PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Lm7 stand alone help!
  2. MSD atomic ls
  3. Water Temp Sensor
  4. B7 Audi A4 LS4 AWD swap
  5. DBW conversion on 2005 lh6
  6. 93 Jeep YJ 5.3 Swap
  7. MAF Sensir and intake tube size
  8. Looking for opinions on the air inlet. Be honest and don't spare my feelings. Persona
  9. 5th Gen LS3 drivetrain and PCM into a 4th Gen F-Body
  10. Old Sedans to L Swap?
  11. 750 Horsepower Lingenfelter 1972 C3 Stingray
  12. W202
  13. Dual in / Dual out Muffler
  14. New to LS questions
  15. FITECH Stand Alone System
  16. LS/LT Mockup Block JIG
  17. Cooling issue
  18. Harness and ECU Shop
  19. Hydraboost Block off Fitting?
  20. LS into a CESSNA airplane
  21. Looking for some advice and such
  22. Inspection/smog
  23. 5.3 Vortec long crank issue
  24. Help
  25. 495 HP LS3 Engine Swapped 2006 Cayman
  26. 96 impala 4l60e with gen 3 5.3?
  27. 1986 mustang tach wiring
  28. E38 Pedal Help
  29. Custom engine mounts?
  30. Crank spacer
  31. Need help with front accessories
  32. 4th gen x-body headers?
  33. Ls2 E38 no spark or injector
  34. E38 OBD2 Help
  35. L59 5.3 foxbody fuel system kit any suggestions?
  36. Emissions...Anyone?
  37. Help!! LQ9 PEDAL SWAP
  38. 1978 Firebird budget swap
  39. ly6 throttle pedal
  40. Lq9 pedal swap
  41. 98 V6 to 99-02 LS1 - How big is the dash side harness?
  42. LQ4/4L60e in 1990 Mercedes 500SL r129
  43. A-Body longtube header HELPPPPP
  44. My first build... help!
  45. how to tell if the cars a converted v8 from v6 or a v6 thats been converted
  46. A Body springs
  47. 96 impala lt1 into 94 Camaro z28
  48. New Turbo 6.0 Advice
  49. Starting issue
  50. Buying Z31
  51. Engine will not shut down
  52. 71 Nova/Ventura Turbo ls keep a/c?
  53. 944 clutch problem
  54. L92 w/LS3 intake
  55. 2000 TA ws9 y82
  56. Finally after 10+ years- the Hip-E-Van Econoline has its first drive
  57. Show Me Your Custom PCV Hoses/Fittings
  58. SN95 LS swap available options
  59. Ls Swap 2nd Gen F-Body: Fueling
  60. Performance Online's LS Swapped 1969 Camaro
  61. LS Manual 4x4 Blazer
  62. Identifying borg warner 4 speed? Help?
  63. TCC brake switch
  64. Possible to Retrofit Volt or Prius AC compressor?
  65. Tesla Model LS4
  66. Lm7 to borg warnerT-10 help?
  67. 89 C30 Crew Cab - Gen V LT1/8L90e Install Questions
  68. Whats radiator and fan set up are you new edge mustang guys running?
  69. LS7 980HP 1966 Chevelle Restomod by Ringbrothers
  70. Need pic of ls mounted on 4th gen stock k-member
  71. Anyone have non SS 72 Chevelle wiring diagrams?
  72. 5.3 Vortec random hard starting and sputtering
  73. LQ9 Accessory Drives
  74. 1957 Chevy 210 2 Door post LS build
  75. 1993 firebird engine wiring harness
  76. New to the LS swaps
  77. Vintage air usable with ecm?
  78. Alternator wiring... so much contradictory info
  79. 1969 C10 - LS Swap
  80. P0300
  81. Traction control on an old LS-swapped Chevy?
  82. L86 swap fpcm connector
  83. DBW pedal for gen v swaps
  84. OBS LS swap how to make gauge cluster work .
  85. HELP! F150 LS Swap 4 Oxygen Sensor problem
  86. Check Out This Tasty LS3 '68 Camaro Restomod
  87. 2008 Escalade guts into a 1953 Chevy 3100
  88. 6.0L has “Jerky” idle
  89. Ls2 swapped c10 - what stage cam is best?
  90. Ls swapping z32
  91. Front end conversion kit
  92. LS3-No Start-Error-No Codes
  93. Dr44 Alternator and starter wiring on 65 nova
  94. My s10 build thread
  95. 3 Relay F-Body Fans setup with AC and Terminator Max X
  96. Sources for salvage engine transmissions
  97. s10 motor mounts
  98. Please help!? Conversion 1993 4l60E standalone
  99. A Body Turbo Guys
  100. A 1970 Chevelle SS With All The Options You Want
  101. E38 PCM fuel pump trigger
  102. Best Tuning options after LS Swap
  103. 68 Camaro with 2010 Camaro
  104. 69 Camaro build with 2012 SS donor
  105. 70 Nova LS project beginning - help me plan out the build!!
  106. Looking for ac compressor block for my swap
  107. Help with theft deterrent system on swap
  108. Theft system during LS Swao
  109. Theft system during LS Swao
  110. 2003 chevy express van 5.3 awd
  111. This 1956 Chevrolet 210 has Something Special Under the Hood
  112. 4l80e neutral safety switch wiring
  113. DBW THrottle body
  114. 65 Lemans sedan 5.3/4l60e build
  115. fixed the sticky throttle in my 5.3 drive by cable
  116. Did any LS Vehicles come with a side post Alternator?
  117. relocating inner tie-rod for oil pan clearance.
  118. F-Body LT1 to LR4 4L80 turbo accessories brackets?
  119. 52 dodge b series ls swap
  120. 5.3 bored to 5.7 with 243 heads
  121. Gen 5 to Gen 1 wiring help please
  122. Help with holley terminator x max
  123. Holley 302-1 oil pan issues - Transmission cover
  124. Building an EVAP System
  125. Question about pcv when using TBSS intake on Gen 3 engine
  126. LS1 diy fixed belt tensioner?
  127. What to do with Evap port?
  128. Gen IV Cam sensor gap
  129. What's going on with A.I.
  130. Brake Master Cylinder bore size - 67 camaro
  131. 1972 Chevelle backdate LSA T56
  132. 8L90e Yoke Question
  133. Questions about a Gen V L83 swap into a '77 C20
  134. transmission swap questions
  135. 66 Ford T-Bird + LS engine and 4L80E
  136. EVAP System Without Pressure Sensor
  137. 67 C20 patina build
  138. Helpful parts for swaps
  139. LS1 Swapped 1964 Chevelle Wagon Is a Super Sleeper
  140. Air box question for ls swap
  141. El Camino daily driver
  142. Connect and cruise question
  143. CTSV - Swap Questions.
  144. Anyone Re-Clock their Alternators?
  145. ‘67 C10 shorty
  146. 69 Chevelle 2010 Gen IV 4.8L swap
  147. ISO TV made EZ by Bowtie
  148. Modifying P59 Blue/Green PCM's for Analog 12V A/C Request
  149. O2 or maf issues after swap
  150. Classic car insulation
  151. Quick question about 6.0 6L90E and harness removal
  152. Need something more for my '94!!!?
  153. e38 windstar wiring help please
  154. LS7 shift point questions. What do you shift at?????
  155. Wiring Diagram of LS Swap
  156. 1971 camaro LS swap Questions
  157. Bent Axle? (Video Inside)
  158. Best highway RPMs on an LS3?
  159. Fox body swap guys: fuel system questions
  160. LS3 coolant pressure issues
  161. Ls1 swap voltage drop issue when cranking
  162. Fuel question - 67 Camaro LS
  163. 1966 Chevy C10 LS Swap
  164. Starter not engaging help
  165. Traction control requested torque on a conversion
  166. Gen 3 to gen 4 ls fbody wont start
  167. Using fbody fuel tank with no internal baffles- add baffles or use Hydramat?
  168. 1965 F100 ls1/T56 swap
  169. Ls1 swap problems
  170. Throwback: 1972 Chevelle Gets New Life With Restomod Build
  171. LS / 4L80E Swap into 1995 Camaro - Crossmember Questions
  172. LS1 Swap into V6 - what parts should I replace / install while the engine is out?
  173. 2004 gto ls1 wiring diagram
  174. Vacuum issue
  175. Introduction SC300 Gen V swap
  176. Chevelle HOT side plan help
  177. 24 Pin C206 Pinout
  178. 72 K10 L86 8L90 swap
  179. LS7 in 1969 Camaro
  180. 2006 Tahoe Fuel Sending Unit
  181. LS swapped GM A-body owners weigh in on driveshafts
  182. Can a Terminator X run a stock L76 with stock cam abd VVT?
  183. L59-T56 Daily Driver 91 S10 Rustomod Planning Questions
  184. Roadmaster Wagon 6.0 LQ9/4L80E Swap
  185. ADR0182 replacement alternator option
  186. Should I do Lq4 + l96 frankenstein or..?
  187. Roots supercharger in 94 Camaro LY6 swap?
  188. AVS Did Poppers.. anyone used these?
  189. 5.3 ls swap not reving in gear
  190. silverado 96 5.3 swap wont start??
  191. Bosch 044 Check Valve; Keep or remove?
  192. 08 Tiburon engine swap
  193. Sequential gear box for my LS3???
  194. Gen 5 LT and Restomod AC Control
  195. LSA with LS7 Card Style MAF And 102mm Tube
  196. 1993 4 Cyl Foxbody Mustang LS Swap Turbo Build Thread
  197. Throwback: LS3-Powered 1970 Chevelle is Dazzling Restomod
  198. need A/C spacing info
  199. 1968 Camaro Resto-mod LS3/6 speed; Project Penny Pincher
  200. 1965 Biscayne
  201. Restomod tank for chevelle PN 15071
  202. Simple S10 LS3/TR6060 build
  203. L99 swap Fuel Pump Control Module (FPCM) wiring
  204. Anyone using a Speedhut tach?
  205. '71 C10 Frame-Off Build aka "Mr. Goodbar"
  206. K5 Build - Back to Square One
  207. PCV or not with Holley valve covers
  208. Project "Whitte Noiz" TT 5.3 Glide build
  209. 1967 Mustang /GEN V L86 / 4L80 Build
  210. Holley LS install kits
  211. Crappy Mileage stock 5.3 4l60e In Montero
  212. LQ4/9 heater core tee part number
  213. 77 c10
  214. 67-69 Camaro/Firebird LS swap radiator hoses
  215. Throwback: 1969 Convertible Camaro Gets Modern Refresh
  216. LS3 C4 Corvette Swap.....
  217. LS swap wiring help
  218. Pin to add to a harness - part number - 2006 6.0
  219. Ls swap wiring
  220. C4 swap
  221. Chart for electrical connectors?
  222. Drive Line angle #'s
  223. fox body budget swap and build
  224. Oil pan options with the holley gbody ls kit
  225. 1970 Oldsmobile Cutlass S Project... Need a bit of help.
  226. Hooker LT mid-mount crank pulley options
  227. 1968 Camaro Tears it up at The Drag Strip With 2,400 HP
  228. Oem fuel pump for ls swap
  229. Project "hole in the head." LS376/480 into my 1991 Fox Body Coupe
  230. Restomod details
  231. 2008 Yukon ECM with a 2013 engine and Accelerator pedal
  232. Newbie swap question
  233. 1969 Olds, 6.2 Escalade, T56, accelerator pedal inop
  234. 1970 GTO Version 3.0
  235. Gen3 5.3 to BOP 2004r
  236. Chevelle T56 floor/driveshaft clearance
  237. 2013 LSA engine and trans swap info
  238. The "value" of a crate LSA
  239. Brake booster
  240. Chris's Chevelle upgrade
  241. Vintage air, what AC signals to PCM?
  242. 88 firebird 5.3 rough idle and misfire once warmed up
  243. 1980 Camaro RS L92 swap
  244. Truck/f-body cooling setup
  245. Two Wires: Fuse Block C2: D3, F8
  246. Any new LS engine starters that aren't made in china??
  247. choosing a ls controller/harness kit
  248. advice fuel system setup ls swap
  249. 5.3 LS s10 swap
  250. Can Anyone Explain Why I Would Need the Quad Alternators Swap?
