View Full Version : Conversions & Swaps
- LS2 Swapped Porsche 911 Widebody. Project<Pics.
- 88-98 silverado LSx swaps? how many?
- oil pressure???
- Cold Air Tubing
- C5 vs CTSV balancer
- Anybody successfully extended their wiring harness?
- Air Intake Tubing Question
- Hyd clutch problems, v. strange. please help.
- Can a 700R4 handle 6700 rpm ?
- Standalone Harness?
- 65 Chevelle Swap pictures
- Advantage of 5.3L over 4.8L?
- t 56 conversion
- Where do you install youre oil pressure sensor?
- looking for help with TH400 transmission and NA LS1 in a 70 Nova
- 3rd Gen Tach - Strange Problem
- LS1 swap candidate car 87 Turbo II RX7
- ls1 240sx up and running and killing tires
- An introduction...And my build...
- 73 Nova
- T56 ==> C4 corvette bracket
- LS1 Dragster...why not?
- Trailblazer swap???
- Looking for a bit of help regarding C4 corvette swap...
- Making 1 out of 2
- how vss pulses on a 1988 third gen
- yup it was wrapped in plastic...
- headers/swap parts for 6.0l S-10
- FWD 383 is Finished!
- help
- What psi radiator cap for LS1 with old school radiator?
- my ls1 powered rx7 gets mini tubbed and caged
- sump oil pan infomation
- Should the starter crank the motor without a harness?
- WTB - f-body oil pan, widage tray, tube and dipstick.
- Twin Turbo Ultima GTR
- 1st gen S10ers
- need wiring help
- What will it look like with an LS1
- Eliminate the power steering pump
- Six months and she's back on the ground.
- With ZERO tuning the LS7 Monte SS rocks the dyno rollers with 487/470 RWHP/RWTQ!
- Headers on an LS1 98' Silverado
- corvette harness
- LS1 into a TT 300ZX
- Fueling the 68 c-10
- ls-1 or carburated s-10?
- 6.0l for my s-10 xtreme
- The Day Has Arrived!!! It Runs!
- How to make a 700r4 work with an LS1?
- LQ4 into C4 Vette build is getting very close to completion
- LS1-1970ElCamino-Th350-will it work?
- What year camaro is this????
- 2 Plugs I have no idea what they're for...
- LS1 & T56 in 1985 El Camino questions
- LSX into an BMW 3 series!
- T56 mount...rubber or poly
- LSX Conversion Car Websites - Post Yours Here!
- Shifters
- Wiring harness sensor wires
- LS1 in Foxbody need help radiator hose
- Taking off for Viva Las Vegas
- teaser
- Junkyard Gen II Iron vs Aluminum
- Need help.. pics included
- Ls1 Fox Body Mustang?
- TH400 into 3rd gen ls1
- The ultimate LS1 sleeper . . . .
- LED Sequential Tail Light Install Video
- 66 nova LS1
- LS1 into LT1 k-member
- T56 bolt to 8.1L 496 big block?
- Ls6 383 Powered Miata
- It is getting so close to "Fire Time"
- started detailing the ls1
- Trying to test gauge to see if it works
- LS1 booster/master to a 67 brake pedal
- t56 clutch bleeding. stumped.
- Bosch 02 sensor interchange
- Wiring upgrade for older cars pics and ideas.
- Crap
- 4.8 trans am.
- what to buy?
- Chevelle Fuel Tank
- LS1 Stroker FWD - Tuners Beware!
- G-Body LS7 swap complete and running!!!
- Viper T56 to 99' LS1
- Air intake.... Who is interested?
- LSx into my 65 Vette
- LS1 S10 pro-street project for sale
- C5 PCM same as F body PCM?
- Need picture of IAC Valve
- 8.1L 496 pass emissions for 5.7L TBI?
- IROC Camaro finished pics
- Need help wiring pop-up headlights
- F-body motor mounts.....
- catch can for pcv -oil in intake
- possible conversion
- Normal Idle speed?
- VATS Removal?
- Want to swap 3.8 to 5.7.....
- ls1/t56 combined shipping weight
- Ready to start but.....Help!
- Throttle Position Controller
- 4th gen harness labeling?
- LS2 Throttlebody
- What to put it in???
- Fuel Pump pressure test and other ?
- EFI Sensor Suppliers
- Truck 5.3 HP question
- LS1 master question
- 3rdgen LS1 Swap, Engine not running on all 8...
- twin turbo headers and downpipes are done!! ...
- Lt1 T56 Onto Ls1???
- ls1 into 96 s10 blazer 4x4
- LS1 Chevelle Induction
- Converter Louckup/Unlock?
- Auto to Manual trans harness
- Going into a 79 camaro
- Source for LS1 information?
- kit car assembler
- First Gen Hooker Mounts with t56??
- Toyota Corolla GTS
- gm guide
- S&P mounts positioning
- '68 Lincoln Continental + LQ4/4L80E
- Wiring question pertaining to old voltage regulator.
- A/C Question
- looking to do something diferrent
- Anyone ever delt with these bozos
- Carburated 6.0L swap
- front sump oil pan
- Cold Air Filter
- LS1 chevelle headers
- LS1 Converted Chevy Silverado
- GTO windage tray w/F-Body oil pan?
- Wiring Question
- For those of you who have done the V6 to LS1 swap..
- A/c condensor
- Harness/Engine interchange help needed
- LSx into '06 Miata?
- 6.0 in a Jeep CJ5-Vacuum ?
- Which Computer?
- Dimensions of 5.3L vs. 6.0L?
- my camaro's gone
- turn key engine supply
- Lt1 ??
- 6.0l Ls1 Fly Wheel To Lt1 T56 Tranny??
- Hot Rod Mag 'Old-Schooling the LS1'
- Good low mile waterpump for sale
- Camaro oil pressure sensor specs
- How much oil with S&P F-Body pan?
- Need to confirm a wire color on 02 Camaro PCM
- new to ls1
- Help please. LS1 in my RX7 wont start
- headers
- clutch master cylinder
- Is eBay low, high, or about average on LSx and LTx engines?
- 77 Bandit TA
- I need a Fbody oil pan
- ATS LSX engine plates in stock!
- First trip to the track
- Lokar part # for throttle cable?
- Time for some update pics
- 6.0 Lq9 into 68 sbrc
- ls1 into a 97 v6 camaro...HELP
- Lm7 Computer
- 79 Camaro with LS1
- Power Steering Pulley Question
- Jeep
- What thermostat with the CSR housing?
- What is this connector for ?
- A/C compress options?
- windage tray
- 3rd Gen LS1 Quick Question
- Is this a good deal?
- Help, What could it be?
- LsX engine swap into 1967 corvette
- ford longtube headers adapted for ls1 thirdgens
- ?s about T-56 trans.
- What about making acc. brackets for S10 swap?
- 3.5 gen Camaro update - Guages, exhaust, etc
- what else do i need? advice...
- Gen 3 in '55 Studebaker PU - Camaro Subframe
- Throttle cable ? for Mustang guys
- LSx Center sump oil pan?
- need gto oil pan pics please,need to buy.
- High Mount A/C Bracket
- fox driveshaft
- Question Reguarding Procharger in Rx7
- 5.3 to TH400 problems
- 2nd gen headers
- March Performance or Street and Performance Pulleys
- Exhaust Question? Need some facts
- LS1 ballast resistors
- putting a 5.3L in a '55 Studebaker pickup on a '75 Camaro subframe - mods?
- Upgrades for your conversion
- LQ9 windage tray with LS1 oil pan?
- LS2 into 1967 Tempest/GTO Clone
- V8 swap for a V8
- need oil pan ideas.
- A/C: Mustang airbox, LS1 evaporator!
- VATS bypass help!
- Progress Report
- LS1 in 84 corvette
- Clutch master and slave cylinder???
- Year of donor car for LS1/T56 Chevelle swap
- How much heat can the PCM take?
- Wiring in power feeds to PCM
- C4 LS1 swap gets intake installed
- ls1 into 1970 mustang mach1
- lil update on my 69 camaro
- 3rd gen LS1
- emissions
- TT LS1 in a Volvo Wagon!
- MAF Location
- 68 lemans please help
- Hurst 'linear' shifter for non stock T56 swaps!
- Flooded Engine?
- Updates on my project.. (56k modem melter)
- Someone with the Fbody manuals please help.
- 1994 GMC Sierra LS1/t56 anyone?
- evap
- Fuel tank 78 T/A + LS1
- Oil pans for 1st gen F - body
- Ls headers for a 69 Cam.
- 1965 Impala SS
- MSD hardware and software for conversions
- Thanks to All the 1960 Corvette is Alive!!
- 1993 RX7 LS1 for sale cheap
- LS6 pcv connections
- Steve68's Camaro.
- Can I fire up with out O2 sensors connected?
- LS1 into 95 318ti
- LS1 chevelle guys
- 6.0L questions
- Is this mount setup strong enough?
- Help with plumbing fuel system
- ls1 in a 93 3.4 v6??
- Headers
- LS1 Oil Pressure take off adaptor
- Anyone need a set of Corvette accessories/brackets?
- exploded views of F body 4L60E
- LS1 wiring harness
- LS1 5.3 vortec in a 1975 monte carlo - hood clearance problems
- Tuned for 3:73's can I drive with....
- Extended oil pickup tube
- Advice! Fuel tank for LS1 in 70 el camino
- Ls1 in an Eclipse NEED HELP!!
- AN fittings on a sumped pump Question
