PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175
  1. Cooling fan for conversion? CFM rating?
  2. 97 LT to LS1, what wiring to get inside gauges working?
  3. ls1 to carb
  4. LS1 swap headers?
  5. PNP sensor?
  6. Fuel pump relay connector?
  7. where to look for an ls1/t-56
  8. 69 Camaro and LS1 conversion parts for sale
  9. Second Gen ls1 install
  10. V6 To V8 Swap
  11. swap pics of my LS1 S10
  12. 79 stroker iron block into 2000 camaro
  13. Anyone have pics of their S&P oil pan installed?
  14. Is there a VIN# on my block?
  15. Putting a LS6 in a 1998 Trans Am possible?
  16. 96 Camaro Engine Swap
  17. Anyone use one of these for a gauge?
  18. 99 Jimmy LS1 Swap ??????
  19. Magna Charged LS1 El Camino
  20. Motor Mounts
  21. 03 5.3 into a 94 chevy fullsize
  22. What value of fuses go here?
  23. LS1 Power Brakes/69 or LS1 pedals Question
  24. Oil Pressure
  25. anyone need a 300zx body???SMOKIN DEAL!!!!
  26. Debating a 93V6 to Ls1 Swap please help.
  27. Torque convertor bolts? Size? Thread pitch?
  28. Wiring diagram??
  29. fuel system question...
  30. 4th gen swap
  31. Retain VATS
  32. Hawk's LS1 tubular K-member
  33. Finally, The Time Has Come - W-Body LS1!
  34. New alternator placment
  35. LS1 into 93 - 97 Camaro
  36. Engine Stand ?
  37. Almost done 67 Bird
  38. LS1for sale
  39. V6 to 382ci LS1 NEED HELP!!
  40. Coil Pack Wiring Scheme
  41. 4th gen gas tank in 3rd gen?
  42. All LS1/S10 swappers check in NOW!!!
  43. PCM fan outputs
  44. Need radiator that will hold 480 bhp
  45. LS1/M6 in 55 chevy
  46. 71 Chevelle W/LS1 T-56 For Sale
  47. Got my Speartech Harness today!
  48. converting ls1/4L60 into ls1/t56
  49. Alternator problems
  50. will a gauge cluster from a93-97 lt1 hav the same pinouts as a 95 3.4l v6
  51. finnally got started on conversion. have some ?s
  52. Where to mount the computer in 3rd Gen
  53. Body Work First :(
  54. Please join me in welcoming our two new Forum Moderators!
  55. Fuel Line plumbing question
  56. LS1 and T56 in '66 ChevyII
  57. Speed sensor??
  58. oil pressure sensor
  59. power steering question on first gens
  60. T56 into Stingray, details wanted.
  61. 91-92 ls1 swap m6 price?
  62. LS1 crate engine installation
  63. 87 RX7 Update
  64. Cutting a transmission tunnel out of an F-Body (T56) so I don't have to fab my own?
  65. UPDATE!! New pics of Mark IXZD150's Corvette
  66. ^.0 or LS1 into 97 Z28 6 speed (is it worth it)
  67. Corvette drive train
  68. ...and it begins....
  69. Who makes adapter plates for the LS1 ?
  70. Just got LS1/6spd - part choices for 67 camaro install
  71. california emmisions
  72. ls1 in a S-10/Sonoma??
  73. Sanden 508 A/C Compressor Question?
  74. Wiring Harness for 69 Camaro w/ TH350
  75. Heater hose connections
  76. what donor car should i use?
  77. 5.3L Truck motor ?'s
  78. LS1s do fit in Mustangs with minimal work! (pics)
  79. Has anybody put a LS1/6 in a 69' Mopar?
  80. loooking to swap a ls1 into my stang
  81. Ls1 into 94 Sonoma
  82. F-body fuel tank pressure sensor--part no.?
  83. LS1 or LT1 into 87 firebird
  84. LS1 into a 72 camaro
  85. ac problem
  86. PS Hoses and my Options.
  87. need a little info
  88. Extra parts in FS forum.
  89. Wires to Alternator? Ground Strap?
  90. New cooling system
  91. LS1/6 Speed Trans. Crossmember Just Completed
  92. Third Gen Swap
  93. New exhaust
  94. 408ci with an LS6
  95. wiring
  96. 3800 to LS1 swap
  97. ls1 into 1987 El Camino
  98. S&P header problems?
  99. My 91 LS1 swap
  100. Help LS1 / T56 into 95 v6 camaro
  101. Vacuum for accessories??
  102. LS1 into 3800 camaro
  103. Need some Wiring help please....
  104. GTO Exhaust Manifolds
  105. Ls1 dimensions
  106. ls1 in a 78 Fiat Spyder :P
  107. what's up with this?
  108. ls1 steering column in 1st gen
  109. 4th gen k-member in 3rd gen
  110. need help with putting the ls1 in a 93 chevy truck
  111. rx-7 swap site, any experience?
  112. V6 /LS1 swap tip
  113. Average price range for swap?
  114. What have you put a LS1 in?
  115. Starting the engine - what do I need?
  116. LS1 Fuel Pump/Gas Tank Questions (69 Camaro)
  117. Rebuild/conversion v6>v8 camaro
  118. i need help installing painless LS1 harness
  119. Accessory Bracket Questions
  120. ls1 throttle cable
  121. fuel tank question again
  122. How to Remove Oil Filler Neck?
  123. How to Remove Injectors from Fuel Rail?
  124. Fuel Rail Shrader Valve Threads?
  125. How much space btwn tranny and tunnel?
  126. How to test electric fans?
  127. Old school big block headers for LS1 Gen 2 swap?
  128. corvette rear in 1st gen camaro
  129. F.S. Corvette oil pan and harmonic balancer
  130. Painless Harness, ran tach wire to Autometer Tach, very far off
  131. 2002 Ls1 In 1970 Camaro
  132. VATS question for 3rd gen swapers
  133. is $10,000 enough for ls1hybrid?
  134. 93 v6 camaro with 95 trans am motor, trans, rear end?
  135. 4L80E Conversion
  136. Oil pressure and alternator lights
  137. 4.8 in a 78 Malibu?
  138. Pulley arrangment
  139. motor mounts
  140. Dual fan setup - will this work?
  141. will auto wiring harness work with 6spd?
  142. will auto wiring harness work on 6sp?
  143. vintage air trianary switch
  144. Swapping an LS1 into a 02 Gmc Sierra
  145. Can't seem to find oil pan for swap...
  146. 90 caprice
  147. 3rd Gen LS1 RX7 for sale
  148. Removing emissions stuff
  149. Headers for a 67 Nova w/LS1
  150. custom headers?
  151. I'm running one fan with the Green wire but I'm still getting error code p0481?
  152. 99 or newer stang with ls1
  153. Using M6 PCM retuned for A4, what to do about wiring and sensors?
  154. Anyone have info on the Hotchkis Camaro?
  155. John/Speartech
  156. Ls1 in a 240sx???
  157. Where to get the metal clips for injectors?
  158. Source of engine harness plugs?
  159. 3rd Gen swap Wiring questions
  160. anybody put a LS1 into a OBS (88-98) chevy 1500 truck.
  161. vent fuel system?
  162. What determines the 'year' of the motor in CA
  163. 1st 300ZX LS1 to exist for sale.....
  164. motor mount/ A/c bracket problems
  165. Where does the signal wire go on the starter?
  166. How to hook up ammeter/alternator?
  167. best ls1 hybrid
  168. Can I use another year ecm with a 2001
  169. Where to get rubber grommets for firewall etc?
  170. ls1, or any v8 into a colorado
  171. How to make the LS1 alternator 1 wire?
  172. she lives again!!!!
  173. LS1 swap into mustang
  174. Where can I buy Helms manuals?
  175. Where to get 99-02 LS1 engine harness? (OEM not Painless, Speartech, etc)
  176. Gas tank requirements - CA ls1 smog
  177. C4 corvette
  178. 69 Camaro Motor Mount Width Question
  179. Disabling VATS
  180. Motor Mount Problem
  181. Shelby Cobra Conversions, any pics/info
  182. Paging Speartech - CA smog RX7/LS1 harness
  183. Need advice on a frame for my ls1
  184. no alternator plug on Painless harness
  185. 6.0L in my S10
  186. need advice on exhaust flanges.
  187. what work should i get done from speartech
  188. 4th gen rear end in 3rd gen, brake lines question.
  189. CA swap- smog provisions
  190. Tapping into block for mechanical temperature and oil pressure guages
  191. LT1 --> LS1 swap success?
  192. what is this connector too?
  193. Swap is done. Need help really bad!
  194. Looking for recommendations?
  195. Aftermarket Wiring Harness: Questions and Opinions
  196. Can I use any ECM from an LS1 vehicle in my project?
  197. Questions about completely rewiring a car....
  198. LS1/6-Speed In 69 Camaro (Crossmember)
  199. Need help with Third Gen Radiator
  200. 70 nova ss gen3 conversion
  201. fuel pump relay question ( paging speartech or anyone)
  202. ls1 in a 1st gen rx-7
  203. Fuel enable and vats?????
  204. new radiator in my 69 is finished !
  205. Question on third gen instrument cluster
  206. 78 El Camino + LS1 or LT1- questions
  207. Chassis reinforcement in 3rd Gen T-top?
  208. LS1 rear end in third gen?
  209. Fastest Swap Ever???
  210. Help! Where does this connector go?
  211. Jumping the gun
  212. Clean 92 Camaro RS LS1 swap questions
  213. What's the value of a 69 LS1 / T56 Camaro
  214. Third gen ls1 swap
  215. BRP Rack & Pinion Installed!
  216. Any Fiero owners in here? tranny question
  217. Help - Cable X converter not working
  218. My project(s) Dreams coming true!!!
  219. powerglide on LS1, any problems?
  220. air conditioning delete
  221. Very impressed with Speartech harness quality
  222. LS1 Novice need harness/ECM help
  223. 6.0 ls1 in 67 camaro
  224. and so it begins....
  225. LS1 in '95 C/K??
  226. 3rd gen question(paging speartech)
  227. S&P LS-1 Conversion mounting plates - Any Problems???
  228. New idea for coolant steam tubes
  229. Need help with fan problem(Speartech)
  230. car update!
  231. Ls1 in 97 Fbody- Best intake idea?
  232. LS1 ThirdGen Questions
  233. RX7 Daily Drivers
  234. Using Intank Pump W/ Stock Tank
  235. Need help! Using 1998 Dash harness with my 1994 Steering column...pic inside...
  236. 70 Corvette 4-Speed with LQ4 6 liter
  237. LS1 in 68 Corvette...Shopping list needed
  238. Extreme-G '69 updates - tons of photos!
  239. couple of questions
  240. about to get conversion running might need help
  241. Good conversion project car for sale, Cheap!
  242. LS1 Motor Mount for 2nd gen camaro
  243. Any AWD cars that can fit an LS1?
  244. Help stuck on headers
  245. need swap info for 5.3l vortec to 82 silverado with 305
  246. Ia a 98 350 harness compatable with a 01 5.3?
  247. 3rd Gen Swap: Exhaust question
  248. will LS1 coil pacs work on a 5.3 vortec?
  249. ls1 longblock package
  250. 3rd gen exhaust
