PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Youngest to do LS swap?
  2. Well, I'm starting to take the plunge
  3. My slow and steady lt1 to lq4 swap
  4. 93 camaro V6 swap to 2000 LS1
  5. corvette filter fitting leak
  6. Radiator Hose Question - Radiator Swap
  7. Fuse Box Design
  8. LS1/T56 1971 Firebird Project
  9. Anybody that's into early Novas
  10. Don Nguyen | My Porsche 911 V8 Build
  11. 66 Catalina GEN IV 5.3/Muncie
  12. 6.0L LQ4 w/L92's & 4L80e in 1970 Buick GSX
  13. Drilling LS2 water pump?
  14. Project ls swap c10 *update post 48*
  15. getting a factory 69 tach work with a ls1?
  16. LS2 into FC RX7: Power steering elimination?
  17. 94s10 v8 swap?
  18. LSx w/ TH400 into 1967 Tempest – Complete Parts List
  19. Holley Hi-Ram intake mani on LSX S-10
  20. Transforming a tired Nova
  21. 5.3 mustang swap wiring issues
  22. Fox body swap
  23. 5.3 swap
  24. PNP NSBU Switch 4L80E
  25. t56 shifter issue
  26. 6.0L oil question.
  27. turbo 5.3 build in a 67 camaro motor mount question.
  28. I made a slide show of my LS swap
  29. I really need a hug!!!
  30. Vortec throttle body elbow
  31. LS2 58x E67 PCM Wiring Diagram?
  32. LS1 in 2013 Chevy Cruze
  33. ECU Relocation question Porsche 911 ls1
  34. Nissan S14 T70, 4.8, T56 build
  35. Input plz
  36. Looking for 72 nova midlength headers- tired of dynatechs hitting
  37. 105 TB, super victor
  38. 5.3 Swap in 71 Blazer starts and dies
  39. third gen t56/4.8 swap
  40. Nova/Camaro tranny dipstick
  41. Doug Thorley Headers 67-87 chevy trucks w/ LS
  42. l99 & 6l8oe in hot rod
  43. LSX Swap with LT1 K-member?
  44. 57 chevy ls6
  45. Wiring harness help!
  46. Relay and fuse panel - affordable
  47. FAMOUS! & STOLEN '84 C10 5.3 article posted on LSXTV.com
  48. i need some advice with my lh6
  49. 'bout a '92 Dodge Stealth ES ?
  50. bolting tremec to a 05 ctsv ls6 help
  51. Budget 4th gen LQ9 build???
  52. LS6 Nova Badging... What's your opinion?
  53. Is this what I need
  54. heads for lq4
  55. Alternator wiring
  56. gen 3 wiring
  57. Ls1 into Datsun 280z fuel system questions,
  58. LS1 Miata question
  59. 99 mustang gt 5.3/t56
  60. Couple of quick wiring questions
  61. Oil pan advice
  62. New Internal Fuel Pump Option???
  63. 69 camaro ls3 a/c bracket location.
  64. Starting issue
  65. 5.3 Fox Body swap
  66. Looking for thread about Audi install
  67. 4th gen seats in A-body
  68. Custom header kits?
  69. LY6 valley cover swap to LS3?
  70. 70 camaro LQ4/T56 swap... Gauges
  71. HELP! LY6 conversion into 68 firebird
  72. 5.3 4wd s10.. This is going to take a while
  73. 1976 camaro ls1 swap
  74. f body headers
  75. Transmission to Oil Pan Bolts
  76. 05 lq4 egr question
  77. 1971 Firebird LM7 5.3L Swap
  78. 64-67 A bodies using BRP mounts??
  79. 05 lq4 to 4l60e
  80. Fox body swap
  81. DBC Throttle Body?
  82. 93 Digicamo Rx7 'The Beater'
  83. 240sx 5.3l n20 th350
  84. 67 Camaro swap, project "belly button"
  85. GEN IV engine with mech. clutch ?
  86. Radiator Size Requirement
  87. PCV for TBSS LS2, Corvette Intake, TBSS DBW TB
  88. another abomination complete!
  89. 71 chevelle...lq4/4l80 swap..motor mounts??
  90. 4L60-E Neutral Position Switch Wiring
  91. 1st gen Camaro/T56 guys step in please...
  92. Microsquirt LSx Walkthrough
  93. 2nd try 84 blazer swap
  94. Ultra-Light, 505 WHP AVI Racing Corvette GT1
  95. 68 camaro swap
  96. What shifter for th400 in 99 mustang
  97. psi harness plug help.
  98. 1969 camaro l92 swap
  99. 400 crossmember help please
  100. How did you select your LSx recipient?
  101. First gen ls1 oil pan
  102. Psi is offering you $100!!!
  103. Cable X hook up (question)
  104. Any cons to using a LS2 intake?
  105. LS376/515 70 Camaro
  106. Motor mount help
  107. DBW setup worth?
  108. What would you choose??
  109. no lope
  110. 01blazer ac
  111. Where to put my O2 sensors on my turbo 5.3
  112. 2003 Porsche 996 C4S, LS3 Conversion
  113. Tap Shift Technology on 1997 LS1
  114. 98 V6 to 99 LS1
  115. '49 3100 grafted to a C5 chassis/engine (link)
  116. Lsx coupe (budget) built question
  117. Lookng at LS? for a 996 Porsche renegade Swap
  118. AJE crossmember QA1 control arms.
  119. 84c10 5.3/4l60e
  120. Wireing Harness ?
  121. 5.3 87s10 pt 47/88. Build/pics
  122. g body starter question
  123. 5.3 4L60E in an 88 mustang
  124. Lokar DBW Pedal
  125. TR6060 question
  126. Lq4 Swap in 96 firebird
  127. ls6 miata starting issues
  128. 97 v6 camaro body harness to ls1 motor harness
  129. Anouther LS1 Miata build
  130. Custom Long Tube Header / Exhaust Build ***DYNO Results are In***
  131. extension harness msd6010 box to ls2 cam sensor
  132. F11 Park/Neutral Start Switch Signal?
  133. GM Holden LX Torana - LS1 Conversion
  134. GM LS high pressure sensor fittings?
  135. Turbo LS G-body with A/C?
  136. 03 lq9 into 02 z28
  137. 64 chevelle /96 ss impala gas tank
  138. polyurathane motor mount inserts
  139. 03 Infinity G35 Sedan LS1 M6 swap
  140. Rebuild Heads Only? (not bottom end)...
  141. Ls 5.3 truck cruise control in a 40 ford
  142. ls1 in 63 nova questions
  143. OK, new here, have 2 oddball questions
  144. '00 BMW M Roadster - LS1 Swap
  145. Fuel tank
  146. 57 chevy ls6
  147. Electric fan won't turn on
  148. 57 chevy 2002 ls6 with 2002 camaro oil pan
  149. Loose Dipstick Issue
  150. Trunk fuel pump access
  151. ls swap into 75 gm a body
  152. College Budget Four Door Chevy2
  153. computer interchangability
  154. New Car Wiring Harness Question
  155. Motor Not Functioning With New Harness
  156. new build 95 s10
  157. 54 chevy sedan with 5.3 and a 4l60e daily driver
  158. Need LS conversion help in Nth Florida
  159. booster questions
  160. People boosting 4.8-5.3?
  161. wiring question
  162. Fat Smokey Burnout! '84 Chevy C10 5.3 Swap
  163. Swapping a ls1/t56 into a M3, what should be PM?
  164. Solder heat shrink connectors / solder sleeves
  165. 93 Cobra Clone 6.0 408 Stroker, 4l80e, S480R Turbo Build.
  166. ls2 swap in 96 z28
  167. Cam,intake,exhaust 5.3/4LXXE '85 C10! PIC HEAVY!!!
  168. Neutral Safety Switch Wiring
  169. what tuner do i need for swaps
  170. ac compressors?
  171. Fox k member with 4.6 mounts?
  172. 98 LS1 into 93 T/A
  173. 55 chevy swap
  174. Fuel pump for G-Body
  175. 4l80e crossmember for fox.
  176. wiring up aftermarket gauges
  177. Electric to Mechincal Speedo VSS wires
  178. LS1/T56 into a 68 Camaro
  179. What to do to bypass clutch switches to start fox
  180. 04 5.3L carbed in a 68c10 questions?
  181. s10 ls air cleaner placement
  182. Standalone wiring issues
  183. Fuel Pump Location for my swap?
  184. trailblazer ls2 ps pump
  185. any input before i hit the buy it now button ?
  186. 5.3 truck egr?
  187. 2002 Mustang GT 4.6
  188. Fox In-tank pump vs A1000 for LQ4 turbo
  189. 1971 Trans Am - 496 BB Chevy
  190. new ls1 for a zr2
  191. How much can I cut from A truck oil pan
  192. ls4 fwd engine into rear engine Corvair?
  193. 68 Chevelle LS Build
  194. Racetronix fuel pump ??
  195. Weld-up header kit
  196. 01 camaro brakes lock up, 65 nova
  197. What's needed to bolt a 6l80e to a ls1
  198. Newbie needs help
  199. Truck harness in 96Z28
  200. Why is an "X" pipe/crossover pipe so important?
  201. VIDEO of my LS1/T56 300zx driving and pics!
  202. 67 Buick GS LQ4 swap.
  203. G Body Oil Pan
  204. LQ4 Dodge Ram!!!
  205. ECU tuner in Sacramento?
  206. ECU tuner in Sacramento?
  207. LS1/T56 2nd Gen Fbody Conversion in progress, Just a few specific questions
  208. Speartech Gauges for 6L80/6L90 Swap Projects
  209. Helllppppp
  210. variable fan speed switch
  211. swap project
  212. AutoMeter Speedo and Tach Solution!
  213. 95 k2500 nv4500 6.0 swap
  214. Stall for stock 5.3
  215. what is this wiring for fox ??
  216. SN95 & New edge mustang swap guys
  217. F-Body LS1 E-Fan Amperage
  218. Today it begins! 1990 Mustang Vert LS Swap
  219. Denso or Sanden?
  220. Compression Test Question...
  221. LS1 to Muncie M21
  222. Why doesnt anyone make repro electronic speedomeeters?
  223. IS300 swap
  224. What are these wires/vac for? Fox.. picture
  225. Fox Mustang Swap with AC?
  226. Tainted's 408 240SX Build
  227. Help with my Vega swap sh*t storm
  228. Ls1 g body
  229. help on chevelle measurement
  230. 1979 trans am oil psi switch using factory guages.need help
  231. Ls1 86 g body regal
  232. tach signal dead
  233. Oil pan?
  234. Antique and Collector Insurance, who?
  235. Vintage air questions
  236. Stupid Plastic Pedal and Big Alternator
  237. LQ4 power steering delete????
  238. Autometer Speedo Doesnt operate?
  239. 6.0 LQ4 into a 72 Buick skylark convertible
  240. Conversion Harness
  241. Need info on pinning out a harness
  242. Fuse/relay box for modified harness?
  243. need truck accessories
  244. LS1 smoking like crazy...why?
  245. TH350 issues
  246. LS Swap book update
  247. Springs for an LS1 A-body
  248. oil pickup tube problems.
  249. Building an f-body from scratch; need Engine A6 transmission help
  250. LS1 Stand Alone Wire Harness Fuse Block Question...
