PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 [169] 170 171 172 173 174 175
  1. Thinking about an LQ4 6.0L Vortec Engine swap for my Caprice
  2. Video, LS1 Running In my 68 Camaro!!!!
  3. corvette ls1 into 98 firebird
  4. speedo....
  5. radiator for ls1 in 69 camaro ?crossflow or not ?
  6. vortech inline pump
  7. i need help
  8. Heeelllpp!!
  9. LS1 in a miata...
  10. ls1 rx7 conversion questions..
  11. Feedback on taking body off of frame!
  12. Flywheel inspection area
  13. Turbo GN 3.8 motor swap into 94 trans am?
  14. UPDATE; MarkIXZD150's 1963 GS progress w/pics
  15. Wiring troubles(Paging speartech)
  16. Wanting to put LS1 into 72 camaro
  17. brp t56 crossmember
  18. Water temp sensor / IAT
  19. need a techies help with parts
  20. 3rd gen motor mount q's
  21. a/n fittings on fuel rail
  22. ls1 into 96 lt1
  23. LS1 in a Boat?
  24. Cooling system help
  25. C5 instrument cluster with F-body PCM???
  26. a/c compressor compatibility
  27. 88 formula fiero+Ls1
  28. C3 Ls1 Conversion???
  29. LS1 swap into 95 Camaro....
  30. for those that have done the 67-69 f-body swap
  31. Anyone relocating coil packs in early F-body?
  32. ls1 into my 97 camaro (6speed)
  33. 6.0 liter into my 97 camaro(6speed)
  34. Engine into Dash pinouts
  35. LS1 RX7 headers??
  36. 2003 Ls1 5.3l
  37. can i see pics of your fuel system
  38. Need help with a LS1 swap into a 91 1/2 ton chevy truck
  39. F/S complete LS1/T56 combo
  40. factroy ls1 mounts
  41. Couple of questions on third gen swap
  42. Ls1 Installed, Now Need A/c
  43. LS1 hydraulic clutch master - to '69 clutch pedal
  44. LS1 throttle pedal in '69 Camaro: How To!
  45. 4th Gen seats into 1st Gen F-body: How To!
  46. LS1 into 85 Trans am, need core facts
  47. Anyone swap LS1 into 450sl?
  48. 69 Firebird LS1 swap questions
  49. out the paint shop....
  50. Just gathering some info...
  51. How much did you pay for ur LS1???(Speartech Comin too Please)
  52. Getting cars titled and inspected w/LS1 swap?
  53. Cylinder head air bleeds
  54. Question for Brian Hinson
  55. 5.3L in a 67 chevy pu Exhaust help!
  56. BRP Bind
  57. Narrowing C5 Rear Suspension???
  58. swap into 84 BMW 325e?
  59. Gen 1 SBC Into LT1 Car
  60. 67 camaro swap (headers?)
  61. what antifreeze is everybody using?
  62. Which pulse dampener to use?
  63. fuel pump info
  64. LS1 - C3 Vette - Power Steering?
  65. Rear engine transaxle?
  66. Shifter location in 2nd gen
  67. 3rd Gen LS1 Conversion, Radiator question
  68. What headers work?
  69. SHE LIVES.......Jeep Wrangler Comes to life....But
  70. T56 shifter position in a C3
  71. LS1 to 2nd Gen swap questions
  72. Metric bolt sizes?
  73. More wiring questions
  74. Wiring harness questions (2000 A4)..
  75. Pics of my '86 Z28 LS1 swap
  76. Wiring Questions........Need HELP
  77. ls1 swap into a ski boat
  78. LS6 Conversion into 91 Turbo Talon <pics>
  79. Stock LS1 Parts For Sale
  80. Fuel Pump Question
  81. questions about late F-body wiper motor
  82. So It Starts
  83. 2003 Hyundai Tiburon conversion to the LS1 Project.
  84. reversing the Intake Manifold?
  85. What is the lightest RWD car for my hybrid? Give me some ideas please.
  86. LS1 in a VW Bug
  87. Wiring guru question...Stock guages
  88. T56 tailshaft question for 1st gen swap
  89. Bolts
  90. LS6 in a Helicopter - How Cool is This?
  91. Vette Pcm In F Body
  92. DLC Connector Connections
  93. Need help with 5.3l conversion
  94. where do the plugs from the LS1 harness go???
  95. LS1 to fine german engineering
  96. What am I missing? Estimate inside
  97. need some help
  98. 69 cam sbc headers for sale.???
  99. 69 LS6 Camaro - Supercharger/Engine Photos
  100. Ls1 With Etc Won't Run After 1st Start
  101. Conversion Question
  102. Which wire for VSS / Cable-X?
  103. T56 swap in an auto 1st gen
  104. What size is the clutch master pump?
  105. Project Extreme-G 1969 Camaro SS updates
  106. Throttle cable - How long?
  107. Rx7 conversion running
  108. OEM straight thermostat housing!!!!
  109. LT1/Auto in a 94 Silverado???
  110. LS1 into C3 Vette???
  111. found a freebie for a swap !!!!!
  112. Alternator bracket template
  113. CTS 6 cylinder supercharged?
  114. Oil Pan question
  115. LS1 into Camaro 67, positioning of engine
  116. Need info on fox body swap
  117. Ls1 Crank Part #
  118. 3800 series 2 into blown 350 carb
  119. Electromotive Tec 2 and LS1 HELP
  120. ANyoen ever put LS1 under a LT1 OEM SS hood?
  121. Picked up the swap canidate!!!!
  122. Anyone else using Modular Mustang Hydroboost Brakes?
  123. LS1 in a early Nova
  124. Need LS1 wiring diagrams
  125. LS1 install update pics.
  126. LT1 to LS1 abs brake module
  127. First Gen Ls1 Swap
  128. FS: Complete LS1 /w 6spd setup, 425rwhp
  129. LS1 + 4L60E into 3rd gen????
  130. TPI Conversion Questions
  131. Thinking about selling my car ..how much should I ask ?
  132. Any reason why a 02 tranny wouldnt work behind 98 PCM?
  133. LS1 into 89 Blazer
  134. Radiator options?
  135. First smoke out of my LS1 swap
  136. complete LS1/Auto on eBay
  137. Heater Hose Plumbing
  138. alternator wiring question on 1st gen with ls1
  139. LS1 conversion help?
  140. engine wiring
  141. Ls1 Into a 1956 Chevy
  142. is it worth it to buy LT1 from GM parts?
  143. Ls1 in Monte carlo
  144. LT1 to LS1
  145. A blown, carbed ls1 first gen?
  146. Real Cost estimates of a 1st gen swap
  147. Suburban LS1 swap
  148. LS1 bu????
  149. Does anyone know speartechs phone #??
  150. Speartech Harness question
  151. Coolant vent pipe to lower radiator hose.
  152. Question about BRP set up.
  153. V6 to LS1 swap finally done! 98 Firebird
  154. Tearing a car down, never know what you will find...
  155. LS1 and Sidepipe Exhaust Question
  156. V8 engine into a 4th Gen (stock V6) question
  157. Header question for the second gen guys.
  158. battery positive feeds.
  159. Looking for compact high output alternator!
  160. Wiring Harness
  161. vented gas cap for 68 camaro
  162. 2000 Ls1 Into 98 V6
  163. Headers
  164. Fuel system fittings?
  165. EVAP, what to do, My options are............
  166. Oil pan clearance problem...
  167. home made selectra wiper
  168. Ls1's with dress-up parts... or PAINTED blocks
  169. Chevelle 71 Swap
  170. headers for 68 camaro?
  171. BRP Nightmare.....
  172. 2002 PCM and 1999 Engine Harness?
  173. Which brackets in a 64 Chevelle?
  174. Oil Temp / Pressure Sender Unit location
  175. Spark plug wire question:
  176. Ford (Mercury)Capri LS1 install
  177. Need help figuring out complete AutoMeter Gauge Setup
  178. LS1 vs. Truck Coils. Problems?
  179. Truck LS1 power steering pump/alternator bracket?
  180. 4L60E manuals?
  181. LS1 engine to C4 transmission?
  182. I need an answer quick please... Cruise control module:
  183. stupid question but dont want to screw up
  184. LS1 Conversion motor mounts...
  185. would pedal assembly from 4th gen f-body fit my 68 camaro?
  186. Engine Runs!
  187. Ls1 On Nos Purge Video
  188. Fuel tank pickup
  189. Aligning the drivetrain
  190. 95 3.8lt -> 98 Truck Vortec
  191. I need Long tube headers that hug the motor, what would work?
  192. LS6 MAF Sensor Swap
  193. 700R-4 Trans. TV Cable?
  194. Who has the fastest heads and cam hybrid
  195. 35 chevy sedan
  196. I have a question on my 93 RX7 swap.
  197. what guages for 68 bird
  198. Finished 67 LSX/T56 turbo swap
  199. Motor wont start after swap. What to check?
  200. Anyone using the Abbott Cable-X?
  201. 64 chevelle wagon swap
  202. 93-02 Wiper Motor Wiring Pin Outs ?
  203. Post pics/webpages of your conversions
  204. 64 Chevelle Tie Rod Hitting Oil Pan
  205. LS1 RX7 guys, how does this car look as far as a swap goes?
  206. 96 V6 to LS1 Conversion finished
  207. 99v6 paid off. starting to look into a conversion
  208. Post pics/webpage for you conversions
  209. How do I figure out what year my engine is??
  210. speedo
  211. Can I use my stock radiator?
  212. In LS1 harness- looking for correct VATS bypass wire
  213. 98LS1 to 97 v6 fuel and wire questions
  214. Cruise Control
  215. finding ls1s/trannys
  216. Dual tensioners?
  217. It can happen
  218. Fuel system question... non-baffled/sumped tank??
  219. Coil relocation brackets are complete!
  220. Calling the RX7/LS1 swap guys. I need help on my swap!!!
  221. Need Help.. fbody shifter cable too short.. need alternative.
  222. ls1 in a 2ng Gen
  223. Let me see pics of your clutch ped assm.
  224. Which is the inlet/outlet for the heater core off the ls1?
  225. Autometer Speedo question...
  226. What emissions is CA looking for to make smog legal on ls1 swap??
  227. LS1 240z track day
  228. '65 Pontiac Tempest LS1
  229. First test fit of LS1 & T56!!!!
  230. '74 260Z is on the way
  231. alt mounting
  232. Some pics of a hybrid 'Project' we're working on.
  233. HELP! LS1 Locked up!
  234. engine jerking hard at100mph then stalling out?
  235. gen III motor into 68 camaro
  236. '86 Z28 LS1 swap is finished
  237. Alternator relocation for clearance issues
  238. S-Truck PCM Mounting Bracket/Base??
  239. Engine TEST stands??
  240. vette filter/regulator
  241. Fuel lines?
  242. how about the radiator???
  243. I need help with my clutch
  244. lt1 to ls1
  245. alternators different
  246. Any 65-67 GTOs?
  247. 3rd Gen LS1 Conversion
  248. What connectors are these in my 2000 T/A harness?
  249. Starter just clicks
  250. problem w/ BRP rack and pinion kit
