View Full Version : Conversions & Swaps
- C5 Torque Tube, who can lengthen one?
- Got myself an LS1!!!
- LS1 conversion via 928 Seen any?
- MERCEDES Benz W114/5 CE/8 ls1 swap
- LS1 into a Lotus?
- 2002 6.0L LQ4 installed & running on Megasquirt! 1967 chevy pickup
- pics of my ls1 240z swap
- Video of LS1 944
- mercon III or synchromesh
- T/B Bypass hose question???????
- New discoveries for LS1 into Mustangs Swaps
- Ls1 and Wayne Due subframe
- Rear Brake Question?
- Help- No spark PUZZLER
- 98 m6 to a4 swap
- Cooling question
- 1968 LS1 Camaro
- how hard and/or realistic is an ls6 in an 88 iroc
- Help! Can I swap a 5.3 into a 4.3 truck?
- 300z Ls1
- LS1 with a carb setup
- Anti-Rice
- oil cooler line plug
- ls1 c4 corvette conversion, some questions
- Vortec 6.0 to 87 Monte LS swap
- 2100lb roadster built for under 20k?
- LS-1 Swap Parts Needed.
- Fuel Regulator on return line of 5.3 Gen III?
- removing excess wiring
- lt1 to ls1 swap
- questions about 98S-10 to a 5.3L??
- Which should I go for LS1 or LS6
- Slowly but surely
- Might be doing LS1 in thirdgen conversion, any tips or warnings?
- 96 Tahoe to LS1 conversion questions
- 6.0 motor swap
- Are these conversion motor mount plates similar to the S&P plates?
- ls1 conversion kit for 67 gto $530 ??
- LS-1 Porsche 944 Racecar - Fired up and running
- Oil level sensor and PCM connection?
- Fox Stang LS motor guys...how much room to hood, and what accesories?
- 98 Ls1 Pcu
- Best spot on engine to check for angle?
- Old Flywheel on 5.3
- Can any 4L80e go with a 6.0?
- Swapping LS1 into V6 Camaro
- What to do with LS2 throttle body?
- 6.0 conversion in 95 Caprice,,=UNDER WAY!!
- LS1 AC Question!!!
- notched oil pan for 2nd gens
- truck headers on s-10?
- storage crate for motor
- 2001 camaro power rack in 69 camaro
- Low Oil Level Sensor
- 87 firebird gta f/s
- Gto Dash Wiring Help!
- 68 birdls1 for sale
- clint
- So it begins...fox conversion
- GEN III swap into early S10/Blazer
- exhaust manifold help
- 70 El Camino...Lt1 or Ls1
- header help for ls1 in 69 camaro
- Trailblazer straight 6..
- 95 Mustang + Gen III (6.0 fox body)
- hehe.. GREAT use of LS1!
- Need a little 98 ECU Help/NO SPARK
- need help engine want stay running, will pay for help
- 5.3 to 98 rcsb
- Sweet S-10 conversion on Ebay....
- Needed HELP hardtop to t-top conversion
- couple of swap questions
- LS1 Engine Running Poorly
- 8.8" in Nova
- fuel/mounting questions for 1st gen camaro
- 69 camaro ls1 harness and computer
- LS1/Vortec radiator hoses
- Rim ideas for my 73 Camaro LS1
- Anyone make a kmember for 66 gto-ls1
- 281 F-Body
- few questions on astro vans
- crate zO6 Motor in 94-95 Camaro or T/A?
- fuel pump control
- PCM mounting
- Hurst Pistol Grip Quarter Stick will it work with a 4l80e?
- Questions on Conversion
- looking for those LS1 grandsport pics
- 93 Rx7 sick of Rotaries
- GMPP Trans controller?
- 3rd gen LS1 computer ?
- LS2 Third Gen Project has begun!
- abs?
- automatic shifters
- fuel relay not getting power so......
- Need help on purchase of LS1 engine
- 5.3L/t56 in a 98 camaro
- help identify LS1
- Options with hydraulic clutch?
- Keeping my baby cool
- ls1/t56 first gen swap.....
- Third gen PA tubular k-member and MACs
- Has anyone used these LS1 to AN fuel line adapters?
- Can you use LT1 hydraulics on LS1 six gear
- 76 LS1\M6 in May HP Pontiac
- someone who's been there
- Question on LS1 swap.(Fuel System)
- gen 1 sbc swap pictures?
- FD RX7 w/ 4l60e?
- LS1 header measurement
- I`m looking for a complete LS1
- ls1 swap
- Corvette Gas Tank dimensions
- Third Gen LS1 conversion motor mounts for sale.
- Wasn't feeling good today.. Sooo
- heated seat conversion
- my exhaust sucks, please give me input
- 1st. gen to 4th gen brakes
- Estimated cost of Fox swap?
- Cruise Control Wiring Questions
- inline pump question
- Removing Tranny Dowel Pins how to?
- Buying a ls1! what to look for
- tunnel clearance on a ls1/68 camaro conversion
- Fuel system conversion!
- 5.3 LS1 in a third gen
- 2nd gen fbody ls1
- WTB 2001+ PCM or trade for my 2000 PCM
- Data Link connection location
- Chevy 2 headers
- Headers for 2nd Gen? Anyone?
- Here comes another Third Gen LS1 car...
- Good price for a ls1
- vette gauges
- How do you hook up OBD II connector to Engine Harness?
- 98-02
- test
- Engine details.
- Help with 3rd gen swap!!
- Can you still access the PCM w/ ATAP or Edit?
- NEED Harness to wire dual power seats in a camaro
- long tube headers for 68 camaro w/martz chassis
- california SMOG!!!!!
- 10 sec videos of the LS1TECH '69 SS
- Anyone ever put an LS1 into a 914??
- LS-1 944 porsche
- non ls1 mazda..
- What was your 3 biggest issues to overcome?
- Help Hp Tuner??????
- LS1 for sale
- sway bar conversion
- 3rdgen LS1 swappers, where did you mount your PCM?
- Front Springs
- Traction control adaption
- weight numbers
- what belt tensioner to use?
- Building my own harness, any good info??
- 1994 v6 to carb 383
- LS1 in a Fox Body Questions
- Traction Control!!!!!!
- Wiring
- Engine Covers
- 1959 LS1 Apache?
- 68 Camaro questions
- To EGR or not
- ls1 in 91z vert?
- Had a wreck in my Z!! Get a V6????
- 1981 Corvette
- LS1 in a 240sx.....240ss!!!!
- 5L50-E Transaxle for ls-1 For Sale
- Throttle Body/Air Intake Tubing
- LS1 in Integra?!
- For Sale Tubular Control Arms 69 Camaro
- Non Supporting Vendor Reminder
- LQ4/LQ9 in a B-Body
- ls1-->6 banger
- Evap/Purge system
- 6.0 in 71 GMC 4x4
- 98 PCM upgrade
- LS1/700R4 in 3rd gen(PCM signal ???)
- Need help finding a project car
- LS1 into a 1993 GMC Sonoma need some help...
- LS1 in RX7
- Need Help Wanting To Convert 86' Vette To Ls1
- 10.7s tonight in the '69 Camaro
- Helpful Accessory Drive Conversion GM Part Numbers for OEM Parts
- First-gen starting point advantages/disadvantages?
- Thoughts on a tank mods to run fuel injection.
- Flange Bolts
- 1st/2nd gen shifter conversion kit
- 90 300zx LS-1 header question
- stock o1 intereor fuse box cover
- Steering U Joint won't clear LS2 manifolds
- MAC Mids hitting the steering shaft!
- Need corvette acc. brackets for S-10 swap
- Hooker Longtubes fit!(but not perfect)
- What is needed to put an LS1 in an '80 vette?
- PCM/wiring harness question.
- computer harness conversion
- c3 vette headers
- LS1 in a Chevy 2
- fox body ls1 question
- data link connector
- LS1 into a 95 v6 camaro
- Fs:parts For Ls1 Conversion
- p0178
- '69 Camaro magazine article online!
- V8 Dash Conversion
- Carb'd Gen III V-8's?
- 4x4 Camaro......
- Headers for 280Z conversion
- Alt bracket?? & crank/converter spacer??
- Need help on tranny swap
- Anyone use a late model brake booster?
- how many alternator wires?
- Easy diff/tranny driveshaft alignment?
- looking for some answers
- LS1 & 4L80E, In a 1990 4x4 suburban?
- 2000 ss camaro eng#s
- last post on this, LS1 gas tank into LT1 car
- Check this site out
- tube for LT1 motor useing LS1 Air Lid??
- Need help to disable VATS at pcm. PLEASE
- 700r4 or 4L80E?
- Do you think your LS1 Conversion is calendar material?
- The Third Gen LS1 is Alive!!
- has anyone tried ls1 headers on a 1st gen
- 3rd Gen swap guys, supercharger update!
- Question for you conversion guys
- Model Year Differences in 5.3
- Horse Power gain w/o EGR
- Need to find answers before disaster
- Fuel Tank harness diagram?
- sn95 stang ls1/lt1?
- ?LS1 70 Chevelle?
- Install LS1 in 69 camaro
- i need wiring help
- fan question
- transmisson bellhousing
- 2nd gen pics
- How much power will this swap make?
- ?Fuel managment? steering ?clutch? for a ls1 in a 68 camaro convertable
- Different engine under TBI
- Researching V8/240z conversion
- I need a good 1st gen site.
- LS1 Cobra hybrid?
- Anyone used Dakota Digitals in a 1st gen LS1 swap?
- sonoma swap
- weld up header kits
- hazards, but no blinkers
- windshield wiper
