PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. 4L60E auto shifter options
  2. Factory Five GTM..
  3. Walbro intank noisy??
  4. survey: engine cooling system
  5. 4l60e into 68-72 gm A-body shifter linkage
  6. 1964 Chevy Covette LS1/Turbo "PICS"
  7. LS1 1995 GMC 1500 conversion
  8. Aluminum Fittings on Stainless fuel line?
  9. Help! LS conversion won't start!
  10. Thinking about buying my buddies caprice and doing a swap?
  11. vendor help
  12. Stand Alone Wire Harness
  13. fuse/relay box used on LSx swap with stock harness
  14. questions on swaping 6.0 and 4l80e into v6 firebird
  15. took my swapped cutlass to the track
  16. LS seies engine/tranny source
  17. Newbie O2's wont read
  18. Jag to gto conversion
  19. Possible Alternator Problem??
  20. I tried search.... 5.3 in K5 questions.
  21. LSX 376 or 454
  22. Finishing up my 98 firebird v6 to 2000 LS1 swap
  23. tb heating hose solution
  24. 48 Chvy Truck 53L - vid
  25. Anyone got a Dakota Digital SGI-5?
  26. almost ready to roll
  27. megasquirt questions
  28. Using PowerGrip hose clamps with fuel line
  29. Ls1 sn95 with 4l60e shifter question
  30. Alternator Wire Gauge?
  31. FS: Edelbrock A-Body Adapter plates
  32. LS3/4L65E Swap into '67 Chevelle Completed!
  33. auto shifter connection
  34. O2 sensor question
  35. exhaust manifolds for 91 rx7 5.3 swap
  36. conversion kit
  37. LSX 1970 Chevelle Conversion
  38. starting build... ls1 c-10
  39. 1991 SBC fox speedo question
  40. GMPP ls2 engine controller, case learn ?
  41. Quick wiring question
  42. L92 needs smaller 2 wire alt
  43. 1st try at rod build '41 Willys/5.3L LM7
  44. Swageloks long term?
  45. Help! I need radiator hoses for 65 Chevelle...
  46. LS1/A4 GTO on my 73 camaro Finaly ready!!!!
  47. 4L80E Price
  48. Alternator charging problems
  49. Storing a motor question
  50. Oil Pressure/Coolant Temp sensors...
  51. Anyone swapped into 99-04 mustang street car?
  52. 1990 Nissan 300zx, What should I do?
  53. I need a little help on knowing what all I need for a motor swap
  54. LS2 / 4L65E Swap into a Buick T-Type
  55. Electrical Question
  56. Need help! 69 Camaro/Procharger
  57. propane injection setups and blow threw?
  58. 3rd gen fbody,ls1, procharger help!
  59. random misfire p0300????
  60. Anybody try this.."Sharkhide"
  61. 2000 S10 LS1 swap info??
  62. steam vent tube hose
  63. Exhaust questions
  64. Where to buy an LS3?
  65. 1/4 mile times - what are your thoughts. . .
  66. ls1 in 94 firebird
  67. Some questions about doing an LSx/T56 Mustang...
  68. I scored a doner
  69. L92 Cooling in 1969 Camaro
  70. power steering pump line leaking
  71. Carbed LS
  72. L92 wiring a generic O2 sensor
  73. 03 5.3L G-Body race build questions??
  74. ls1 dlc question
  75. I want to change all the gaskets were oil can leak from
  76. 6.0 fox opinions
  77. why not use a batwing oilpan
  78. LSX 454 controller question.
  79. Dakota Digital SGI-8 + Ls3 480 controller + 90 Camaro Tach
  80. concerns about MAF
  81. Anyone mod their water pump??? Need advice.
  82. Putting an LS1 into a 68-72 A-Body. Need a good message board...
  83. Fly by wire pedal has very little play
  84. Help with common trouble codes LS3/92 into 68 camaro
  85. Does a TBi tank work with LSX FI???
  86. What kind of motor is this?
  87. LS6 into an '87 GT?
  88. Fuses on charging & main electrical system
  89. Drive by wire pedal pictures?
  90. perplexing clutch issue
  91. motor mount problem
  92. what does stock ls1 throttle cable (pedal end) look like?
  93. LS3 burping coolant from radiator cap
  94. Pontiac electrical problem
  95. Pro-Flo xt stiin on my 39
  96. LS1 Chevelle exhaust clips
  97. 5.3 Build ????
  98. Motor washing and taping advice
  99. in severe need of help..and part #s
  100. My almost finished 84 LS1 Cutlass
  101. power Steering Resovoir Dimensions
  102. Fuel filter for a system with a return line?
  103. Wire harness basic ?
  104. Oil pump priming
  105. starter relay wire y/bk
  106. Can I use a 5.3 ECU on my 95 TA?
  107. newer 5.3 intake on lq4
  108. LM7 W/LS1 Heads
  109. Which LS motor??
  110. Low drivers alternator belt squeeks
  111. 5.3L/4L60E doesn't fit in 64 Chevelle
  112. headers...
  113. PS Pump Install & Removal w/ or w/o pulley?
  114. BRP Conversion Kit Updates
  115. boring out a LM7/5.3 Vortec
  116. Grand National LSx swap
  117. ls2000 v8 s2000 @ track on new set up
  118. NewB and need help in HoustonTX
  119. 200+MPH at Fall 2010 Mojave Mile event: turbo LS3 FD RX-7 :)
  120. 1977 Monza 6.0 build
  121. Posted this in the pcm tuning section and section and no one aswered
  122. How to run fuel pump wires through top of sending unit?
  123. keyless ignition w/ momentary start
  124. 94 4l60-e behind a SBC temporary till 5.3swap
  125. LU3 V6 Install in 75 Monza
  126. My LS1 in a coupe Mustang
  127. Cranks but wont start
  128. 1998 Camaro: 3.8l/T5 -> 6.7l/T56
  129. A little wiring help please.
  130. LS engine in 5th Gen Mustang???
  131. Stock intake question, is this fixable?
  132. LSX Notchback Build
  133. First Gen Camaro Tic Toc Tach
  134. subframe catera v8
  135. help
  136. Which FRCs would you use?
  137. evap system diagram
  138. Jaguar XJ8 / LS2 4L65-E
  139. wiring question
  140. Cruise control fro GMPP engine controller??
  141. Finally Got the Malibu up and running (vid inside)!
  142. Help with DBW 496
  143. 68 Chevy C10
  144. 1993 Camaro LT1 to LS1 conversion
  145. Make your own mounts vs. brp kit
  146. Few last things before i hit the start button? Help me id a few connectors
  147. Need help with LS1 swap that is running to hot
  148. neeeed hhheeeeeeellllpppppp!
  149. help with intake selection
  150. What is the thread pattern in genIII heads for the temp sender?
  151. mustang ls1 swap with t56 6speed
  152. Alternator wiring
  153. LQ4 oil pan in a 74 camaro f body
  154. lq9 PCV
  155. I want a build thread too....'63 Chevy II Wagon.
  156. Maggie in 92 C1500?
  157. car shop conversion plates
  158. G Body 5.3 Swap Questions
  159. Throttle body coolent line?
  160. ls1 swap
  161. need measurment on header
  162. Electrical Issue.
  163. Tach ??? Swaped 95 T/A
  164. help with lq9 in 67 bird
  165. Lm7 & lt1 engines opinion
  166. x-body or first gen f-body with ls1 oil pan
  167. LS Swap into Fox Body Mustang
  168. Volvo Hits the Dyno
  169. 12V Power Supply
  170. LQ4...............408 or not?!
  171. Weiand 300-111 ls1 intake on Lq4?
  172. fs: fox body aje motor mounts
  173. LS1 Porsche 928
  174. Stupid Instruction :(
  175. Pcv?
  176. LS2 storage
  177. L92 with VVT and Working 4L70E video first start
  178. E38/E67 with T42 questions
  179. 5.3 Mounting problems in 2nd Gen Camaro...
  180. cheap or home-made accesory drives
  181. Fuel pump keeps blowing fuses - 99 Jeep TJ
  182. hydraulic cylender swap 67 - 96
  183. LSX into Porsche 928 Completed
  184. Hey Porsche guys, anyone know what happened to Simpson's website (porchev.com)?
  185. 2 wire truck alternator wiring
  186. LSX Motor In 1966 El Camino
  187. Toyota Truck 5.7 LS1 Conversion
  188. 2nd Fbody owners....
  189. Verification of grounds L92
  190. Making the change...LS into 94 Camaro
  191. Another update
  192. ls1 vs ls3 in my 74 z28??
  193. Monza Engine Swap
  194. Cams???? What to buy???
  195. 79 trans am ls1/th400 w/ gearvendors
  196. 98 pcm/harness on an 01 ls1?
  197. basic pcm tune question
  198. th400 , gear and tire size for my 89 notch 60ft help
  199. flipped camaro manifolds for turbo mustang?
  200. 02 sensor wiring issues
  201. Making 6.0 truck manifolds flipped forward/down work in a g-body? Lets here it
  202. L92 in a 2005 CTS-V
  203. T56 swap to 4L60E
  204. Plan: LS Engine in my '47 Dodge
  205. Strange Issue! Cam sensor
  206. LSX Shootout
  207. Need advice on an lq4 swap...
  208. Build Plans... NEED HELP
  209. for those of you who have done the 2nd gen f body swap
  210. 1984 rx-7 dbw LS2 h/c/i
  211. 5.3 87 Chevy P/u 4x4 it runs!!
  212. LS1 In mustang with AC
  213. DBW throttle body rapidly clatters
  214. oil pan for 85 regal? LH8 or f-body?
  215. Which cam/controller package for 1969 firebird l92/4l80
  216. s&p oil pan users please chime in
  217. 90 FORMULA LS1/T56 swap (future single turbo)
  218. Source for short air filter/MAF combo?
  219. LS? into a 62-67 Chevy II
  220. LY6 6.0 into an '85 C10 Suburban
  221. 427 swap into an 02 trans am
  222. What motor mounts and trans member to use on a 72 4x4 k5?
  223. Ls7 nsx
  224. 4 wire TPS Sensor
  225. Wiring: Radiator Fan - ECU help!
  226. air filter dimensions
  227. L92 will turn but no start - help a newbie!!!
  228. Which Exhaust Manifolds Fit Best on First Gen Camaro or Firebird
  229. Need some help
  230. Cousin's LS1 240
  231. 69 Nova Build - pumpgas twin turbo 408 LS
  232. Ls2/t56 gto fit into 4th Camaro?
  233. Trans and Harness Questions for LM7 s10
  234. Filler neck question
  235. Oil Pan Bolts
  236. 5.3 into a toyota
  237. Stock oil pressure sensor output????
  238. LS-Camino build thread....complete with track times....
  239. 3.4 conversion to 5.3
  240. Street Legal 1976 AMC Pacer
  241. Vintage Air Controlled by PCM??
  242. 3rd gen LQ4/400
  243. '93 Mustang LS1 Swap. Motor Plate Options?
  244. Help Identifying Power Steering Fitting
  245. 1971 cutlass s lsx swap
  246. 81 Camaro Wiring help
  247. 5.3 LS with 4 speed M21 in 69 Camaro...help
  248. Things you missed before first starting your motor.
  249. Griffin 22x19x3 radiator 100shipped
  250. what headers to use with ls1 in a 67 camaro with a rack?
