness to M6 ?
- Coolant Flow Direction
- Heater Hose block it off or not
- Bypass Type Heater Valve
- Pics of Trans Tunnel Cuts for T56
- SCT SF3 Power Flash Hand Held Tuner # 3416V
- Alternator wiring question
- What does the "charge indicator control" wire do? (connects to alternator)
- AC not blowing cold, compressor engaged not cycling
- shorting sump on my 5.3 pan..can it be done????
