View Full Version : Conversions & Swaps
- Swap question
- Air Conditioning Bracket # 10118751 -Truck Engine
- 2001 s10 2.2 flex/auto to V8 ls/t56
- S10 guys inside
- 86 cutlass need help with LS1
- LQ4 PowerSteering Pump Fitting Size
- 92 coupe with ls1 fast 102 235/239 pat g tune
- Help with 64 Impala 5.3 Swap !!
- 5.3 will not run!
- 99-2000 truck dbc bracket wanted
- Fuel System Limits
- fox body which oil pan?
- conversion with 700r4 question
- Help with fuel line...
- LQ9 to replace my LT1
- New clutch, what size?
- SLP MAF question
- Trans Bell Bolt pattern
- 5.3 swap in a 55 chevy
- DBW to DBC conversion?
- Bug+ls1 ?
- Part out or sell without motor/trans?
- Got a Cooling issue.... need some opinions.
- 86 k!0 swap.
- LS1 swap
- does this look normal?
- Drain in a radiator hose??
- Plastic Fuel Line???
- Truck dipstick replacement for 5.3 ?
- LS powered early Bronco
- Build thread...LS1 / T56 into 1975 Corvette convertible
- Has anyone ordered an GM oil pan?
- Need pinout for f body fuel pump bulkhead connector
- 5.3 power steering pump ?/Oil filler neck
- Starting my 5.3L Vortec conversion (need advice)
- Mustang and AJE users come in please
- Jaguar Xj V12
- Need a Transmission segment swap
- Just got my 1772 miles 79 malibu ALL original time capsule
- F.s , ls / foxbody alumimun driveshaft
- totalled my z
- LT1 to LS1 fuel question
- Wrong water pump??
- Difference between 78 a body and 82 g body?
- 01 firebird motor swap?
- Strange SES behaviour
- Pontiac GTO hood tach and HP tuners "tach output" setting
- 98 Firebird Disk brakes on 67 Camaro
- Engine placement
- LS1 to t5 questions...I searched
- 05 BMW with TT LSX
- newschool72 build pics....DONE !
- Help Electronic Throttle pedal not working
- Not LS related, worlds smallest V12 engine.
- 6.0L harness and pcm
- 69 camaro ls1 swap a/c, th400 and oil pan questions
- DBW Pedal Bracket & Placement
- noobie clutch question
- 92 F swap. Odometer not working
- 88 Mazda RX7 TII LS1/T56
- conversion mount/plates
- driveshaft questions
- ECM location?
- Tach Hookup
- A-body swaps ... Are you happy?
- 1986 Caprice Coupe LS Swap
- Fox body Mustang/4L60E Drive shaft Options
- Inches of vacuum from a 2006 LS2?
- common question....engine swap to LSX
- Anyone ran reversed passenger manifold on e36 driver side?
- ABS Sensor as VSS Source?
- BBK LSx swap headers
- Corvette accessory drive
- Parts question gentlemen???
- Why does everybody recommend converting to drive by cable?
- how much to do 6.0 swap in my coupe?
- Best drag radial for LS6 Cobra kit car
- Ls1 in notch!
- ls1 to 5.3 swap
- Mating an old SBC Manual trans to LS engine?
- GTO Gauge Module ABS Fault
- LH8/GM Muscle Pan, Holley oil pan, windage tray and bolts question.
- 3rd gen auto to manual question
- 71 Chevelle+LY6+T56,
- MAF Harness Extension (how to?)
- using LS1 harness on 5.3 questions
- ls to 700 questions
- TSP 233/239 in a lq4
- 3.8l pinout?
- For anyone interested in Speedhut gauges
- Individual Connector Pinout
- '62 Nova with LS1 finished
- Anyone install a F-body console in a Foxbody?
- LS-1 use in Airplanes
- please HELP my install 4l80e on ls1
- Fyi
- donor ls1/4l60/pcm/harness into 2nd gen TA questions
- Parts needed for long block
- Not another 240sx build...
- LM7 vs LQ4 in C3 Vette
- My turbo 4.8l 87 IROC build
- Project Ugly Betty LQ4 with a 4L60E into a 1966 Mustang
- Wiring thoughts on powering pcm relay or no
- Can you do away with the vinyl roofs?
- Notchback LS1/A4 swap question
- S&P MAF & Fresh Air Intake
- Are there any tried and true Chevelle LSx Header/Mount combinations?
- TEA243s on LY6?
- BMW E46 converted to LS1 - Wich gearbox ?
- 5.3 swaped into an 84 ae86 corolla
- LSX Questions
- Ls3 376/480hp swap
- anyone familiar with 2005+ grand cherokee computers?
- Tarus fan size
- fuel sender with built in pump for 68 camaro
- Is there a site with parts diagrams w/part numbers?
- 4.8 c/10
- What mufflers do i use????
- I need your input on a single exhuast design, please.
- Exhaust Manifolds
- LS1 radiatior in 69 GTO
- Stand Alone Transmission Controller
- Trans Question-94 vette m6
- Jeep YJ with a 5.3 needs Air Conditioning need suggestions.
- 78 camaro lsx swap
- Budget Carb Vs. Budget EFI
- L33 help for swap into Porsche 944
- what wiring harness to go with for ls swap?
- 4.8 to 4l60E questions
- What exhaust manifold for a 65 chevelle
- what diff ratio??
- Anyone use Chevy Thunder harnesses for their swap
- 95 z28 ls swap ?'s
- LS1 Swap Candidate?
- wiring harness help needed
- Fox body guys, anyone running a TH350?
- Kooks vs. Dynatech in Fox body swap..
- 1978 911SC Targa LSX Swap
- Those with a PSI coneversion harness, have a question
- LS Swap Questions
- 65 Nova Wagon Ignition
- The Most Tucked LSX Manifolds that I have seen
- recommened fuel pressure
- el camaro LS1 t-56
- 2.2 swap into a Vega
- Cam recommendations wanted for LS1
- ok thinking of using a 8.1 here
- Painting an LS1?
- 5.3 shortblock differances??
- c3 lsx side pipes
- finally it's alive
- Best lsx foxbody swap kit? Opinons welcomed!
- New Edge Mustang LS1
- Just purchased motor and Trans for my swap
- what size AN is the factory power steering hose on a LQ4? can i cut it and...
- drive shaft length question
- LS4 in a '00-'04 monte?
- Lexus SC300 6.0/T56 swap first start up
- Time for another build...2001 Miata L33 w/t56 conversion
- Neat new product at SEMA
- Camaro/G8 and CTS-V and or bad angle trans yoke options for swaps
- Mid 90s truck swaps
- C6 header fit a foxbody?
- 1981 Second Gen Camaro Berlinetta BUDGET build (Updated FiTech injection/Boost!)
- LS1 Conversion, what is this pin?!?!
- LS3 Crate into a 93-97 F-Body
- Are 5.3L & 6.0L exhaust manifolds the same?
- How many miles is the LS good for?
- Need G-body frame notch pics
- anyone have a fluttering issue at idle with autometer tach?
- Ls into a colorado
- 5.3/4.8 fuse block question
- Diesel Trans Am?
- scored a chevelle
- Are oilpressure release valves universal between sumps
- LQ4-Mustang....Alternator/Starter Wiring??
- Where to source relay sockets and connectors
- What should get the LS1 80 Camaro or 70 Chevelle
- Do iron brocks brake at the mount?
- LS1 Turbo 240sx All Done *vids and pics*
- Need some help with my 02 Denali. Simple DBW stuff
- steering too soft !
- info on converson
- What car should receive the LS1?
- s-10 underhood fuse box?
- Source for a full GM vehicle schematic?
- Headers & catback
- BMW X5 wiring diagrams??
- Exhaust question
- Motor Swap??
- Opinion's needed!!!
- 5.7 LS1 Wiring Harness Question. Does the year 98-02 matter?
- ac bracket
- looking for: pictures of a specific 68-72 GTO
- 2nd gen F body with Tick adj M/C??
- I have a performance goal...should I go Turbo or N/A?
- LS into a-body...header/manifold recommendations
- vega lsx info.
- LQ4 in a 1965 Chevelle - What stock exh. manifolds fit?
- camaro dash in a gbody
- LS3 in 67 Camaro
- THREAD UPDATED!! 87 Chevy Silverado short bed 5.3 vortec,4L60e trans swap
- what gear to run?
- 89 camaro lh6 swap questions..
- Corvette accessories?????
- LQ4 water temp gauge problem 98 TA
- Ls1 1989 Iroc No power steering?
- Neutral Safety Switch
- 1969 camaro Pillar post
- Fuel Mileage, Reliability, for a Buick A-Body
- Need a smaller PS pulley - What donor vehicle?
- Help! 5.3 into a 71 Chevelle...
- X-body Nova LSx questions related to truck engine
- 5.3 into 96 2 Door Tahoe light resto
- 1967 Camaro Ls1/t56 Next Stage- Poor Mans DIY 3 Link Rear Suspension
- project barn find ls2/magnacharger
- Camaro Front Accessories parts list (99-02)
- L92 into BMW E46 questions
- a/c compressor in a Fox Mustang with swaybar. With pics!
- Opinions on 1 5/8 long tubes on a LS1
- DBW vs DBC...does it matter which one?
- 66 GTO Convertable 6spd
- LQ9 PS Pump with Delphi 600 Box
- LQ9 IDENT fast!
- lsx chevelle conversion Q?
- Speedo Quit working.
- Harness ?'s...
- Any header/midpipe that bolts up to Mustang cat back?
- I have a couple LSX questions...
- Planning LS2 into 68 Camaro. Comments welcome!
- DBW in my boat?!?
- LQ9 swap with 4l80e Trans help
- 4l60E & Dakota Digital gauges
- LQ4 oxygen sensor plug
- V6 to V8 swap,both cars are 99
- Does mileage matter....5.3 for Turbo project
- Advice needed for 350z ls1 project
- Turbo LSX Powered Fox Body
- Harness questions: Car Vs. Truck pinout.
- does anybody know about nissan rb25det or rb20det engines?
- Another exhaust size question
- LSx with t56 into foxbody questions.
- 67 nova lsx 454 lower radiator hose
- ProCharger Rebate Program!
- If you could do it again...
- 5.3 lm7 question
- 5.3 Swap Ground Help
- Anyone machined solid inserts for their AJE k-member?
- Solstice Transmission Question
- For those running truck accessories that want a low mount alternator.
