View Full Version : Conversions & Swaps
- Spark Plug Wire/Plug Question
- 95 camaro wiring vs 2000 trans am wiring
- LS P/S lines with Jeep Cherokee box?
- Help figuring out which 5.3 I have
- anyone have an ls1 mustang with working a/c?
- Grounds for LS2 in 68 Firebird
- Question about Truck accessories.
- please delete
- VSS signal requirements
- ats plates can they be flipped?
- Spectra fuel tank in a 67 Chevelle
- Suggestions for a '67 Chevelle
- Whats the ideal shifter height for a stick shift car?
- Anyone know the correct delphi terminal pins for the tac module connector?
- typical fuel pumps used?
- LS1 throttle
- 1969 camaro 6.0 swap questions!!
- master cylinder help
- LS3 In a 1963 NOVA?
- F-Body Oil Pan
- F/S S10 computer tray
- 88mm Turbo LQ4 6.0L '87 GN -- BMF Racing build/swap
- Ls1 to Lq4 swap
- LS1 EVAP System Requirements
- corvette fuel pressure regulator?????
- 4.8L into 4th Gen FBody
- LS1/1969 Camaro Install - clutch master cylinder and pedal questions
- 09-11 cts-v alternator wiring
- Where to buy air intake tubing and filters?
- Gbody LS mounts ?'s
- 1994 s10 AWD build thread
- Lsx in a 81 malibu
- Need PS pulley for LQ4 transplant
- Link to thread
- 2010 camaro SS LS3 starter for swaps
- Cooling Issues
- LS1 Engien Harness Re-work
- awd ls1? bmw x-drive?
- Can GMPP ECU/Harness 19258267 do VVT?
- Need Advise about Swap
- LSX swap into 95 bird
- Registering and insurance on a converted car, what do you guys do?
- Fox Steering Shaft/Column
- Project OVRMYHD comes to life
- '72 nova engine mount pics
- Early A-Body swap: 95-up two piece case 4l60e for less tunnel bashing?
- 350Z LS2 Project
- T56 electrical connections required in 71 A-body?
- '37 4 door build thread: check it if you'd like
- Truck Harness to Camaro MAF
- G-Body Cold Air Intake Setups
- dbc throttle body, dbw intake manifold.
- swapped vehicles and inspection time
- Anyone in Riverside Ca that can do a cam swap?
- What driveshaft for 4l60e in sn95
- Datsun 1200 utility LS1
- 2009 Australian Land Rover Defender
- Engine Dilema, Need opinions.
- Help with fuel line on LT1 conversion???
- 63 Nova brake booster question
- wiring harness mods
- Ls1 fbody oil pan and pick
- A body p/s pump to gear clearance issue
- Have decided to put an lq4/9 into 93 fullsize blazer
- Has anyone used the Dual Sync dist?
- 1954 Hudson Hornet Build Thread
- BRP engine mounts with Mast pan Chevelle
- Oil Pressure HELP!
- 5.3 swap in a 92 s10
- ls1 install question
- shorty camaro headers for foxbody swap?
- 69 c/10 what radiator/electric fans is everyone using?
- What kind of power steering fitting is this?
- game-over's 69 lsx 1/1/13 new pics (UPDATE) pg.10
- Pics of Chevelle with Rack and Pinion?
- 72 c10 LS6 can't keep running
- lsx fox connecting fuel lines to fuel rails
- LQ4 in 69 Chevelle...LS7 manifolds?
- LS Powered XLR?
- What steering box for 3rd Gen Iroc upgrade?
- Corvette filter issues?
- '69 4WD LS1 swap
- Custom Build???
- 5.3 + 700r4 tv cable
- '88 Mitsubishi L300 "Express"
- Is DBW setup wirth it?
- Camaro/Nova PCV routing?
- Use of expansion tank question
- TBSS Intake ?
- GMPP harness and ecu...worth the price?
- Built 480LE with transbrake & manual valve body?
- 50's era GM truck 4x4 info wanted
- 1986 Mustang Notchback street/racecar....
- 1985 Cutlass 2006 5.3 and 4L60E
- 5.3 90 fox hatch t56 need advice
- Anyone know the height of a stock A4 shifter?
- LS1 240sx Help Please!
- Why? lS1 oil pan, heads WONDERING
- Does the 9117 autometer tach adapter work?
- radiator help
- ls1 71 camaro
- a few things i need to know
- My ls1 powered---1952 Willys jeep restomod
- 99' - LS1 in an 85' CJ-7
- Anyone make a cheaper 4L80E floor shift than Lokar?
- oil pan fitment
- LS power steering pumps
- 70 chevelle build
- What wiring harness is this?
- 70 stepside 6.0 swap
- Clutch master cylinder
- 5.3
- SC400 lsx swap
- How much power to expect?
- Radiator Question
- 1988 lsxfox finally finished
- Camaro Radiator question
- 4l60e PwM ? for 5.3 conversion
- Coolant overflow question
- catalytic converter question
- HELP! Wiring a LS1 into 87 firebird
- Truck alternator not energizing via ECM
- LS3 throttle body 90mms 102mm
- Low profile headers...
- T56 reverse lockout activation via ecu
- 95 Silverado RCSB to LQ4/4L60e Swap (56k Heavy)
- 2nd Gen Eclipse LSX Swap?
- Any 7.4L TBI to L92 swaps out there?
- new member, question on LS motor and T56 transmission
- 1968 XJ6 Ls turbo project
- New guy to forum 54gmc ls1 4l60e
- F100 / ls6
- How do I change power steering pressure on a power steering pump? (CTS-V)
- Firebird 1980 LSx project 700r4 tranny
- Twin TB on 2X4 tall plenum LS Carb intake with MPI
- LSX 70 Camaro Split Bumper
- Quick wiring summary
- lt1 to ls1 tranny??!
- Building the right engine
- another 69 camaro oil pan question
- Best Aftermarket Harness Ever
- what headers are people runnin in ls swap foxes
- throttle body/intake question
- LS1 fit and brakes
- Cable-X converter.
- best hydraulic cylinder firewall bracket for a 68 camaro
- 240sx conversion factory c5 corvette mounts.
- A question of exhaust (g-body)
- 69 Plymouth ls swap, what are my options for a gas tank?
- New Stainless Works Header Design?
- Fit and finish disappointment.
- Wiring up 98 Gauge Cluster
- Thermostat Question
- 3 series bmw 5.3 swap
- LS7 powered 59 BelAir
- what oil pan can i run for mustang lq4
- How many 944 swaps are out there
- Holley/Hooker mount kits for A body
- A Body using Tanks Inc Pump?
- 05 LS2 in 78 T/A, cam sensor issues, extended crank, HELP!
- Normal Alternator Voltage?
- 1966 impala lq4 4l80 swap help wanted
- what manifolds for 73 nova turbo setup
- f body dash in g body
- '99 Chevy S-10 Xtreme - 6.0l Swap
- 59 El Camino LS3 Build
- 67 Chevelle LS1 T56 Build
- Any fox guys running Kooks swap headers
- Nova Oil pan- Hitting steering link
- Flex plate? ? ? What needs done
- oil pan interchange
- DBW throttle will only open about 20%.
- LQ4 + 4L80 in 89 Notch
- LQ4/LQ9 FI guys did you delete knock sensors?
- building 5.3L advise on current plan...pointers?
- DBW Help 2002 5.3 In 1971 IH 1310
- Ford Taurus 2spd electric fan in 69' Camaro w/LS-2
- 89 Notch build thread
- Corvette Accy drive Power steering Hose
- 70 Chevelle Swap help with steering box.
- LS1 Swap into 67 fairlane
- T-56 reverse lock out
- dies in gear
- Need some Arizonian input
- holly retro oil pan
- What Spark Plug wires??
- Spark Plug wires, longer
- Valvespring retainers - Ti or 4140?
- engine swap question. G8 to Trans Am transplant?
- A-body engine mount?
- Need help deciding on mounts for LS1 into a-body
- started my car without the slip yoke in... fluid leaking out??
- g body wiring
- 5.3 Blazer Xtreme MP T-76
- DBW Not working !!!
- thinking out loud, would like some ideas.
- Driveshaft install
- bending headers?
- Alternative to S&P oil pickup tube?
- Chevelle and ElCamino guys I need help!!!!
- stall converter measurements
- Intake size?
- Quick time rm-6023 questions
- ls into 92-2000 el dorado?
- Please help 81 camaro 5.3 tons of questions
- What stock manifolds fit a 67 Camaro with LS1?
- Anyone use a 6l80e from a g8 ?
- Foxbody Thunderbird Swap
- Exhaust manifold interchangeability
- Transmission wiring 4L80E
- LS swap into 06 Jeep Wrangler
- LS Powered 300zx aka mmmpshh
- Power steering questions
- Fuel pressure too high with Vette FPR.
- VSS output to original speedo
- Plumbing the fuel system
- 5.3 potential??
- need some help with 93 s10 5.3 ls1 swap
- LS1 PCM in a S10 1993 truck ??
- EROD LS3 & 4L70e into '87 Vette
- TCU? Cruise Control?
- Steering Columns
- 03 silverado 4.3 to 5.3 or 6.0
- exhaust manifold help 64 chevelle ls1
- need some help, ls1 in mustang swap
- First big part of my build.....
- GBody EFI Gas Tank Years and Models
- AJE or TEAM Z??
- Other Jaguars with LS power
- 87 Notch ls1/t56 Updated with 1/4 mile times!
- Blueprint Engines 427 crate motor - a good buy?
- Carb Advice
- Need some wiring advice
- Need some help car won't start
- 4l60e in gbody cutlass
- My swap. 5.3 into a 1990 3/4 ton 4x4 Suburban.
- Exhaust systems
- Need help with temp sensor
- need a little help: can anyone identify what kind of slip yoke this is? [pictures]
- LSX swap in either 91 Camaro or 93 Camaro Z28?
- 5.3 truck & 5.7 A/C compressor mounting questions
- My e30 ls/t56... PICS AND VIDS INSIDE!!!!
- Auromatic or manual harness???
- New muffler recommendations please
- 5.3L Install
- Will Z06/LS7 exhaust manifolds work on a LS2?
- Trans selection help please
- Kwik accessory bracket issues
- LM7 + T5 92 Camaor swap questions.
