View Full Version : Conversions & Swaps
- Speedometer signal
- Hooker Blackheart 1973-87 Chevy K10/K20 LS and LT swap
- Is it a Prototype, a swap or what ?????
- Vibration only between 2700-3100 rpm with 40%+ throttle
- Ram electronic gear selector with 6L80/90E
- Drive By wire going WOT once powered?
- Lq9 with early model 4L60
- 1966 C20 Longbed to C10 Shortbed
- Ls swap random misfire +25 bank 1 help
- Issues with U0107 TAC module comm. Pedal/ ECM confusion.
- 1996 Land Cruiser Swap
- Exhaust shop in Atlanta Area
- 1967 Camaro LS3 fuel system
- 1999 v6 firebird to 6.0 lq4 harness questions
- Kit car with donor Camaro. How to determine What Camaro??
- ls to 1978 trans am
- 4l60E fluid amount after swap
- Looking for recommendations on P01 vs P59 and DBW vs DBC
- Advice on fuse block for L99 6L80 swap
- Howie's Z28 5.3 Gen 3 LS project.
- LS3 in a 2002 C5 track car...some questions
- 5.3 Ls to th350 Detent Cable problem
- Lm7 to Tko 600 swap
- Kit car SBC 350/350 swap to 4.8/5.3 & 4L trans
- Buying Holley Terminator X Used?
- Ly6 cam info
- 4.8/4l60e to 6.0/4l80e Swap Help
- I'm lost on these O2 sensors
- 4L60eAuto bell to ford t-5?????
- LS mechanical fan blade options? Need smaller than factory
- LS3 swap into 2000 Trans AM
- best transmission
- Newbie needs gearing HELP‼️ What’s new?
- 4L60E Trans
- 5 Affordable LS-Powered Performance Cars
- LS Swap ECM/TCM
- 2001 Silverado DBW to Cable Throttle Body Conversion
- Colonel Mustard
- Alan Grove low mount AC compressor bracket
- Any difference
- 04 silverado v6 to v8 swap
- T56 to 4.8L
- G Body LS swap TAC module APPS help needed
- Need help fitting headers!!
- Surge Tank Suggestions
- Ls3/ls7 card style maf air intake/air cleaner
- Does this PCM have the IACV drivers?
- MSD TCM wiring questions
- Swapping engine and trans from a 2015 Silverado into a 2005 Escalade.
- Odds and ends for my LS swap help needed. PCV, Oil cooler, Terminator X etc
- Madaguy 1955 Nomad Build
- Which LS motors share the same "footprint"
- 4l65 Transmission Help needed
- LS Swap Wiring Question
- 4.3 to 4.8 Silverado swap
- s197 turbo build 07 mustang
- Ly2 4x4 manual swap
- 4.8 vortec swap problems
- 1999 S10 - LS Turbo Swap
- Humvee Ls 5.3 swap with 4L80e
- E30 with L33 and Dual Clutch (DCT) build thread
- Newbie needs help: LQ4 into '77 Ford F-250
- Exhaust leak or something else?
- sn95 swap
- terminator x harness
- 1971 Cutlass
- Buford - 1941 Ford COE LS1 swapped
- Panel for fusebox/relays??
- Intake swap
- Colorado 2009 L4 TO LS 5.3
- 58x to 28x
- Factory '86 GMC cruise wiring for DBW PCM ??
- LS6 with classic intake manifold ?
- Where to get GM wire harness loom clips?
- 1994 TransAm LS3 Swap Is Finished!
- x6 e71 (LM7 swap ) need help
- '03 5.3 to 6.0 LQ4 swap
- 1990 Mercedes Benz SL 500 5.3/TH400 Turbo Build R129
- 2000 ls1 Doner car For 2001 3.8 Firebird wiring Help
- Lq4 to l96
- Ford Ranger Swap: 02 L59
- Swapping my 2015 Silverado ls3 with a 6.2 LT1
- I have a 1990 chevy 4x4 with a 305 efi what I need to swap for a 2004 5.3 motor in it
- Fuel gauge to pcm wires
- 1989 S10 Build Thread
- 1257080 TB wiring help.
- L92 throttle body/injector questions.
- 6.0 93 obs swap WIRING!! help
- 1971 Riviera L92 Swap.
- Won't shift
- Brake booster for 1970 Impala
- TBBS intake fit stock hood fox mustang
- 1963 corvette LS2/3
- Last few wires for Connect and Cruise swap
- Autometer speedometer input from e67 ecm ls3
- LM7 crank no start - fires on starting fluid
- Question regarding GTO e40 ecu pinout
- 98 1500 to LS1
- 1967 4 door rebel
- No fuel pressure / Holley in tank pump
- Cooling system issues LS1 swapped BMW E46
- Finally finished my 68 Firebird
- 1969 International Loadstar 1600 LS SWAP
- 1990 OBS 2x4 auto TO 6.0 w/manual - CD009 or AR5
- engine swap btw 1958 cars
- OBD2 scanner won't connect with engine running.
- Ls3 6.7liter?
- No Throttle on EROD LS3 Swap
- LS3 engine swap evap
- Boosted 70 Impala Intake options
- General Dimensions
- Holley 12.3 fuel level help
- 74 4.8 swap planned - anyone here in San Diego, for advice?
- IAT sensor position?
- 2000 5.3 DBC GEN III LM7 wont start, but runs with throttle
- A/c high idle and fan control
- Morning/Cold Start...hesitates, flutters and then stalls
- Calling all electrical gurus
- 92 YJ with 4.8L
- Injector issue
- Harness pcm
- 2005 GMC 1500 5.3 Swap
- Ford Aircon signal question... can I turn a square wave 12v A/C signal into 12V DC?
- Questions about 6.0 in Chevelle
- The Great 88. Bricknose LS Turbo
- Differences in the 4l60e trans based on year
- LS7 Swap: Engine runs rough and goes into low power
- 1976 F100 4.8/4L80e Swap
- Confused on Flexplate for 1999 LQ4
- 2000 5.3 oil pressure sensor in 1990 K5 Blazer
- Chevy 5.3 swap
- 1969 Chevelle turbo LS ProTouring build 1KHP, 14" brakes, T56 Magnum etc....
- Engine swap what will fit
- Cam position sensor
- Limp Mode Help
- LS swap into Cutlass. only runs in start position
- LS3 Swap into 68 Camaro
- Question regarding e40 reverse lockout on 2006 GTO
- Not sure what flex plate I need.
- P2138 '59 Apache
- Corvette regulator distance from gas tank
- 93 TA help with tank swap
- LS3 Throttle body on 01-02 DBW truck
- LS3 swap stock or Holley kit
- 2014 chevy silverado 4.3l v6 swap to 5.3l v8
- Accidentally started new crate LS3 with no oil pressure
- Fuse/Relay box?
- 5.3 swap
- Need to fit M14x1.25 temp sending unit. Relocate ecu sending unit to other side?
- OPTIONALLY Hydrogen Powered 4th Gen LS3 / BTR Stage 2 Cam possible?
- What intake duct could possibly work here?
- Brushless Fans for LS Swaps DIY - Let's get out of the stone age
- Ls swap 96 ta with t56
- Alternator options for 1968 Camaro
- Ls1 Swap - start up problems/fuel pump?
- T42 4L80E pinout
- Can Big Block Engine fit in a Pontiac Firebird '90?
- LS9 Supercharger on Corvette LS3, possible w/ Vintage Air Compressor
- Cranking amperage for a stock (-ish) LS engine??
- Using a Cable driven VSS with speedo ratio adapter box
- Looking for dimension clarification
- Dakota Digital Help
- Ls Swap 5.3 with 4l80e transmission question
- Ls Swap 5.3 pcm & harness concerns
- General AT question
- 5.3 ls with BOP th350 problems
- Iron Gen III vs Alum Gen IV
- Magnuson TVS 2300/2650 on LS3 Front runner
- SLP supercharger and Gen3 block
- 5.7 crankshaft in 6.0 block
- 2003 LQ4 DBC won’t start but will run
- Hooker Blackheart - no reducers - preferred way to connect?
- Miscellaneous problems with my 1979 firebird 5.3 ls swap
- help with ls 5.3 and 6.0 wire harness and pcm
- 68 Chevelle with Holley swap....driveline vibration
- LQ4 swap dies instantly
- Lq4 with mods question
- Hello all foxbody t56 ls1 swap.
- LS Swap into Fox Body
- Anyone able to guide me with stripping an LSA (CTS-V) harness and PCM?
- 2003 4.8 + 4l60e speedo question
- LS3 350z dying throttle while driving, P060D
- Wiring harness change for trans change
- Questions on the nv4500
- LS 5.3 Truck Motor swap issues
- California 2003 S10 swap questions
- LS1 swap into early chevy trk
- LS3 short block with ls1 top end
- Building oil pressure for 79 firebird 5.3 ls
- Ls swap wiring question
- Tach issue
- 1979 firebird LS wiring not working
- Lq9 to l96
- Custom 1967 Corvette by Jeff Hayes Headed to Auction
- 98 Camaro V6 Swap to LS V8
- T56 magnum e36 driveshaft looks too long.
- 1979 firebird wiring to 5.3 ls
- 1966 GMC P1000 (C10) Resto w/6L & 4L80e
- 79 firebird wiring for 5.3 ls
- Stock truck intake, hole on one side
- Dakota Digital BIM-01-2 question
- Fuel line size
- Rubber versus polyurethane engine mounts
- 79 trans am stock radiator to 5.3 ls coolant hoses
- 6.0 ls swap on 69 camaro
- Oil pan and filter confusion for 5.3 ls swap
- 944 LS Conversation Shops in the Mid-Atlantic?
- Pictures of my LS conversion
- LS3 / 6L80E Swap.. Rough idle..few codes
- LS-Powered C2 Corvette is a Real Smokeshow
- Not an LS swap.. but 1993 Silverado V6 to Carb'd 1970 SBC 350?
- 5.3 Jeep - VSS, OBD and other questions
- Fuel pump harness connector
- iat sensor problem
- Emissions crap
- Return style fuel system
- Anyone use a MSD Solid State relay for relay block?
- 2002 f150 4.2L v6 to a LS
- LS3 into 94 LT1 F-body, return style fuel rail?
- Crossover Line Hitting Alternator
- Who is considered a Chevy Performance LS crate engine guru?
- 5.3 Genesis Coupe
- Will 4.8 LS work w/ borg warner T5?
- LS1 swap coolant tank hose routing question
- Need measurements of a holley 97-205 mid-mount Harmonic Balancer if possible
- Second Gen Camaro overheating issues
- An LS4 in an 80 Corvette? Say it ain’t so.
- Lq4 swap
- ls1 auto car . manual engine harness
- New pan, tube, ring..oil pressure from ops
- New swap project, 1968 Camaro getting LS2-T56
- DriveByWire help, GENIII into 73 nova
- Engine swap headers
- 2010 CTS V "clone"
- Thermostat and housing
- 1995 camaro 3.4l suspension swap
- 5.3 ls swap into 1979 firebird fan problem
- 02 Sensors New - Error Codes - C10 Swap Help?
- Need help with nss wires
- Fuel system for a 1979 firebird 5.3 ls swap
- 5.3 ls motor mounts for 1979 firebird
- Upper radiator hose help
- Need advice/info with LS swapping a 1960 corvette
- Headers for 68 Camaro - current ones hitting
- LS3 crate: long block vs complete for f-body?
- Help With Fast Throttle Body
- 57 chevy truck swap, cooling issues
- LS Swap Direct Fit '96 B-Body LT1 Harness Question
- 5.3xth350/400 questions
- 1996 firebird 3.8 ls swap , no fuel ,no spark gremlin
