View Full Version : Conversions & Swaps
- Where can i find a part# for IAT?
- Do i have to connect the ALT wire on 02 5.3 truck engine swap?
- hello from spokane need help with ls swap
- 68 Camaro LS1 swap questions
- Trouble solution at the time of the start
- Aftermarket intake and sensors?
- LSA in a 65 Impala stock hood ?
- Hybrid conversion.........maybe??? Part 1: Engine
- Which o2s?
- Ly6 6.0 to th350 HELP!
- 71 El Camino LS Swap going to need some help !!
- will a truck oil pan work?
- Wire harness and ecm
- ls swap 944/240sx/3rd gen firebird
- 2001 5.3 power steering pump to power rack hoses/fittings
- What is MAF wiring route on 03-07 truck engine?
- 93 coupe, LY6 swap
- Starter for ls w/ 621 bellhousing?
- Fans setup help
- Nova C5 brakes help
- S10 4WD LS oil pan woes
- Pedal and tac question
- ls holley efi. stumble help
- 5.3 Vortec Relentless P0101 Code
- What Clutch flywheel for hooking up to a TR6060 (M10)
- 71 C3 gas tank vent
- 1977 Trans Am LS1 / T56 Build
- Leaving knock sensors in place but tuning them out?
- LM4 vs Lm7 for swap
- Need cold air intake with MAF to fit close fan shroud
- Holley Hi Ram in 1st Gen Camaro
- DBW to DBC coversion
- LS3/T56 magnum swap 68 firebird, tunnel mod?
- Which oxygen sensors do i need?
- Camshaft Identification
- Putting an LQ4 in a Slowpar...
- LSx 1970 Chevelle Vintage Air - Charging Problems..
- Check Out This LT1 Powered Off-Road Supercar
- 56 Nomad LS3 conversion
- Need help with set up 1967 with ls1
- 2002 Eldorado Northstar swap to LS4
- Plug wires arcing to the header through wire sleeve
- 5.3 engine cover
- GMPP Muscle car pan
- ls3 swap
- HoodRatHotRod LQ4/TKO600 '79 Malibu G-body
- An LS Powered Car That's Made with Hemp!
- Newbie questions for a 5.3 Datsun
- Conversion wont idle
- ls1 e46... AWD
- EVAP purge sel.
- Cbm ls remote oil filter adapter
- Another Twin Turbo Chevelle
- Holley mounts for LS/T56 in 67 Chevelle? need info
- t-stat housing question
- Oil Pressure light setting on LS-1
- What to keep from my donor?
- Project Dragoon: LS Rat Rod 'Goon
- Ls1 harness
- Hotwheels 70 Camaro gen4 5.3 build
- LS3 powered C-10
- Fuel vapors
- '71 Chevelle P.S. issues
- LC9 Harness Connector Identity
- Will 2002 van engine Mounts work for this swap?
- LS3 Erod overcharging, WTF
- Egr
- mercury zephyr wagon update
- Chevelle ls swap radiator?
- Street and performance LS engine mount plates,where does it set the engine??
- '00 LS-1 Oil Pressure Gauge warning light in '64
- 05 GMC 2500 purchased for engine
- GTO Standalone Wiring Harness
- Tach issue LS1 swap in 88 Firebird
- 69 LS Swap with T56 - Clutch issues
- 1990 trans am gta project L99 (ls3), digital dash from 1988 into 1990 analog car
- LS Swap kit in a GM A Body Recommendations
- 76 Nova w/LQ9 OBD II not communicating
- ANOTHER Porsche 996 911 LS1 Swap
- Won't rev above 3500 (LS1 2000)
- 2008 4.8 DBW in 91 GMC w/ 7004r
- Supermatic controller battery draw
- LS7 in 2000 Camaro
- Cts, awd, 2door conversion insanity
- gmmp ls3 crate revlimiter sucks
- 2006 LQ4/4L80E into 1987 G20 Van
- 90 degree coil boots, anyone used them?
- Modern LS6 Project
- Voltage drop issue
- Adapter - Does is exist?
- 1986 El Camino ls1 Swap Info (cross member for holley setup, )
- 2003 lq9 mated to 2000 4l80e
- VATS delete on 2010+ ls3 cars?
- 5.3 motor with ls1 ecu and harness
- Holley 302-2 sump cover depth
- The Craziest VW Golf with LS1 Engine You'll Ever See
- Need the weight of an old 350 engine block
- Gen IV throttle issue
- Alternator Wiring
- wiring diagram
- Gen IV E38 with VVT and a manual will it work?
- Where is the pink MIL wire?
- 997 LS conversion with automatic
- Wanted to say thanks!!
- '62 Scout 80 w/ 5.3 4l60 NP208
- C6 corvette Alternator wiring ?
- 96 TA gauge cluster question
- out of storage
- GM muscle car oil pan
- Another fox swap
- 1970 nova LQ9 headers help
- 98 LS1 computer and harness??
- LM7 240SX Build
- Couple of wiring questions
- LS3 T56 in 1978 Firebird Restomod Questions
- DBC to DBW? Drive by cable to Drive by wire conversion.
- Introducing Project Sandman 1967 Camaro
- 56 ls swap
- GM A Body Intercooler Location
- LS3 swap, LS2 ALT, Fbody spacing ???
- Volvo swap guys - Steering question
- Photobucket
- Power steering cap
- tko 600 (ford input shaft) to ls1 bellhousing to
- TCC made my tach go crazy
- No shift into OD
- Wiring harness help!
- adapt factory air filter box to swap vehicle??
- 69 F100, LQ4, o2 sensor conundrum
- Datsun 620 w/ LS & T56 - Build thread
- turbo truck is finished + new project debut
- LS engine swap expert needed
- 2002 5.3 Transmission Compatibility
- Mustangs with Speed Engineering headers- lets see your X-pipes
- Am I stupid for trying to use an engine out of a burned car????
- need help! 5.3 dies when coming to a stop
- S10 lq4 and nv3500 with internal slave
- GM throttle body connector PT2706
- BBC with 0411 Conversion 72 Chevelle
- Valley plate with port what to do with it.
- 1970 Chevelle LS1 Swap Question
- what radiator can I use?
- The Alternator Bible!
- 2002 Porsche 911 L76 Swap
- 95 Mustang LS swap
- Cayman LS3 Swap
- 1990 chevy 1500 swap ls1
- chevelle digital dash
- 160 thermostat
- Ls2 swapped colorado help!
- My 350 Eng Mt swap to my LS1?
- 1970 Chevelle motor mounts - staggered or straight across?
- Which pre filter with external fuel pumps?
- 5.3 CJ7 install
- Gauges and sending unit question
- Holley LS Swap Pan Baffle Fitment Issue
- Head gasket on a lq4
- Which timing chain
- 5" gauges in first gen
- C5 alt and truck harness
- lm7 swap p/s pump pulley clearance
- Radiator Hose woes
- Aftermarket 6.0 truck intake
- 95 c1500 6.0 swap
- 6.0 from a 2003 van
- How to test electric fans?
- Could I use LS3 coils part# 12611424 on my 5.3L engine
- 12624621 oil pan
- LSX Exhaust Manifold identification
- Overdrive and lockup
- 73 Nova 5.3 w/4l60e swap
- cable
- what supplies power to 95 silverado ect gauge?
- 5.3 ls w/ 317 heads, intake and cam need advice
- Rockers ?
- Porsche 997 GT3 With LS3 Conversion For Sale
- 5.3 nv3500 wont shift after swap
- Radiator Pressure Cap
- O2 sensor connection
- Help. Throttle body question
- Power stearing hose
- Mast motor sports....what the hell
- 94 chevy ls3 swap
- Help with battery hookup/ stand alone harness
- No converter to flexplate clearence
- AC issues sanden 508
- LS Swap in 70 Chevelle wont crank
- Anyone using a stock ls1 fbody engine harness for their swap?
- Trailblazer ss throttle body or ls1?
- LQ4 Fires for half a second sputters and dies
- DBW Throttle Body differences
- Need help with a stock ethanol sencer
- LS6 going in 2000 Silverado - What do I need?
- 2013 L96 into 2005 Silverado originally LQ4
- Anyone use a CTS-V T56 for their 6 speed swap?
- Verify O2's?
- starter options
- LS1 E36 running rich and stalling
- L96 into 2007 Tahoe swap issues
- what car should I Install a 408 supercharged LSX engine/4L80?
- 5.3 Stroker motor in 2002 Trans am
- One speed fan to 2 speedi
- Relocating battery to hatch wiring questions
- Gen IV header to block interference help please
- My first LS swap questions.....
- ls swap
- Car revving when cooling fans come on
- ECU question
- lt1 to ls1 a/c components 4th gen Fbody only
- Need ideas for a conversion please
- how coneccted eobd1206 to opel astra h 2014
- Just another ls10 408 s485 glide build
- Need help figuring my tach problem
- 72 Chevelle LQ4 Swap Recommendations
- Easiest cars or old trucks to LS swap on a budget
- what size ls will fit a 1963 c10 trck
- exhaust question. 67 GTOLS1
- 1948 Chevy 3100 5.3/4L60E/8.8 rear swap
- LS1 LSA balancer compatable?
- LS swap advisors please report here to advise lots of good advisory
- rebuild LS6 or swap to LS3?
- 77 trans am clone, want to do turbo LS, 6 sp, 12bolt
- Converter for 5.3 with Texas speed cam
- Swap shops in NorCal?
- Misfire on throttle but not at idle?
- LS Swap 69 Camaro Wiring
- Check Out This 1956 F-100 with a Sweet LS2 (Photos)
- Riddle me this 4.8 vortec
- Alternator charging by itself...?
- Efi harness to painless chassis harness(63chevy pickup)
- ls3 - 4l60e /gen 2 firebird
- Few harness/wiring questions
- 5.3 Problems with idle. Need Help!
- turbo truck update & logging drive pressure
- BB Olds/Cadillac to LS motor Mounts
- Looking to hire someone to wire my LS1 swap St. Louis area
- ls1 harness convertioon for a 88 528e
- pontiac g8 clutchless a/c comp
- PCV Valve routing questions
- Gen 4 new venture 263 transfer case
- 97 s10 blazer 4x4
- lowered 4th gen, scraping lts, how to determine ride height
- 1972 SWB C10, LY6 S480 build
- First LS, first conversion, first swap, first post...
- power steering pump 72 monte/ LQ4
- Adding trinary switch signal to fan relay setup
- A couple issues - 5.3 S10 swap
- What is the shortest I can make a L92?
- Fuel system gurus--flex fuel ?
- 5.3 with 2x4 harness swapped into 98 chevy 4x4 wiring
