View Full Version : Conversions & Swaps
- Corvette filter/regulator AN adapter question
- 5.3 4th gen z28 pwr str hose part #
- 1969 GTO LQ9/T-56 swap
- wiring question
- ls1 camaro water pump spacers
- 4.8 in a 91 mustang
- C5 as donor car
- L76 in 02 silverado questions
- LS7 exhaust manifolds on third gen ls swap
- Third Gen LS Swap Headers
- Green Plug Identification help! Picture inside!
- Cruise control switch for dbw swap
- LS-swapped thirdgens? (esp. turbocharged)??
- 2001 Silverado 1500 ECU upgrade for LSX tow motor
- 91 Camaro LSX No start!!
- Dead...
- Considering LY6/6L90 into CJ7 - have some questions
- 97 Jeep Wrangler
- 5.3 into my '95 K2500
- Ly6 lift plate dimensions
- LS3/T56 swapped 81 camaro bogging off idle
- L99 Body/Fuseblock connector info
- 1980 Trans Am LS1 to TH350 Question
- The ImpoSSter- 6.0 swap 1990 RCSB Truck- With a 5 speed!
- Alternative method to run a ProCharger on LS Transplant Vehicles
- Right size motor in a 75 Pontiac Grandville (GM B-Body)
- Issues after ls1 swap
- Ls3 l99
- Dirty Dingo, Fox Body, and which headers?
- Mail Order Tunes! More ECm's supported Now
- 1997 Camaro to LS Wiring harness
- 12 Gen F150 Prerunner with LSX Swap
- Lingenfelter converter box feedback
- DBW Pedal Mounting
- Dave's Vette
- help with 70 chevelle drivershaft length
- 1970 Pontiac GTO build
- 02 Camaro Dash Swap Wiring- Not getting Serial Data??
- QA1 K-member fox body
- 2000 Blazer LS1 Swap
- 65 Impala SS - LS swap
- Ls3 with 4th Gen FBody accessories?
- Front cover alignment tool?
- '67 Impala. Factory right-hand drive. 6.0L swap.
- 1959 IMPALA 06 LS2 WITH AUTO TRANS-suspension and brakes?
- Turbo C3 76 Corvette, 4l80E, 4 link rear, street cruiser/strip fighter
- 67 chevelle ls1 swap best cam??
- Wiring question
- 71 Chevelle LS2: best way to get a/c working?
- First gen camaro A/C compressor mounting options
- Motech L86 Gen V first start!
- New SC LT4 in Gen IV Car???
- 1999 chevy 6.0?
- Looking for a low mount AC bracket that is inline with other accessories
- Winter/spring engine build up
- Sbc clamshell question
- Psi harness
- cast hooker header equivalent?
- PNP circuit question
- Spilling coolant - Am I plumbed correctly?
- Holley/Hooker f-body exhaust??
- 6L80 brake switch
- L33 questions
- Agrivating Misfire
- 6L80e 2wd to 4wd.
- 6.0/4l80 into fox mustang
- best place to buy gauges for conversion '68 camaro
- Need Alternator Help Quick !
- Thinking About it. 1978 Cadillac Coupe Deville 425 to 6.0 LQ9 swap.
- HELP! LS swap guru needed! E-Rod LS3 swap, ready to set it on fire...
- Best mustang forum
- L92 on the manual transmission
- I bought a 64' Chevy C10 with a 66" 327 corvette 350hp engine, Twin turbo it?
- engine bucks and jerks
- 2004 6.0litre swap into a 2001 truck - some questions
- Turn signal switches
- 5.3 Wiring Harnesses
- Help with decisions on a wire harness
- Pass Side Injectors losing Voltage through Main coil plug
- Fox Body Swap Headers
- Diablo Grotesque, Pre-build, planning thread
- GenV LT1/LT4 FEAD
- 1980 TRANS AM LS3 GM PERFORMANCE T56 build pic and question thread..
- LS stand alone harness, fuel pump won't run
- fuel tanks revisited.....Holley sniper??
- Ls1 into vn wiring
- Microsquirt LQ4 Rock crawler
- 1" set back plates work with ac
- 99 K2500 OBS lq4 swap
- Transmission is ALLLLLLMOST there!!
- Solution: Swap with 3 wire VSS
- Questions about converting C5 LS1 to DBC for E36 M3
- pcm and electric fan
- 1984 c10 Ls swap electronic speedo questions
- Easiest L83/LT4 swap recipient?
- 1987 rx7 fc s4 ls1/t56
- Supplier for AC braze on fittings and tubing?
- Any S197 Mustang swaps out there?
- BABY STEPS-Research for 911 ls swap
- Retrofit gauges for ls swap in classic vehicles
- 1999-2004 LS Swap Help?!
- second gen LS preference 5.3 or 5.7 or 6.0 for a budget build
- Another fourth gen LS swap question
- top water neck came out
- Rebuilt LS1 under performing with cam/heads
- C5Z06 LS3 Engine Swap Running Hot
- looking for advise
- New Hooker SN95 Mustang LS swap system preview thread
- H/c LS1 Iroc with billet 78/75 VS turbo and 8.8 build
- My 63 Impala 5.3/4l60e swap
- cam sensor/ spark issue
- 5.3 Fusebox Problems!
- 1966 Nova - 480 HP LS3 - 4L70E
- LSx in a 78 C10 - California Smog
- Need help! 5.3 swap, blowing IGN Fuses
- Fox body project begins
- Rock Buggy LQ9 - setup parameters - Bog/lull off idle
- 68 Olds 'A' body trans tunnel Modification
- 4L80e swapped - what shifter?
- iPhone app for code reading and much more
- Potter & Brumfield relay information
- 1988 volvo 245 wagon V8
- 67 camaro (free time build)
- 6.0 lq4 vortec swap in 72 Chevelle
- Been a very long time
- PCV valve
- Keith's 65 Impala Upgrade
- LSA into a 70 Chevelle, need pcm and harness recommendations
- 5.3 in 82 Monte Carlo, Motor mount question
- modded ls2 into a ls1 info search
- Wiring Harness Questions
- 2000 Mustang V6 to 5.3 TH350 build
- E67 TB and pedal compatibilty
- 5.3 into Jeepster Commando will not stay running
- Worlds First GEN V LT4 69 camaro swap!!
- Help with Elect Speedometer
- sway bar help
- General Exhaust Guidance
- LS2 Swap fires and dies need help.....
- Neutral safty switch help
- Ls swap s2k vs miata
- Hot August Nights ?
- LM7 swap a/c issues
- Project kick-the-CAN 2005 bmw E60 545i 5.3 swap
- 1965 Olds Cutlass LS327 swap/build thread
- 4l60e hd built for ls6
- Need help with my Ly6 6l90 build
- 66 Corvette transmission swap
- Dallas, TX 1993 Volvo 240 LM7 swap
- 58k mile LS1 questions
- Factory push lock braided line for swaps?
- First fire on cammed 69 Chevelle 5.3. $2300 TOTAL budget.
- LQ4 as LS2 substitue
- Harnass vendor for a 5.3 to Toyota swap
- 4l60E trans line connections
- LS Powered Nissan GTR
- Need help with an LS Swap.
- Sensors for motor build
- 6.2 L92 wiring diagrams needed
- P0171/4 Codes - About to torch the car...
- RUST FREE 72 K5 4X4 ready for LS swap in for sale area
- Norway: 1972 Lemans "Light Pro-Touring" 5.3 swap
- Newbie question on clutch problems
- Drive shaft bolts continued
- E-fans tripping breaker/not running
- Introduction and project F1000 build thread
- [HOW TO] 240sx speedo wiring Dakota Digital SGI-5E
- 40's dodge with a modern heart
- First Gen camaro guys help..
- Labor Costs of lm7/4l60 Swap into a 50s vehicle?
- adjust DBW throttle
- Noisy LS1
- Ls swap new edge ac
- '65 C10 2015 Silverado Pullout laying frame
- Using truck intake, and fpr?
- Starting a LSX Swap in my 03 Mustang soon need some guidance
- LT1 to LS1 style fuel pump...do I need to change the tank?
- Mail Order Tune Swaps $100 for July
- Performing a V6 to V8 swap. Missing the tach signal destination.......
- Need Help with broken LS1 Vacuum/MAP plug
- 61 Bubbletop->LS3->Exhaust man clearance?
- T6060 hydraulic line fitting
- Need help with lc9 swap harness and ecu
- Pinion angle
- Drive shaft bolts?
- '89 S-10 LQ4 4L80E Project
- Starts in every gear position??
- BP harness question
- 06 lq4 block
- Vintage Air
- data link connector Gen5 info needed
- Help me understand starter wiring
- Need TAC module help!
- Little Grandpa
- '78 Datsun 280Z LS2/T56 Swap
- 240SX Oil Pan - Canton 15-276 or Moroso 20146?
- Confusion on if my swap will work without modification
- Help with Cruise Control
- 2013 CTS Wiring
- Ls swap #2 & #4 cylinders won't fire at an idle
- Cheap PWM fan relay - solid state relay
- Volvo 240 swap/parts gathering.
- LM7 Volvo 240 Swap - No Crank
- Help choosing motor mounts (LM7+TH350)
- new guy with a question
- Fuel pump or relay won't turn on with ignition
- Overheating
- 2000 6.0 mated to 04 4L80E
- A body T56 clutch pedal travel
- 5.3 express van ac wiring
- 67 firebird LS1 Boggs at starting line
- Cruise control wiring for DBW, what type of switches
- Regular cab Colorado 6.2!
- Mass Air Sensor location
- Drive by wire gas pedal?
- LS7 and 200r4 trans
- Jaguar S Type Turbo LS Swap
- gbody monte carlo radiator nipple
- Hooker 68-72 A-Body Swap System Measurements Needed - Monte Carlo
- Does LS Engine need VSS and ECT (Engine coolant temp) to run?
- LS6 Swap In A LT1
- 199 S10 blazer 4x4 with 4.8 LS. Need AC bracket help
- Dakota Digital Dash with 97-98 3-Wire CTS
- LS3 Connector list
- ICTBillet LS Adapters in my 96 LT1 Firebird.
- Headers for 2wd Toyota pickup
- Need a quieter muffler
- Alternator won't charge, 470ohm resistor inline
- No Cruise with Gear Change.
- fans acitvate with AC
- DR44 alternator wiring
- Chevette LS1 Swap, overheating
- 50 chevy kustom ls conversion
- 5.3 truck motor - Did it ever come with a manual transmission?
- Urgent! Swapped LS1 shuts off at 1500 rpm **not resolved
- lsx Toyota pickup exhaust help
- Ls swap gen 1 Camaro/firebird 0-60
- General Tourque Specs
- LS2 C5 swap oil leak issues.
- How hard to change heads in a 240SX?
- Ls1
- 1999 suburban ls engine swap
- L83 6L90 swap into 2004 suburban
- Removal of hydro steering return on PS pump
- LS1 S2000 swap
- Anyone Use the Jeg's LSx oil Pans? Specifically Part # 50228
- Porsche 996 Turbo with LS7
- T56 swap question
