View Full Version : Conversions & Swaps
- Camaro Firebird combination. Is this the right thread?
- 1995 v6 3.5l to 2004 silverado 5.3l motor swap fuse box wiring
- question about installing donor fuel bucket
- 97LT1 to LSX Conversion???
- Starter question
- Gen V 8L90 connector issues
- LS3 swap
- V6 to V8
- Pin14 and 48 in 2011 E38
- Noisy valve train
- E30 ls1 swap autocross and road (tail of the dragon type) need help on which engine
- GenV swap without FPCM
- Pinout help
- 1965 Lemans Gets Booosted
- 1965 Lemans Gets Booooosted
- 2004 mustang 6.0 build
- HELP - '99 LS1 No crank No start - MAF problem?
- Msd6014 no start
- 03 yukon denali swap
- Sensor ?
- 72 T/A engine swap idea
- Gen III PCM Run Gen IV Gauges
- Clutch questions
- Hand throttle possible?
- 70 challenger swap??
- Piece together or complete
- 98 Camaro to an 01 Harness question
- 79' C-10 BigTen Buld
- Gen V swap DBW pedal issues
- LS Headers on Blazer K5 4X4 Frame
- Help with starter and alternator wiring (LS Foxbody)
- Does anyone have a good way to add a reluctor ring....
- new here. Dakota digital tach signal / alt wiring
- LS3 Need help with connections
- 6L80 tuning
- transmission wiring
- O2 wiring question
- key hot wire issues
- LR4/4.8 v8
- PCV Sucking Oil Filling Catch Can
- Crusin the Coast didn’t go as planned
- high idle lq4 swap s10
- LS Swap into Isuzu Amigo? Thread Title Change...with exploded motor!
- Gen V ignition wiring
- 1996 Impala SS LSX/LSA 15 year build LOL
- Speartech E67 ECM and Cruise Control
- 1960-66 Chevy/GMC 4x4 LS Swaps?
- Gen 5 with a carb........
- LS and RWD swapping my Beretta
- '73 Chevelle SS 5.3L Swap
- Ls sway
- O2 issues
- Battery Voltage Fluctuation when cranking
- EVAP Connections
- VATS (pass key) Bypass
- 1964 corvette coupe LS1/T56; Project Queenie
- Bad, bad noises (videos)
- 1977 Nova Swap
- 1999 m3 ls1 t56- cruise control question
- How do you run cruise with an E38
- BMW E36 M3- LS1 - AC Thread (finally did it)
- Dirty Dingo Motor Mounts
- OBD Splitter Harness
- Cooling the beast
- Ls7 in 69 camaro
- Chevelle alternator hood clearance
- TCC wiring
- No spark, no injector pulse. Help needed
- Newbie - Swap Issues
- 2003 LM7 valve cover bolt question.
- Help rekeying a GM ignition lock
- Firebird Ls1 swap
- Lowest profile accessory setup?
- 2006 gto ls2 swap
- LQ4 intake to fit a gen 2 Camaro
- What Term X PN / injector style
- Gen V tuning
- 1970 LS2 Chevelle Restomod Is the Whole Package
- Gibson MWA dual muffler
- 1968 Camaro 350 4-spd to LS (LQ4) TKO600 5-spd Swap
- PWM recommendations
- E38 ECM and cruise control
- I'm not sure which part of forum to list an item
- My 300zx to LSx Build
- 98 LS1 cranks but won’t fire- worked fine before
- LS3 Mass air flow sensor
- LS Swap
- D(?) Body Fleetwood LS Swap
- Fbody radiator Fox mustang.
- LS-Powered 1972 Chevelle is an Ominous-Looking Creation
- Pinout for 88 chevy c1500
- Moving to Colorado - Engine Swap
- 4L75e pan with side drain?
- fuel pressure question
- Transmission range selector
- Need help
- ‘21 trail boss 4.3
- CD009 Slave Cylinder Shim
- IROC Z Camaro Gets New Life With LS3 Transplant
- 5.3 to ls2 intake manifold
- 72 Blazer 5.7 T56 swap
- Fox Swap - Which Mounts Do I Need?
- Alternator getting REALLY hot...
- LS swap Throttle problems
- My Vibration Saga Continues.... New Driveshaft?
- Oil Pan Question
- E38 DBC for Boat
- Converting Auto Harness to TKO-600
- Hp and track time estimate. 88 foxbody
- Gen V L86 swap no start
- Needing some details
- New to swapping, need help
- Strange vibrations
- 1992 Buick Roadmaster Questions
- Rad hoses for LQ4 swap
- CRANKED FOR FIRST TIME TONIGHT! VIDEO Included. Now a ?
- 86 Fox wiring.
- ls swap in obs in austin
- Help needed - EVAP system causing high idle
- Heater bypass block
- 1938 Oldsmobile business coupe with a lq4
- 5.3 Swap Into 95 Camaro Z28
- Chevelle transplant
- 2002 LS1 fan wiring for single fan
- Overheating on LQ-9 Swap
- LS based V16
- 08 ly6/4l60e conversion help dipsticks oil and trans
- Poweer to ECU
- Why no Mercedes swap kits?
- 2011 l99 6l80 swap no spark
- Tremec tr-4050
- Mazda RX8 LS Swap Steering Rack Choices?
- Crazy idea but.. ..Hydrogen Powered LS3?
- no prep/street build
- 70 Chevelle LS swap on a college budget
- GM A Body T56 master cylinder / hydroboost bracket
- 2003 Mustang Cobra Build (Turbo/Powerglide, PIC HEAVY)
- Newedge Mustang LS Swap A/C Control?
- 86 C10 LS 5 speed fun driver
- 84 Olds delta 6.2L twin GT35 holley term X 80e
- Ignition coil harness
- New TKX 5speed to a lq4
- LM4 Swapped 260z Shaking Under Part Throttle
- 72 chevelle ls1 swap , what accessories kit?
- 4l80 going rate?
- 1957 Chevy
- Crank 5.3 88 foxbody wiring “for dummies”
- Any idea on what I need to do?
- 6.0 swap
- Holley terminator x problems. Please help
- Cooling system advice needed - LQ4 swap
- LS7 Swapped Pro Touring Corvette C3
- LS6 5.3 vacuum ports and routing.
- Swap Emissions
- LS151 Build thread from the beginning til current
- Vats question
- Starter hitting flex plate
- Were Holley LS swap parts always
- 1200hp AWHP TT IRS 2nd Gen Sonoma weird ideas.
- DBW gas pedal
- Drive Junky vs Wegner serpentine drive for LS1...
- 1981 Mercury Capri L33 T56 swap
- Dual Fans Don’t Run
- 1982 Isuzu i-mark
- Throttle body selection help
- LQ4 4l80 swap wont start, looking for help
- Radiator hoses
- Help and Thanks
- 1968 Chevelle LS swap Wizard Cooling radiator install
- 2000 pcm compatibility with 04 engine
- What wire to use for engine harness?
- Ls3, '04 gto t56
- 6L-90 Crossmembrer
- MAP location
- Need help diagnosing o2 issues
- 97 Fbody LQ9 Conversion
- This 1957 Cameo Restomod is Rocking an LS3
- oil leak after installing rear main-while parked
- LS1 into 1999 v6 Mustang
- LT1 to lq4
- LT1 to lq4
- Almost ready to crank. Closer and closer.
- Anyone get their new Holley Terminator Xmax recently?
- LS swap harness/pcm question
- Alternator diodes keep blowing? Alternator is Pulling amps, killing battery
- Cold air intake on my 1967 Chevelle
- 70 PSI High Fuel Pressure Dilemma
- Have some Turbo/LS Intake/HP questions
- T56 Alternative
- 2010-2015 Camaro LS3 in 63 Nova
- Fuel Check valve location
- Gen 3 to gen4 conversion kit corvette c6
- E38 ECU to LS1
- C5 Filter/Regulator leak at outlet...
- 4L60E - torque converter wont seat
- Variable Output AC Compressor
- I am swapping an ls1 into a honda fit
- LM7 Cam choice + Power Brakes.
- Build your own oil pan?
- TR6060 - 1350 Adapters - Malex Vs. Sonnax
- E38 single fan control
- Non-Hydroboost Power Steering Pump
- Ls swap issue, dtc P1689
- 73 Cuda LS Swap
- A-Body Master Cylinder upgrade/ update?
- thermostat question
- 1962 LS7 Swapped C1RS Restomod is Too Cool
- what OEM k member will swap . MY HEAD IS GOING TO EXPLODE !!!!
- My Turbo LS Third Gen
- 4.3 to 5.3 problems
- LR4 serial number location
- Ls3 in fbody wiring harness
- SLOVA (Formally NoLove, Still "GAPPLESAUCE LM7" Powered)
- 5.3 swap fox, AJE k member, speed engineering headers, x pipe question.
- 1960 Cadillac LS swap, questions !
- Alternator questions
- L92 to lq4 with 6l80 swap questions
- Any Low Mount AC that runs on the Main Accessory Drive?
- Engine swaps - what power steering fluid did you use?
- Will an LS still get spark with no injectors plugged in?
- Electric fan wiring
- Benz 190E LS1 / T56 swap
- 1979 Malibu LS swap radiator question
- LS3 card style MAF DTC P0102 low volume
- Where to run key on 12 volt power 68 chevelle?
- LS1 swap -- engine starts then immediately dies.
- Ls4 swaped jetta se
- BMW E46 Ly6 swap, headers question.
- 5.3 LS swap O2 sensors
- LS3 swap into C2 Corvette ... popping/backfiring
- Electric Fan Issues On LS Swap
- '02 SN95 instrument panel options
- Keith's 65 Impala LS upgrade
- 72 Elco 5.3 swap, P0151 when towing a camper?
- Green/blue connector harness with factory DBC
- 1968 camaro, what motor to go with ls1 ls2 ls3?
- Dakota Digital module mounting
- LT1 to a Ls3 swap
- My first ls swap
- First ls swap
- Wire brake switch for 4l60e
- 02 LQ9 Engine Drive By Wire To Cable
- O2 Sensor out...OK to Drive?
- LS to Th400 adapter and flange built on torque converter.
- 1,210 Horsepower LS Swapped Porsche Cayman!
- Map throwing P0641 and no start
- 4l80 into typhoon with 6.0 swap with stock 700r4
- Plug wire question
- First time LS swap
- 94 Yukon 5.3 4x4
