PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 [127] 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. John at Speartech?
  2. LS1 & Procharger in a G-body??????
  3. Engine start up
  4. k-member question on firebird to LS1 swap
  5. Which do I build
  6. 5.3L Swap 700R4 lock up?
  7. What upgrades should I do to the LS1 before I throw it in my bmw...
  8. WTB - Helms Manual Set 2006 Corvette LS2 engine with autotrans
  9. Looking for a little help with tuning using HP Tuners
  10. How do I remove the roll pin, in the slave cyl?
  11. Carshopinc.com starts a ls swap
  12. parts for mustang swap? wiring? headers?
  13. 99ls1 in a 72 vega?
  14. qestion
  15. L92 swap - wiring question
  16. Need wiring help, newb here
  17. A/C on 84 Chevy Gen III swap
  18. Mast Motorsports L92HO/6L90E Powered 1968 Short/Wide---Hot Rod Power Tour Long Hauler
  19. Help-Swapping Gen III 4.8L into 84 Chevy p/u
  20. 98 ls1 computer compatible with 98 trans and 01 ls1?
  21. Carb LSX guys step in please...
  22. what radiator to use in LSx swap?
  23. Truck Oil Cooler Block
  24. How should it idle with these disconnected?
  25. Cut harness issue
  26. Motor mount question
  27. Pink wires
  28. My LQ4 into G-Body Swap (updates to come)
  29. LS1 in my 55 Chevy
  30. what do i do?
  31. motor plate for a 6.0ls in mustang
  32. Problem
  33. dbw not working
  34. debating swap on an 88 ranger
  35. question about truck harness.
  36. Problems (240sx LS1)
  37. Chassis Harness and HVAC Box
  38. Ls1 into a 3rd Gen
  39. the mother of all lsx mustangs :D
  40. K&N Cone filter for my LS2
  41. Surging
  42. LS1/Muncie
  43. Any body putting a Ls1 into a 67-70 impala
  44. Parts ID
  45. 03 5.3 DBW to cable throttle conversion
  46. 1st gen Camaro/Firebird LS swap performance numbers
  47. 1991 RS Convertible LS1 Swap with pics!
  48. Manual Transmissions
  49. K Member Swap Possibilities
  50. Does PCM Case need to be Grounded?
  51. LS1/Elec Throttle-> Pause/miss?
  52. 5.3 LH6 Progress and Problems
  53. Elelctric fan problems
  54. LS1 into a 87 FOX BODY!!! NEED HELP!
  55. LS1 to LQ series swap
  56. Ls1 Fuel pump issue? I think?
  57. Hot August Nights!
  58. ls1 in a 94 trans am need parts list please.
  59. 57 chevy L92 swap
  60. 5.3 in a 49 pickup
  61. a good oops?
  62. My Toy 1969 Firebird LQ4 L92 L76
  63. P0453: How to get rid of?
  64. cruise control module v6-v8 swaps
  65. question concerning fuel relay power from PCM
  66. More 1992 LS3 VIDEO. 3rd gear drive by.
  67. msd 6010 box and timing?
  68. ls3 exhaust in first gen camaro
  69. Any Chevelle owners able to run flipped truck manifolds for turbo?
  70. The beast is finally back on the road with LS Power this time!!
  71. A body/ first gen f body with 4l60e in here please
  72. LS2 in a XR4Ti
  73. What motor tranny to buy?
  74. 67 RS LS1 .. 16" fan too small?
  75. Corvette Power Steering Hose
  76. Intake manifold help
  77. Drive by Wire or cable?
  78. PCM Bracket?
  79. Any successful c5 cluster swaps?
  80. Quick throttle body question
  81. Engine runs for a few seconds after key is off
  82. Keeping VVT from a 07 escalade
  83. finding a LS1
  84. ls1 in mustang parts for sale
  85. How much to cut out LS2 pan?
  86. Lights/Wiring problems...ideas?
  87. Russell Twist Lock Hose VS Stainless Steel Hard line
  88. Give me a hand here! Myth or Fact? Thanks guys
  89. 98 car with 00 harness/pcm...HELP!
  90. Removing fuel related codes
  91. Fuel rail options with return style fuel setup
  92. 1979 Z28 02 LS1-t56
  93. Bullrun Caprice
  94. T-56 in my 64 Nova
  95. fuel return line
  96. cadillac ctsv tranny question
  97. Back fire issues
  98. Shopping list for 5.3 into '46 Coupe
  99. BRP LS conversion kit 2nd Gen Camaro Firebird Motor Mounts/Crossmember
  100. GTO trans wiring?
  101. How do I know what year my motor is?
  102. complete longblock and gto pan for sale
  103. stock donor harness
  104. Blazer with Supercharged LS2
  105. Question about radiator, fans -LS2 into 97 Camaro
  106. DTC Code P0706, whats wrong with my transmission
  107. VATS bypass
  108. 66 GM A-body LSX swap
  109. ls1 to mustang headers and driveshaft
  110. '83 G body - ls6 swap
  111. 94z lt1 to ls1 swap Tach is off
  112. 2001 camaro V6 to LS1
  113. Ls1 in third gen camaro
  114. hi idle-carb, msd 6010
  115. 93 RX7 with LS1
  116. RX7 LS1 Gauge Cluster issue
  117. LS1 RX7 question! Please help!
  118. ls1 into 95 formula wiring questions?
  119. Circuit 1020: Where is it at?
  120. Gen III Wyllis Jeep Swap?
  121. Who Has Made Their Own Wiring Harness
  122. first gen camaro question
  123. LS4 help
  124. its alive! OMG!
  125. converting 5.3 truck motor to fit in LT1 camaro
  126. Fitting size for Walbro pumps 255
  127. World's First Flex Fuel '71 Chevelle!!
  128. Ls1 into Xtreme Blazer (Plz post opinions and helpful facts)
  129. ultimate DD 4.8/5.3 swap into 95LT1 w/t56
  130. How Much is a LS1/ Mudstain worth?
  131. Is it worth the trouble?
  132. how is the t56 reverse lamp switch wried?
  133. opinions on socketless hoses for fuel
  134. 89notch 6.0swap
  135. need all info on 1974 ls1 swap
  136. Anyone ever make a front runner style accessory drive?
  137. 4th Gen pedals in 3rd gen T 56 swap and clutch master cylinder
  138. Started my LS1 swapped 240sx today for the first time v.videos
  139. How fast is my car?
  140. ls1 muffang
  141. Fuel pressure/return questions?
  142. Belt question for ls1 a/c delete
  143. What do you guys think....
  144. stock exhaust manifolds for a 69 camaro
  145. Question about intake
  146. Brake Booster connection
  147. Performance Auto Fab's 1951 Austin Sheerline Ls1 swap
  148. LS1 into a 51 Chevy Pick-Up
  149. 71 Nova 350/350 to 5.3/4L60 conversion help
  150. LSX fox body questions
  151. need supplier for a few wire connectors. LSX
  152. Ls engine in a 94 Z28!
  153. Need Fuel Injector pitails
  154. LQ4 accessories in C3
  155. LS1 RX-7(FD) Complete!
  156. What is this, and do I need it?
  157. PA Racing LT1 Tubular K-Member
  158. 3.4L to LS1 Swap - Fuel question
  159. VDO Tach Install - Lessons Learned
  160. Can 06 LS2 engine be swapped and run off stock ECM and modded harness w/o reprogram?
  161. Truck Harness
  162. P1153 issues
  163. Which cables from PCM to OBD-II
  164. a/c wiring question
  165. 1986 Pontiac Fiero GT
  166. camaro cluster in a stang?'s
  167. Its alive!!!
  168. Starting an opinion thread that is controversial, EFI vs Carbed LSX engines
  169. I have a dumb question
  170. Compressor relocation brackets?
  171. LS1 in a 3rd gen w/ M6
  172. How To Identify Connectors In An 02 Harness?
  173. 240sx swap question
  174. Rx7 owners, come in please ( need advice )
  175. FS: 2002 PCM with harness
  176. rear end issues
  177. Colorado Swap
  178. LSx Coolant Temperature and Oil Pressure Sender Adapters
  179. Manifold vacuum hose for brake booster 11/32" or 3/8"
  180. 5.3 wire harness
  181. S&p
  182. Help! HP Tuners keeps saying,"the interface was not found....
  183. Do I need to connect TCC-brake cable
  184. how to calculate speed from rpm
  185. Engine rpm drops
  186. Please help with swap
  187. Gen IV 5.3 Vortec in 1997 Tahoe motor mount questions
  188. Ls2 & 4l60e
  189. Stinkin Pink Wires!!! -plz help me finish this swap-
  190. pics of my 6.0 swap to 70 chevelle
  191. 98 Grand Prix GTP RWD conversion with LSx/T56
  192. Power steering pump interchange through LSX motors
  193. 1992 Firebird LS3... Video....
  194. What do I need to make it run???
  195. Where can I buy 3 1/2" to 4" 90 intake elbow?
  196. Neutral Safety/Clutch Pedal Position Switch?
  197. Anybody have a GM partnumbers for 98-02 Fbody accesorys?
  198. LS1 S10 guys please help
  199. tbss wiring harness in camaro
  200. 99-02 schematics
  201. lsx in a 96 camaro
  202. If you did your own fuel system, please come in
  203. ls2 to a 1970 deville convert
  204. Some help please on a conversion
  205. I finally got my engine, now I got some questions...
  206. I need help!!!!!!!!!!ls1 in 67 camaro
  207. LS1 into 1999 Pontiac Grand Prix??
  208. LS2 or LS3 Swap
  209. S10 Wiring question
  210. 4th Gen Fbody motor mounts in 1st Gen Fbody.
  211. Need a mellow-sounding muffler -- !
  212. Fuel tank: sealed or vented?
  213. MIL & TCC Q's
  214. Wiring harness questions
  215. 1979 c10 silverado
  216. OBDII swap into OBDI car
  217. Sponsor for external Walbro pump?
  218. Bad ass third gen build
  219. 5.3 starts but wont run?
  220. LSx into Jet Boat??
  221. Another LS1 S10 build.
  222. DBW pedal mods for chevelle
  223. Moroso 20140 pan install ?'s
  224. Wiring up underhood fuse block
  225. coolest coil covers ever
  226. Instrument panel on a 87 S10
  227. ls1 master, which line is for the front brakes
  228. 78-81 guys. Where did you mount your PCMs?
  229. LSX Conversion in 73-77 GM A Body
  230. 1st gen camaro update and question
  231. 74 nova 00 ls1
  232. Thanks, '70 Impala running!
  233. LSx in a 97 Z28
  234. LSX/t5 question
  235. Any interest in my Edelbrock 7118 carb kit?
  236. Motor Mount Plates
  237. how do i test the crank sensor & circuit? injectors & coils not firing
  238. Any successful 4th gen LS1 dash (w/cluster) swaps??
  239. 06 Rubicon Ls6(gm Crate) Conversion
  240. in the middle of swap please help!
  241. A/C Cycling Sometimes, Sometimes Not?
  242. Help me check my order list?
  243. LS1 into 84 vette need info-wiring harness,ect
  244. updates of the ls1 94 v6 mustang
  245. sbc to 4.8 LS motor all info is BIG help
  246. Anyone Need A New Ls1 Conversion Swap Car?
  247. why not?
  248. inline fuel pump options
  249. Just your average Ls1/T56 stripped RX7 With Plans of Racing
  250. Bastard motor
