View Full Version : Conversions & Swaps
- LS S10 Auto to Manual
- 5.3 LS swap no start please help!!!
- Longtube Headers...
- My Drag week 2015 ride
- TUTD shifter question? should be a good one.
- LM7 in foxbody what alternator?
- Mustang 6.0 swap overheating - HELP
- 6.0L/4L80E into '94 K1500 Questions
- Questions on swapping a 6.0 into 2010 silverado
- Can I just modify the harness without thinning?
- E38 X1 pin 9, TCM pin 42
- LQ9 into 81 El Camino... Smog Legal
- Help me on my time line
- Stock vs Aftermarket ECU for swap
- High comp Forged 5.3|T56 Twin Disk| Nitrous Coupe
- 1st gen f body's: wiper arm question
- a/c fitting id
- Can I grind this down?
- Help with Current Performance harness
- Truck A/C wiring help me verify I did it right
- V6 gauge cluster connector the same as ls1 cluster?
- Another 1st Gen Swap 68 Camaro - HELP
- Wiring 4 pin alternator to 2 pin harness?
- Source for LED's for dash lights?
- TKO VSS - Wiring Directly to E38 PCM
- Datsun 280z lsx swap Q's
- simplest swap
- brake booster loose pressure
- DIY harness fuse / relay center: fuse amperages?
- 4.8 in a 94 astro
- connecting LQ4 harness to 1968 Camaro body
- wiring help
- 03 mach 1
- Did I score?
- stock style air box for rx7 swap
- Accessory drive first gen camaro LS with A/C
- Constant RPM Stumble LS3 525 E38 Speartech
- Started my new project! 97 LS1 swap Nissan frontier
- AT doesn't shift correctly from computer
- '87 Monte SS LS2 Swap
- LQ4 LQ9 Education Needed
- LQ9 and LS1
- Project: Black Power (LS1 S10)
- L76 in a G-body
- 2012 4l65e trans install
- LS swap harness questions
- Hot August Nights ?
- 78 elco 5.3 swap correct headers?
- Help with LQ4 swap in 91 Z71 RCSB
- LSA Swap Harness?
- Does PCV hose orientation matter?
- 2nd gen 5.3 swap
- 98 LS1/T56 into 76 Trans Am
- 1982 Chevette Swap
- Adding pins to red / blue PCM?
- Rear End Shake. Drive Shaft Phasing??
- Liquidation Sale On FAST EZ-EFI Self Tuning Kits @ Hinson Motorsports
- Any budget LSx builders out there?
- Anyone ever use the entire donor harness? I am doing/trying it. Advice?
- Fuel Pump power issues
- 4th Gen LT1 to LSx swap issues...
- Researching for LS build, a few questions
- Maf wiring
- Ls1 headers
- Volvette Build - 1990 Volvo 740
- Used UMI tubular Xmember has odd fit with oil pan...
- MAP sensor
- s10 steering column retrofit
- Adapter Plate Question
- 08 e38 ac wiring
- LS Controler
- 88 crew shortbox project more door
- BMW E36 TR6060 LS1 shifter help
- Oil Pan ??? (I know, I know)
- nolimitpkr's 1975 LS swap bracket build
- LS1 shuts down while cruising around 60
- Trying to gather a parts list for a simple 85 camaro swap
- pics of LSX malibus!
- How much wiring do you grab when pulling a donor?
- Wiring ? 5.3 swap 1990 Chevy truck
- 95 impala racetronix fuel pump kit for 71 chevelle L92/LS3
- Replacement LS6 MAP sensor to eliminating vac lines?
- Air Filter options for stock LS1 Intake (Holley HP EFI)
- Truck PS pump work with C4 rack?
- Lean condition
- 4L60E neutral safety switch
- Running issues, need some help!
- 1968 ls swap engine and transmission mounts
- need help deciding which way to go
- quickest way to install lq4 in 97 C3500 with 5.7 vortec?
- Walbro 400lph
- 83 chevy twin turbo 5.3. swap
- Question on 6L80 brake switch
- fuse box pinout?
- 5.7 Swap into 71' Chevelle
- Lq9
- wellcraft nova ll ls swap
- New Edge Mustang with Ford A/C
- First gen f-body swappers, where are you mounting the PCM?
- ls fox afco radiator question
- 5.3 tuning issues.. advice please..
- OE Style Electric Fan Ass'y For 1969 Camaro with Griffin LS Radiator?
- Anyone know where to find some ls4 front accessories
- minimal GTO harness w/ e40 pcm
- built 5.3 swap starts great but then dies
- Drive by wire compatibility
- LS Swap Bracket Question
- Flexplate/crank help.
- 20 amp fuse for coils
- LS gauge cluster swap with Ls2/ E40 pcm harness?
- cooling a boosted ls1
- Where to find LS4 front accessories?
- fuel injetors
- 1989 Silverado "Ugly Bruce" Build Thread (RCSB OBS)
- Picked up an old Champ/Sprint car last week.
- 80 Z28. LS6 Intake. What throttle cable?
- Little Harness help with LQ9 swap
- I swapped a LS3 stroker (416), engine will fire up and will shutdown instantly!
- L33 swap into C5 motor mount problem.
- whats a foxbody lsx swapped worth?
- Ecm pin terminals were to buy them?
- Ls1 pan or ctsv fox and k member.
- LS1 w/4l80 Cruise Control
- P0480 code when A/C is engaged
- Will this crack / Break!?
- Help-1960 impala 2 door hardtop ls conversion
- Fuse block for thrifty swappers
- LS1 SWAP 5.3 in 89 Caprice
- Issue solved
- 99 mustang 5.3, s475, holley hp, leash...
- is this a good idea, jeep WJ
- Start - Dies issue (beating a dead horse)
- 94 toyota bagged ls swap
- DD LS 350Z Build!
- LS1 Alternator Location Adjustable Mount
- Need programming review
- 95 gt ls 5.3 turbo swap!~~
- 68 Camaro convertible build...New suggestions!
- 2000 Dodge Ram van with LQ4 and 4L80e swap
- E39 bmw lq4 s480
- Ls to th400 setups
- 1999 dakota R/T cam and LS3 intake on LY6 engine
- g body build
- Is the VATS not turned off? Car won't start...
- Retain AC on s2000 swap (electrical questions)
- hydroboost/power steering/brakes help
- 1956 f100
- what hole size for ls f-body wheel studs
- LQ9 wire harness help
- 383 twin turbo build for my 1950 Buick Sedanette
- need help
- Built a fan shroud for my 67 Chevelle - Pics
- Swap 2000 SS drivetrain to a 98 Z28
- Oil Pressure and Water Temp Sensors
- 14GA or thicker shorty headers?
- Emission equipment 2004 & 2006 Chevy Trucks
- 5.3 in a 94 1500
- L33 Powered s14 240sx Charging Issue
- 1979 ford supercab swap questions
- innacurate speedo in '94 bird after LS swap
- Newb Ques about Accessories
- Corvette PWM connector kit?
- 2nd Gen Camaro headers in A body?
- LS2 Into 97 Camaro - Few wiring questions
- Suggestions on fuel line routing. 6.0 in a 67 Chevelle
- 6.0 swap into 2001 camaro??
- Engine mount angle
- Need Gauges or Gauge Modules to Make Your Dash Work?
- Cooling fan and O2 sensor issues
- Twin BW Turbo '84 Cutlass Build
- LS Rx8 Project
- Project DOPEFOX Build Thread
- Need help finding Gbody ls swap headers
- ls notchback help
- Nissan 200sx (240sx) LS build (long term build)
- T-56 and Holley swap crossmember
- r33 ls2
- 1978 Pontiac Trans Am
- LT1 to LSX Power steering question
- ls9 4.100" bore vs stock 5.3 3.78" bore
- Rear End Gear Ratio Help
- lsx swap carb vs efi single turbo
- LS swap question
- LT1 T56 to LS T56 - Clutch pedal mods needed?
- GPS Speedo with no VSS
- twin turbo 5.3 89 nissan 240sx
- LC9 Spark Plug Cans
- What aftermarket radiator are you using?
- 376/525 in c5 corvette?
- foxbody 5.3 ls swap
- P0335 p0336 code troubles
- After 317 head swap
- 2" SN95 swap headers
- Help identify my driveline issue
- 94 Silverado Swap
- 6L80 Trans lock up wiring issue - need help
- 1992 S10 Daily driven LS build
- 2006+ Miata Info
- Need help with aftermarket tach for LS swap
- quick help on engine mounts
- LQ9 to TH400??
- 4L80 swap fox body help
- 4l80e bell housing mods for a foxbody
- Ls2/4l60e or L76/6l80e for a jeep swap
- Asked a million times I'm sure
- A-Body Fuel Line Questions???
- What fire extinguisher/bracket are you running in your car?
- Anyone using American Racing VN327 rims
- V-belts on ls ?
- Driver side a/c bracket for LS engine?
- cant get alt to charge over 12 volts. carb ls
- LS (Vortec ) swap motor noise Please help..
- MuscleRods?
- 4.8 vortec swap
- D^3 Dad's Down and Dirty 1955 Pickup, Nerd Rods C4 on the Cheep
- 5.3 DBW will not idle
- LQ4 swap keeps blowing SEO IGN fuse?
- SAE flare to Metric o ring adapter?
- LQ4 swap into 97 C3500 Vortec truck - advice on best products please
- Need help identifying a few connectors on 2000 Camaro ls1
- Worlds first late model Charger w/ LS engine
- 69 camaro lq4 swap
- Bad Idle Air Control Motor?
- 2005 GTP L32 Sand Rail swap - supercharged
- LS to 95 NV4500 in a 72 C10
- What throttle cable are guys using for A-Bodies with stock 5.3
- LS1 T56 Throwout Bearing Torque Spec? - quick help please!
- What oil cooler adapter are you using?
- LS1 T56 McLeod Bellhousing 1/4" longer than stock - what to do???
- 5.3 vortec ls swap???
- ss trailblazer ls2 awd trans convert to 2wd
- Is this fitting going to work?
- Wich radiator hoses for obs truck
- 99-02 Camaro Pump mounting
- Source for replacement Power Steering Pulley
- 84 LS1 Monte Carlo Throttle Cable ????
- 3rd gen Camaro guys come in
- A/C Integration Solutions!
- LSX foxbody fuel setup
- 94 Z28 With a 5.3 LS Swap
- ls1 swapped rx8 4l80e hd 2 kit ?'s
- Alternator help
- LS1 T56 - Mcleod Bellhousing (pn 8710) and Blockplate (pn 8711) QUESTION!
- Big brake swap
- EVAP sensor
- LS1 Swap AC wiring
- My 6.0 swapped malibu and twin turbos walk around and vs a busa.
- The JS Racing 944 with turbo 5.3 progress.
- 5.3 Swap into lt1 car
- AC pressure sensor solution
