View Full Version : Conversions & Swaps
- AC aftermarket through pcm problem
- starter
- v6 firebird to ls3
- Has anyone tested their cooling fan relays?
- Anyone gone blow thru lsx yet?
- v6 to v8
- LS1 68 camaro. what? how? and is it worth it?
- Wiring harness question.
- Externally Regulated to Internally Regulated w/LSx??
- So after looking over all the fox body/lsx swaps......
- fuel pressure reg
- lsx iroc ?
- turbo first gen camaro
- anyone w/techII in Mass, NH?
- New times with the LS1 mustang
- FM Turbo ls1 in a 3rd gen
- '72 Monte LS1 swap almost complete
- A/C Questions
- LS1 pulley set up on a 6.0L block?
- Trans dipstick question
- New 1st Gen Fbody PCM mounting location!
- Are these hookers too close...
- couple of problems/questions...
- did some more tuning on the carb
- SN95 Mustang swap...electronics?
- shorty headers
- new member
- 6 speed to 6.0 ls1 help
- New 68 Camaro Project
- lq4+powerglide...
- Fox swap guys.. people ok with it?
- Compact LS Accessory Drive
- changed some stuff, still NO fire.
- Project LS1Bandit finally hits the road!
- .......LS1 Carb guys please......... enter?????????
- Kooks Fox Body Swap Headers anyone?
- Carbed LS-1 in 1977 corvette with sidepipes!
- Check out our LS2 based stroker Pontiac Solstice!!! Pics and dyno video.
- 2002 stang GT LSX swap info needed
- LS2 swap drive by wire problem
- Problems with my new fuel setup
- PS Hose question
- swap car and vats issue.
- fitting for spectra premium fuel tank
- Belt Driven Fan for LS2
- New Here With ?
- Fox Body Ls2 Turbo Build
- Finally it runs sort of...
- LSX Conversion Headers
- D&D T56 mated to a LSX
- turbotacoma & other LSX Miata's inside (Extraction hood)
- 95 Camaro LS3 Conversion for Dummies
- anti-theft device
- LSX in 51 GMC comlpeted
- LQ4 in Third Gen Camaro
- 2000 4.8 no fuel
- michigan Lsx swappers? may need help
- Ls1 5.3 in 1st gen nova headers??
- corvette chassis under a c10?
- 1968 Camaro LS1
- wont crank, getting fuel, getting oil.
- Harness help (pics inside)
- Those running BRP LSx headers in their G-body, in here please!
- The Start of the Razor S10 build
- Looking for an 80's model s-10
- 99' GMC 4.3 to 5.3 conversion
- OH NO, Here I go again....
- LS! C3 Corvette
- More room with headers or stock manifolds?
- Which headers....
- tech guide needed for replacing a steering wheel
- 05 Vette alternator wiring question
- norcal ls2 foxbody mustang build!!!!!
- fuel plumbing?
- What Generation Motor??
- Talk me into or out of this (has anyone done it yet?)
- Thermostats interchangable?
- Corvette FPR Filter Connection. Will This Work? (Pic Inside)
- Noob ??'s 4L60E and O2's
- G8 engine and 6L80E transmission
- 98 mustang cobra with turbo 6.0L fs
- Starting The Single Cab Ranger Ls1 Swap
- donor vehicles...
- What steam line comes out on the passenger side?
- 85 Monte Carlo SS Swap
- Camaro shell fit on C5 chassis?
- engine starts to tick after 15 minutes of driving ls1 240sx
- How low is too low?
- cable-x guys
- any lawyer members I need advice
- New Project Coming......maybe
- Totally wired from wiring!! Almost done...help!
- Can someone ID these two plugs on my harness please?
- 5.7 to 5.3
- v6-v8...what wire to allow 4 cyl-8cyl from pcm
- Gear Reduction LS1/LS2 Starters
- 5.3 header
- 84 C10 Fuel System Question
- fox swaps beware!!!!
- harness blues...
- Lm4 Id?
- Turbo LSX in a 240sx
- Selling my LS1/FC3S RX7 Exhaust
- fuel pump wiring...size/routing
- conversion
- If you had a free LT1 and 4l60e
- Don't want power steering or a/c on my LS1 swap!
- f-body oil pan modification
- parting out lsx mustang swap parts and motor
- looking into a swap
- where do you mount your ECU in your lsx mustang?
- Headers for 65 nova lsx swap....
- Fuel Pumps?
- sensor
- fuel line fittings
- Iroc-Z Swap
- block hugger measurements needed
- thread size question
- Austin Healey LS1
- CA Engine Swap LS1 into 2000 Jeep Wrangler....
- LSx in a '66 LeMans
- ATC Fuse Terminal.
- Where to buy 5.3 or 4.8 Vortec Dropout
- swappers: need a cheap powerplant?
- Help. Car died. No power from computer
- 67 Camaro - Newbie LS1 Question
- November Issue Camaro Performers
- Big Thank You!
- What year 4l60e?
- fox body LS1
- cruise control issues
- Cheapest Auto Meter guages?
- Warning: SW headers do not fit the BRP engine kit for first gens
- where in houston to do LS1 swap into 68' c10?
- ls1 swap...carb or fi? 65 nova
- Bye Bye factory guages.. Hello TFT and Single Board Computer
- Swap Newb with a few questions...
- LT1 swap,,,,,
- LS1 s10 83-93 or 94+
- ? about swapping ls1
- what fuel pump (search engine down on my end)
- Ls1 Temp Sensor Adapter
- My LS1-powered 1970 Corvette featured in a magazine
- Anyone w/ AutoMeter gauges in 80s Chevy Trucks?
- compatability question 00 vette computer/99 fbdy harness
- starter
- Are all LS1 Starters the same?
- Anybody headed for the LSX Shootout?
- Camaro 3.8 1998 swap to LS1 ?? Help
- GM Part #88963646 Conversion/Hybrid/Swap Fuel Pump for sale $20
- Injectors only pulse twice during cranking. Help?
- LS1 in a second Gen F-body - looking for info
- Edelbrock Headers in a 2nd Gen
- F body Crossmember, anyone fabbed one
- tapping in for vaccum
- 1990 c4 corvette 6.0 t56? swap help? or talk me out of it!
- ls1 in 1986 s10 wiring questions
- Taking the plunge: LS3 into '64 Tempest. Need help with shopping list.
- HELP! Racepak (IQ3) to MEFI 4B Interface
- MSD 6010 map sensor 2bar 1bar ???
- 6.0 wagon at the track.....
- Balancer Mix-Up
- Another Wiring Question
- Finally Running!!!!
- trying to find pin for MAP sensor.
- Starter Bolts - both knurled?
- car together, injectors not firing
- Anyone need a GTO Cluster WITH PIGTAIL?
- LS Computer Help!!!
- anybody running without a T-stat?
- 6.0/Th350 Mustang going back together...again
- New Project: 6.0l/4L80E Turbo Notch Stang
- She's Alive!!! It's been a long journey.
- 99 z28 swap to ls2 ???
- harness
- MSD 6010 Help ASAP
- Headers studs
- LS6 Heads Standard On 4.8 And 5.3 Engines?
- Auto Meter Gauge Swap into 84 C10 Questions....
- 6.0 LS for G Body swap
- 97 Fbody LT1 TO LS1 Swap
- Motor Mounts
- tach output wire
- Non-TCS Cruise Control Cable Part # Request
- 90 Firebird, 3.8L LC2 to 6.0L LQ4 swap!!!
- 96 Vette Turbo/ 402/ TH400/ 12 bolt
- 1949 Chevy Truck with a 5.3L
- What DBW pedal will work with '08 E38 PCM?
- hood ?
- 4th gen headers work in 2nd gen?
- Odd question about an ls1/3rd gen rx7 swap
- Relays...how many is enough?
- TQ converter in light weight car?
- A couple quick questions
- VSS without a 4L60E
- Fuel system testing
- project car questions!
- LS1 + T-56 in a '72 Firebird
- Oxygen sensor connectors.
- Relocated battery, what size of cable?
- Fox LSX motor mounts
- Cable Clutch? (03-04 Cobra setup)?
- flex fuel injectors
- 1979 Caprice Classic?
- Anybody got an expansion valve setup figured out for a Vintage Air?
- How do i make my tach accurate?
- ECM A/C controls, whats what?
- LS7 into an FBody
- Which wires are power and ground for the ecm?
- LS1 Studebaker
- electrical problem: voltage drop
- Another dumbass noobie!
- pcm power w/ battery cutoff switch
- Vortec 5700 swap
- 98 Cobra...LS1 or LS2?
- LS2 in 63 Ford Falcon
- Double checks on wiring before giving it power?
- new addition.....62 chevy II....who has an lsx conversion?
- LM7 vs LM4/L33 engine weight
- Perfect radiator hose for 71 a-body chevelle
- G Body Long Tubes
- fuel pump ?????
- GMPP Catalog: Awesome!
- custom headers???
- cost of ls1 swap????????
- LS1 questions... What is this?
- Where are you guys buying your PCMs from?
- what do you guys suggest? LS1 in 2nd gen
- G Body LS1 with motor plates
- Very easy wiring question
- I have a G Body and I have a 5.3l swap question
- 72 chevelle ls1 engine swap mount trouble
- Flex Fuel Sensor Wiring
- speedometer reading wrong
- Yank converters for 200r4/700r4 4 sale look
- what car for ls1 swap
- Quarter Mile Times
- Need some help diagnosing PROBLEMS!!
- Any body use Current Performance Wiring?
- power steering whine
- What kind of steering hose do I use?
- Turn key 383 ls1??????
- After 2 years in the making...
- NEED ANSWERS: Wiring Pinout questions*!*!
- mustang ecu mount problem!!!
- transaxle for a 6.0?
- ls1 240sx OIL pressure gauge??
- **Speed INC. alternator relocation kit SALE!!**
- 408/TH400 in a 93-97 fbody?
- 04 5.3 harness to standalone
