View Full Version : Conversions & Swaps
- S10 5.3 Wiring - Is it really this straightforward?
- 4wd s10 ls1/ls2 swap?
- Radiator- How do i choose one?
- No spark
- Transmission
- The G-Body Swap Thread
- Harness Question
- What Clutch for ls1 with tko600?
- Alt only on a 5.3
- need to know coolant temp wire
- Search for Info and Answers to questions !
- 5.3 vs. 6.0
- More 8100 Info Please.
- Any conversions going to CarCraft???
- 69 camaro cold air intake?
- LS swap Mustang cpe track times.
- No PS, No AC belt setup?
- PorVette takes 1st in Class and 1st Overall - endurance race
- Harness Issues
- Vdo M12x1.5 temp sender #323-092?
- switches and toggles (not anything glowing or ricer) just some nice well built ones
- Fuel design setup.
- 1966 B-Body install
- Opinions on timing needs for MSD/Carbed LS6
- EVAP /Return hose on 04 GTO motor Plug it or must it return to the tank?
- ls1 hybrid help!
- putting ls1 in a 85 c10
- Is this a retarded idea for a LSX swap?
- LS1 Miata
- LSI into ,68 impala
- almost ready to begin the caddy swap
- Oil Pressure Problems
- My car was featured on Jalopnik
- LS1 Mustang starts great, no fans or tach
- Better "Lopey" cam for an 8100?
- 1974 Corvette - 8.1L 496 swap !!!
- Car no start.... please help
- LS2 Harness with cable throttle body?
- Turning the fuel rail??
- Metal intake elbows
- 3.8l to ls1
- Gauge pics, paint it or leave it?
- Any help on P/N for intake manifold gaskets on carbed LS1???
- V6 Swap Opinion...
- Spohn 3rd gen mounts
- Turbo or supercharged 5.3?
- ls1/t56 mating question
- engine temps (Ls1 Corvair)
- Thirdgen with corvette accessories
- MSD problems
- All you LS1 swappers, how are you aligning your drivetrain
- mustang chassis harness
- Accessory Drives
- LSX Project 88 Mustang For Sale
- 94 Z-28 Conversion
- school me on wiring for efi
- Running speedo off computer?
- Feedback Wanted On Dorman Fittings For Vette FFR
- mustang ls1 swap parts list
- G-Body Engine Swap.
- Oil Pressure Gauge Sender Location
- Single Chambered Exhaust or Magnaflow Exhaust or Other
- T56 removal questions
- Chevy truck wiring help
- what is this? exits int mani
- Wiring up 02 vette alt in 02 s10
- Fuel system plumbing with a returnless system
- RX7 w/ LS1 Dyno video, graph & build pics
- LS 2 power steering pump to ford rack
- Temp and Oil sender question
- 4 sale LS1 mustang project bad ass car
- 67 LS1 swap driving
- wiring questions on truck harness
- LSX into 2000 S10???
- LSx Mustang vids
- ats engine mounting brackets?
- ignition 0 voltage
- ? on ls2 2nd gen f-fody
- ls1 in an lt1 car?
- trans angle ?
- 1st gen crossmember question
- Finally my autometer tach reads right
- displacement on demand plus oil pressure swith
- 3" y-pipe too much/stock manifolds?
- Anybody need some header flanges?
- Sedan Deville conversion
- Lookey what I got for my bday
- 3rd Gen Fuel Pump
- lq4/4l80 into lt1/t56 f-body
- LS2 swap into LT1 F-body
- Ls1 all wheel drive
- PVC routing
- Alittle MAF advice please
- Damn those nipples!
- Need modified oil pan for 66 Impala swap!
- after the swap: front brakes work, rears dont...??
- 90 degree intake tube
- Convert LS1 A4 radiator transmission lines to -6 AN
- LS 1,2,6 power steering to rack problem
- name that harness [help needed]
- s10 ls6 engine swap
- a few videos of my ls1 jeep wrangler
- 1995 silverado 1500, 6.0 swap
- What shifters are you using with the 4L60E?
- Stock LS1 power steering to older gear boxes?
- 03 Mustang LS1 Conversion
- been searching and can't find my water pump answer....please help!
- Fuel rail question
- Short video
- My 240sx V8 swap (dry sump content!)...
- LSx motor in 91-96 B body?
- 1988 IROC, LS1/T56 Heads/Cam full bolt-on First Startup VID*
- need exaust manifolds.ls2 67 chevelle
- Question on Spark with LS1
- alternator isnt charging my battery...
- fuel line at the fuel rail...
- 5.3 questions
- 5.3 vortech (truck) into 69 camaro what oil pan.
- Foxbody swap turbo kit...
- LS2 power steering lines
- o2 Sensor question
- Quicksilver shifter in a 68 camaro (1st Gen.)
- LS6 into LS1 Fbody???
- it this a good deal for a 98 vette ls1?
- electronic transmission shifting
- 96 caprice LT1 into 86 trans am
- v6 to LS1 swap
- Anyone coming to Hot August Nights?
- LS1 oil leak- sump query
- Who makes wiring harness LT1 to a LS1 conversions
- Anyone running only an alternator?
- 83 chevy truck LS1 motor
- plug #230
- Vacuum source with LS1??
- LS1 swap for an lt1 car
- 5.3 and TKO500 in a '66 Chevelle
- 6.0 first Gen question
- Cheaper motor?
- List Your Conversion Gas Milage....
- first gen s10 guys...
- Help with an LS1 into an S14 240sx
- header help
- banjo bolt...
- what are people using for springs on 1st gens?
- Speartech! Where are you!?
- Yet another wiring question
- I need Help picking out a cam
- 2001 ls1 into a 1998 car help!!!!
- using a muncie with a LS/LQ motor...
- Switching to LS1 in LT1 car
- Final Steps for A/C - Relay/PCM control? Electronics gurus?
- 2nd gen ls swap
- Ford Lightning swap?
- Tach problems 89 Camaro
- Gauge question for conversion
- Fan Relay Question in Stand Alone Harness
- Pulling engine
- few diff harness q's hopefully easy...
- 67RSSS' project spreadsheet
- 1971 Chevelle LS1 H/C Pics and Vids
- LS2 Chevelle Project.
- Throttle By Wire
- 95 Z28 to 99 LS1 Conversion Guide...:)
- Wiring question
- ALDL connector
- Fuel Pump???
- Stock fuel pump relay wiring question
- Ls6 intake gaskets?
- Pics of my 66 nova ls1 M6 C4 conversion.
- C4 owner opinions Dana 44 halfshafts allignment?
- sbc mustang wiring issue
- 67 camaro speedometer ?
- Recommended Oil Pump
- LS7 is alive
- Dana 44 fuild "so many choices" which do you run
- GM LS1 swap manual $9.36!!!!!!!!!!!
- Look at this sweet deal on corvette fuel filter/regulator $37.93!!! $38.34 on ebay!!
- C100 Plug help needed!!!
- Ls1 no spark
- Couple of stupid questions...
- LS13 project
- LS series iron block???
- ls2 accessories onto gen 3 block!!
- What connects to the pitman arm on a 67 camaro
- Power steering line question....
- Oil pressure range 2002 LS1
- My LS1 300ZX
- GM quick disconect fuel fittigs , where can I find them?
- More Ford infidelity-
- My LS1 S14 Build Thread
- Starting on a 67-72 GMC 6.0L pickup
- 1998 3-wire Temp Sensor
- Rx7 Headers
- operating temp range of LSX??
- awesome conversion on ebay
- 1957 Bel-air LSX
- Getting Autometer Gauges. What works and what doesnt?
- BUILT LSX Stroker into a 95 Z28
- Track times
- LS into 74 Camaro/ 59 Suburban
- Colling system problems
- Camaro 3.4 question
- Ls1 swap into sn95 Mustang
- LS1 into a 00' Sonoma/S10
- Another LT1->LS1 Conversion (pics)
- downsizing the wire harness
- Might sell my bu wagon
- swap parts
- fuelling issue- can you give me advice
- Engine/trans angle question.
- Fuel pressure issue
- 98 Temp sensor pin out?
- Practice pictures
- my 240sx/ls1 swap PICS
- 1984 LS1 Vette FS
- Any other probs with S&P modded oil pan? PICS
- A-body LS-x swap guys, read this before you get started!
- Rack and Pinion. ?high pressure side?
- Brake booster blockoff?
- Oil Pressure problems
- 1st gen 4" cold air induction pics
- Newbie here. . . just thought I'd post pictures of my Chevelle LS1 Conversion :)
- Do I even need to install cat/converters?
- wiring schematics key
- Pedal Assemblies
- 5.3/4L60E into a 68 elcamino??
- 2nd gen LSx conversion
- Exhausting question, clock is ticking for me
- link to garage sale with some nice conversion items for all makes....
- AC wiring?
- Location of cats
- Finally, Some Progress
- ls1 in 69 camaro wiring alternator
- Need Help -ASAP
- How small is too small on the return line???
- 0-60
- lt1 to ls1 wiring question
- AC Hookup Questions
- ls6 vs ls2-7 front accessory interchange?
- Harness to ECU pins
- Smaller Bellhousing
- ‘69 LS1 C-10 Pace Truck build
- Help on motor swap LS1+miata
- My Fiero/LS6 project is now on Ebay.
- My LS1 E36 BMW 357i
- 6.0vortec into 4th gen f-body possible???
- Exhaust manifold help NEEDED on home built turbo setup!! (pics inside)
- 2003 6.0l 4l80e into 95 Silverado Conversion Questions
- viper v10 swap
