View Full Version : Conversions & Swaps
- what fuel pump
- opening up a cruise control anyone done it?
- replacement fuel pump
- Solstice swap
- Solved a stupid tachproblem
- truck 6.0
- Neutral Safety and TCC Wire?????
- Wiring help
- Looking for pics of S&P Headers
- Incredible helpful L21, LS2 etc parts website
- Low Cost Alt only Accessory drive?
- 6-speed in a 68 firebird
- fuse block ?
- Need Help. Ls7 clutch wont disengage.
- does anyone know much about pitman arms on first gens?
- Flex a lite 210 in 94>s10's
- Help on Part #'s
- Volvo 960+LS1
- ls240 clutch engagement issues.
- '67 Nova-LS1-T56-C4 IRS
- Help needed
- oil pan question
- exhaust on an rx7/ls1
- LS1-Running Very Cool. Not normal?
- Engine/tranny mounting question
- LS1 fuel pressure shut off???
- My Goal 700RWHP in Foxbody
- speedo any one want to be confused
- source for 5-pin truck MAF connector?
- Will 94 p.up speedometer work with ls1 vss signal?
- LS1/LQ9 swap into 96 firehawk
- Harness to ECM extender?
- ls conversion-best way?
- lt1 4l60 can it be used with a lsx?
- LS1 -> Porsche 944 Conversion Help
- thermostate housing
- trouble with stock harness
- Power steering pulley on truck accessory setup
- More Pics of Ls1 240
- Exhaust Manifolds/Headers for tight swap?
- 85 Monte Carlo SS dash gauge signal input?
- ls truck pan/fit in an "A" body car
- Ls1 into a V6 Fbody??
- Delima
- another MAF question..
- GN powertrain into 88 chevy s10?
- Anybody NOT using a T56 in their hybrid?
- LS1 ONE-WIRE Alternator ???
- cruise control wiring
- Help!! possible? ls1+ 6sp into 91 Caprice
- 1966 Nova nearly finished (just a little fender rub,soft clutch,and brick like brakes
- Engine Coolant Level Switch (how to bypass)non stock radiator.check out my vids
- Foxbody swap ??
- F-Body Longtubes in a 69 chevelle?
- Question about F-body hyd clutch line in a fox
- tranny or clutch problem, swapped with custom mounts
- TBW pedal assembly
- Anyone using a 700R4?
- Need Info For LS1 Swap
- Need power steering & A/C hoses made-up in Seattle
- Anyone mounted a 200 4R to a LS1
- Ls1 heads on
- Anyone use Wait4meperformance??
- Motor plate + accessory question
- LS1 into a 944 discussion.
- Anyone using a "scangauge" on there ls1 swaps?
- Dave at OC Stangs
- Temporarily incr. idle-drive by wire
- 1980 Buick LeSabre sleeper
- Bmw E30 Ls1
- LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
- Guess the chassis.....
- Recommend me an OEM pusher fan of some sort.
- 6L80E Swap
- ls2 a/c belt alignment problem
- Difference between C5 balancer and F-Body?
- problem with initial starting.
- 66 Nova LS1: Donor vs. engine/tranny only
- obd2 diagnostic connector?
- S10 Swap Using Mustang headers Question
- What fitting do I need???????????
- 5.3 wiring problems
- LS2/L92 block strength?
- Thee Alternator FAQ thread
- 2JZ into a C4 in Kuwait...
- LSX in a g-body, what trans?
- Thoughts on purchasing a pull out from a rolled vehicle?
- I have a chance to buy an LS engine. Should I or Shouldn't I?
- mass airflow meter ?
- 6.0L LQ9 + Magnacharger into '94 Caprice
- My LS1
- LS S10 plug wires?!!!
- guide by wire throttle body bypass?
- lsx into gbody, speedo questions
- fuel pump problem
- What does it take??
- Buing the right donor car for a 68 bird
- LS1 into a Cadillac Catera (56K=death)
- Alternator output through ODB II port?
- 69 Brake conversion...Alittle help???
- im a confused car guy !! mexican japanese car american v8?? WTF
- Heater install question
- Fuel Rail Dilemma
- thirdgen f-body oil psi ? with ls1
- 87 gn
- Help with fuel pump
- s10 advise...
- ATS and Autokraft oil pan questions
- anyone tried this one?
- 2007 Schematics
- How can I retain VATS?
- Electric Fan question for 5.3
- A few pics of my Fox/LS1 build
- Aftermarket dash
- 5.3 alternator
- Which stalk switch for CC and ETC???
- newbie, LS-1 into a '64 LeMans
- LS1 in 48 Chevy Coupe
- T56 crossmember question
- Dash harness
- LS1 P/S pump to AGR rack?
- Anybody with a C3 Corvette using stock AC comp?
- camaro fuel tank dimensions
- Custom a/c lines?
- need help with nelson harness...
- LS2 in LT1 Camaro?
- MSD 6010 Question about MAP sensor
- Gbody Turbo question
- serial 2 data line, help(pic)
- Fuel economy
- 6.0 in a 92K15 SWB 5sp
- i want to put a LS6 in my 2007 mustang GT
- Fox K member question.....why?
- Help! Throttle Cable Bracket Install on DBW Manifold!
- Needed for LS1 LT1 Swap??????
- 63 Chevy II Header Question
- LS1 into 97 f-body, what does it take?
- questions about LS1 in 97' Formula
- Which Headers good start for Vega swap
- Extra amp draw?
- Help identifiying harness plugs
- ls1 into honda s2000
- Best year for LS1 swap?
- Underhood Heat Issues?
- Not that I would, but ... LSX/T56 into a Pacer
- Calling thirdgen LSx Swap guys
- Chevy Ii Fuel Tank
- 6.0 (or similar) into a thirdgen - what parts?
- LS7 Ultima Driving!!
- is my autometer tach (needle bouncing) gonna break?
- How hard or easy would this be??
- 79c10 procharged ls1= need lots of help!
- diagnostic port help
- Is this worth it for mock up?
- LS1 Not Start-> Gas contiues to pump
- Doing LS1 - BMW swap - need bleeder line info
- LS motor in a 96+ 2 door tahoe
- ac high pressure switch
- Who wants to put a LSx in a Porsche 944? Start here.
- Need Help
- a/c pump
- Check engine light grrrrr!!
- Anyone using the Street and Performance Trans crossmember?
- Fuel pressure not adjusting...???
- Opinions! (since everybody has one)
- Swapping LS1 into BMW 325 -- PCM questions
- Would an LSx fit in here?
- Dreaming....APS TT LS1 in RX7
- Running fuel line, have questions about the fittings
- LS1 going in, but which one?
- ls2 in 3rd gen question???
- difference between the 2 coolant temp. plugs on the ls1 block?
- throttle body swap
- LQ4 swap into a 68 GTO A-body: Questions
- oil pan ?
- LS1 in my wrangler won't turn over
- question for you guys looking to use 'vette fuel filter/regulator setups...
- Fuel Tank Swap Problem
- Ls1 in a 1997 Chevy 1500
- Whats Up Gonna Be Doing A LS Swap Into An Early 240Z
- It's ALIVE!!!
- why would I make a vette look like a viper?
- S10 pro street
- Non-LS1 fuel pump options
- 4th gen Fuel Pump work in a 3rd gen tank?
- Where to go? 1979 Silverado
- Impala Sender question
- ls1 engine install guide pdf file
- PCM fan relay control question
- ls1 240sx question
- Few lil problems with first run
- A-Body Hooker headers and F-body Oil Dipstick
- LS1/3rd gen f-body coolant hose
- 04 GTO Motor and 6spd in 69 Camaro
- Creature Comforts question
- Putting 99-02 fuel pump in 95 Z28 ?s
- looking for a mustang
- Help installing a LQ4 into a 65 Chevelle
- Old Dog Z31 300zx LQ9
- looking for some insight on a toyota swap...
- LS1 5.3 into an '82 k10
- WHOOHOO !! My LS6 Mustang has PAINT !!
- Street & Performance ?
- Where to connect coolant crossover line?
- 5.3 carb swap
- smog on a LQ4-9
- Help
- 5.3 in a 2wd 72 blazer (oil pan problems)
- 550 rwhp for 68 Camaro
- Built rear-end in C3 Vette. Looking for possibly 750whp with n2o...
- LS1 to LS2/LS7/LSX conversion
- 98 F body harness, how to hook up my volt guage?
- Does anyone have shorty headers on a F-body
- Water Pump question??
- LS7 in a Silverado SS?
- Fiero with ls1 or ls2
- 2nd Gen Camaro
- LS1 to LS6 Conversion....HELP!!!!
- would shorty headers work?
- Twin turbo ls1 foxbody...? You can have it...
- Pacesetter Franken-headers
- fuel filter?
- LT1/T56 into 2nd Gen Swap
- Project Progress Report - 72 Chevelle
- Headers or OEM exuast manifolds?
- 67 c-10/ ls1 headers
- L92/L76 Intake to TAC module Wiring HELP!
- Anyone using AFCO swap radiator, F/A body
- converting from 3-wire MAF to 5-wire MAF???
- Anyone using the trans dapt motor mounts on their 67 camaro
- A-body crossmember pics
- 3.8 to ls1 will standard trans bolt up?
- Washing the LS1?
- what intake to use on 4.8
- Harness Question
- Ls1 into 240sx____PICS
- LS1 Mustang new times again !
- Invading Germany: LSX into BMW E34 525/535
- LS1 84 Vette just needs a little work to be complete
- I need a new driveshaft right?
- ls1 won't start?
- Wrecked my baby....
- Switches for Cruise Control?
- Year One Bandit shaker scoop
- LS1 swap in 75 Camaro HELP!!!
- LS1 swap HELP!!!
- cruise control
- gas tank
- Electric fan choices
- 5.3 in a 69 camaro, will the alt clear a cowl hood?
