PDA
View Full Version : Conversions & Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. Alternative to Abbott Cable X ???
  2. let me see your air intake setups
  3. need exhaust manifold advice (240sx)
  4. Using a 99-02 truck ecm...will the fans work?
  5. first gen camaro L92 victor question
  6. 6.0 conversion runs pig rich
  7. lsx fox which headers?
  8. Help with LS2 P/S Pulley
  9. 5.3/4l60e/np208 lots of questions????
  10. What???
  11. Gauges HELP
  12. Computer & Harness Question
  13. Ls2 gm performance harness oil pressure
  14. LS powered Vega.
  15. saving the live of a harness?
  16. Inline fuel pumps
  17. what gauge cluster can i run
  18. 72 forumla stock gauges
  19. current performance adapter harness help
  20. AC setup on GENIV engine swap to 1997 Tahoe
  21. Pressure!
  22. Moroso 20140 Pan
  23. Anyone using the stock F Body throttle cable?
  24. How hard to put a ls2 into a 1971 z28?
  25. 99-04 mustang swap questions.
  26. few questions mustang swap almost done
  27. 1991 ls-10
  28. In the middle of modifying LS1 wiring harness. Question on something...
  29. A/C through e38 pcm LS7
  30. C5 donor to _???__
  31. 6.0L vs. 5.3L
  32. aje k-member,kooks,and stock suspension?
  33. It's alive finally.
  34. starts, won't run
  35. Thermostat ls motors
  36. Nissan 200(240)sx with 2004 GTO LS1+T56
  37. Driveshaft lengths?
  38. Power Loss LS1 Intake On A 2005 LQ4
  39. 99 LS1 into 98 Camaro - Need Help Dash
  40. What length of drice shaft.
  41. F-Body Fuel Pump Dimensions
  42. Anyone know A/C Shop that works with those crimped hose ends ?
  43. Travel Question Mounting Clutch Master
  44. Turbo my old daily driver/ shop truck?
  45. How close is too close?
  46. sbc s13 coupe questions?
  47. Isuzu question
  48. Aftermarket plug and play harness.
  49. fuel rail fitting part number
  50. G-body wiring
  51. 3 Wire ECT sensor
  52. gto dbw pedal with 03 truck pcm?
  53. Manual to Automatic transmission harness swap.
  54. looking for some input
  55. Corvette regulator filter question
  56. 1969 Chevelle with ZO6 LS6 4 speed
  57. 1964 Chevelle - 5.3 LQ4/4L60E
  58. Accusump; Wiring for Solenoid
  59. Flex plate adapter part number
  60. LS1 or LS2 intake manifold for LQ9?
  61. Programming 5.3l pcm
  62. Ls Motors
  63. LS2/3 thermostat housing
  64. Fuel lines and EGR for my 87 camaro
  65. adapter harness or stand alone for ls1
  66. lpp truck headers??
  67. Electric fan advice please!
  68. 5.3(lm4) aluminum block in a C3 Corvette:Swap Thread!
  69. 72 Chevelle LY6 Cam Only Dyno #'s
  70. whats needed to run a th400 behind a 5.3 LM7
  71. Need help! 4l80 swap in an ls1 86 camaro
  72. New Motor Start-up
  73. VIN code for 5.3 LM4?
  74. is it normal(ls2)
  75. question about buying my ls motor?
  76. Question about fuel rails
  77. New uk member looking to do swap into Jaguar
  78. 5/16 vs. 3/8 fuel line in LS1 swap
  79. Automatic trans clearance in first gen F
  80. Corvette fuel filter adapter
  81. starter will not turn over
  82. V6 to LS1 or 6.0 Swap
  83. Cant fill new gas tank fast..
  84. LS1 C3 Vette guys!
  85. Adding sump to stock fuel tank
  86. Impala SS AC Questions
  87. ls1 in to a fox body swap questions
  88. Y-Pipe Pressure Test
  89. Complete LS1/LS6 Victor JR, MSD 6010, demon carb, fuel pumps, for sale
  90. F-body Injector plugs
  91. LS2 into 99 Mustang
  92. anybody have a 99-02 a4 harness for sale
  93. coolant sensor location
  94. 6.0 lq4 coolant hoses
  95. Ack! Electric problem (blowing alternators)
  96. LS1 Third Gen owners step in
  97. Those with Facebook and LSx conversions...
  98. Is there a definitive answer to LSx into E46?
  99. f-body pacesetter long tubes on a g-body
  100. 11.92 for my Monte SS LS2 on Tues.
  101. need help with 4l80e shifter cable
  102. truck VS fbody ECM on a 6.0 harness
  103. 87 Iroc Z LS1 Swap
  104. which donner vehicle 4l80 2wd
  105. what radiator hoses for the fox body with
  106. Quick Question on LM7 and LS1/6 variations.
  107. 96 lt1 into 95 3.4
  108. Anyone ever use a truck harness for an Ls1 swap.
  109. Need help with a/c ?????
  110. Has anyone used Russell/Edelbrock fuel system for ls conversion
  111. Factory guages
  112. truck gauge cluster
  113. LQ4 280Z running TERRIBLE!!!
  114. A few questions before I start the build. Please help me with my parts list?
  115. Lsx 302?
  116. Standalone LS1 PCM/Harness Question
  117. Wiring problem please help!!!
  118. ls1 and t-56 g-body
  119. A Little Help Please!!!!!!!!!!!
  120. LQ4 or LQ9 how do I know?
  121. Headers and oil pan for 2nd gen camaro w/ 6.0L?
  122. does anyone know????
  123. swap prices range??????/
  124. trans am diff
  125. LS2 ECU(e40) wiring questions
  126. 98 s10 with 5.3l swap????
  127. A/C pink wire?
  128. anyone put ls1 into 94 v-6 car
  129. Headers for LS1 swap into 71-76 b-body
  130. LS1 into an RX-7 FB?
  131. 64 malibu with truck acc. a/c brackets
  132. Need 66 Corvette LS1 T56 install info
  133. LT1 into a 1985 camaro
  134. 383 Sonoma goes 10.46.
  135. Just another 3rd Gen LS swap
  136. My C1500 383 build up
  137. Cutting the floor to fit a t-56 in a 2nd gen?
  138. Question on single bolt or two bolt T56 transmission mount.
  139. what do i need to put an ls in a fox body
  140. Ls1 into 94 v6 wire harness help
  141. LS1 A-body Conversion Headers, Engine Plates & Clutch Hydraulics F/S
  142. Exhaust mani for S10 swap
  143. f-body v6 to ls1 swap. Injector wire splice?
  144. 1972 Short bed 6.0/4l80e
  145. Adding an Electric Fan to Original Chevelle Fan Shroud
  146. LS1 powered 69 Transam
  147. Fuel pump relay
  148. 2007 6.0 liter wiring help
  149. Front accy brackets & pulley's
  150. Anyone familiar with NY state emissions inspection ?
  151. coolant line help guys
  152. LS1 into C4.. headers?
  153. 2000 Dodge Durango
  154. what about an 8.1 or vortec 8100 swap?
  155. brakes
  156. 5.3 in nissa 300zx
  157. ls1 s10 blazer pics!
  158. In car Video 10.04
  159. Charging System Question
  160. 68 Camaro LS1 idle problems
  161. Ricks hot rod tank dissappointment
  162. 5.3 swap
  163. wiring harness conversion
  164. E-fan question
  165. 3 inch cat.
  166. 2001 ECM on 2000 LS1
  167. 65 GTO ls1 swap header,exhaust and radiator question
  168. Thinking of going carb... what's you opinion?
  169. LS2 thermostat and housing on LS1 pump?
  170. New Motor Start-Up
  171. 99 LS1 wiring questions with a 95 Camaro
  172. LS1/T56 In A Subaru SVX...
  173. Super Chevy mag.
  174. long tubes for 88-98 fullsize?
  175. starter hesitates
  176. 69 Camaro ZL1 clone w/LS7
  177. First gen, Tanks Inc anyone?
  178. 02 DBW A4 1st drive problems...
  179. lsx into C4 Vette
  180. Wtb: Fox mustang swap parts
  181. Just finished 67 Nova LS1,6 speed 12 bolt SLEEPER
  182. ls1 swap fuel gauge problem
  183. Sn95 with 5.3/T56 conversion. Pics and questions
  184. LS1 swap question
  185. Ls1 in 59 Chevy Biscayne
  186. PCM controlled A/C 2003 Silverado, is it possible?
  187. Best way to keep stock gauges and gain overdrive in a 72 A-Body
  188. 73 chevy 5.3 swap carb ?
  189. electric fans for a body
  190. LS Fox Mustang guys with Kooks headers come in
  191. LS1 F-Body Swap Info
  192. little help guys
  193. ignition coil difference?
  194. underhood fuse box
  195. ls1/ls2 engine mounts the same or different?
  196. Wiring Job on my '07 LS2
  197. 5.3l LM7 Question
  198. How important is the trans crossmember??
  199. VSS signal for 4l80e
  200. pan swapping question
  201. LS7 Manifolds
  202. 6.0L with m21
  203. lq4/glide 92s10 on a budget
  204. Conversion / Drop out starting point
  205. Need to find out if my motor is a 2006 6.0 Please help
  206. 6.0L 68 Camaro Conv Questions
  207. Temp sensor wiring
  208. Power steering hose??
  209. F/S Beautiful 92 Mustang GT twin turbo LS
  210. Couple T-56 questions
  211. '71 C10 Motor mounts for 6.0 conversion
  212. Older SBC In a 4th Gen
  213. she"s ALIVE !!!!!!!!!!!
  214. 2 questions guys, these will make mine efi or carb
  215. 2003 1500 ls6 swap
  216. Anyone got a truck dipstick/tube measurements?
  217. Trans codes thrown - No 12v to pin E - source?
  218. L-Terminal Error Alt Not Charging
  219. electric gas pedal in a f-body
  220. 84" Suburban/6.0l header ?'s
  221. LS1Miata-need 04 GTO cooling fan relay pinouts
  222. Help with identifying some connectors in 2002 truck engine harness.
  223. Finally got some nice weather in nyc so i took out the Ls1 fd (pics/vid)
  224. Camaro vs. Vette alternator location
  225. LQ9 Swap runs - Need help diagnosing some problems
  226. Ford tremec 3550 to LS1 anyone?
  227. more questions- which swap kit?
  228. visible difference between 5.3 and 4.8
  229. custom dash gauge with warning lamps...
  230. 4L60E on a 6.0
  231. Considering doing a LSX Miata- Experts Help
  232. edelbrock header/mounts first gen
  233. LS1 Air Intake
  234. v6 camaro LS1 swap, Kmember diff/steering
  235. Conversions on the Power Tour
  236. 2005 6.0-What harnesses are compatible?
  237. LS2 350Z begins.. Part II
  238. 98 firebird dash into a 96
  239. LS1 water pump flow direction
  240. LQ4 yr? TH400 spacer needed?
  241. swap wont start
  242. got some codes, one concern...
  243. Oil breather problem on GM CHEVROLET Valve cover
  244. New F-Body oil pan being a pan in the ass!
  245. Calling all lsx bmw guys....need alittle help
  246. Can you use a T56 6-Spd Trans from a ’93 LT1 on a LSX Engine?
  247. LM7 into a '66-67 Nova?
  248. Another will this cam work question
  249. Startup vid
  250. Starting my LS1 Panoz (cobra 4.6L Mod) Swap
