PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. 68 Camaro 5.3 swap
  2. Hooker mid length headers for a 1st gen Camaro ?
  3. 5.3 into a 1953' Chevy 3100 Thriftmaster Thread
  4. 1993 Mustang coupe - LQ4 4L80E 7875 turbo build
  5. Who is using the Chrysler PWM fan modules???
  6. Will 4L60E out of V6 truck fit 5.3
  7. V6 automatic/dbw pedal assy
  8. 1970 Chevelle 5.3 swap ( stumbles in low rpm)
  9. Need advice on my wrecked LQ4 Denali
  10. 1971 gt 37 pontiac lemans ls 1 6 speed swap
  11. Ls1 e30 m3
  12. 5.3 into a 73 caprice
  13. Help with stock harness
  14. Anybody swap a 2015 5.3l ecotech yet?
  15. Quiet muffler options for 454
  16. Radiator info needed
  17. How to install the corvette fuel filter/regulator on a fox?
  18. wheelie
  19. plug'n'play Tuners on a 5.3/4l60e swap?
  20. 5.3 donor vehicle what do I keep
  21. Question about adapting factory fox fuel lines to 5.3
  22. 1979 Firebird Build
  23. Are gen4 dbw pedals interchangeble
  24. Looking at a swap Apache
  25. TB, DBW and pedal question
  26. Coolant reservoir or not?
  27. 67 chevelle clutch pedal
  28. 1996 2wd f150 5.3/nv3500 mustang guys please chime in
  29. best fitting 64-67 A body swap parts
  30. LQ4/LQ9 into 2nd Gen Camaro
  31. Its coming ...... LT4 crate engine
  32. fox or new edge with AC?
  33. Breather tube question.
  34. Walbro fuel pump install for B-Body tank question???
  35. Ls1/T56 mustang swap people
  36. Worlds first Ls3 lexus ls430 is going RHS 454
  37. LM7/NV3500 240SX Coupe swap (Boring build)
  38. Project: Single Digit Brick
  39. Ls help
  40. Sema 2015
  41. LS3 short block With 228r and 241's
  42. Clarence issues on a 68 Chevelle
  43. 2nd Gen Camaros 70's questions
  44. Fox body won't shut off!!!help
  45. DBC cruise and Toyota switch
  46. 8.1L/Alison into an 06 F650...
  47. Oil Pan Modification
  48. 1972 Chevelle LSA/4L80E Swap!
  49. L92 plan not a good one?
  50. Yep another 5.3 turbo fox aka "tha myth"
  51. exhaust manifold questions??
  52. Best Quality LS1 AutoMatic Radiator?
  53. Pedal to TAC Wires
  54. running a 6.0 off a 4.8 ecm
  55. Grandmas Camry
  56. 5.3 identifying help?
  57. Ls3 into a 99 ws6
  58. Anyone have experience with PA Racing A arms??
  59. Which LS motor to replace LT1?
  60. 98 Fbody to 0411 Conversion-TCC issue
  61. 52 Studebaker Truck #2 (daily driver)
  62. Ls1 and 4L60 swap into a 60 El Camino Problems shifting when you get on it
  63. A body LS1 Radiator hose
  64. 2000 Roush Mustang 5.3 & 4l65e
  65. Trinary switch for AC question
  66. lt1swap sites harness guide
  67. Volvo 760 - 5.3 or 6.0
  68. 1967 impala ls2 conversion--suggestions?
  69. LS1 swap into '03 4.3 Silverado engine harness question
  70. 2002 Mustang GT Build thread
  71. Ls1 brake booster vacuum
  72. Which A/C compressors are variable rather than on/off with a clutch?
  73. Gmpp harness VSS to T56
  74. C5 corvette tac module question
  75. Mail order tuning
  76. S-series swaps!
  77. 4l60e bellhousing to LY6
  78. Throwing away GTO modules?
  79. 1955 Chevy Bel-Air Convert
  80. Flex plate spacing
  81. 2006
  82. Dorman nylon tube to 1/4" NPT?
  83. LS2 07 TBSS into Jeep Tuning integration issues
  84. LS2 E40 Harness and PCM questions
  85. nova headers
  86. Holley 8501HKR exhaust manifolds in a first gen?
  87. Fuel Injector control wire routing
  88. 66 Buick Special
  89. Balancer substitution
  90. Please Help!!! Any input is apretiated
  91. Finding an LQ9.... prices
  92. 65 Impala t56 swap
  93. 06 truck intake.???
  94. 94 Z28 LS1 swap torque arm relocation bracket
  95. The JS Racing Products 944 runs 8s on a cold slick track.
  96. 1971 Monte Carlo Wiring Help
  97. DR44G wiring?
  98. Stand alone fusebox wiring questions
  99. GMT400 Wiring Questions
  100. First start of LSXOCET
  101. LS1 Swap into a 1941 Ford - Cruise control??
  102. any s13 twin turbo builds on here?
  103. 02 New Edge LS swap
  104. E40 Wiring Blues
  105. How would you build a poorman's 300' <5s?
  106. 04 silverado LM7
  107. 5.3 swap into 75 k10 w/th350
  108. 1 gen s10 had a 2.5 to LS 5.3 solid motor mounts?
  109. Mount advice please! 5.3 into PA Racing K member
  110. 73 Caprice 5.3 vortec swap
  111. Converting 5.3 to LS1 or LS6 intake - questions
  112. 1999 mustang swap
  113. Holley AC Mount with Corvette Fuel Rail Covers
  114. LS1 and 4l60e Swap into a 1967 Tempest Custom/GTO Clone
  115. Intermittent Misfire
  116. Engine and trans angle fox with aje k member
  117. Radiator hose reference drawings?
  118. 92' Roadmaster + LS Engine = ??
  119. Ls3 with older (2000) 4L60e ok or need newer trans?
  120. Power Steering system creates air pressure
  121. ls 5.3 to th350 gap issue
  122. 1997 LT1 to LS1 wiring woes
  123. Current Performance fuse block, need some help
  124. BMW 540i engine swap
  125. 2010 silverado 5.3 to 6.2 swap.
  126. Ls 5.3 carb to efi swap
  127. Murder Stang - 96 5.3 turbo build
  128. 5.3 swap fan wiring problem
  129. P0351 but car runs fine
  130. Another 5.3 swapping to ls6 intake
  131. LS4 in a 240sx
  132. Which QuickTime bellhousing?
  133. What motor mounts to use on a mustang 2 subframe?
  134. What motor mounts to use?
  135. New Hooker 1968-72 A-Body LS Swap System Preview
  136. 5.3 vega swap final touches and questions
  137. 1996 GMC Sierra 1500 LS Swap (Project Money Pit)
  138. superskater's Foxbody 408 LQ9/S480/T56 Build Thread
  139. Divco Milk Truck Rat Rod
  140. HCI LS Fox Dyno pass
  141. 96 t56 Lt1 to ls2 swap
  142. after building 4 wire harness?
  143. LQ9 block... what now?
  144. LQ4 value
  145. 1979 TA with a LS motor, need advice
  146. LS2 swap 01 camaro
  147. Any source for fuse / relay holders for custom harnesses?
  148. LS7 Exhaust manifolds in a first gen
  149. 5.7 to 6.0 gains (only swapping the short block)?
  150. 2000 Silverado SWB 4.1L manual..want to swap bigger engine
  151. 1999 Suburban 2wd 5.3 with 6L80E Swap
  152. LS EFI help
  153. Twin turbo ls1 ford crown victoria
  154. Autometer gauges ls swap in 3rd gen camaro
  155. high moun ac compressor for ls turbo setup
  156. 5.7 harmonic balancer on 5.3?
  157. What I used in my 69 Camaro LSA/4l85 swap
  158. Post up some measurements of your swap!
  159. Open space mock up?
  160. jeep zj race rig. ls newbie here looking for some direction.
  161. Website issues
  162. Blew up my 355, time for a 5.3 N2O e85 bargain bin build
  163. LS1 Firebird Fuel Tank in V6 Firebird
  164. 5.3 low idle at stop quick question
  165. Lifters needed
  166. L83 power steering pump bracket
  167. 6.0l blown ski boat
  168. 2003 350Z LS Conversion
  169. 1965 Pontiac Lemans LS1-4l60e build...pro-tour style kinda
  170. What Cam will work best in a 5.3 lm7.
  171. 1988 Mustang Coupe LS/T56 Swap
  172. What can I do to my heads to get more hp
  173. Educate Me on Cam swap for 5.3 engine
  174. Gbody 5.3 swap 4L60e tranny help
  175. foxbody ls 5.3 cam only 1/4 mile times?
  176. 1988 olds cutlass ls conversion
  177. Alternator and battery cable routing
  178. e36 ls1 wiring face palm. requesting assistance.
  179. Ideal carbon canister purge conditions
  180. F1a 5.3 swap 04 mustang questions
  181. 67 Skylark Convertible
  182. 1962 Nova
  183. LS Wire Harness
  184. Fuel system question for 240sx LS1 swap
  185. Tanks Inc and Holley Hydramat
  186. Square body lsx swap help
  187. Turbo Gen4 Tubbed 72 Nova -()()
  188. AllData or other site?
  189. Fueling needs for 6.0L on run stand? *EDIT*
  190. Cam Options
  191. DBW gas pedal stops responding.
  192. LS foxbody clutch issues
  193. 799 Heads with LS1 2in. Intake valves
  194. Overcoming CANBUS in an LS swap into a Genesis Coupe
  195. 1990 foxbody 5.3
  196. LS6 in to E46 BMW wiring questions
  197. 1962 Bel Air 4L80E clearance
  198. Smog rules for California.
  199. "1997" Camaro LT1 to LS1 Swap Thread
  200. 2005 silverado ls swap
  201. L33 compression test, 130 all across
  202. LS Swap gauge cluster ideas
  203. Need help with cold air intake for 5.3 in 1990 c1500
  204. 1972 chevy c10 5.3 swap need help
  205. '72 Chevelle, BRP mounts
  206. coolant temp sensor problem
  207. Tach & Speedo Help
  208. LSA Engine PS pump fitting question..
  209. My Craig's List Scores
  210. ls1 engine work recommendations
  211. 96 Silverado + 5.3, on3 76mm turbo, 80e swap and journey to LS Fest 2015
  212. 2000 Sonoma 5.3 t56 idle issues
  213. Cooling issues
  214. 1996 firebird lq4 or lq9 swap
  215. Community consensus for universal air intake kit
  216. LQ4 in 1964 Cadillac??
  217. 1976 nova ls1 4l60e
  218. upper radiator hose Idea's
  219. coolant temp problem
  220. 3800lbs/5.3/On3-76/e85/10s !!!!
  221. Alt charging question
  222. Camaro Water Pump Spacer for Truck Accessories - Feedback?
  223. No throttle pedal codes p0120, p0220 p1516
  224. My 6.0 malibu and 5.3 porsche 944 join the 8 second club
  225. Dakota Digital pass threw 8k pulse wiring
  226. How does the oil pressure sender work?
  227. 5.3 lt1 camaro speedo and tach problem
  228. How to make a PWM alternator work?
  229. Lq4 tr6060/magnum hybrid clutch and flywheel?
  230. 87 Fox Body Mustang
  231. 83 c10 lq4/4L80e Tranny issue
  232. T56 magnum with tr6070 gear possible?
  233. Questions about a stall
  234. ZR1 BCM Pinouts
  235. ZR1 E67 Pinouts
  236. ls swap problem
  237. Obs swap
  238. Setting up my fuel system
  239. Hybird
  240. Corolla LSX Swap PCM Question
  241. LSX Innovation mounts
  242. LS into 64 El Camino
  243. 2000 Durango SLT 4x4 LS Swap-Build thread
  244. Have a couple small wiring questions
  245. Need Help........
  246. LS swapped, rwd converted 6th gen Monte?
  247. lsx swap advice/info for 1967 Bonneville
  248. 5.3 into my 57 chevy pickup - Questions
  249. 4th gen fbody guys: gauges, AC, cruise?
  250. Which setup for LS to Dodge Dakoat swap
