PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Mr. Sixtoes1313 having some fun...
  2. A body LS1 hooker headers
  3. who's car is this?
  4. New Member Needing Opinions
  5. LQ4 70 Firebird conversion questions
  6. found a shitty "camero"
  7. Filling dry 03 LQ9 with coolant
  8. Swap to f-body accessories
  9. 2005 gto wiring schematic?
  10. 1952 studebaker commander swap oppinions
  11. Header build for LSX in Chassis car
  12. Anybody sell a PCM extension harness?
  13. BMW e39 540i LQ4/T56 swap project
  14. Any A-bodies using BRP 3/4 length headers? Opinion?
  15. Project: "Barter Build" (96 Silverado)
  16. exhaust issues, suggestions needed
  17. LH6 5.3 build experiences
  18. cons of a 98 ls1 computer?
  19. Can I do this?
  20. G-body oil pan
  21. CBR's 64 Nova Wagon
  22. Mustang T56 Guys..... What rear gears are you running?
  23. Mustang guys with AJE K-member
  24. Can I do this?
  25. LH8 Oil Pan machined for Bypass Valve
  26. Fuel return
  27. Trans / clutch noise during deceleration !? 01 c5 z06 ls6 swap 93 mazda rx7 fd
  28. lq9 swap 02 ceta!
  29. lt1 F-body swap question
  30. foxbody auto trans swaps
  31. Fox guys with lsx ,i have a ? about aje mounts
  32. Can A Crank Pulley Be Put On Too Far?
  33. 2006 GTO LS2 w/4 speed auto in 87 Buick GN
  34. Clutch Chatter issues
  35. 4x4 6l90 into 2wd?
  36. 4x4 6l90 into 2wd?
  37. LQ9 Cast Iron Block with H3 Pan which dipstick
  38. LY6 Conversion - ECM/TCM/DBW Pedal Question
  39. Thinking about a 370z...
  40. Fitting for power brakes part number 12559760
  41. Cheapest Vette fuel regulator I've seen $15
  42. 2010 LS3 and TR6060 in a 68 Camaro
  43. F/BODY accessories with LY6 timing cover,VVT
  44. Project Emmy Lives!!! 1968 Bel Air Wagon L92/6L80E
  45. 93 LX Mustang 4cyl to LQ4 swap questions
  46. LS1 F body brakes on a Chevelle or other older car?
  47. Functional Ram Air Hood....Nova
  48. 72 Chevelle with LS-1 411
  49. Starter /crank rpm question for hi compression 408
  50. LQ4/4l80e/241c in my 88 Grand Wagoneer
  51. cammed 5.3 in 87 camaro. Take off issues
  52. Turbo 400 to LQ4?
  53. Tach signal help.
  54. g-body swap info needed
  55. Mustang dynatech vs kooks
  56. LQ4 into my 68 Chevelle build
  57. Car porn alert: 'Orange Crush' - New LS6 w/ TVS Magna Charger
  58. 81 vette LY6/6peed build. need lots of help!!
  59. Possible engline swaps
  60. Lsx iroc z
  61. 2000 Fbody charging woes!
  62. Motor starts and then dies? Sounds like VATS, but....
  63. 2006 Pontiac GTO LS2 w/4 speed automatic in 1987 Buick GN
  64. Does E40 ECM need to control cranking?
  65. LS1 in my 79
  66. s-10 radiator and condenser???
  67. Need help from y'all Chevelle swappers
  68. 67 Impala ss 6.0 swap
  69. Carb to FI Swap, already LS
  70. Chevelle/GTO/Cutlass with B-body EFI tank questions in progress
  71. 1968 ss camaro procharged LS2 m6
  72. 4.8 Vortec - radiator, MAF questions
  73. Flex plate confusion
  74. Boosted ls1 240sx pcm power question
  75. Flywheel spacer for early 80E TQ on 6L80 flexplate?
  76. Power Steering Question
  77. 67 camaro/ls2 headers clear clutch z bar?
  78. 2010 ls3 stock exhaust manifolds - pic request
  79. lq4 guage cluster swap?
  80. Help! LS1 swap complete but car vibrates
  81. 6.0 S10 Blazer died and wont start!
  82. GlowShift Elite 10 in my Ls1 Buggy
  83. Can dbw be converted to cable driven?
  84. Modern AC in Chevelle
  85. BMR K-member problems
  86. 1976 nova ss (4th gen)
  87. 1984 chevy pick up dual tank
  88. can any oil pan be swapped onto a 03 5.3L?
  89. Fuel pressure regulator to plug fuel damper hole
  90. Throttle body question
  91. Anyone running upr a arms on there aje k member?
  92. LSX Noob needs install direction
  93. Help me identify these plugs
  94. Need advise on which LS set up to use on 67 C10
  95. 2008 2500 6.0 with 823 heads. 81 vette swap!
  96. a/c wiring question
  97. Ls1 cluster
  98. flywheel and spacer
  99. Fan does not come on with the a/c
  100. 2001 camaro v6 convert to ls1 swap questions
  101. 1998-2002 Fuel tank fitting
  102. c101 connector, extra wiring
  103. Good price for 6.0L/T56 pullout combo?
  104. 1970 Chevelle LS1 Conversion
  105. S-10 potential project question.............
  106. Question!! engine code and hp rating!!!!
  107. Chassisworks Mounts - Which Headers?
  108. walbro pumps
  109. Car won't turn over
  110. 5.3 for e30 bmw swap
  111. LS1 swap intermittent hard start / rough idle
  112. can an ls1 radiator cool a turbo lq4?
  113. 99 olds intrigue 5.3 abs with trac control
  114. ECM/harness recomendations for LY6 needed
  115. newschool72 vid
  116. 2004 LQ4 VSS diagnosis
  117. Has anyone done an SN95 with an LSx?
  118. Engine Swap 5.7L to 6.0 L
  119. Issue with starter after swap in 76 Camaro
  120. LS1 mustang w/a TH400, no VSS & won't idle?
  121. 1996 camaro 3800 engine harness removal??
  122. LQ4 carbed swap questions
  123. 3.4 to 5.3
  124. what parts are needed for a ls1 or lsx swap into a foxbody
  125. Fuel Injector connection ????
  126. motor swap options
  127. Project "White Lightning"
  128. G-body steering box - Truck Power steering
  129. lq9 fuel injectors + aftermarket rail
  130. LS Conversion
  131. LQ-4, T-56 S-10 build
  132. 81 Malibu Budget 5.3 swap!!
  133. LQ4 Oil pressure problems!!
  134. Having trouble starting new motor
  135. 46 Ford Pickup, S10 Chassis, Air Ride, 99 LS1
  136. accessory belt question
  137. How do I wire this 02 connector/alternator wiring ??
  138. LS1 350z Drift Build 'Nuff Said'
  139. Psi launches new website www.psiconversion.com
  140. Just a thought, curious if it will work.
  141. 5.3/auto swap has hesitation..dbw ?
  142. A/C Guru Question...?
  143. Sensor delete/fuse double check
  144. fuel system question need to hear from the experts
  145. LS Motor radiator question
  146. LQ4 Horsepower Question!!
  147. LS6 Cobra swap Speedo and Tach hookup tips
  148. 1967 Camaro + 2006 GTO LS2 + Autometer Tach: How do I hook up my Tach????
  149. Can a TPI Ecu & MegaSquirt II run a LS engine??
  150. Cable TB cruise question
  151. Border Patrol Buggy
  152. LQ/ LS Swap Guide: 47-54 Chevy Trucks
  153. 1959 GMC Fleetside Truck
  154. I need some LS SCHOOLING!!
  155. pcv help !!
  156. OBD II Connector with light
  157. Need help for installing th350 to ls1
  158. Vette C4 dana 36 & 44 or viper dana 44 rear end traction?
  159. Spectre Tank Help Please!
  160. e38 standalone, starts and dies after 2 seconds max
  161. Radiator Hose Help (a body) w/ 99 camaro radiator
  162. Is their a way just to run an alternator?
  163. LS 376/480 information
  164. Help with initial ECU programming
  165. Miata swapper
  166. LSX in a '68 Javelin
  167. Mustang Clutch Master Location???
  168. LSX in '93 Silverado
  169. LS1 amp question
  170. CTS-V vs fbody accessories
  171. I got a rear gear question
  172. just starting with my swap
  173. 1995 4.8/4l60e project
  174. 81 malibu ls1
  175. LSx nova project
  176. OBD2 port and tuning issues
  177. Any experienced welders out there? I need some help.
  178. Help! Video- Car idles and revs but not in gear
  179. 93 firebird xmember?
  180. 07+ Van Engines
  181. Fuel/temp gauges inop
  182. 94 s10 LSx swap accessory drive
  183. 88 Annav. TII RX-7 Ls1 swao
  184. 1998 F body fuel pump in lt1 car?
  185. 3rd gen fbody ls ac compressor
  186. lq4, fbody pan what all has to be swapped?
  187. ProCharger LSX Transplant kit for sale - ALL brackets, LS9 cam, injectors,
  188. No start and need help on swap
  189. accessory drive set-ups
  190. Feedback on my motor mounts
  191. LS1 swap charging issues
  192. LS+Pentastar crossbreed
  193. My 78 camaro / 00 corvette hybrid
  194. Air Cleaner ???
  195. Fast102
  196. l92 swap for 71 el camino
  197. Escalade LQ9 Question? Whats a good price?
  198. Oil Pressure Sender wiring '98 LS1/Mazda
  199. Fired right up for the first time! On the first try!
  200. quick G body mount question..
  201. NAPA green brake lines
  202. Help...'98 harness
  203. LS1 in Nova with Heidt's clip-motor mounts
  204. Getting engine/trans into final location
  205. questions about a lsx swap into 99-04 mustang GT's?
  206. LS2 Truck intake swap for camaro/corvette intake
  207. LS2 Corvette waterpump on F Body/ corvette brackets- please read and offer info
  208. Help Needed!!! - What DBW pedals/TAC are you using?
  209. Need help fast guys! LS2 in a Chevelle
  210. Schematics
  211. t56in a 64nova
  212. AC amp draw
  213. Turbo Ls build in a 96 cobra
  214. Easiest LSX conversion vehicle
  215. 68 camaro ls; how do you guys feel about Martz 4 link and dse mini tubs
  216. Help with alternator... and ive read the stickies
  217. Help with a turbo ls yj
  218. Questions on a LS 68 Camaro Swap I am preparing for
  219. 05 mustang swap
  220. 69 chevelle 6 liter resto body off or not?
  221. This pinout for this computer??
  222. Fbody Gauge Cluster in Your Swap(Little how to inside)
  223. LS into 190e 16v
  224. 1970 Olds 442 clone gets Gen IV 6.0L & 6 speed manual
  225. LQ4 into a 79' Malibu
  226. 73 Corvette LS1 Conversion
  227. LT1 to LS2 swap
  228. 2004 fuel pump wiring question
  229. Im going to be parting out my LS2 turbo 350z.
  230. 77 Pontiac 400 to LSx Mounting
  231. What Auto trans seems to be the ticket for swaps?
  232. check my wiring
  233. Looking for opinions on fuel line options
  234. LSx engine swap guides
  235. LS1/T56 into a 67 Chevelle
  236. 63 fairlane
  237. Help! 67 Chevelle alternator steering box problem
  238. 68 camaro: Will a hiedts rear four link system work with DSE mini tubs?
  239. Supercharged 6.0L in a 67 Camaro Have DBW Throttle Body Questions
  240. 86 c10 a/c compressor pics
  241. VVT Delete question???
  242. LS376/480 Fuel Problems
  243. Anybody put an LS engine/trans in a 55-57 Convertible?
  244. Mechanical Speedometers and the 4L80E?
  245. Transmission Range Sensor - required?
  246. Major problem with build!!!! A little help please!!!
  247. 1995 z28, ls1 4l60e swap
  248. remote coil plug wires ? any P/N?'s
  249. Harness connector and a couple missing connectors ID help
  250. 5.3L into 86 C1500
