PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 [171] 172 173 174 175
  1. Speartech
  2. LS1 into 300ZX Manual on Ebay
  3. LS1 into a BMW?
  4. LS1 Vette Power Steering Pulley Part Number?
  5. for sale: LS1 Holden front sump oil pan
  6. gtm-200
  7. LS1 tuning in california?????
  8. Picture and comments on my S&P notched oil pan
  9. Please Dont Kill Me
  10. Chevelle headers ???
  11. head coolant hose, where do I hook this thing?
  12. Slowly starting to come together....
  13. wiring Help??
  14. LS1 in 97 Silverado
  15. Cali guys, how do I get legal??
  16. flipping intake manifold 180
  17. Coolant Inlet/Outlet??
  18. Why doing a leak down test is important. - My results
  19. Please help me build a parts list, '94 Camaro V6--->LS1
  20. conversion help???
  21. Evap ?
  22. Ultima GTR w/ LS1
  23. Have a couple ?'s
  24. Third gen motor mount ??
  25. Radiators
  26. CAUTION! S&P ... what's the deal with these guys?
  27. speedo converter
  28. Proper Fuel line size and return line size? 3rd Gen lines ok?
  29. Control of fuel pressure by PCM
  30. LS6 electronics
  31. Installing FPR on '97 vette fuel rails
  32. Fuel Pressure Regulator
  33. Moroso Custom Oil Pan Kit
  34. New to this site and need some LS1 build up advice
  35. steering fluid cooler
  36. LS1 to Cadillac Catera conversion
  37. FYI for all those using a T56
  38. C5 Rolling Chassis
  39. Got a big wooden crate today!
  40. LS1/T56 in a 1968 Camaro?
  41. Allow me to introduce myself...
  42. how did yall get engine and tranny to fit (68 camaro)???
  43. Need advice: LS1/A4 should it go in the 91 RS or 72 Vette?
  44. 65 malibu LS1
  45. Caddy CTS-V
  46. What to use for a shifter (automatic)???
  47. just curious what im going to run in 1/4 in 68 camaro
  48. Return fuel line necessary?
  49. I should have known better....bastXXX.
  50. LS1 into 94 Silverado
  51. manifold ???
  52. Bracketry for ls1 in el camino
  53. Need some help with air intake
  54. convert 68 camaro to power steering & a/c
  55. who makes best wiring harness for LS1
  56. pic of new custom radiator and fuel cell..
  57. 68 camaro wiring questions
  58. Headers for 58-63 Full Size?
  59. Fuel Connections
  60. Received my Centerforce today.
  61. I just bought an LS1 for my '63 Vette!
  62. 300ZX--LS1 Conversion Pics!!
  63. difficulty of ls1 to a 93-97 body (v6)?
  64. 6.0L swap into Chevelle
  65. Now I know why my LS1 is not shiney..
  66. F/S Chrome starter, PCM
  67. Charcoal canister for land cruiser conversion
  68. anyone know of a company that makes an adapter plate for a t56 to a 4.8l?
  69. 5.7 LS1 swap into 99 Blazer?
  70. ls1 in my truck
  71. Problems
  72. Will a 00 gauge cluster work properly with a 98 PCM?
  73. Picked up my LS1/A4 driveline Saturday!
  74. Need tips for install TPI fuel pump to use w/LS1 in 3rd Gen
  75. What doed it take to swap an LS1 in to a 1992 Camaro?
  76. Hot heads??
  77. 69 chevy pickup conversion?
  78. Front sump pan
  79. fried fuel pump relay?
  80. How much does GM charge to reflash a ECM?
  81. LQ9 into 67 Chevy II
  82. LS1 into 240sx
  83. ls1 conversion ?????
  84. Can I Reuse the Fuel Pump from a 2000 Trans Am?
  85. Can one add rear O2 sensors to Painless wiring harness?
  86. Anyone made a vette heads up display work in a LS1transplant
  87. reverse lock out selonoid.
  88. what do i do with this '85 Trans Am?
  89. Rear spring re-location kit.....
  90. Will C5 corvette gauge cluster work with ls1 conversion?
  91. LSx in Conquest Starion?
  92. I need some opinions on transmission
  93. 88 S-10 LS1 swaps anywhere?
  94. Is it a big deal to make your own harness?
  95. 69 camaro with ls1
  96. External measurements and weight
  97. Rearend Gear ratios?
  98. Exhaust manifold for '67 Chevy II ?
  99. LS 1 type engine in a Late model Astro Van?
  100. I guess I should introduce myself.
  101. need pinouts for 4l80e
  102. FS: #3500 Complete 02 SS LS1 & T56
  103. Heater outlet ?
  104. What fuel regulator and how do I run the fuel lines?
  105. RX7 with modded LS1 Video!
  106. Anyone know this LS1 RX7 guy?
  107. LS1 Powered RX7 Video
  108. LS1 Info Wanted
  109. Anyone looking to do an FD/LS1 hybrid?
  110. Photos: Magna Charger on LS6 (Project Extreme-G)
  111. Props to John & Speartech
  112. pics of yet another mid engine Fiero
  113. Woohooooo!!!!
  114. PHOTOS: powdercoated subframe, restored 12-bolt.
  115. passkey
  116. I'm supposed to make this engine beautiful?????
  117. Headers that work with an LS1 and Gear Box? (69 Camaro)
  118. Scanner and SES light
  119. Rear LS1 brake swap.
  120. recomended shift points?
  121. Accel DFI GEN 7
  122. Electronic Throttle control.
  123. External Fuel Pump
  124. pic of my mid engine LS1
  125. puting a LS syle motor in a 1979
  126. 91 Chevy Blazer"LS1"
  127. How is the A/C pump lubricated?
  128. Whats an easier conversion into a 69 Camaro.. auto or M6??
  129. Project Extreme-G updates - End of September
  130. 3rd gen Rx7 with ls1
  131. 2002 Sierra LS1 and 4L60E into an 81 GMC Jimmy 4x4
  132. LS1/LS6 in a 67 cobra?
  133. ls1 PCM wireing harness diagram??
  134. LS1 BMW Taking shape...
  135. truck fuel rail
  136. Flashing computer
  137. 1998 vs 2002 PCM
  138. Throttle by wire?
  139. Startup Help....
  140. Homemade Headers
  141. Any LS1 LT headers fit 3rd Gen w/aftermarket K-member?
  142. Difference between a auto and M6 engine harness??
  143. Autometer tach slow to respond?
  144. try this one.
  145. 51 mercury conversion pic......maybe
  146. LS1 in V6 Car????
  147. Anybody Need A Vette Alternator/PS Bracket? *DELETED* *DELETED* *DELETED*
  148. Cooling problems? *DELETED*
  149. LS1 Engine length?
  150. need help it starts but shuts off after about 3-5 seconds
  151. LS6 Transplant in WS6
  152. SOOO Close!!! Just wanted to thank everyone here.
  153. Undecided: LS or SBC
  154. HELP wanted!!!!!! Over Heating at Idle.
  155. finished my underhood wiring harness
  156. good looking 69
  157. new pic of my car
  158. 8.1 496
  159. LS1 swap to 70 Camaro.
  160. My ls1 swapped vette went 10.5 last night on 450 rwhp
  161. What PCMs to look for (buy)
  162. 98 harness, 99 computer
  163. PCM/DLC/wiring problem & swap update (almost finished)
  164. coolant tubes
  165. 89 IROC -Z with 98 LS1 please help!!!
  166. More wiring woes...but almost done!
  167. Collector Flange on Stock Cast Headers
  168. Can a 98 PCM work with different year 4L60e ?
  169. New BBK 1-3/4 Primary shorty header - Fit a 3rd Gen w/LS1?
  170. Ultima GTR
  171. Calif Smog laws
  172. Where to get harness connectors(ls1) and wire?
  173. Black 280Z w/LS1?
  174. External Fuel Pump Recomendations
  175. LS1 and Audi 5000 Transaxle
  176. Speartech harness and P0102 DTC code getting thrown!!
  177. First long road trip
  178. Aluminum Radiators..........What do I look for?
  179. Who did the Monster Miata LS1?
  180. Is there a way to achive more FUEL PRESSURE in a Jeep TJ
  181. 69 camaro swap questions.
  182. LT1 in a fox stang?
  183. One wire alternator question
  184. Not deleting trouble codes from swap, cause to run poorly?
  185. trans problem.
  186. Dyno results
  187. 97 V6 gets 99 LS1...no fuel
  188. LS1 harness For sale M6
  189. What Is SpearTechs Phone Number?
  190. Cheapest wat to get a LS1
  191. Power brake Vacuum line?
  192. Big Thank You to John @ Speartech
  193. 95 and newer S10 pick up truck conversion question?
  194. problems after 1st regular "legal" drive
  195. 3 Questions
  196. 94 Camero Engine Swap v6 to v8
  197. Complete Fbody accessory bracket setup??
  198. Alt & AC brackets
  199. Vintage Air?
  200. Reverse lockout and CAGS on aftermarket harness
  201. Kits for 69 Camaro
  202. Engine prices
  203. LS1 in a Miata need answers to swap questions.
  204. BBC headers for LS1 swap into 3rd gen?
  205. More wiring questions!
  206. A new guy with a lot of questions
  207. 99 vette regulator PSI
  208. Fuel pump power wire routing?
  209. Lokar throttle cable, early rod linkage car.
  210. Heater Hose Blockoff???
  211. Finding 12v in on and run- problem
  212. 88-98 fullsize chevy truck LS1swappers....please step inside
  213. LS1 swap into Jeep TJ........Need more fuel Pressure?????
  214. Lokar throttle cable
  215. Going to Dream Cruise with the Ultima
  216. ls1 into foxbody stang?
  217. now that ive gotten ahold of a first gen...
  218. Steam vent tube
  219. A/C in Camaro with LS1
  220. What did my engine come out of?
  221. Jeff, anyone, need help with hydrolic clutch placement....
  222. Cooling system problems
  223. Question for Speartech
  224. Car died and wont start, just cranks
  225. so.... the Ultima GTR with the ls6 didn't make it....
  226. Starting 98 v6 to 01 ls1/t56 conversion
  227. Disadvantages of aftermarket harnesses??
  228. Thinking about an 86 Trans Am LS1 Swap
  229. FYI for VSS and Autometer Speedometer
  230. Fuel pump wiring Q?
  231. Where to mount my computer....Help!
  232. LS1 80 Malibu pic:
  233. I need some tight fitting headers!!!
  234. Progress report
  235. Chevy Radiator Suggestions
  236. The only Mazda I would buy...
  237. My conversion pics(2nd try)
  238. anyone knows how to wire the torq converter to a 1969 camaro
  239. 69 CAMARO LS 1 , motor mounts and accesories?
  240. My conversion pics
  241. 69 CAMARO AND LS1 TRANNY QUESTIONS
  242. C3 LS1 swap guys, what are your costs overall?
  243. Any 62 - 64 Pontiac Hybrids?
  244. 12 MPG????
  245. Need Sounding board: Convert the 91 RS to LT1 or LS1?
  246. Radiator inlet and outlet size
  247. Tubular K member for 69 Chevelle?
  248. may have found a 67 camaro waiting for an LS1 transplant...
  249. Finally a few pics
  250. conversion parts for sale.
