View Full Version : Conversions & Swaps
- Fuel tank choice
- LS1 TH350 Kick Down Cable Help!!!!
- 74 nova swap headers
- F-body alternator mount on Truck block
- LS1 in 68 Camaro - exhaust question
- 1963 Corvette Grand Sport LS2/T56 Build(Lots of Pics!)
- help me with cam selection
- Aussie HJ Kingswood single turbo lsx376
- MAF ? speed density?
- Lsx 1967 Nova swap
- Vss question
- 89 camaro Iroc with LS1 motor question
- 63 Riviera=X-frame and rear steering! What to do?
- where does this plug go?
- vid: SLP PowerFlo exhaust, but need new ideas
- New Kooks header for A-bodies?
- Need 2 ecm plugs for E38 ECM
- Awd t-56
- Question on L76 from a Pontiac G8 into 68 Camaro
- What motor mount adapter/headers did you use in your gbody?
- 1993 FOX notch LSX + turbo swap pics
- 2008 TBSS pinout and source for ECM wiring, connectors and terminal ends
- 2 questions on steam lines
- 1985 Dodge W150 LS1 swap
- Summit is awesome!
- need quick help for alternator wiring
- Traction Light
- Fuel system question
- Newbie LS1 question...
- lq4 3rd Gen camaro
- LS1 Miata build cost?
- 5.3 accessiors s13 swap
- Taurus fan using ecu to control high/low
- starts but no idle or throttle response
- Problems with gauges!!
- ls1 swap?
- LQ4 in a 95' RS
- Ls1 swap question
- Cut Frame 1st Gen S10 Clearance Issues!
- 79-04 Mustang/AJE measurement needed
- SOLD__ high mount A/C bracket available
- What is this connector for/do ?
- another fuel pump shit da bed
- LS1 Conversion Gas fumes *fixed*
- 69 Camaro LS2/4L70E install
- 69SYC, 69 Camaro LQ/4L60
- 5.3 harness
- 5.3 engine tunning questions...
- 1st gen camaro header info--please post your setup
- tuned headers
- surge tank???
- LS1 Motors - how do you buy a "Good" used one?
- LQ4/4L80E, A-Body Chevelle, No AC Compressor, LH8 Oil Pan Kit = Cheapest Mounts?
- 08 gmc sierra v6
- Has any body modified Gen. 1 SBC headers to fit a LS 1 ?
- ls1 into 77 t/a cost
- 06 GTO LS2 --> 89 Formula
- LsX Typhoon swap grounding problem
- vintage air compressor bracket?
- express van gas tank dimensions
- What to get for exhaust?
- MSD vs Taylor Wires
- Changing my fox to 6.0 .. Front springs???
- 89 240sx
- where to start????
- 4.3 vortec throttle body to ls1
- Possible fuel pressure issue
- LS1 S14 Wont start
- lm7 with 1991 5 speed
- stock fusee block
- 6.6 dmax intake air box
- lsx drive by wire or cable
- My 64 IMPALA
- Twin Turbo AES 390 in 70 AMC Javelin
- 4l60e wiring help, see diagrams!
- what tuner???
- Help me pick the best swap vehicle - SUV 'vert
- stalling problem.
- 68 Camaro LS3 swap begins!
- Radiatior over flowing?? after long trip?
- LQ4 swap, where can I hook up vacuum brakes?
- Help
- Code Confusion
- 4.8 swap into TJ questions
- Thermostat temp/ fan temp
- ls2 swap in a 71-72 chevelle??
- i have a ls3/l92 victor jr for sale PN 28457
- 180* crossover headers 944/ls1 conversion
- Anyone use truck hybrid platform for an LSX conversion?
- fuel line help!!
- Tranny crossmember???
- Plug in o2 sensors motor stumbles help
- LQ4 6.0L swap 1980 Pontiac Firebird questions..
- ls7 swap project
- Small Power steering question
- ls1 85 s10
- JZ Motorworks (Holley) Conversion Pan for sale - $350 shipped OBO
- Sound Deadener Makes Hot Rods Better
- Carbed LS1 in a 3rd gen
- No CPU signal to #1 Injector
- 1972 mercedes 280se benz with 5.3 swap trans issues
- help plz!!!
- Mini starter question. LS1 into BMW M3
- issues with LS2 in SVO
- bench seat and a t56
- Anyone using an LS3 GM controller kit on their swap project?
- LS1 Motor mount plates, prints?
- SAFEST/EASIEST way to lift a LSx engine/trans combo? pictures inside
- Thoughts on selling LS2 G35 for new Z06
- first gen crossmember
- what do you think of this solution?
- dbw help please. accel pedal isnt doing anything
- LS Impala SS with Tach and Speedo Problems
- 06 gto/amx
- Mustang swap needs help
- Painting LSx block, timing cover, valve covers, etc
- turbo 5.3 s10 build
- Pros VS cons mechanic gauges or electric
- original oil pressure sensor
- For those of you who have done the swap...
- My efi lsx/th350 mustang
- motor mounts
- Ls7 intake on lq4?
- LS6 backfire
- 5.3l drive by cable, turbo 350 trans question
- new jersey area swappers
- Help with electric fans
- cooling fan question
- Compression too low?
- Help planning LS swap -LM7, LQ4, LS1??? - 70' chevelle
- No oil pressure?
- LS1 flywheel for 09 6.0?? does it work??
- What harmonic balancer for 6.0 LS1????
- Rebuilt alternator
- L92 6L80E Swap - Trans in limp mode - DTC P2534
- LS1 stumbles and tach flutters (video)
- Oil Pressure on a Steep Grade
- Tach not working!
- Shifter cable help!!!
- Forgive me about this.
- "Stock" LQ9 Horsepower??....
- Superlight 240SX V8 swap
- questions about an B-Body caprice LQ4 LS1 swap
- 5.3/4L60 Ford 8.8 in 95 Jeep YJ completed
- 2001 S10 5.3 swap
- help with alternator wiring...
- Stock lm7 in 3rd gen camaro track times? A4
- intake and throttle body 5.3 question
- Oil Level in LS1 Pan
- truck oil dipstick with fbody pan. need info asap!
- 4l80E
- Anyone convert their Drive By Wire to Drive By Cable?
- Transmission cross member for LS2/4l70e in 69 Camaro
- Has anyone made their own speedo reluctor?
- 475 RWHP G35 Finished
- ls1 swap in a 95 camaro
- Should fuel pump have 12v from PCM with key on?
- turbo 5.3 in a 67 chevelle
- Copied from FS section. 86 Rx7 perfect swap car
- 1970 Chevelle Conversion using Holley Parts... Road to LS-Fest
- LS3 standalone harness, oil pressure sensor
- 04 GTO LS1/6spd donner
- stock fuse block
- Help 4l60e problem!!!
- what is a strong stock irs center section?
- ECU Mounting
- LS1 Mustang on Spray *Video Inside*
- New LS1 Sand Rail First run - Now questions
- 2009-2011 CTS-V accessory belt spacing same as early LS1 F-bodies?
- transmission help before I shoot it please!
- 4l80e question...
- 4L60E DTC P0470, which wire do I test?
- Is it worth it to get the fuel injectors cleaned?
- LS3 ex. manifold on a LQ4 - 65 Chevelle Build
- Accessory drive
- 1974 Stingray Convertible
- 5.3 to 6.2 swap
- Recommend mufflers for EXTREMELY aggressive sound?
- NA 600hp lq4
- My 2004 LS1 FC3S RX-7
- Wheel alignment problems!!!
- Clearance for engine movement
- motor mount orientation
- All aluminum 5.3L ????? Need help!
- ?s ARP torque specs.
- fuel lines newbie questions
- flexplate interference?
- LS1 Into '72 Camaro!
- Flowmaster exhaust/compt problems
- EPS Cammed LQ9 in Christine ...Many Videos inside.
- Is their a way to verify miles on a LS2?
- Tvr Ls1, pcm clicking on cranking
- LS1 miata race video - battle with MazdaGT
- 4l65 bellhousing what happened?
- Lokar Trans Dipstick ?
- Pink wires and orange wire question
- DBW only getting 70% tps in 68 nova?????
- LS2 G35 Dyno Numbers In
- 5.3 into a 1st gen s10 project questions
- A Body Chevelle Oil Pan Problems Solved
- Strange Coolent issues Please give info.
- Harness testing, what on engine gets ingn voltage.
- first gen firewall hole
- '67 Z21 Camaro 5.3L/4L60e Implant
- PCM Capabilities
- 89 lx mustang going 5.3 then turbo.. .
- DIY Cold air intake
- 66 Impala Convert LS2 Conversion
- 05 LH6 in a 91 S-10
- Can't find pcm
- Ls6 RPM won't go past 3500
- *** Important info for those going to run a Super Victor carb intake P/N 28097 ***
- Using the engine fuse/relay box
- starter relay is grounded
- Ls1 in a Nissan 240sx?
- 6.0 in 99 mustang
- ls style motor plate??
- LS1 vs. LS3 intake manifold bolt patterns
- LS2 swap\computer question...
- 5.3 vs LS1 alternator wiring?
- Conversions and Hybrids welcome at LSX Shootout
- hickup / hesitation
- New Conversion--81 TA
- pcm and harness help (Will this work with my setup?)
- Lt1 fuel pump and 4.8 vortec
- nylon fuel line
- LY6 cam swap. Dont need to pull heads??
- What crossmember for 4l60e in a second gen?
- o2 sensor
- LS3 Fuse Box Hook-Up
- LT1 Fbody to LS1 Fbody Conversion Motor Mounts
- l92 malibu 10 seconds
- 01 Firebird cmad v6 to LS1/80e swap completed
- Alternator wiring help :[
- v6-v8 NBS Silverado
- lq4 truck harness questions
- Need wiring harness recommendation.
- shifter cable for ls 60e 95 stang
- radiator hose help stock 69 camaro
- ls1 swap headers
- ford power steering pump on 95 F bod?
- Need 1 3/4" 304 stainless LS1 header flange
- ecu switched power/ecu ground
- DBW Cruise on a Mustang? Factory cruise buttons? Anyone done it?
- Move coolant temp sensor
- A-body guys with T-56 and remote bleeders in here
- Rev limiter wont change
- Having a DBW issue, could use some help.
- Big Inch LQ9 Stroker ?s
- F body pulleys help
