View Full Version : Conversions & Swaps
- 5.3 into Cadillac BRougham
- 1933 Ford Coupe/Roadster Stroker Build
- Interesting power/non power issues
- Yet another Gotcha to Look Out For
- BMW Z3 install started
- a few questions for the LSX notchback guys
- Vintage Air w/F-Body condenser?
- I want to run a mechanical water gauge on my LS1. HOW?
- anyone who has done a swap in 68-72 abody ecm tail length
- See anything odd in this engine bay?
- conversion accessory drives
- GTO oil pan/Oil pressure sender
- 1970-1972 Monte Carlo swap Kit
- Early Cadillac CTS-V Oil Pans
- BRP Hot Rods NEW Fox Body Mustang LSx Swap Kit
- Classifieds Link: New GMPP Front Accessory Kit
- 80s stock wiring, Dielectric Grease? or Goo?
- 98-02 Radiator
- Ls1 to ls6 swap
- Anyone Looking for LQ4 Truck Exhaust Manifolds...
- ls7 powered Mustang Fastback
- Many misc LSx parts available:
- LS Fest - Car Craft Engine Swap Challenge Details ->
- G-body LS1 4L60E folks- which shifter are you using?
- getting a little hot
- What oil pan?
- 6.0 engine help on conversion
- 6.0/4l80e in a 65 impala
- AN fittings for F-Body PS Pump?
- eldelbrock carb intake
- New LS1 FC RX-7 owner, questions
- Hey New Guy here building a 5.3L for my chevelle, what intake????
- Slow 6.0 Ta
- 67 camaro LY6 carb conversion - E.T.'s inside
- The Real Evolution (2009 Lancer-questions)
- Which Wiring Harness and PCM to use?
- Using an F-body alternator with a GTO harness
- Ressurection Project: 2003 Cobra | 415ci LSX | GT4780 | RMVB 4L80 | 8.8 SRA
- 1975 Olds Delta 88 Convertible E-Rod
- 66 chevelle ss t-56 anyone?
- LS1 in second gen firebird; issues with frame mount holes
- LS mount plates on 68 camaro
- 63 impala ls2 & rear end strength
- Coolant flow (lack of)... making me hot!
- Operating temp?
- help identifying this frame mount
- Need help with conversion
- LS Conversion cooling/Fuel systems
- Powertrain Advice
- not getting any tach signal, help?
- Gonna sell my LS1 swapped Nova
- Getting hot inside car
- converting dbw to cable
- anyone used motor plates instead of motor mounts?
- Coils not getting signal??
- shop that will lsx swap my 67 impala in houston
- A-body firewall flexes with S&P master cylinder mount
- 5.3 Alternator output??
- flywheel spacing?
- V-6 Rescue
- 4l60E shifter question
- short exhaust.... need quieter muffler
- genIV dbw...all hooked up..not responding..
- What degree do you mount the engine?
- LS1-LT1 swap, how can I read codes?
- 5.3 info
- kwik performance brackets.... turbo question
- Fantasy LSx swaps
- LS1 Miata starts & dies Vats is OFF
- Can you guys point me in the right direction?
- Powertrain Diagnostics Enable wire coming out of E38 ECM
- F-Body Computer-What Pin # For 128K VSS?
- last minute ls1 to lm7 swap ?'s
- LT1 swap for L92 in a '96 Impala SS questions
- Turbo kits for LS1 RX7?
- LSX swap into Full Size Jeep
- ProCharger LS Transplant Specifications
- C100 question
- 62 Studebaker Lark
- Running rich, rough idle. Help!!
- LS1 Swap
- Do I need a TAC Module?
- Plastic Mockup Blocks
- Help wishy washy choose a gear
- P1125 code on 5.3L 2004 Avalanche with DBW
- Anyone need a chevelle ls/t56/12 bolt driveshaft
- Pacesetter longtube LS truck headers on Nova
- Unknown wiring connector ?
- how to add 2 quarts to oil volume
- 04 GTO P/S pump question..
- Guys with RX7 FD Turbo LS1's. How did you build your turbo headers?
- Spectra EFI tank for 68-72 Nova ?
- LT1 to LQ9 swap
- Lowest HP LS-style engine?
- Molded heater hoses
- ls swap into carb'd car thread????????
- need input on a ls1 swap in a 90 300zx
- Hot Engine
- Cruise control help?
- Help me build my motor.
- Feeler - V8 Miata conversion axles
- LS1+T56 swap to my -68 Camaro
- 5.3 into a 2000 tahoe limited
- If all was the same for a LSx swap, 3rd Gen or a 240sx?
- 94 RX7 Swap - Best/Cheapest place to buy a LS1 / T56 Dropout?
- clutch master cylinder in a g-body
- power steering pump lines
- How to get P.S. pulley off?
- Cookie Cutter - 5.7LS1 in a 240sx- pics/vids inside
- c5/c6 vs Wilwood Brakes
- Ls1 and trans alignment?
- LS1 steering rack into 2nd gen T/A
- Rack and Pinion in a 3rd Gen?
- 2 questions
- Anyone using Pacesetter 4th gen headers?
- 5.3 in 70 gto
- ls1 fan problems
- Hot at start and run
- aftermarket EFI controls?
- 2010 Camaro Engine Cover.
- My nissan 530sx Build
- Camshaft suggestion for Carb'd 5.3
- Can use some help - LS1 => Porsche 928
- Assist w/push-on fuel rail fittings please
- lsx swap in a 2004+ f150?
- power steering line conectors
- C100 Pin G
- Question about wiring up 700r4
- need some help
- 02 sensor problem?
- Swap a LS1/7 in my 1950 Chevrolet Styleline
- motor mount/plate issue
- 3.8 99 Camaro To 5.3 Lm7?
- Help - ODBII connection
- re-programming AND tunning?
- quick question droppin an ls1 in a truck that had a 6.0
- anyone looking to do a ls1swap in fox mustang??
- LY6 Wiring Diagram Here
- Trans dapt mounts
- victor jnr carb studs
- Ls1 v8 350z
- July 9th, 2010 "National Collector Car Appreciation Day"
- 1996 BMW Z3 V8 for sale
- G-Body CTS-V And John B
- LS1 Radiator question
- Hot August Nights, Who's going?
- 60s chevy mount the same as early 70s?
- cheap headers.
- power boost
- Mounting the a/c Drier
- What to do with rust inside the frame?
- 91 to 90 formula to ls1
- Modifying a crossmember on a 80 Trans am
- headers for ls1 fd rx7?
- how long - balancer installer
- fuel line question.
- what shifter 6 speed auto
- HELP ENGINE WONT START**fire missing
- Help with Fuel System design...
- Igntion Coil Relocate??
- fuel injection line??
- 01 5.3 into a 99 blazer
- Moser Muscle Pak Rear Ends
- T56 hard shifting
- My Iroc LS1/T56 Swap Build Thread (56k Death)
- 6.0 from 2500 HD into 1974 impala?
- TH350 to LS3 flexplate adapter help
- what type of LS motor??
- Swap Gauges
- want more out of my lq9'd c10
- need a starter for LQ4 T56
- computer issues
- What did you use fuse block/relays
- 12576106 Pinout for Fans......
- wire harness
- Ls1 to 5.3 Swap
- i have an msd 6010, megasquirt 3, for sale in the classifieds
- Autometer speedo
- 5.3 in a 69 camaro. Help please
- LY6 pressure relief valve
- Carbed LS1 into my jet boat - Finally Done!
- NEED HELP with vss
- V6 to LS1 Fuel Pressure
- Autometer tach on 04 ls1...suggestions??
- Stupid ? about bolts
- t56 hard to go on reverse
- help wiring 2 step on msd 6010
- 1985 Regal Wiring help
- My fuel system plan
- Russell fuel pump kit.
- pcm question
- 5.3 into 2nd Gen Camaro questions/feedback
- Project: Red Rocket Olds - S475 Turbo'd LY6/4L60e
- LQ 9 into a 67 nova w/heidt's front clip
- 76 Camaro w/LS1
- 1980 trans am 5.3 tahoe engine and trans advice
- Ls1 rx7 Fuel System (CA smog way)
- 4l80e into 3rd gen camaro
- who sells lt1 to ls1 motor mount conversions?
- What if...
- BIG Engine in little BMW -- Check It Out!!
- Is there a how-t0-thread on making ur own harness?
- TCC Wiring
- DBW question
- HELP! Dynatech headers burning plug wire
- Thanks to LS1tech.. 2 years later 408ci
- LQ9 engine builds... opinions needed
- thinking of a 5.3 swap into a 79 trans am, need help!
- LY6 in a '76 GMC
- LS Foxbody Throttles
- 67 camaro steering linkage clearance
- wiring connector help needed
- 5.3?? or 4.8??
- 5.3l dies when put in reverse
- just double checking will this fit with no issues?
- CSR TStat housing heat question?
- F body power steering hose routing
- ls motor on alcohol
- LQ4 or LQ9 with PRC 2.5 5.3L heads..
- Radiator set up for 87 C/K w/ 5.3
- new retrofit oil pan
- Acc drive questions?
- factory engine wireharness delete on g-body??????
- G-body ecu wirning
- Tuning a ls6 porsche 944
- 7.4L swap please help
- 07 trailblazer ls2 into 00 fbody questions
- HELP. LY6 timing covr bolt torque
- 69 camaro ls1 - first start-up video
- 04 GTO alternator or volt signal
- Best way to put coolant in system?
- Camaro or Corvette Accessory drive system?
- BMW M3 LSx conversion - Engine weights
- LQ4 wire to cable conversion for throttle needed
- question on ls1 pcm cooling fan control...
- LQ4 AC hook up to Chevelle stock AC
- 98 blazer
- Used LS Motor. How many miles is too many?
- It's ALIVE! (sort of.. Error code help??)
- Bosch Relay Connectors, Looking For Large Wire Versions...
- Wiring Help Needed Installing F Body Cluster with 03 Truck Computer
- HELP.....looking for g-body oilpan that clears co
- chevelle / nova guys. turbo hotside available
- my custom intank walbro setup
- Final bits of 1978 Jeep CJ7 LM7 swap
- s14 vs s10
- 2000 BMW 525i
- 1969 Chevelle fuel pump in tank?
- 2006 ls into my 72 blazer...
- How to stay broke: IS300 + LS1 turbo
