View Full Version : Conversions & Swaps
- 5.3 T56 4th gen....whos got one?
- 1983 Z28 get LS1/T56 and Cyber Grey paint
- 5.3 swap in 94 beater
- Any one swapped a 98 mustang v6 to LQ4?
- What do I need to do to start the engine while it's out of the car?
- Trans cooler line fittings for radiator
- C3 78' Corvette LS1/T-56 with Holset HX-55 Turbo build
- 4.3 Tranny from a 94 Blazer...will it handle the power of a 5.3?
- Pulley System Question on 94 s10 ls1 swap.
- LY6 BCM plugs
- 1996 WS6 LT1383 to LS3
- Spectre tank lives up to it's bad reputation
- ls3 for 69 Camaro
- Car wont start?
- 73 L92 progress pics
- Almost there, couple of questions
- How durable are 37 degree -AN connections?
- Any members doing LS Harness modifying?
- 1970 Chevelle - LY6/4L80E swap
- Grand Cherokee Swap
- Foxbody/LS guys - procharger fit?
- Engine/trans not straight in car, problem???
- LSx into 1988 Caprice Wagon
- 93 S10 - LS1/ T56 Swap
- Fuel Line connector question
- To cut or not to cut? (My Harness)
- What LSx headers to use for a '91-'96 B-Body (Impala SS)?
- Selling notch with Lq4/ L92 combo
- Year T-56 for 2006 LS2 swap?
- 5.3 into Jeep Swap Q's
- Testing harness before bringing to shop to break in new engine.
- Cruise Control with Drive By Wire for Swap
- Is a Fuel Pressure Regulator needed?
- Holley Pan
- '71 Chevelle LS3 w/ Vararam
- a/c sealing
- 72 Camaro LS6/T56 Swap Help
- lq4 in a 90 c4
- ? F-body4 radiator
- 1970 GTO fuel tank options
- LTX --> LSX Conversion Sticky
- Switching carb to FI
- LS1 stumbling, almost stalling everytime when stopping...?!
- 6.0/4l80e into a 1968 C10
- going to the dark side *engine is in*
- ratchet shifter?
- TC's '68 'vert project "Pro-Crastination"
- G Body mount!
- 3 speed on 5.3 questions
- Any 4.8 swaps out there??
- New Scion FR-S: Who will be the first?
- lsx mustang! muffler choice help please
- 66 GTO LY6 Swap with VVT
- 90 C1500 LM7/4L60E swap. Speedo question
- Which gauges
- What goes and what stays?
- how do i know which motor mounts i need?
- G body oil pan Q?s
- What vehicle did this oilpan come from??
- Need to determine value of L92/6L90e/transfer case
- Thermostat cover/outlet
- 69 skylark 4 dr lsx engine placement issues
- Cant post in parts for sale..
- does this A-body engine position look right?
- 5.3L swap
- What is this for?
- 3rd gen NOVA LS swap guys. underhood wiring questions
- 45 degree flare on spectra tank leaks...
- DBW idle controlled by TAC or ECU????
- Installing LS1 in my 1977 Camaro
- 2002 5.3 in 1986 Chevy C10
- Aftermarket 2010 LS3 thermostat housing??
- 1987 Buick GN Lq4/4L80e Twin turbo
- Datsun Hybrid 240z
- Ly6
- lq9 flywheel bolts and spacer
- Quick question..
- 1x or 4x cam gear???
- a/c compressor bracket for ls1 in jeep tj
- I need help!
- need to switch from Truck to car accessories
- what stock exhaust manifolds would fit a 74 nova?
- LS1 alternator on LS2 Engine
- no start!
- MAF placement
- Fuel Gauge Issue on Camaro Conversion
- LQ4 with an f body oil pan issues
- anybody have a mustang aje k member with no motor mounted?
- Can A/C shops make custom hoses out of old hose ends?
- Gen III vs Gen IV Advice Needed
- 97 o2 sensor on obd1 wont start?
- L59 into International Scout II...
- Corvette Hybrid/Conversion
- LQ9 408 in 1970 Trans Am
- ECM question
- Need some dimensions..
- Building A/C system, need to know line sizes and which fittings
- starter, starter, starter
- L92-lingenfelter converter-schwanke harness-won't start!! Help!!
- LS1 T-56 swap
- First Start Video-DBW issue??
- Exhaust suggestions
- A/C in a Fox Mustang, Please Look At This PICTURE and tell me if I'm missing anything
- LY5 standalone wiring harness compatibility
- F-body shifter with truck harness question
- LS1 swap wiring upgrade
- Drive by cable confusion.
- 01 3.8L V6 Camaro to LS2 conversion
- spectra premium A body tank...fuel pump dead??
- 1987 Trans Am - 6.0 & 4L60E swap
- LS Studebaker
- 57 chevy fuel gauge ?
- Motor plates to set motor back
- 98 ta with 02 motor
- Which FRAME mounts for 81 camaro 5.3/4 speed swap
- 5.3 liter truck sensor question
- T56 or 4l80E? also a few other questions...
- Hello
- 66 Impala LS2/4L65E swap Info
- Where to find manifold for truck AC compressor?
- 2007 5.3/4L60E into 1948 Chevy pickup
- Can a stock Impala fuel pump handle ~400hp LY6?
- Driveshaft problems!!!
- Fox-Mustang guys, how are you running a/c? PLEASE HELP, NO AC IN TEXAS IS HELL!!!
- PCM Female Connector
- 97 LT1 M6 to 99+ LS1 A4
- 5.3 into 74 nova ss
- Flexplate, converter, and starter issues
- Motor position
- ?s ARP torque specs.
- hughes flexplate/th400
- The myth of the electric fan
- Driver's side header is luke-warm
- No spark.
- whats a good 07' 4.8 and trans price
- bell housing bolts for 4L60E
- 5.3 Swap into OBS 99 4x4 Tahoe - Header options?
- Which P/S pump has no hydroboost?
- Custom length spark plug wires?
- Converting an 86 K10 to an 04 Silverado
- Getting wiring to the front side of engine mounts??? Coilpack relocation.
- LS1 Conversion Ignition Voltage Problem
- F body manifold needed!
- Smaller power steering pulley
- video..carbed "ly6 70 chevelle cammed"
- I know this is sacrilegious, but...
- ls3 or ls1 crate engine
- Fuel pump 2 second on-time question. Runs continuously.
- LQ9 auto to manual & general q's
- LQ4/4L60E a body conversion headers
- LS6 Cobra
- fuel for fox
- Classic car conversion questions
- g-body steering question
- thumper cam
- 408 LQ4 with LS3 Top End... Water Pump HELP
- S10 LS1 swap, Help please!
- 4l60 e 2wd
- 2011 Holley LS Fest Engine Swap Challenge!!!
- Ls1 5 speed swap 1948 chevy truck
- Estimated cost of build??
- connector for brake booster on truck intake - 2004 6.0 into 86 K5
- lq9 in foxbody, need help please...
- Where to get Wiring and stuff
- What you think of these prices?
- wanting to use truck harness and intake on a 68 camaro
- CTSV vs Corvette accessories
- 72 cutlass supreme build thread and questions
- Cam choices?
- Procharged LS9 Cammed LY6 '69 442 - Red Rocket Olds
- Fuel Pressure Reg??
- What are people doing for a switch for T56 reverse lockout
- Hedders for 1970 Corvette LQ4
- 66 Nova LS1/4l60E Swap
- After Market Gauges??
- Threaded oil cooler block off plate.
- 5.3/4l60e in a 62 impala wagon need help!!:)
- Impala gas tank connections
- 98 3wire temp sensor to 66 chevelle temp gauge
- LS3/4L60e in a 64 impala
- Progress on the 67 LSx Nova Wagon
- Random Stalling and p0101 code
- Looking for some different views
- Test fitting motor
- Fuel pump mod PN
- Need 99 ls1 pcm diagram i guess thats what its called
- Cooliong issues
- 88 Mustang 5.0 ls1 swap help/job
- LS Swaps in Vettes, Camaros and Chevelles
- Dakota ls1 swap advice
- '04 5.3/auto with 4th gen tank ?
- ls1 240sx. Wiring harness and Ecm question
- Engine harness info
- Conversion Harness Suggestions
- Anyone ever swap a 6speed auto with paddle shifter?
- o2 sensors
- Preparing for my LS2 swap and 4L60E rebuild
- 5.3l burping issue
- 77 Corvette Ls1/T56 full restoration
- PSI Conversion Harness FTW
- Ac for chevelle!
- ls2 68 camaro hotchkis lowering springs? ride? and height?
- Cheap and Easy Hydroboost for A-bodies with LQ/LM engines
- Request for sticky... how to be legal?
- what motor plates are equavalint to thoes from edelbrock
- ls1/th350 into a 70 chevelle question???
- oil pan?
- whats the deal with Ebay turbo kits?
- gauge cluster!!!!!
- help 2nd ls1 swap wanna keep A/C this time
- 1995 Mustang best place to order and??
- ls1 into a 1998 toyota avalon?
- 81 Turbo Trans Am Conversion Help
- Stock in dash tach not reading correctly
- Dakota Digital TH350 Speedometer Pulse Generator Wiring
- List of items and info for swap
- engine wires
- A new twist on hydraulic clutch conversion
- typical engine swap question.. with a twist!
- lq 4 70 firebird questions
- LS1 Miata Race Video - Infineon Again!
- LSX alternator relocation kit
- Starter turning in on postion
- LS1 brake conversion Threads
- 240sx Lq9 swap IAT issues
- 1998 Jeep Cherokee Conversion w.i.p
- For Sale-C3 Corvette LS1 Conversion Fuel System--In tank
- Bout to pull the trigger
- 1982 Chevy C-20 Project
- Enough ground clearance??? Exhaust cutout seems too low.
- 240 sx 4.8
- WTB: Single turbo kit for LS1 fox body
- LS1 Mustang, 99+ T/A Gauge Cluster help???
- help with putting a 5.3 in 68 camaro
- L92 Pistin/rod
- Trans dapt 1" back mounts what headers
- Parting out LS Powered Mustang
- Front spring question
- What do you guys think about this?
- My tri-five swap has begun, I need suggestions...
- Do Edelbrock motor mounts put the Transmission in the stock location
- ls1 intake swap
- inline fuel pumps - recommendations?
- 5.3l quick question
- Fast EZ-EFI
- Which oxygen sensors for PSI harness?
- Finally going to do the swap, 71 Nova
- 77 280z ls1 wiring
- do they make a conversion kit
- fighting the motor mounts
