View Full Version : Conversions & Swaps
- Twin Turbo LS3 / Graziano Transaxle / Cayman
- Fuel System: 78 caprice/5.3
- Fuel Line connections
- AC high pressure switch location
- 1970 Chevelle LS2 / 4L80E Build - Start to Finish
- A little opinion and guidance, please
- What type 1/4 inch hose was use from top of motor to radiator?
- c5 vette gauge cluster compatibility
- Is an AC Evaporator Temperature Sensor Required?????
- radiator hoses
- needs lots of info
- LS2 from 2005 Corvette to 4L60e - Flexplate?
- p0053 and p0059
- ls swap into gto
- Holley Oil pan alignment
- 86 c10 5.3 swap
- 5.3 Silverado header/collector help needed
- Heater core bypass block
- What harness for DBW Red/Blue setup?
- B body ls swap
- 94 z28 ls swap guide
- 1978 Aerocoupe Caprice
- Gen 4 V6 to V8 Conversion
- Need some help with 6.0 build (been searching)
- Help with LS1 4X4
- Question about fuel pressure regulators
- A/C question - my tuner is ready to disown me
- Tony Whatley's Pro Touring Camaro
- Smaller fan that will fit LM7?
- 5.3 swap Camaro
- P0758 Transmission Code Help
- 1966 chevelle oil pan issues hitting the drag link
- 1979 Corvette with LS Power is a Grand Sport in Spirit
- engine swap
- 1997 Truck Cruise Control Cable #15734163
- 4l60 wont shift out of 1st
- obd port wiring question 2004 gto
- 1969 'Vette Earns its Keep with an LS Makeover
- LT Gen V fuel pump control module wiring diagrams
- Accessory drive critique
- 5.3/4L60E swap - trans wont shift
- 4.8 truck engine high mount AC
- Stupid Trans Question
- LSx engine block swapped over to run the LSA SC'er and LSA offset pulleys.....???????
- LS3 manifold and exhaust tubing questions...
- Lq4 into 2006 jeep wrangler lj
- BRP Muscle Rods Conversion Kit - Need Opinions
- Cayman LS Question
- RMD Garage's Understated Apache
- Deep Planning Research 73'-87' C-10
- What ECU does it have
- 1970 Nova
- Odd electrical loss on LS1 swap after 100miles
- Back-up lights
- Corvette C3 From Sweden with Love
- Exhaust shop high on fumes?
- Power Steering leak
- UMI Motor mounts w/ F-body oil pan fitment 1970 chevelle? Anyone have experience?
- Yes, Another Alternator Thread - Drag Racers, Come In
- 8l90e in first gen
- LS1/T56 in Vega no room for clutch line
- my ls wont start
- FWD auto to mate to LT4
- Best Gen III Air Filter Kit??
- LS swap
- 4th Gen Camaro Radiator Install - 69 Camaro
- 4l80 column shift issue
- accidental duplicate post - delete
- Does this swap look decent?
- Anyone used the Holley LS swap components for a 4L80E in a First Gen Camaro
- PCV routing question
- Ls 6.0 and 8.1 big block
- Fox Mustang coil-over strut ID?
- Yet another New Edge Mustang, Turbo LQ9, T56
- Fitment
- LSA swap recommended fuel line size
- 1969 Camaro L99 with 6l80
- 1938 Ford Pickup Becomes Barrel Racer
- 2000 LQ4 and LS6 intake with 2005 GTO accessories
- 1974 Chevy C10 JY Turbo fuel question
- O2 Sensor Heater Codes - New Sensors
- Can i use 5.7L harness with 6.0
- Ls swap new edge
- Cadillac TR6060 conversion to C3 corvette what do I don't need on the transmission
- Compatibility between 01 4.8 and 04 5.3 4L60
- What Would Have Been a Camaro
- 65 gto 421
- 5.3L 4l60E swap
- Jeep L92 swap questions???
- Duel to single fan wiring
- LS Hilux with twins
- 67 Chevelle trans crossmember/driveshaft clearance
- AC Experts????
- Transmission
- Doing a 5.3 build on 300 siverado and wanting to put a turbo 350 how do I do so
- square body ls swap engine mounts????
- Braking & Idle Questios - Hydroboost
- LQ4 in Sonoma build
- OK, so I am pulling the trigger finally
- Stalling with hard braking
- 5.3 to 6.0 swap pcm problems
- Need help finding a fuel sending unit
- EFI fuel system for fuel cells
- accessory drive without brackets
- Moroso 20142 oil with a AJE k-member in a mustang
- let's build a miata on the low
- 2005 subaru RS + commodore LS1
- 69 Camaro LS3 swap upper rad hose needed
- High horsepower with power brakes?
- first fire up on swap no spark or fuel
- LS3 Exhaust Manifold flange size?
- If a Corvette, Camaro, and a Firebird Had a Child
- Need help identifying a truck harness wire
- 1969 Hugger Orange C10 - New Project
- Upr k members and speed engineering headers
- Newly swapped 4L80E wont shift
- Hey ls family
- 411 swap on 99 Tahoe
- LS swapped k1500
- 69 El Camino Ls swap
- Imagine Track Day in this LS1 Powered RX-7
- 12v+ Power only when engine is actually running
- Transmission spacer and flexplate
- LC9 swap to non AFM
- More questions about LS 55 swap
- stock harness
- ? Where to buy AC compressor electrical connector?
- Boyd Welding EFI Fuel tank
- LS Swap in 55 Chevy 210 Radiator Question
- Rear end chevy
- LM7 swap won't start
- My first ls swap and motor seized HELP
- Gmpp lsa standalone ecu
- 2004 Ford Ranger 4.8 eBay Twins
- Driveline vibration in a certain range
- help me spend money. procharger or another build
- 64 f-100 lq4 low buck swap
- What is this LS2 Bracket?
- 5.3/ 6 speed standalone harness
- 97 S10 Twin Turbo 5.3 build
- Getting new 6L80e up and running
- Engine and Transmission Help!!!!!!!
- Custom engine harness - 5v reference issue
- Tanks Inc. fuel neck problems.
- Budget 5.3 in a '69 Bird Newb questions
- E46 M3 Powered by Supercharged LS2
- How to guide for troubleshooting a fuel sender
- Valve/coil covers
- LS 7 heads LQ9 block
- LS3 E-ROD Gas tank on 2nd Gen F-body?
- 5.3 swap in a 98 Camaro - Can't get it to start
- 2001 Corvette Trades LS6 for 1,000 hp LQ9
- Turbo 5.3 idle issue.
- Gen IV 5.3/6L80E into a 1974 gm truck
- Junkyard LS Swap, The Cheapest Solutions
- 2015 Silverado gauge cluster working in swap
- sqaurabody ls swap questions
- HELP!! TPS 100% after 67 Chevelle swap
- 1967 Camaro Ls 427 / 4l80e swap
- Rear end gearing in a 99 camaro with a t56
- fuel regulator with rail return
- Durability of LS swaps into 60's cars
- 6.2 swap vs 6.0 swap
- Any details on a 67 Chevelle LS Swap with AC?
- Swap idles but dies when hit throttle
- 2001 5.3 to 79 camaro wiring questions
- 2002 5.3 ECT sensor wiring question
- Turbo LS/T56 IRS Swap New Edge Build Thread
- LS2 T56 Nova Build
- 3rd gen nova ls swap shorty header
- Mustang LS Swap Nothing Fancy
- Tremec t160
- LSX Equipped Turbocharged 1936 Ford
- LFX/auto into RX8 no pedal response
- LS3 and T56 in '68 Camaro
- 1999 tahoe
- LQ4 or LQ9
- TH400 and e38 pcm?
- 03 Ss Silverado
- Carb Conversion, computer delete, problems?
- Big time newbie with 72 Nova and LS Swap
- Jaguar XJ8 Gets LS3 Power
- Wiring 2-Post Main Power Switch
- F Body advice needed
- Mirco Squit tune
- It's finally done LT to LS swap
- Gauges don't work in my 98 camaro
- ls swap with a 4l60e
- Help! 5.3 ls foxbody swap
- 73 Camaro 5.3/80e swap with 8.8 rear EDIT: Now running!
- Dbw harness 2 wire plug
- 5.3 Swap into 1971 C-10
- Passing emissions testing in Phoenix
- 4l80e swapped in, overdrive not working
- Conquest: Home-Made with a V8 Heart
- Foxbody Radiator
- LS into a 1989 Subaru XT6 wedge
- Hello need help
- Ls swap new edge
- LS1 Swap into 2000 Chevy Blazer
- Bad Fuel Pressure Regulator caused broken rod & hole in block. Fixable ?
- Introduction with accessories question on lq4
- LY6 / T-56 driveshaft order to be made - quick questions
- haeness hookup
- LQ4 T-56 DBW, engine wont rev past 1500 rpm (ish) abuse mode removed
- Need info for GenIV Swap Using BCM
- 1954 Chevy 3100 5.3
- Hello from MotorJoe!! New to the LS world. plans to build a 91 c1500 LS2. tips??
- Mounting LS3 Fuse Box mounting
- 5.3 To LS 1 Swap
- Missfire under wide open throttle
- 2006 express 6.0 pcm pinout
- New member, need help with stand alone harness
- Driveshaft for my 67 chevelle
- Have fuel pressure, have spark- still no start
- LQ9: can I rotate the throttle body on the manifold?
- Crate ls3 easy steam solution
- LS1Nova71 need help! Schematic help please...
- harness hookup
- 5.3 with 6.0 heads ported backfire and initial stumble
- Corvette fuel filter diameter?
- 92 4l80e In 2000 3/4 6.0 help
- Finally started my 67 Chevelle Turbo 5.3!!
- Questions about removing engine & trans...
- Show off your painted motors (orange, blue etc) with a TRUCK intake
- RWB 964 Rises from the Ashes with an LS3 Implant
- 93 truck 05 6.0
- E38 pcm with 4l80e info needed
- New LSA - Noise in gear - Help!
- 1st Gen F-body - Hooker Trans X-member ??
- 93 rx7 5.3 procharged swap wont start, unlocked pcm
- LKQ Pricing Question
- upgrade water pump for higher flow at idle?
- Ls1 Front Accessory Question
- LM4 rebuild Jeep conversion
- fuel sender info
- LQ9 swap first street drive "bogging" issue
- Truck intake on LS1
- Header Suggestions for LS Swapped 69 Camaro with column shift
- LSX b15 into 96 Impala SS WIRING
- 94 Blazer 4x4 LS swap question
- ls swap and transmission range switch
- LQ4 DBW, accelerator pedal not working / no reponse
- A-Body LY6 questions about FEAD & VVT
- 2014 4.3 swap
- E38 ECM 4000 rpm rev limit with manual swap figured out
- Need flywheel/clutch and bellhousing advice.
- Help figuring out my intake swap from a truck 4.8
- 1970 Chevelle from Goolsby Customs Was Built to be Driven
- Dirty Dingo slide without hoist?
