PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. ls3 motor mounts not aligning (pics) 69 camaro
  2. CAR WON'T START OR CRANK!!!! Help!!!
  3. is it possible to get a CARB/BAR sticker from crate engine?
  4. Which Ecm and Harness
  5. Project 87 t top
  6. 5.3L into a 2wd s10 blazer help/advice needed.
  7. Opinions on radiator
  8. Project "Blasphemy" - LSx Foxbody
  9. 1970 Nova LY6 TT build
  10. 2001 v6 a4 to ls1/t56 no power in gear
  11. 8100 caprice
  12. 02 Firebird LS1 swap - No power to Fuel Pump
  13. Prime Wheels??
  14. Pinout opinions
  15. Do 2011 camaro manis fit anything swap wise?
  16. Possibly dumb wiring question
  17. LS in a Lamborghini Diablo Roaster
  18. LS1->LS3 erod so I can pass !@#$ CA smog
  19. Any recommendation on wire harness books?
  20. Fox lsx swap headers in New edge?
  21. BMW 528i ls1+6sp
  22. Need pcm, tac, and pedal pin out for 2002 5.3 DBW
  23. BP Automotive, and introduction thread.
  24. 2002 Firebird V6 to LS1 Swap - No power to Starter Solenoid
  25. goodbye v6! hello ls
  26. goodbye v6! hello ls
  27. Newbie with questions
  28. Anyone swaped a L92 from a E38 to a E67?
  29. Foxbody ls1 procharged????
  30. What is my project worth?
  31. could i use this for a breather catch can?
  32. Help with disassembling red/blue pcm harness plugs
  33. Tips on making engine harness
  34. 2000 t/a and 2001 2500hd engine swaps
  35. DBW No throttle, pulling my hair out.
  36. Holley Sanden A/C bracket
  37. G Body motor mounts?
  38. Battery keeps going dead after sitting a few days
  39. which flywheel?
  40. cooling fan
  41. E67 computer VSS questions, please
  42. Heat shrink tubing?
  43. Manual Trans for LS in '66 A-body?
  44. More PCM questions.
  45. Dynatech headers rusting on my fox already
  46. Tapping into a VSS signal?
  47. Trans swap question-6L80E to 4l60E
  48. Porsche LS1 Swap - Shortest Long Tube Headers?
  49. LSx 92 Coupe
  50. 1970 Chevelle going for broke!
  51. "RELAPSE" 61 rag build
  52. 2000 mustang gt ls1 swap
  53. Help W/PSI conversion Harness
  54. Good cam for 2800lb LS6 BMW
  55. Aftermarket Harness Fuel Delivery Question
  56. AWD operation - Front Diff (Open vs. LSD)
  57. losing throttle input
  58. Needing some good advice..
  59. My winter project. (Rebuild after fire)
  60. 93 Mustang LQ4 Build
  61. Delayed shutdown
  62. After seeing this several times, I thought I would raise awareness
  63. It's special
  64. Top end?
  65. 1st gen fbody 1-3/4" midlength swap headers Hedman husler 45060
  66. Throttle cable
  67. tach inop and cam codes
  68. What is acceptable pinion angle?
  69. LS2 in a ls1 f-body what all is needed
  70. 1995 Silverado TT.. Redsled
  71. My LQ4 S4xx 86 Mustang build
  72. Black plugs OMG!!!!
  73. Help 5.3 4 cylinders are misfiring
  74. V6 swap
  75. Harness Question.
  76. yet another mustang swap
  77. First Big Purchase
  78. 62 Buick HT 6.0L TT build
  79. foxbody swap question on guages
  80. Affordable cars for an LSx swap?
  81. diy solid motor mounts?
  82. Malibu after cam exhaust video
  83. 302Long tubes on LS??
  84. camaro cluster in mustang
  85. first time out lq4 5.3 heads cam 6speed
  86. Jeep CJ7 TT-LQ4 Build- Lots of PICS
  87. Shifter choice
  88. Tach signal without BCM, LC9 engine
  89. different first gen Camaro drag link available?
  90. Quick Alt question.
  91. Would you use this Flexplate?
  92. help on wiring please
  93. Fox with Griffin LS swap Radiator
  94. 2BFAST's 69 Camaro LS1/60E swap
  95. And it begins. 1973 Oldsmobile Omega swapped.
  96. 93 Sonoma, 5.3, 4l60e, which tranny dipstick?
  97. PCM computer wire removal
  98. Using Ford Taurus 2speed Fan in 69 Camaro conversion
  99. lq9/ls3 top end conversion
  100. help Missing fuel relay wire
  101. volvo 242gt lq4 swap
  102. 4L60e electric issue
  103. swap ls1 intake manifold for ls6
  104. Smaller starter(ls1/t56)?
  105. Parting out '69 Cutlass LSX project: Kooks, Vaporworx, BMR, LY6, L92s, 4L60e
  106. Turbod jy5.3 Mustang Build
  107. fbody mounts on gbody!
  108. T56 Shifter location
  109. Where did you get your harness/engine management/ecu?
  110. 6.2l with t56, whats it worth?
  111. Nissan 200sx s14 LS1+T56 Drift project
  112. ?? Dimly lit check engine light. No codes present.
  113. 86 el camino LS3 swap help
  114. G body-will these mounts, plates work
  115. "Help" 1986 El camino LS3 swap
  116. AJE k member ?
  117. Help with Red/Blue wiring harness
  118. what kinda gas mileage you guys gettin???
  119. Motor mount options? and oil pan
  120. Ls1 69 camaro build
  121. Which Engine Harness Do You Use?
  122. GTO alternator problems
  123. C5 regulator and boost reference regulator
  124. 63 Lincoln Continental - 5.3 Turbo Swap
  125. darkside pt. II (pics added)
  126. '00 S10 4.8, 4L80, P1SC and Ford 8.8" swap
  127. dual fan troubles???? please help
  128. plastic fuel lines?
  129. Need some serious help
  130. 84 Trans am LS1 T56 swap
  131. 92 coupe lsx swap
  132. ar design: E28 LSx Turbo Budget-Ish Build
  133. Lost the 67 in the storm
  134. LM7 in 94 Ranger oil pan and exhaust manifold issues
  135. 1st gen camaro aftermarket subframes
  136. Turbo LSX Fox Body Mustang with Power Steering?
  137. 3.8 a4 to 5.7 t56 help
  138. Stock uncut Fbody pan & manifolds in a 1st gen camaro, they both fit.
  139. 600Z build
  140. Motor Mounts Help
  141. Need help deciding what color Speedhut Gauges!!
  142. Ls1 in a 99 mustang GT build
  143. turbo project
  144. LS1/T56 in 67 Camaro TRANS HITTING TUNNEL
  145. 82 c10 with 5.3
  146. Super vic question
  147. New at this site need help with engine build
  148. Foxbody Swap Crossmember Information (LSx) The CHEAP and Easy way
  149. carb'd ls1 ignition problem
  150. Got LQ9 6.0 for 1968 Camaro – Best low cost setup for fuel injection ? Help !!!
  151. Brz Ls swap thread?
  152. can some one please post a drawing for cooling fan wiring
  153. Ls? Swap mustang cobra 1997 vnmous !pics
  154. Fuel delivery help please!
  155. Oil galley plug thread size???
  156. Engine starts but dies after 5-7 seconds
  157. 98-02 Fuel Pump Pinouts!!! Using a Vetteworks Kit
  158. What ECU / Wiring harness to use?
  159. 00 v6 formula to lq4 turbo swap
  160. 1935 Buick LS1 swap questions
  161. Sachs NFW1050
  162. 61 belair, LS3/4L60 swap
  163. AC Delco part-number for C100,101,105,220,230 connectors with pigtails
  164. ls? s10
  165. L92 oil pressure spikes.
  166. need some direction lt1-lsx swap
  167. Looking for Mustang swap results with EFI
  168. driveshaft? ???
  169. need part number for correct oil pickup tube please
  170. Oil pickup tube hits pan - HELP!
  171. 86 Notch Project Halfbreed gettin close!
  172. 4,000 ppm vss for 5.3 th350 swap what's everyone useing??
  173. 57 Chevy with LQ$
  174. 96 s10 cheap 4.3 to ls swap?
  175. 67-69 1st gen camaro guys, how close is ur engine to the firewall?
  176. 86 Monte SS. 5.3, Single turbo, Megasquirt II. Lots of pics
  177. what can i remove
  178. LS swap into 71 Nova. Mount issues
  179. Emissions and Registration engine swap questions?
  180. Not the norm for a ls1
  181. GEN III or IV: Which engine?
  182. new in town
  183. 6.0/5.3 conversions w/o power steer and a/c
  184. 98 SS swapping everything into 95 v6 shell
  185. Need LS motor advice for 69 Camaro swap
  186. Anyone know where you can get covers for these fuse holders??
  187. Using a 2006 GTO front drive
  188. 64 Chevelle LS swap questions
  189. oil sending unit
  190. Building a LS1 M122 Blower Intake. Need some help.
  191. Twin Turbo LS powered AC COBRA Kit Car Build
  192. Question for LS/t56 foxbody guys
  193. LS1/M6 to A4 into 3.8/A4 Firebird
  194. Who should i send my harness/computer to for mods?
  195. 71 camaro+lm7+dbw=headaches!
  196. Autometer guage (TACH) inop
  197. New use for truck mounts
  198. some ls foxbody swap questions
  199. foxbody questions
  200. 1978 opel
  201. Stick guys, I'm ignorant and need help.
  202. need a shop that can finish a LSx swap
  203. What cam for a ls1?
  204. What motor mounts for 80 malibu?
  205. Champion ls3 miata dyno
  206. '88 Supra Turbo LR4 swap BW S472
  207. power steering issues-98 Vette LS1 & pump feeding into 89 S10 box
  208. Best mechanical speedo kit for 6 speed ?
  209. LQ4/T56 g-body swap ecu ?'s
  210. Please Help! Jeep Grand Cherokee steering box swap on a-body
  211. LS2 Miata @ PBIR - Drag Video
  212. 1967 Ford Mustang LQ9 swap - Lil' Heathen
  213. Cooling - Help - lsx fox swaps
  214. E38 ECM Harness extension?
  215. T43 OS swap (6L80E TCM)
  216. Power Steering Rack - something other than Mustang II
  217. Car warriors ls3 nova
  218. 1968 Camaro question (brake)
  219. Remember Cash for Clunkers when you vote tomorrow
  220. Starting a 86 conquest ls2 swap
  221. 5.3 swap issues..
  222. LM7 5.3 verses 5.3L LC9
  223. Cooling fans and A/C compressor wiring
  224. Problem starting engine that hasn't run for 3 years
  225. 5.3/4L60e first start
  226. LT1 T56 to a LS1 engine
  227. Help with crazy (and/or stupid) idea
  228. Need help with a A/C & Alt Relication
  229. Strange O2 Sensor Problem
  230. using motor plates?
  231. Another 5.3.......Well 6.0 Mustang Build
  232. 2002 pinout instrument panel
  233. ls into 82 Caddy
  234. c220 and c230 harness to insturment panel $$
  235. Msd atomic ls efi system
  236. air condition swap
  237. fuel line question
  238. LS2 Alternator wiring help
  239. Mustang AJE K member questions
  240. 64 Nova wagon with heidts
  241. Chevrolet Performance 19155067 Serpentine System
  242. 2009 GMC 1500 nemb question
  243. Just received my convesion harness.
  244. L33 stand alone harness
  245. what to use for a pedal/slave cylinder setup in an ls/t56 swap into a g-body
  246. Angry and eternally burned by carburetors and gasohol vapor lock
  247. Will ls1 fit 3.8l 5 speed?
  248. 89 Formula getting 5.3
  249. 07 LS2 into a 70 Chevelle
  250. 1998 Vette DBW question
