View Full Version : Conversions & Swaps
- buying a used engine what to check?
- crossmember modification- need your input
- steering shaft trouble after AJE kmember install
- '48 Diamond T pickup with 6.0/4l60E IS ALIVE!!
- fuel system Questions?
- My cam choices for 2010 6.0L VVT L96--watcha think?
- eddiecate me on harnesses!
- Help! Need pinout for '04 Vette harness with blue green PCM.
- L96 flexfuel injectors--do I need to swap out?
- "intake hoses" on LS2
- Tick adj Clutch MC--ok to point down?
- BMW 840ci with LS Engine
- Th350 kickdown cable for ls1 swap??
- Putting 99 L S1 in my camaro, what do I need?
- 65 Nova 4L60E transmission crossmember
- Chevelle Wagon is on the road
- MSD Fuel pump kit from Speedway, Anybody use it?
- 71 nova ls1 t56 cam only
- e38 ecm out of what vehicle?
- Drive by wire throttle question
- Another LT1 departure, going turbo LM7
- twin lq4's in formula
- Green pin 59? Crank Voltage? Needed or not?
- C6 LS2 manifold flanges?
- Ls1/t56 clutch issues need help
- Aftermarket AC w/GMPP Corvette Accessories?
- Stock LQ4 water pump with dual pass rad
- doing ls1 swap and need help.
- ls to old style manual trans...flywheel?
- ls1 into lt1 car
- My 86 cutlass 5.3 build trend....slowly but shorely
- LS7 Syclone
- first time with swaped 7 at the track
- ls2 cam choice?
- 67 Firebird w/ BRP engine kit and Unisteer steering kit, any problems?
- did i do something wrong?
- carbed 5.3 upgrades?
- filter prior to fuel rail
- 3rd Gen swap. Wiring harness?
- LS-1 steam pipe
- Swapping GTO engines - help sought
- 2002 v6 camaro swap
- "SSAWD" Project Camaro
- fuel tank welding
- speedway high mount brackets
- 1987 Iroc-Z LS1 conversion
- fuel flow/pressure question
- Red/Blue Oil Pick-up tube O-Ring??
- 5.3 ECM to LS1 intake & harness compatability
- 03 truck alternator..what voltage regulator do i need for one wire setup?
- gas filler tube mod
- 74 Nova LS swap questions
- CTS-V mani's-01 Camaro A.I.R relocation?
- LS7....in a Prius!
- Project: LS197
- caprice gas tank
- What are my MAF options for L96/LY6?
- I need a wiring harness for my LQ4 swap ***SpearTech.com WTF?
- what plug is this?
- Car Built For Mileage - need input
- headers
- My 83 Chevy Pickup conversion - a few questions
- 69 camaro ls install kit
- Need info on toyota truck lsx swap
- Running on 5 cylinders 1,7 and 8 aren't firing
- anybody use Kooks G8 mid length header/cat combo in a-body?
- '61 LeSabre LS3/6L80E
- Can VATS be disabled on the late production E38 ECM's?
- 67 LS1 Nova to 73 L92/TKO 600 Camaro swap
- 93 coupe 6.0 swap need to knows lol
- Best way to swap a 240sx?
- Radiator cap
- Dlc?
- 07 toyota x runner ls1 swap!!!
- PCM tray?
- LS engine with early transmission
- 89 Sierra RCSB 6.0
- '98 Nissan 240sx from Florida.
- Truck throttle body... sensors needed?
- 04 LQ4 to th350
- Wiring harness plugs and cant find their home.
- LS2 Syclone (finished)
- Couple ls questions
- pcm connector disassembly
- anybody have ls4 pinouts or wiring schematics?
- Injectors not pulsing
- How do I set my fuel system up?
- Alternator wiring - diagnosis?
- Gen I S-10 Blazers
- SBC accessories on LS motors?
- 5.3l into 79 Chevy K10
- ls engine w sbc radiator?
- Newb here and ? about price for LS1
- How to decrease the power in a LS1
- sbc to lsx motor mount adapter
- 1994 s-10 turbo bucket.....
- front springs 1966 GTO
- LS in a stang
- F body alt bracket on a 5.3 question
- Foxbody mustang...which auto transmission
- 2001 4l80e to 2006 lq4 - crank spacer?
- Wiring harness placement and positioning in engine bay
- Exhaust pipe size ??
- 5.3 turbo/t56 in notchback
- New guy with some manifold Q's
- Want to see shifter placement on LS1 Foxbodies
- ls-1 plumbing
- Some Conversion Questions
- Edelbrock Conversion Headers No More??!!!
- 5.3L in 95 GMC 4x4, need advice and guidance
- 89 iroc 6.0L swap
- Where to get computer programmed?
- C320 Ls1 Swap questions
- ls-1 painted intake
- 5.3 or 6.0 price diff.
- Ly5
- Daft Innovations wiring harness trouble
- need help with lower radiator hose for g body swap!
- LM7 regal misfire help
- My project, a 1968 pontiac catalina with a C5R 427
- Wire harness
- Lm7 Hybrid engines for a conversion...
- Yet another 6.0 question
- Oil pressure Mxx to 1/8 NPT adapter? Autometer Mechanical gauge.
- how to pre lube a LS7 before start-up?
- Parts value
- 1987 Monte Carlo SS Aerocoupe LSX conversion
- Help, low oil pressure in new swap
- LQ9 injectors in LS6 intake
- question about autometer guages in a ls1 foxbody swap
- 5.3 in amc
- I made Jalopnik!
- 68 camaro LSX Swap fuel questions.....
- New mechanical speedometer drive solution
- Need pics, PLEASE!
- 65 chevelle ls3 & t56 conversion
- Another LSx S-10 headr option
- 6l80e stuck in 3rd
- Anyone swapped an LSx into a late model dodge ram?
- Throttle cable
- ecu question
- full LS1 swap on ebay?
- lsx swap ?
- 4L80 behind sbc in 66 Chevelle?
- Who has a Mach 1 with a LSX conversion? I need some help/recommendations.
- Can someone put my ls1 4l60e in my hot rod? Im in dallas,tx
- ls2 into 67 camaro swap questions
- 4x4 cam
- My Grand National LQ9 build
- LS2 engine harness 05 GTO to a O2 LS1 ??
- Fuel for chevelle
- Lq4 into 1966 Chevy c10 stepside
- LS carbed Fox Guys Less wires is better
- lsx swap in a g body
- Enable EGR and AIR Setting in HPTuners
- Need swap headers for fox body
- T56 Wiring harness question
- Cost to do an s10/ls1
- Looking for a Motor swap soon
- My wife always wanted a Cadillac !
- How do you measure for drive shaft length??
- Universal tank straps
- Lsx/T56 Mazda Rx8 Build Thread.. Pics inside
- Not sure I posted in the right section
- What AC Compressor to use
- 67 RS swap Questions
- using GM ls3 controller for 5.3
- LQ9 Mustang Coupe
- 427ci LS1 project Help Please!
- 6.0 LS truck motor in a 93 suburban???
- 66 chevy II nova ls1/76mm
- Whats inside this?
- 64 impala ls1 radiator question
- Turbo LM7 72 240z: The Quest for Power!
- 1967 GTO LQ4 (L92/LS3) swap
- What engine do I have 4.8 or 5.3
- 95 s10 ls1 build
- Anyone used GMPP Harness/Controller kit?
- 04 ls1 motor in 2000 z28?
- 5.3 swap wiring 4L60e to 88 NP241 - VSS/OSS?
- Engine Swap Going Wrong need pointers
- IAC started acting up.....
- Engine prelube problems w/L96 (LY6)--wrong port?
- 1966 Nova build??
- 1964 Buick Skylark T-56 crossmember
- 68 camaro throttle cable (carb)
- TH-400 users come in! VSS
- oreilly gauges?
- Ground Issues???
- LSX FOX Help needed!
- F Body Pan FYI
- How do i convert my ls2 gto to speed density instead of MAF
- crankshaft position sensor wire
- Anybody parting out a 99-02 truck? I need the cruise mod
- 56 Ford F100 5.3L swap
- L92 wiring harness help!!!
- coated headers
- Injector lengths?
- My wiring harness build thread
- Pin-out purgatory, please HELP!
- DOD what triggers it
- Truck Wiring Harness Question
- Flex Plate Spacer Drawing
- f-body headers on chevelle
- Help!!
- New Project Need info 5.3 dod 4x4 84 silverado
- 98 firebird v6 to ls1
- Fuel pump problems
- please help me pick a k member, ready to order and can't decide
- Corvette Accessory Drive Bracket Mounting
- 2002 mustang gt ls1 t56 swap
- Which Throttle body to buy?
- Anybody recognize these ex manifold"s?
- 5.3 into '72 C20
- easy question about my lt1/ls1 swap
- LSx in a Formula style car. Ever been done?
- firewall grommets for ecm harness pass thru
- pretty pics :-)
- 1994 Camaro Fatory Wiring Harness > CS Vette
- LS1/T56 in 1997 E36 M3 - Samberg kit
- Thoughts on BRP swap kits for GM A-body conv?
- LQ9 Advice
- 09 4L60e has no gear position sensor, 07 does?
- Are two O2 sensors needed or is one enough?
- GOODGUYS TMS who's going this weekend?
- Looking for torque management advice
- GM A-body T56 folks--what clutch master setup did you go with?
- LS1 swap into a 1968 camaro local man or shop in dallas tx
- truck accessories in 3rd gen
- 1957 belair hardtop ls2/4l60e
- K5 swap
- Use of traceability numbers
- 67 A Body 2010 Camaro Accessory Drive
- 94 Camaro 5.3 4l80e
- RX7 LS1 Swap questions
- edelbrock ls swap headers ls3
- Junkyard engine came w/o MAF. What replacement should I get?
- Manual vs PS
- Will a LSx/4L60E fit in a 97 Ranger?
- ls powered blazer
- Oil pressure gauge ?
- ls2 wiring harness
- any 1st gen ls1 guys running autokraft pan
- PCM Fuse/Relay question or opinons ?
- 62-67 nova CBR header for stock steering
- Too many choices
- 1999 camaro pinout (HELP)
- can you use a rear O2 sensor as a front O2 sensor?
- Ls1 in my cj
