PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. 5.3xth350/400 questions
  2. 1996 firebird 3.8 ls swap , no fuel ,no spark gremlin
  3. 54 chevy truck ls swap bad 13mpg
  4. 1962 Chevy Impala -o2 issue
  5. MSD wiring question
  6. L99 6l80e and wiring the brake pedal, HELP
  7. GM Factory Gauge Cluster Compatibility
  8. C5 Corvette flex plate/torque converter.
  9. Confused about my harness
  10. LS3 Swap Alternator Wiring Question
  11. 1970 Chevelle - 6L80E is way above trans mount
  12. free VATS removal
  13. Ls runs like it has 2 step.
  14. 04 l59 flex fuel fuel pressure
  15. Trying to understand
  16. Starter interfering with block help
  17. 1999 pontiac trans am
  18. 96 firebird 3.8 auto / to ls1 swap help
  19. Need help 199 pontiac trans am ls1
  20. LS1 Swap Issues
  21. Flex plate to 71 nova 200 4r
  22. 1988 Mazda B2200 5.3/4l60e conversion looking for Mpgs
  23. Need help w/ swap in my 92 Roadmaster
  24. Would there be interest in splitting for the forum? (read)
  25. 2013 Tahoe 5.3 swapped with 2013 6.0
  26. Cd009 with ls1 issues
  27. LS swapped 68 Camaro ran fine for months and all of a sudden backfired? Holly ecm
  28. Another Trinary switch and PCM question.
  29. Stock 5 speed manual from 3800 V6
  30. 2005 Lq9 68 gto oil pan recomendations please...
  31. Mechanical clutch fan
  32. 2006 Silverado 5.3 swap into 2007 dodge magnum CRANK.. NO START
  33. 1973 C10 - L86 Swap / No Start Issues
  34. LS1 thew a rod, best rebuild project??
  35. 67 camaro swap, no spark
  36. LS7 clutch, TKX trans - clutch won't disengage
  37. I need help! ​​​​​​​
  38. ***Conversions & Swaps Stickies & FAQ***
  39. UMI Big block K member question
  40. Getting started and questions about motor mounts
  41. Noob questions
  42. Need help, seemingly having clearance issue.
  43. Dakota digital dash and small Holley screen or 7” Holley screen?
  44. Coil brackets with truck accessories
  45. Lq9 oil pan?
  46. Coolent help! E46 swap is this setup ok
  47. need brake switch help
  48. 69 Charger LS Swap
  49. Hooker Blackheart S10 headers
  50. 1965 nova 6.2L
  51. AC Compressor
  52. 2nd gen subframe in a 1st gen camaro
  53. Hooker LS Turbo Manifolds....ugh
  54. 1986 Chevy K10 LQ9 swap help needed
  55. 88 Chevy SWB 5.3 swap
  56. Will straight water kill the Water pump??
  57. Terminator X kit question.
  58. GMT400 Master Clutch/Slave Cylinder
  59. 1992 Camaro LS swap help!!
  60. Header selection help for swap. Tight clearance
  61. My last remaining LS1 T56 dropout, what to put it in.
  62. 1961 Biscayne LS Swap / BISKWIK
  63. E36 ls1 ac
  64. Welding on car with ECM concerns.
  65. LQ9 swap 0psi Fuel Pressure at the rails
  66. LS1/ Muncie Issue Need Help
  67. What all to harvest off donor?
  68. Driver side bank not firing
  69. Wiring Help 411 PCM
  70. 5.3 LS swap inquires
  71. LQ9 swap now wont start
  72. need drive by wire help!
  73. Lq4 Build for the new truck
  74. LS SWAP only firing on two cylinders
  75. need help with 1996 3.8 firebird ls1 swap
  76. Gen 4 6.0ls into my ‘04 Silverado help!
  77. u joints and drive shafts
  78. low buck nascar ls swap and rebody
  79. gas pedal , DBW not working ,on and off
  80. LS3 with Magnuson 2650 in an old muscle car, hood clearance?
  81. No closed loop
  82. Wiring swap question
  83. Squeal like a Pig! Belt pulley squeal issues
  84. 1/4 vs 1/2 watt resistor on alternator wiring
  85. Should I swap an LS motor into my 2006 BMW 330i ?
  86. Can my upper hose run up hill like this?
  87. 5.3 Hissing after shutdown?
  88. 70 Chevelle E40/LS2 convert to LSA
  89. LT4 / A10 swap guys
  90. 300ZX/LS3 persistent P2135 problem
  91. 67 Galaxie 383 stroker swap, Donor car runs rough+backfiring through intake
  92. 77c10 l99/6l80e swap
  93. Transmission swap C5 LS1
  94. O2 Sensor Issues
  95. Running Front plate without mid plate?
  96. LS swap not startin at first key
  97. Identify Transmission
  98. crank no start
  99. 1951 Chev 3100 truck LS1 eng
  100. Nylon fuel line proximity to exhaust, how much is good enough?
  101. Looking for some headers for a problem car (LS conversion)
  102. 6AN PTFE SS braided hose. Too small?
  103. Delete, wrong forum.
  104. 70-81 Camaro 4L80E crossmember
  105. MAF location help needed
  106. Need help finding large radius 90
  107. LS Swap help with connections
  108. Calling all 64-67 A-Body owners with LS swaps (longtube discussion)
  109. Firebird LS swap
  110. L83/6L80 Gathering of parts
  111. 1996 s10 rear slicks Hoosier or M/T sizes
  112. Need help with 05-13 corvette pedal
  113. ANY REVERSE tech swaps out there? new car old engine?
  114. GMPP E67 ecu and fan control
  115. Terminator X Max and AC
  116. Crank no start
  117. First Gen Front Accessories
  118. 2006 Canyon rwd with LM7 questions
  119. Help DBW gen 3 pedal into 2nd gen camaro
  120. Need some advice guys! T56 or 6L90 in Pro Touring Chevelle
  121. Conversion advice sought
  122. Conversion advice sought
  123. 92 K1500 Stroked 5.3 Build
  124. Fuel Rail Questions
  125. Lots of confusion about PCV
  126. LS swap 89 foxbody motor mounts
  127. LS swap 89 foxbody motor mounts
  128. Chevelle LS swap won’t stay running
  129. crank no start. got spark but injectors not pulsing question
  130. I don’t know if it’s a conversion…LS4 to RWD in a 1980 Corvette
  131. Engine mounting/engine placement issues in 1947 Mopar
  132. 64 Vette, LS newbie questions
  133. What sensors will keep L59 from startingv
  134. 95 3.4l camaro swap to 5.3l, k member question
  135. Backfires at low rpm
  136. 2002 Camaro. v6 to 6.0 swap. Help me out here, Done a different way to work!
  137. Lq4 powered toyota
  138. 19166753 wiring harness
  139. 8HP70 mated to LS?
  140. Will a 8L90e or 10L90e Fit into 1970 Chevelle? Any cutting Required?
  141. 1970 Duster AlterKtion, 4 Link, LS/T56/Turbo and Minitub
  142. Let's talk tablets and OBDII gauges
  143. Eight of the Wildest LS Swaps Over the Years
  144. ls Air Conditioning in 1963 cadillac help
  145. Maybe the first Gen 5 LT4 Swapped F-Body Help
  146. Early s197 5.3 swap - transmission
  147. LS376/480 cooling fan questiion
  148. Affordable sealed relay/fuse box
  149. TR6060 --> T56 Magnum Parts List
  150. HELP Gen 5 LT4 Swap Into F-Body
  151. Remote Start Tach signal Gen 5 L83
  152. Slow cranking LM7 swap
  153. APE converter (Any - Pedal - ECU adapter box)
  154. Standalone 6L80e controller idea ??
  155. Wiring and PCM options... best choice these days??
  156. GenV FPCM question
  157. Another Build: 55 Chevy 210 remodel and upgrades.
  158. 8 Cars We Want to See LS Swapped
  159. Chevelle swap to LS/LSX 4L80-E Help
  160. 88 OBS 5.3 with little chopper cam
  161. l83 pwm fuel pump height
  162. PERFORMANCE TIRES for 15-17" rim
  163. 2017 L83 with NQH transfer case
  164. Gen 5 dash with LS1 hardware?
  165. 2006 Canyon LS swap questions
  166. 2005 Express 6.0 with 4l80e wiring diagram needed
  167. What gas pedals will work on a GenV swap?
  168. Radiator support
  169. 996 C4S CanBus Questions
  170. Wrong MAF cause issues?
  171. Headers for 5.3L
  172. 6l80e shift detents question
  173. LS swap ECU advice
  174. My brothers 1950 mercury 4.8
  175. My 76 dj5d postal jeep
  176. 4th gen f body oil pan questions
  177. GenV VATS question
  178. Help me with these ports please!!
  179. LS2 Powered '55 Chevrolet Bel Air 6 Speed
  180. Jeep will not move
  181. No Accelerator at Cold
  182. 5.3 swapped Mustang SVO trans and bellhousing questions
  183. Blown head gasket
  184. 1949 chevy truck ecm location
  185. Radiator
  186. LS1 transmission
  187. 2000 Pontiac Trans Am WS6 w/152 miles
  188. Clutch help
  189. LM7+Volvo 245+Water Pump Issues
  190. Correct MAP
  191. 88 OBS with gen 3 5.3, Holley sniper
  192. injector pulse craps out
  193. v6 to ls1
  194. Ferrari GTE 2+2 is Restored With LT-1 Power
  195. 1989 Nissan 240SX Gets LS7 V8 Updrade Under the Hood
  196. LS3/LS7 Height Injectors into TBSS w/Aftermarket Fuel Rails
  197. Intake manifold for LS in Jeep
  198. 65 Riviera
  199. Gen 5 L83 Starts Then Dies......another one.
  200. 1976 Chevy K10 LS swap
  201. 1976 K10 LS swap
  202. Am I going to burn up my starter cable?
  203. Gen V main relay and powertrain relay wiring
  204. Newbie looking for e78 info
  205. Another IS300 - LQ4 & T56mag-F
  206. slow cranking issue
  207. Engine wiring harness question
  208. 66 Cj5 LS swap
  209. Fuel Pump install kit?
  210. Daisy Mae - 91 K1500 5.3 with 5 Speed Swap
  211. 1975 Nova 5.3/4L60 Swap
  212. 1965 nova LS swap
  213. Brushless electric fan
  214. 1965 nova LS swap
  215. 1998 3.8l V6 auto to LS1 T56
  216. E36 m3 ls1– 57a fans on 40amp relay cooked
  217. Aftermarket Temp Gauge Question
  218. Swap shuts down after 15-20 minutes
  219. Fuel filter/regulator and fuel lines questions
  220. 4l60 or 4l80 in 69 camaro with l92
  221. Good source for wiring?
  222. Muncie trans on a ls engine
  223. Assuming fuel issues. Running bad.
  224. Stock Tune on Cammed 5.3 safe?
  225. 1955 Buick Special 5.3 single turbo build
  226. 1997 Turbo LS sn95 Mustang
  227. 6l80 tutd
  228. Ls swap hydroboost power steering question.
  229. Weight of Gen V LT1 vs Coyote?
  230. LS3 with magnuson blower - which ECU to get?
  231. CARB Legal LS3 Wagon Swap Project (Official Build Thread)
  232. 1984 K10 5.3 Swap Build Advice. Bang for buck power.
  233. CPP LS3 coolant plumbing
  234. 1984 Jaguar XJ6 - 6.0/80E/turbo
  235. Operation BitterSweet 1965 Cutlass LS Swap
  236. Fan Control in 2001 Porsche 996 w/LS3
  237. 88-98 C1500 guys - Camaro SS manifolds?
  238. Questions about using a 0411 pcm on a supercharged Pontiac V8
  239. 83 Delta 88 LS3 oil temp sensor
  240. Pinouts and schematics needed L9H/6L80 2009 Yukon Denali
  241. C5 cluster questions
  242. 5.7-Liter LS1 Powered Studebaker Wagon
  243. 1989 Jeep YJ chassis swap, LQ4 & more
  244. 4WD Low Range on 07 Gen3
  245. New to the ls world
  246. 89 K2500 swap A/C help
  247. 1999 Express 3500 - 2019 6.0 L96 Swap - Speedometer & Fuel Gauge Not Working
  248. Is this a good donor vehicle for an LS swap?
  249. 72 Nova Build 5.3
  250. 55 GMC 100 short bed swap.
